Will Posted July 11 Posted July 11 Another one for the collection. Same old story: one day I was mindlessly scrolling through OLX out of boredom and stumbled upon this machine for sale. It was listed as defective and "for parts", not turning on, but the screen, graphics card (NVIDIA Quadro M1000M 2GB), keyboard, and battery (health unknown) had been tested and were working perfectly. Looking at the exterior, the chassis is pretty badly damaged, as you can see in the photos below. Even so, I figured it would be a good deal for the price, whether to restore it or sell off the working parts. I decided to restore and upgrade it, so I'll be posting the progress of this project in this topic. One final note: this laptop is originally a 15 G3 (with an i7-6820HQ), but I'll be turning it into a 15 G4 by swapping out the motherboard. Here are the listing photos taken by the seller: And here’s a photo of the internals: Signs of attempted repair:
Will Posted July 13 Author Posted July 13 UPDATE #1: The screen was actually working perfectly. I sold it to a friend for pretty much half of what the entire laptop cost me. I also started researching and buying the necessary parts for this project, the first item being a brand new ZBook 15 G4 motherboard with a Xeon E3-1505M v6 (CPW50 LA-E161P 921049-601). Again, I'll be buying most of the parts from China, on sites like Taobao and Xianyu. It was a bit tricky to test the motherboard because I was too lazy to completely disassemble the laptop, and on top of that, I didn't have an AC adapter with the right plug for the ZBook. So, I had to use a 7.4mmx5.0mm to 4.5mmx3.0mm adapter that I got from AliExpress with an HP OMEN AC adapter, but in the end, everything worked out fine. Side note: the screen used for testing was taken from a ZBook 15 G2 that I also acquired. I'll make a separate topic for it in the future. The motherboard is working perfectly and apparently had never been turned on before, according to the "Machine is not in committed state!" message displayed during boot. I still need to do more research on this and how to "fix it", so if anyone knows how and can help me out, I'd appreciate it. During testing, I also took the opportunity to install and test the NVIDIA Quadro K1100M that came in the ZBook 15 G2 I mentioned earlier. The driver installation apparently went fine, but it threw a Code 43 error in Device Manager. I'm not sure if the card itself is faulty or if I messed up the driver modding, since it had been a while since I last used NVCleanstall. Also, during boot, a "cooling fan error" message popped up, and I noticed that the fan behavior was a bit weird, with them revving up and slowing down repeatedly.
Will Posted July 14 Author Posted July 14 Regarding the GPU, it's known that the ZBook 15/17 from G1 to G3 (and definitely the G4 as well) have eDP on DP_C. Therefore, if a graphics card with eDP on DP_D were installed - let's say an RTX 4050, for example - I wouldn't get a display on the internal monitor if the SBIOS were configured in discrete/dedicated graphics mode, correct? But if the option were changed to hybrid graphics, would I be able to use it normally with the video passing through the iGPU? And another question: if the GPU has standard DP on DP_C and I use the backlight cable mod, I would get a display on the internal monitor and could use it in discrete graphics mode, correct? @JadeRover@SuperMG can you guys give me some insight on this please?
JadeRover Posted July 14 Posted July 14 @Will Short answer : Yes and yes 7 hours ago, Will said: But if the option were changed to hybrid graphics, would I be able to use it normally with the video passing through the iGPU? Yes, the dGPU will be used a a video accelerator selectable in windows. This allows even GPUs with no display outputs at all such as MXM gpus like the quadro tesla M6, P6, P106m, etc, to work in MXM based laptops 11 hours ago, Will said: And another question: if the GPU has standard DP on DP_C and I use the backlight cable mod, I would get a display on the internal monitor and could use it in discrete graphics mode, correct? Yes, I had put a P3000m in my zbook 17 g3 and I would get no dipslay out if I forced dGPU in the vbios, the reason being that zbook had eDP on DP_C and the card had eDP on DP_D. What I ended up doing was bridging the 3.3v and PNL_ON and PWM of the MXM slot and then forced the graphics mod to dGPU only in the vbios to get a video out. I then had a picture on the screen with no way to adjust brightness, it was stuck at 100%. Using an eDP cable mod v1 or v2 will be much simpler (and less stressful) than soldering direclty to the pins. HOWEVER, nvidia drivers will decide "screw that" after they install and will disconnect the dGPU from the screen, usually ~10 seconds after windows loads and the driver starts. SuperMG found a workaround in windows to force the screen to stay on after the drivers install luckily, it is detailed in his "eDP cable mod" PDF instrutions. Precision M6700 : i7-3740QM | P3000 6gb engineering vbios | 20gb DDR3 1600Mhz | FHD ips dreamcolor | delta fans Zbook 17 g3 : i7-6820HQ -75mv | M3000m 4gb | 16gb DDR4 2400Mhz | FHD ips Precision 7720 : i7-6820HQ -80mv & 102.7mhz BCLK| Zotac GTX1060 6gb, 100w OC vbios | 16gb DDR4 3011Mhz | 1440p165hz (upgrad) Zbook 17 g5 : i7-8850H, -140mv | P5200 16gb | 32gb DDR4 2666Mhz | FHD IPS
