Im thinking off getting ether the P370SM or the P570wm now i got some questions about them,
1. dos anybody have an unlockt bios off them, i coudent find any online
2. dos every P370SM/P570wm have an edp konektor?
Alienware M18x R2 Space Black: I7 3940XM 4,5GHz | P3000 | 16GB Ram 1600MHz | WiFi 6E AX210
Alienware M17x R4 Nebula Red: I7 3920XM 4,4GHz | GTX 1080M Zotac | 32GB Ram 1600MHz
Alienware M18x Space Black: I7 2920XM | GTX 980M | 8GB Ram 1333MHz
Alienware M17x R3 Nebula Red: I7 2760QM | GTX 675M | 8GB Ram 1600MHz
Alienware 17: I7 4710MQ | GTX 860M | 16GB Ram 1600MHz
P870TM1: I9 9900K All core 4,8GHz | RTX 3080 | 32GB RAM 2933MHz
P751TM1: I7 8700 | RTX 2080 200W | 32GB Ram 2400MHz
P370SM: I7 4930MX 4,2GHz | GTX 980M SLI | 16GB RAM 2133Mhz
P570WM3: I7 3960X 4,6GHz | RTX 3070M | 16GB Ram 1866MHz
P370/P375SM I had that. Build quality not good.
I have P570WM3. I can do RTX 4070, 4090 in the main MXM slot with custom heatsink and backlight mod v1.
Yes both have eDP support upto 1080p 120Hz.
I sell heatsink for RTX 3080/4080/4090 + backlight mod for P570WM3.
P570WM3 has better CPU cooling.
Is there a difference between the P570WM3 and the P570wm, i am thinking of buying the one on ebay
Yes.
Cooling capacity, different plateform and different chassis.
P570WM3 (120Hz version) is better. Don't get the LVDS ONE!
There's also a custom heatsink for RTX 3070/3080/4080/4090 for P570WM3.
6 minutes ago, Tenzzy said:
LVDS. You need to contact Eurocom... and buy the P570WM3 motherboard for 480/500€ and eDP cable for 60€. Yes it's expensive but if you have money, it's worth it I guess...
Try to find it on your local german websites. XMG ULTRA 17 from 2012
If i serch for tat, links and so from the X170 and P870 comm up
to expensiv, i was willing to buy one for 500-600€ max
I think i buy the P570wm and maibe buy the P570wm3 motherboard next month or so, even if it is expensive i ned a mor powerful CPU tan an 3940XM
Single core wise they are the same. Want to upgrade to an RTX 3080/4080?
alrede got an rtx 3070, but the I7 3940MX startet to show its age in Cyberpunk and in moddet Skyrim
RTX 3070 MXM? From where?
Got it from eBay , but i think ist an ZRT Cart. I kann later post  somme pictures
You need my heatsink for it then
