ssj92 Posted January 23, 2022 Posted January 23, 2022 Hey everyone, for those who don't know I've been working on getting a Quadro RTX 3000 MXM GPU for my M18xR2. RTX 3000 is basically a Quadro variant of the RTX 2060 (TU106).The GPU I found happens to be about MXM 3.0b in layout made by ADLINK. This GPU is also available from Aetina and PNY in the exact same form factor. I chose this because it requires no mods besides INF and it provides the latest RTX features on an old platform.I made a video of MXM in general here including the raptor NVMe card:The laptop has 32GB 2133Mhz RAM, Wi-Fi6E + BT 5.2 as well. It is basically up to spec.No heatsink mod needed: Here's some benchmarks and pictures:Benches: 7 Alienware Area-51 18 : Intel Core Ultra 9 275HX @ ??? | nVidia GeForce RTX 5090 | BE200 | 1TB Gen5 9100 PRO Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080 | AX210 | Samsung 970 Evo+ Alienware M18x R2 : Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080 | AX210 | Samsung 980 PRO Alienware 18 : Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000 | AX210 | Samsung 980 NVMe More Laps: M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000) | M17xR3 (WX 7100) | M18xR1 (RTX 5000) BEAST Server: Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYT
kenny27 Posted February 2, 2022 Posted February 2, 2022 I am guessing the raptor nvme card drops the primary slot down to x8 does this affect performance compared to x16 at all? M18x R2 | 3920XM | 16GB DDR3 @ 2133Mhz | 980M SLI | 256GB Samsung 840 Evo + 1TB HHD | Audioengine D1 | Beyordynamic DT990 | Corsair M65
ssj92 Posted February 4, 2022 Author Posted February 4, 2022 On 2/1/2022 at 9:17 PM, kenny27 said: I am guessing the raptor nvme card drops the primary slot down to x8 does this affect performance compared to x16 at all? No performance loss from what i can see. My AW18 has only the RTX 3000 and has the newer 4930MX CPU. They perform about the same. 1 Alienware Area-51 18 : Intel Core Ultra 9 275HX @ ??? | nVidia GeForce RTX 5090 | BE200 | 1TB Gen5 9100 PRO Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080 | AX210 | Samsung 970 Evo+ Alienware M18x R2 : Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080 | AX210 | Samsung 980 PRO Alienware 18 : Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000 | AX210 | Samsung 980 NVMe More Laps: M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000) | M17xR3 (WX 7100) | M18xR1 (RTX 5000) BEAST Server: Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYT
TruenoG7 Posted March 29, 2022 Posted March 29, 2022 Do you have an alienware 18, if so, is it true that these have bad VRM and end up ruining the motherboard when you overclock in the CPU? ---Dell Precision M6700---, i7-4900MQ, Tesla M6, M6100/HD 8950M, 1920x1080p 6bits LVDS. ---Dell Precision M6800---, i7-4900MQ, Tesla M6, M6100/HD 8950M, 1920x1080p 6bits LVDS. ---Alienware M17x R2--, I7-940MX, HD 8970M Crossfire, M6100/HD 8950M, GTX 765M, 1920x1200P OC 75 Hzt. ---Alienware 17-- i7-4940MX, RTX 3000(LVDS),P3000, GTX 980M, 880M,860M, M6100/HD 8950M, 1080P, 120 Hz, 3D. --Alienware 18-- i7-4930MX, 32GB RAM 1866 MHz, RTX 4000, RTX 3000, P3000, M6100/HD 8950M, 1920x1080P. LCDOC 75 Hzt. (In use). ---Alienware M18x R2- i7-3940XM, 32GB RAM 1866 MHz, GTX 980M SLI, 1920x1080p 6bits OC 75 Hzt. Youtube Channel : https://www.youtube.com/channel/UCi0b4otJZHtUJePgIejiI4Q.
ssj92 Posted April 1, 2022 Author Posted April 1, 2022 On 3/29/2022 at 10:57 AM, TruenoG7 said: Do you have an alienware 18, if so, is it true that these have bad VRM and end up ruining the motherboard when you overclock in the CPU? I have two AW 18 right now. Owned one before as well. None of them had VRM blow. However I think it depends. Many people had issues many did not. Luck of the draw I guess. I am running the same RTX 3000 in my AW18 as well. 1 Alienware Area-51 18 : Intel Core Ultra 9 275HX @ ??? | nVidia GeForce RTX 5090 | BE200 | 1TB Gen5 9100 PRO Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080 | AX210 | Samsung 970 Evo+ Alienware M18x R2 : Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080 | AX210 | Samsung 980 PRO Alienware 18 : Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000 | AX210 | Samsung 980 NVMe More Laps: M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000) | M17xR3 (WX 7100) | M18xR1 (RTX 5000) BEAST Server: Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYT
DDAY3493 Posted May 24, 2022 Posted May 24, 2022 Hi! I had a quick question regarding the Alienware 18, you mentioned that you had overclocked the screen to 90Hz in yours. Do you have any sort of color problems? I'm guessing you run the laptop with both RTX and igpu. I used to have a single or sli set up, I could overclock up to 95 to 100hz, now when I do this, my color looks all messed up, unless I put it at 75hz. Thank you in advance!
ssj92 Posted May 30, 2022 Author Posted May 30, 2022 On 5/24/2022 at 1:18 AM, DDAY3493 said: Hi! I had a quick question regarding the Alienware 18, you mentioned that you had overclocked the screen to 90Hz in yours. Do you have any sort of color problems? I'm guessing you run the laptop with both RTX and igpu. I used to have a single or sli set up, I could overclock up to 95 to 100hz, now when I do this, my color looks all messed up, unless I put it at 75hz. Thank you in advance! Colors perfectly fine. Tried on iGPU only mode, SG mode and even in PEG on my 2nd AW 18. All depends on lcd panel, each one is different 1 Alienware Area-51 18 : Intel Core Ultra 9 275HX @ ??? | nVidia GeForce RTX 5090 | BE200 | 1TB Gen5 9100 PRO Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080 | AX210 | Samsung 970 Evo+ Alienware M18x R2 : Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080 | AX210 | Samsung 980 PRO Alienware 18 : Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000 | AX210 | Samsung 980 NVMe More Laps: M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000) | M17xR3 (WX 7100) | M18xR1 (RTX 5000) BEAST Server: Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYT
DDAY3493 Posted May 31, 2022 Posted May 31, 2022 ssj92 My color used to be fine too without the iGPU. I was able to get up to 95 to 100hz at one point, that was without artifacts. Now since I'm using the iGPU and RTX 5000, I can't seem to go higher than 75hz without having artifacts on the screen. You think it might have something to do with iGPU bandwidth?
ssj92 Posted June 2, 2022 Author Posted June 2, 2022 On 5/31/2022 at 10:42 AM, DDAY3493 said: ssj92 My color used to be fine too without the iGPU. I was able to get up to 95 to 100hz at one point, that was without artifacts. Now since I'm using the iGPU and RTX 5000, I can't seem to go higher than 75hz without having artifacts on the screen. You think it might have something to do with iGPU bandwidth? How are you overclocking the display? Are you using cru? btw RTX 5000? Got any pics 😍 1 Alienware Area-51 18 : Intel Core Ultra 9 275HX @ ??? | nVidia GeForce RTX 5090 | BE200 | 1TB Gen5 9100 PRO Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080 | AX210 | Samsung 970 Evo+ Alienware M18x R2 : Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080 | AX210 | Samsung 980 PRO Alienware 18 : Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000 | AX210 | Samsung 980 NVMe More Laps: M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000) | M17xR3 (WX 7100) | M18xR1 (RTX 5000) BEAST Server: Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYT
Clamibot Posted June 2, 2022 Posted June 2, 2022 Quadro RTX 5000 in an Alienware 18? That sounds amazing! Routing video through the iGPU may be affecting how high the screen can overclock. The iGPU has a lot less performance and memory bandwidth than a dGPU, so it would stand to reason that it wouldn't be able to support as high of a screen overclock since it's not as capable of a GPU. That may explain the artifacting at higher screen overclocks. However, I've seen iGPUs drive 120 Hz and 144 Hz displays before, so that may not be it. Another potential explanation is the output bandwidth allowed by the internal connection from the iGPU to the screen. Alienware laptops from 2013 and before have a MUX switch that allows for switching between optimus mode and dGPU only mode. The input into the MUX coming from the iGPU may have less bandwidth available to it than the output into the MUX coming from the dGPU. This would make sense since the dGPU is much more powerful, and can therefore deliver a much higher framerate than the iGPU. In short, there is a design limitation somewhere causing the artifacting. Since you were able to get higher screen overclocks in dGPU only mode than you can in optimus mode, my guess is it has something to do with the bandwidth of the video output traces on the motherboard that go from their respective GPUs into the MUX switch. I don't know if both MUX switch inputs have the same bandwidth or not, but I'm guessing they probably don't. 1 AlienyHackbook: Alienware M17X R5 | i7-4930MX | GTX 1060 | 32GB DDR3L Kingston HyperX @ 2133 MHz CL 12 | MacOS Sierra 10.12.5 | Windows 10 LTSC | Hackintoshes Rule! Desktop Killer: Clevo X170SM-G | i9-10900K | RTX 2080 Super | 32GB DDR4 Crucial Ballistix @ 3200 MHz CL 16 | Windows 10 LTSC | Slayer Of Desktops Sagattarius A: Custom Built Desktop | i9-10900K | RX 6950 XT | 32GB DDR4 G.Skill Ripjaws @ 4200 MHz CL 15 | Windows 10 LTSC | Ultimate Performance Desktop With Cryo Cooling!
ssj92 Posted June 2, 2022 Author Posted June 2, 2022 1 hour ago, Clamibot said: Quadro RTX 5000 in an Alienware 18? That sounds amazing! Routing video through the iGPU may be affecting how high the screen can overclock. The iGPU has a lot less performance and memory bandwidth than a dGPU, so it would stand to reason that it wouldn't be able to support as high of a screen overclock since it's not as capable of a GPU. That may explain the artifacting at higher screen overclocks. However, I've seen iGPUs drive 120 Hz and 144 Hz displays before, so that may not be it. Another potential explanation is the output bandwidth allowed by the internal connection from the iGPU to the screen. Alienware laptops from 2013 and before have a MUX switch that allows for switching between optimus mode and dGPU only mode. The input into the MUX coming from the iGPU may have less bandwidth available to it than the output into the MUX coming from the dGPU. This would make sense since the dGPU is much more powerful, and can therefore deliver a much higher framerate than the iGPU. In short, there is a design limitation somewhere causing the artifacting. Since you were able to get higher screen overclocks in dGPU only mode than you can in optimus mode, my guess is it has something to do with the bandwidth of the video output traces on the motherboard that go from their respective GPUs into the MUX switch. I don't know if both MUX switch inputs have the same bandwidth or not, but I'm guessing they probably don't. My guess might be display could also be degrading and can’t keep oc anymore. im running 90hz on aw 18 and 85hz on m18x r2 using igpu. Could also be method used to oc. I like using cru 1 Alienware Area-51 18 : Intel Core Ultra 9 275HX @ ??? | nVidia GeForce RTX 5090 | BE200 | 1TB Gen5 9100 PRO Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080 | AX210 | Samsung 970 Evo+ Alienware M18x R2 : Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080 | AX210 | Samsung 980 PRO Alienware 18 : Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000 | AX210 | Samsung 980 NVMe More Laps: M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000) | M17xR3 (WX 7100) | M18xR1 (RTX 5000) BEAST Server: Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYT
DDAY3493 Posted June 2, 2022 Posted June 2, 2022 Absolutely can post some pictures! I always use CRU as well for the screen overclocking. I gave it a thought many times that it might be the screen degrading over time or like Clamibot said that it might have something to do with the bandwidth coming from the iGPU and going into the MUX switch. I tried messing around with different timings and such in the CRU options but the artifacting was still present. Sorry BTW if I can't seem to respond the right way, to each post. I'm pretty new to this forum thing haha lol! 1 1
DDAY3493 Posted June 2, 2022 Posted June 2, 2022 It's still quite amazing how capable this machine still is for it's age, I have the Area-51M and the Predator 21 X and the 18 keeps up pretty well with either one of those machines.
Rengsey R. H. Jr. Posted June 3, 2022 Posted June 3, 2022 How much was the RTX 3000? How was the performance on gaming?
DDAY3493 Posted June 3, 2022 Posted June 3, 2022 The RTX 3000 or 5000? If you are referring to the RTX 5000, then I got it for about a $1000 almost a year ago on eBay.
ssj92 Posted June 3, 2022 Author Posted June 3, 2022 5 hours ago, Rengsey R. H. Jr. said: How much was the RTX 3000? How was the performance on gaming? I got mine I think around $640 shipped gaming is right on par with rtx 2060. 1 hour ago, DDAY3493 said: The RTX 3000 or 5000? If you are referring to the RTX 5000, then I got it for about a $1000 almost a year ago on eBay. Do you have a pic of which rtx 5000 you bought? Alienware Area-51 18 : Intel Core Ultra 9 275HX @ ??? | nVidia GeForce RTX 5090 | BE200 | 1TB Gen5 9100 PRO Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080 | AX210 | Samsung 970 Evo+ Alienware M18x R2 : Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080 | AX210 | Samsung 980 PRO Alienware 18 : Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000 | AX210 | Samsung 980 NVMe More Laps: M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000) | M17xR3 (WX 7100) | M18xR1 (RTX 5000) BEAST Server: Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYT
aldarxt Posted June 3, 2022 Posted June 3, 2022 (edited) 17 hours ago, DDAY3493 said: Sure do! Here you go How did you get this to fit with the mounting holes being offset? I have seen these and passed them up thinking they won't fit. Was afraid of shorting the card where the offset hole would touch where the other screw is supposed to mount OK My Bad the RTX 5000 is NOT in the Alienware 18, its in something else Edited June 4, 2022 by aldarxt Mistake Clevo P870DM3-G i9-9900k-32.0GB 2667mhz-RTX3080+GTX1080 Alienware M18x R2 i7-3920xm-32GB DDR3-RTX 3000 Alienware M17x R4 i7-3940XM-16GB DDR3-RTX 3000 Alienware M17x R4 i7-3940XM 20GB DDR3-P4000 120hz 3D Precision m6700 i7-3840QM-16GB DDR3-GTX 970M Precision m4700 i7-3840QM-16GB DDR3-T2000M HP ZBook 17 G6 i7 9850H-32GB DDR4-RTX4000maxQ GOBOXX SLM G2721-i7-10875H RTX 3000-32GB ddr4
DDAY3493 Posted June 4, 2022 Posted June 4, 2022 Nope! I can definitely confirm that I have the RTX 5000 in the Alienware 18, the thing is I had to do a couple of modifications in order to get it properly in the laptop. I will post some pictures. Have to take it apart first! 1
DDAY3493 Posted June 4, 2022 Posted June 4, 2022 Here are the pictures as promised. 😁 Also with better upgraded Wifi card! 2 2 1
aldarxt Posted June 4, 2022 Posted June 4, 2022 8 hours ago, DDAY3493 said: Thanks for this, you have opened a whole new set of options for these Magnificent Antiques! A whole new set of mxm cards. That nut is soldered on to the MOBO??? I think I can do that, without removing the MOBO hopefully Just have to decide to go with m17xr4 or m18xr2. So the boss for stock screw does not touch the gpu? And Thanks again very much appreciate this!!! 1 Clevo P870DM3-G i9-9900k-32.0GB 2667mhz-RTX3080+GTX1080 Alienware M18x R2 i7-3920xm-32GB DDR3-RTX 3000 Alienware M17x R4 i7-3940XM-16GB DDR3-RTX 3000 Alienware M17x R4 i7-3940XM 20GB DDR3-P4000 120hz 3D Precision m6700 i7-3840QM-16GB DDR3-GTX 970M Precision m4700 i7-3840QM-16GB DDR3-T2000M HP ZBook 17 G6 i7 9850H-32GB DDR4-RTX4000maxQ GOBOXX SLM G2721-i7-10875H RTX 3000-32GB ddr4
ssj92 Posted June 4, 2022 Author Posted June 4, 2022 10 hours ago, DDAY3493 said: Here are the pictures as promised. 😁 Wait so did you modify heatsink at all? It fits into the slot even with offset core? Idk if this would work in m18x r2 or m17x series with their heatsinks Alienware Area-51 18 : Intel Core Ultra 9 275HX @ ??? | nVidia GeForce RTX 5090 | BE200 | 1TB Gen5 9100 PRO Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080 | AX210 | Samsung 970 Evo+ Alienware M18x R2 : Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080 | AX210 | Samsung 980 PRO Alienware 18 : Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000 | AX210 | Samsung 980 NVMe More Laps: M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000) | M17xR3 (WX 7100) | M18xR1 (RTX 5000) BEAST Server: Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYT
aldarxt Posted June 4, 2022 Posted June 4, 2022 2 hours ago, ssj92 said: Wait so did you modify heatsink at all? It fits into the slot even with offset core? Idk if this would work in m18x r2 or m17x series with their heatsinks He definitely modded it, I can see the bottom left edge was almost completely ground off, the thicker part that drops down. Nice Job, can see where it would have touched, I'll probably get another heatsink for this, maybe a copper with more than 3 pipes The 2nd pic, is that screw grounded? circuits can be funny sometimes, don't know if both stock mounting holes need to be or not. 1 Clevo P870DM3-G i9-9900k-32.0GB 2667mhz-RTX3080+GTX1080 Alienware M18x R2 i7-3920xm-32GB DDR3-RTX 3000 Alienware M17x R4 i7-3940XM-16GB DDR3-RTX 3000 Alienware M17x R4 i7-3940XM 20GB DDR3-P4000 120hz 3D Precision m6700 i7-3840QM-16GB DDR3-GTX 970M Precision m4700 i7-3840QM-16GB DDR3-T2000M HP ZBook 17 G6 i7 9850H-32GB DDR4-RTX4000maxQ GOBOXX SLM G2721-i7-10875H RTX 3000-32GB ddr4
DDAY3493 Posted June 4, 2022 Posted June 4, 2022 Actually that nut isn't soldered at all, I just glued it in place with super glue. Not on the motherboard itself but, on the plastic cover or tape. Aldarxt, definitely true these older Alienwares have a long life time. Ssj92 the heatsink is from an M18x R2 or R1 as the oem heatsink wouldn't fit. The 18 heatsink would be off center. So, I did modify it a little, like aldaext said the bottom of the heatsink is cut off because it covered the screw hole. Also on the other side of the heatsink, I sanded this portion down with a handheld dremel. The oem screw hole ports are touching the card, as far as I know but, it's not making direct contact because on the other side of the graphics is some sort of plastic cover, it's not interferring with any circuits on the card. Also when I first installed the graphics card I also noticed that it doesn't fit in directly, unless you cut off the mxm port graphics card holders, here and here! 3
