reaass112 Posted May 20 Posted May 20 so awhile ago I had this problem where my "D" button wouldn't work unless I long press it, or pressing it right after another button that was working eg, quickly pressing "D" after "S". didnt really try to find a solution for it but recently my "D" button started functioning properly and now the problem shifted to my "W" key. what's happening to my laptop? whats the fix? laptop is asus rog strix g16
Meaker Posted June 2 Posted June 2 New keyboard most likely, the are multi layer PCBs that use a circuit to minimise traces meaning the keys influence each other if they misbehave. Louqe Ghost S1 case (Top hat and bottom extension) Powercolor RX 9070 XT Reaper 16GB 32" MSI 4k 160HZ IPS display AMD Ryzen 7 7700 cooled via Thermalright 240mm AIO 48GB (2x24) DDR5 6000 CL36 Asus B650E-I motherboard 2TB T500 nvme SSD + 2TB SN770 nvme Corsair SF750 platinum SFX PSU
