Sebastian Ramirez Posted March 5 Posted March 5 Hi, Im going to get an GTX1070 MXM soon, but just wanted to be sure, does the Alienware 18 R1 motherboard have enough power to handle the GTX1070's full power? (It wont burn out or something like that?) Thx
Maxware79 Posted March 5 Posted March 5 Yes, many have done the same upgrade in the past with good success. @ssj92 may have a few things to say on using a better card than the 1070, maybe an RTX 3050 or 4050 would be a better buy. https://www.x-vsion.com/product-category/mxms/mxmn/ Alienware Aurora R15 - i9-13900KF - RTX 4090 - 32GB DDR5 Alienware X51 - i7-3770 - GTX 1060 - 16GB 1600Mhz DDR3 Alienware M17x R3 - i7-2760QM - GTX 580M - 16GB 1600Mhz DDR3 Alienware Area 51 ALX - i7-975 Extreme - GTX 980 - 16GB 1600Mhz DDR3 Alienware Aurora R2 - i7-3770K - GTX 670FTW - 16GB 1600Mhz DDR3 Alienware Aurora R4 ALX - i7-3930K - GTX 1060 - 16GB 1600Mhz DDR3 Alienware Aurora R4 ALX - i7-3930K - GTX 670FTW - 16GB 1600Mhz DDR3
SuperMG Posted March 5 Posted March 5 5 hours ago, Maxware79 said: Yes, many have done the same upgrade in the past with good success. @ssj92 may have a few things to say on using a better card than the 1070, maybe an RTX 3050 or 4050 would be a better buy. https://www.x-vsion.com/product-category/mxms/mxmn/ Hello, they are impacted by the TDP bug, 40W or fluctuating between max TDP to 40/55W. So it's not worth it since they are limited by the Optimus MUX Switch. I got the M6800 to work with the modern RTX Ada and there was no TDP bugs.
ssj92 Posted March 23 Posted March 23 On 3/5/2026 at 2:21 AM, SuperMG said: Hello, they are impacted by the TDP bug, 40W or fluctuating between max TDP to 40/55W. So it's not worth it since they are limited by the Optimus MUX Switch. I got the M6800 to work with the modern RTX Ada and there was no TDP bugs. I believe this issue was found by @janepa and I have to still disassemble my aw18/m18x laptops to find the resistor to mod to fix the issue. Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080 | AX210 | Samsung 970 Evo+ Alienware M18x R2 : Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080 | AX210 | Samsung 980 PRO Alienware 18 : Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000 | AX210 | Samsung 980 NVMe More Laps: M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000) | M17xR3 (WX 7100) | M18xR1 (RTX 5000) Precision 7520 (T1000) | 7720 (Tesla P6) BEAST Server: Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYT
