commanderf Posted July 18 Posted July 18 Recently, I got a good deal on an m17x r1. It has a t9600, and dual 260Ms, but one of the games I'd like to play on it has Kepler cards as its minimum. What's the best gen of gpus I can put in this thing? From poking around here, it seems like someone's gotten dual 670MXs running on one, and the r2 seems to have a fair amount of compatibility with newer cards, but I do want to see if I can push it a bit, say with a maxwell card. Also, will the old SLI bridge work on newer cards? Thermals, or heatsink compatibility aren't a concern for me either, I have a set of two MXM heatsinks from a laptop model I know can take maxwell cards I know I can modify to work with this laptop, and i figure i can get around what seems to be the dedicated fan controller chip's incompatibility with new cards thermal reporting by just setting a static curve, or making some other system that reads temps from the cards and adjusts the fans. Main pc - Thermaltake lvl 10 gt snow, Asus b850a gaming wifi, 7900x, rtx 2070 super, 16gb of ram, eisblock xpx aurora, thermaltake toughpower gold 1200w Precision 7740 - i9 9980HK, 32 gb of ram, rtx 4000 Precision m6800 - I7 4910MQ, 24gb ddr3, K3100M
ssj92 Posted July 18 Posted July 18 3 hours ago, commanderf said: Recently, I got a good deal on an m17x r1. It has a t9600, and dual 260Ms, but one of the games I'd like to play on it has Kepler cards as its minimum. What's the best gen of gpus I can put in this thing? From poking around here, it seems like someone's gotten dual 670MXs running on one, and the r2 seems to have a fair amount of compatibility with newer cards, but I do want to see if I can push it a bit, say with a maxwell card. Also, will the old SLI bridge work on newer cards? Thermals, or heatsink compatibility aren't a concern for me either, I have a set of two MXM heatsinks from a laptop model I know can take maxwell cards I know I can modify to work with this laptop, and i figure i can get around what seems to be the dedicated fan controller chip's incompatibility with new cards thermal reporting by just setting a static curve, or making some other system that reads temps from the cards and adjusts the fans. I have a 880M running on my M17xR1. Single GPU. It does ocnflict with the internal hd audio, need to see if swapping the driver install order fixes white screen issue like on M17xR3. I think 780M should work & 680m without the hd audio conflict. You can reusethe heatsinks, I think the SLI cable form fermi to maxwell is the same but 260M is different Alienware Area-51M R2 : Intel Core i9-10900K | nVidia GeForce RTX 2080 SUPER Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080 Alienware 18 : Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000 Alienware 17 : Intel Core i7 4940MX @ 4.5Ghz | nVidia GeForce RTX 4090 Alienware M18x R2 : Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080 Alienware M18x : Intel Core i7 2960XM @ 4.7Ghz | nVidia Quadro RTX 5000 Alienware M17xR3 : Intel Core i7 2920XM @ 4.7Ghz | nVidia Quadro RTX 5000 Alienware M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000)| Precision M6600 (P4000) | 7520 (T1000) | 7720 (Tesla P6) BEAST Server: Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYT
commanderf Posted July 29 Author Posted July 29 On 7/17/2026 at 11:31 PM, ssj92 said: I have a 880M running on my M17xR1. Single GPU. It does ocnflict with the internal hd audio, need to see if swapping the driver install order fixes white screen issue like on M17xR3. I think 780M should work & 680m without the hd audio conflict. You can reusethe heatsinks, I think the SLI cable form fermi to maxwell is the same but 260M is different Thanks for the info, got a really nice deal on a lot of 3 MXM gpus, including a 680m, 870m, and an old fermi quadro card, so I think I'm set with options on what to put in this thing. Managed to snag a cheap SLI cable for an 18 r1 in case the old one doesn't work as well. Edit: Seems like the SLI cable fits fine on the 680m. I do remember reading an archived NBR thread mentioning this cable's connector having to be modified to fit a pair of 285Ms in an R1, so maybe there's both a 280m cable and a 260m cable with connector differences? I do think I could run into some trouble with signal integrity with this old cable though, if the SLI bus speed was increased over the years outside of 10 series HB SLI. Not sure. Main pc - Thermaltake lvl 10 gt snow, Asus b850a gaming wifi, 7900x, rtx 2070 super, 16gb of ram, eisblock xpx aurora, thermaltake toughpower gold 1200w Precision 7740 - i9 9980HK, 32 gb of ram, rtx 4000 Precision m6800 - I7 4910MQ, 24gb ddr3, K3100M
razor0601 Posted November 11 Posted November 11 So which of these cards maybe could work in the M17X R1? I have Dell 765m, 770m, 880m, 7970m, Clevo 460m, 560m, 675m, 770m, 780m XMG U716(Clevo P775DM-G)
razor0601 Posted November 13 Posted November 13 I tried Dell 770m and 880m. Same problem like SSJ92 with no audio. XMG U716(Clevo P775DM-G)
ssj92 Posted Monday at 02:26 AM Posted Monday at 02:26 AM I haven't figured out audio but I am confident it can be fixed. On M17xR3 the trick was, install nVidia gpu drivers first then install audio driver Alienware Area-51M R2 : Intel Core i9-10900K | nVidia GeForce RTX 2080 SUPER Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080 Alienware 18 : Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000 Alienware 17 : Intel Core i7 4940MX @ 4.5Ghz | nVidia GeForce RTX 4090 Alienware M18x R2 : Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080 Alienware M18x : Intel Core i7 2960XM @ 4.7Ghz | nVidia Quadro RTX 5000 Alienware M17xR3 : Intel Core i7 2920XM @ 4.7Ghz | nVidia Quadro RTX 5000 Alienware M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000)| Precision M6600 (P4000) | 7520 (T1000) | 7720 (Tesla P6) BEAST Server: Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYT
