Hi all!  Have a family member starting architecture school, looking for recommendations from you pros.
Not sure if an XPS (if there's a screen big enough) or Alienware or one of the Pro models would be a smarter choice.  You recommend AMD or Intel cpu?  Maybe more importantly, which type of dGPU?  NVIDIA or AMD?  Looking for something that'll last a bit.
Thanks!
The school emailed some recommendations and also said they'll be using Revit in the future.
·       15” screen size recommended
·       Operating System: 64‐bit Windows 11
·       CPU Type: Intel or AMD processor with 2 GHZ or higher base core clock speed.
o   Highest single core base clock speed (GHz) is recommended
·       Memory: 32‐GB RAM (64‐GB preferred)
·       Dedicated graphics card with 6GB of video memory.
o   Accelerated Graphics (for complex Revit models and Graphic files): Graphics card with 8GB or more of video memory recommended.
§  OpenGL 4.5 or higher required.
·       Disk Size: 1TB Solid State Drive
Please note: due to the intensive use of computer graphics in architecture and engineering, a dedicated graphics card is required.  Students that have ignored this by purchasing a cheaper laptop with integrated graphics have had to purchase a new laptop.
Haven't bought a Dell in years, still using my 7740...  Wow, their new naming scheme is confusing!
Looking like maybe an Alienware 16X Aurora with an Intel Ultra 7 270HX Plus or Ultra 9 290HX Plus?  And an 8GB RTX 5060 or 5070?  And then 32 or 64GB RAM.
How's that look?
