Annihilator Posted 4 hours ago Posted 4 hours ago 10 minutes ago, SuperMG said: It could maybe be a driver issue because I didn't have any thermal throttle on the graph. Because I couldn't even edit anything in the Nvidia control panel, I probably did a bad installation thru NVCLEANSTALL. But anyway this heatsink isn't suitable for the RTX 150W. Even for the 135W ones... But the M6800 heatsink sounds more promising because it has a little bit more of endurance and I have the ones with the bad heatpipes! u checked hotspot temps? when just one part is in the red area, will throttle... even when average GPU temp still is fine, same for VRMs, when they getting to hot, they cap the powerlimit Phantom Gaming ITX B550 - 5950X @ 5.3GHz PBO - 2x16GB @ 3700 C14 - 9060 XT 16GB @ 4GHz boost 2850MHz vram - 2TB + 1TB NVMe - 2TB + 2x1TB SATA SSD - Win 11 Pro 7720 - i7-7820HQ - 2x 16GB 2666 C15 - P5200 16GB - Samsung 960 Pro 512GB NVMe + WD SN730 1TB NVMe - Wifi 6E - Win 11 Pro M6800 - i7-4930MX - 4x4GB 2133 C11 - GTX 880M 8GB(not working atm😒) - Kioxa BG5 1TB mPCIe - 2x Samsung 850 Evo 250GB Raid0 - Wifi 6 - Win 11 Pro
SuperMG Posted 4 hours ago Author Posted 4 hours ago 17 minutes ago, Annihilator said: u checked hotspot temps? when just one part is in the red area, will throttle... even when average GPU temp still is fine, same for VRMs, when they getting to hot, they cap the powerlimit Nothing in red or in purple. The hotspot limit is 105C for the RTX 4080 I have.
