panda_zzz Posted September 27, 2024 Share Posted September 27, 2024 1 hour ago, Jerryzago said: Isn't the 4050 a MXM type A? M17x R4 works with MXM type B? Maybe it will fit in the slot but you will not be able to screw it in place, and stock heatsink won't fit! A-type cards fit into B-type card slots without any problems. The reverse situation is practically impossible (except in very rare cases) 1 1 Link to comment Share on other sites More sharing options...
aldarxt Posted September 27, 2024 Share Posted September 27, 2024 4 hours ago, ssj92 said: If that 4050 is anything like A4500 was, then you are going to have a hard time getting it recognized. I recommend SG mode in M17xR4. And if that doesn't work, try my M18xR1 trick. Use M18xR2, primary slot a gpu that works in PEG and then gpu2 will be RTX 4050. Good luck Yes if it comes to that, the card lists DP/HDMI/EDP so if it does not work in m17xr4 with LVDS screen then I will try in m17xr4 with 120hz screen EDP and take out the P4000 and put it in the other. Then if all fail I would like to try the 2nd slot of m18xr2. These old laptops have alot of options LOL. I recently put a T2000 in Precision M4700 and its more powerful than M6700 now. T2000 is an A card, but it has a tab on it preventing installing in M6700, but it also should fit in m17xr4. Seeing how well the T2000 works and seeing a post here on the forums about RTX 4060 mxm A card an ebay selling for $600+ I decided to go back to xvision for $280 Clevo P870DM3-G i9-9900k-32.0GB 2667mhz-RTX3080+GTX1080 Alienware M18x R2 i7-3920xm-32GB DDR3-RTX 3000 Alienware M17x R4 i7-3940XM-16GB DDR3-RTX 3000 Alienware M17x R4 i7-3940XM 20GB DDR3-P4000 120hz 3D Precision m6700 i7-3840QM-16GB DDR3-GTX 970M Precision m4700 i7-3840QM-16GB DDR3-T2000M HP ZBook 17 G6 i7 9850H-32GB DDR4-RTX4000maxQ GOBOXX SLM G2721-i7-10875H RTX 3000-32GB ddr4 Link to comment Share on other sites More sharing options...
aldarxt Posted September 27, 2024 Share Posted September 27, 2024 2 hours ago, Jerryzago said: Isn't the 4050 a MXM type A? M17x R4 works with MXM type B? Maybe it will fit in the slot but you will not be able to screw it in place, and stock heatsink won't fit! The screw holes line up exactly to the board and the heatsink. Only part of the heatsink overlaps and covers nothing, but it should be more than the cooling the card should ever need Clevo P870DM3-G i9-9900k-32.0GB 2667mhz-RTX3080+GTX1080 Alienware M18x R2 i7-3920xm-32GB DDR3-RTX 3000 Alienware M17x R4 i7-3940XM-16GB DDR3-RTX 3000 Alienware M17x R4 i7-3940XM 20GB DDR3-P4000 120hz 3D Precision m6700 i7-3840QM-16GB DDR3-GTX 970M Precision m4700 i7-3840QM-16GB DDR3-T2000M HP ZBook 17 G6 i7 9850H-32GB DDR4-RTX4000maxQ GOBOXX SLM G2721-i7-10875H RTX 3000-32GB ddr4 Link to comment Share on other sites More sharing options...
Jerryzago Posted September 28, 2024 Share Posted September 28, 2024 8 hours ago, aldarxt said: The screw holes line up exactly to the board and the heatsink. Only part of the heatsink overlaps and covers nothing, but it should be more than the cooling the card should ever need Please do post pictures when you will make the install. I was sceptical about this (fitting an A GPU to a B slot). Though I have a quadro M2000m lying around for testing, I didn't go forward. 1 Spoiler Alienware M18x R2 | i7 3720qm -> i7 3940XM | Dual 7970m -> 980m SLI -> HP Quadro RTX 3000 Alienware 17 R1 | 4710MQ | 880M GTX -> PNY Quadro RTX 3000 HP 8570w | i7 3820qm | Quadro K2000M HP DV6000 | T72000 -> T9500 Link to comment Share on other sites More sharing options...
aldarxt Posted September 28, 2024 Share Posted September 28, 2024 11 hours ago, Jerryzago said: Please do post pictures when you will make the install. I was sceptical about this (fitting an A GPU to a B slot). Though I have a quadro M2000m lying around for testing, I didn't go forward. OK, Thanks for reminding me, I am not the picture person in the house, my wife keeps me busy unloading her phone all the time, I just seem to overlook that job until it's too late. How many times I assembled my PC and sat back and said Damn I wish I took a pic! 1 1 Clevo P870DM3-G i9-9900k-32.0GB 2667mhz-RTX3080+GTX1080 Alienware M18x R2 i7-3920xm-32GB DDR3-RTX 3000 Alienware M17x R4 i7-3940XM-16GB DDR3-RTX 3000 Alienware M17x R4 i7-3940XM 20GB DDR3-P4000 120hz 3D Precision m6700 i7-3840QM-16GB DDR3-GTX 970M Precision m4700 i7-3840QM-16GB DDR3-T2000M HP ZBook 17 G6 i7 9850H-32GB DDR4-RTX4000maxQ GOBOXX SLM G2721-i7-10875H RTX 3000-32GB ddr4 Link to comment Share on other sites More sharing options...
aldarxt Posted September 30, 2024 Share Posted September 30, 2024 On 9/27/2024 at 1:13 PM, ssj92 said: If that 4050 is anything like A4500 was, then you are going to have a hard time getting it recognized. I recommend SG mode in M17xR4. And if that doesn't work, try my M18xR1 trick. Use M18xR2, primary slot a gpu that works in PEG and then gpu2 will be RTX 4050. Good luck @ssj92 I was checking specs and the RTX 4050 mobile has DisplayPort 1.4a compared to P4000 has DisplayPort 1.4, I think DisplayPort 1.4a is backward compatible. Just keeping my hopes up cause the P4000 works with LVDS and EDP 120hz screens Clevo P870DM3-G i9-9900k-32.0GB 2667mhz-RTX3080+GTX1080 Alienware M18x R2 i7-3920xm-32GB DDR3-RTX 3000 Alienware M17x R4 i7-3940XM-16GB DDR3-RTX 3000 Alienware M17x R4 i7-3940XM 20GB DDR3-P4000 120hz 3D Precision m6700 i7-3840QM-16GB DDR3-GTX 970M Precision m4700 i7-3840QM-16GB DDR3-T2000M HP ZBook 17 G6 i7 9850H-32GB DDR4-RTX4000maxQ GOBOXX SLM G2721-i7-10875H RTX 3000-32GB ddr4 Link to comment Share on other sites More sharing options...
ssj92 Posted September 30, 2024 Author Share Posted September 30, 2024 3 hours ago, aldarxt said: @ssj92 I was checking specs and the RTX 4050 mobile has DisplayPort 1.4a compared to P4000 has DisplayPort 1.4, I think DisplayPort 1.4a is backward compatible. Just keeping my hopes up cause the P4000 works with LVDS and EDP 120hz screens They're all backwards compatible. The real question will be if the RTX 4050 is wired for eDP and has proper firmware for it too. LVDS should work if the card doesn't have a weird issue like my A4500 did. Where it may need resizable bar/above 4g decoding 2 Alienware Area-51 18 : Intel Core Ultra 9 275HX @ ??? | nVidia GeForce RTX 5090 | BE200 | 1TB Gen5 9100 PRO Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080 | AX210 | Samsung 970 Evo+ Alienware M18x R2 : Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080 | AX210 | Samsung 980 PRO Alienware 18 : Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000 | AX210 | Samsung 980 NVMe More Laps: M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000) | M17xR3 (WX 7100) | M18xR1 (RTX 5000) BEAST Server: Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYT Link to comment Share on other sites More sharing options...
aldarxt Posted September 30, 2024 Share Posted September 30, 2024 1 hour ago, ssj92 said: They're all backwards compatible. The real question will be if the RTX 4050 is wired for eDP and has proper firmware for it too. LVDS should work if the card doesn't have a weird issue like my A4500 did. Where it may need resizable bar/above 4g decoding According to the spec sheet it is DP/DP/HDMI/EDP I am just hoping Clevo P870DM3-G i9-9900k-32.0GB 2667mhz-RTX3080+GTX1080 Alienware M18x R2 i7-3920xm-32GB DDR3-RTX 3000 Alienware M17x R4 i7-3940XM-16GB DDR3-RTX 3000 Alienware M17x R4 i7-3940XM 20GB DDR3-P4000 120hz 3D Precision m6700 i7-3840QM-16GB DDR3-GTX 970M Precision m4700 i7-3840QM-16GB DDR3-T2000M HP ZBook 17 G6 i7 9850H-32GB DDR4-RTX4000maxQ GOBOXX SLM G2721-i7-10875H RTX 3000-32GB ddr4 Link to comment Share on other sites More sharing options...
panda_zzz Posted September 30, 2024 Share Posted September 30, 2024 5 hours ago, aldarxt said: Just keeping my hopes up cause the P4000 works with LVDS and EDP 120hz screens does the rtx3000 card work over edp with the display at m17x r4? Link to comment Share on other sites More sharing options...
aldarxt Posted October 1, 2024 Share Posted October 1, 2024 13 hours ago, panda_zzz said: does the rtx3000 card work over edp with the display at m17x r4? No, the m17xr4 with 120hz didn't work with the RTX 3000 but I don't remember if I tried it in pure UEFI mode which is how the P4000 works now. I would like to have tried it but I damaged 1 of my RTX 3000 when I pulled off the x bracket installing it in the M6700 cause the heatsink has its own special screw setup. I never encountered an x bracket that was glued on so tight. A very intelligent member of this forum @Aaron44126 said I should have used a heat gun, which I have,I would have pulled out my hair if I had some! So I'm not pulling out my working RTX 3000 from my m18xr2 but for a similar $$$ the RTX 4050 is the next experiment Clevo P870DM3-G i9-9900k-32.0GB 2667mhz-RTX3080+GTX1080 Alienware M18x R2 i7-3920xm-32GB DDR3-RTX 3000 Alienware M17x R4 i7-3940XM-16GB DDR3-RTX 3000 Alienware M17x R4 i7-3940XM 20GB DDR3-P4000 120hz 3D Precision m6700 i7-3840QM-16GB DDR3-GTX 970M Precision m4700 i7-3840QM-16GB DDR3-T2000M HP ZBook 17 G6 i7 9850H-32GB DDR4-RTX4000maxQ GOBOXX SLM G2721-i7-10875H RTX 3000-32GB ddr4 Link to comment Share on other sites More sharing options...
aldarxt Posted October 5, 2024 Share Posted October 5, 2024 OK the card came and does not work in m17xr4 with 60hz LVDS screen in SG mode with EUFI settings both with and without Legacy option ROM enabled or disabled The m17xr4 with 120hz EDP screen also did not work in full EUFI and PEG mode. All I got was a screen flah, like a blink and 8 beeps, I did not try SG cause it is not capable of it and didn;t want to flash cMos and have to go thru the GTX 680m reset instalation. The card has some high resistors so I took a copper plate from an old m18xr2 CPU heatsink that got damaged in the past and set it on the m17xr4 heatsink and it sat llevel. The m17xr4 with 60hz screen didn't even show in BIOS or device manager. It is looking like @ssj92 said to try it in 2nd slot of m18xr2 but first am going to try 2nd slot of Clevo P870DM3-G. I am very reluctant to open m18xr2 cause it is running so well I am afraid of "The Rabbit Hole" 1 1 Clevo P870DM3-G i9-9900k-32.0GB 2667mhz-RTX3080+GTX1080 Alienware M18x R2 i7-3920xm-32GB DDR3-RTX 3000 Alienware M17x R4 i7-3940XM-16GB DDR3-RTX 3000 Alienware M17x R4 i7-3940XM 20GB DDR3-P4000 120hz 3D Precision m6700 i7-3840QM-16GB DDR3-GTX 970M Precision m4700 i7-3840QM-16GB DDR3-T2000M HP ZBook 17 G6 i7 9850H-32GB DDR4-RTX4000maxQ GOBOXX SLM G2721-i7-10875H RTX 3000-32GB ddr4 Link to comment Share on other sites More sharing options...
panda_zzz Posted October 5, 2024 Share Posted October 5, 2024 So for now the laptop can't see the card at all? Even in optimus mode? Link to comment Share on other sites More sharing options...
nforce4max Posted October 6, 2024 Share Posted October 6, 2024 Have to wonder is it the vbios or the pcb isn't wired to drive a display so either way for it to not work sucks. Do you have an mxm to desktop pci-e adapter to see if it would drive a regular monitor at all. Link to comment Share on other sites More sharing options...
aldarxt Posted October 6, 2024 Share Posted October 6, 2024 4 hours ago, panda_zzz said: So for now the laptop can't see the card at all? Even in optimus mode? Right, 1 laptop in SG and the other in PEG Clevo P870DM3-G i9-9900k-32.0GB 2667mhz-RTX3080+GTX1080 Alienware M18x R2 i7-3920xm-32GB DDR3-RTX 3000 Alienware M17x R4 i7-3940XM-16GB DDR3-RTX 3000 Alienware M17x R4 i7-3940XM 20GB DDR3-P4000 120hz 3D Precision m6700 i7-3840QM-16GB DDR3-GTX 970M Precision m4700 i7-3840QM-16GB DDR3-T2000M HP ZBook 17 G6 i7 9850H-32GB DDR4-RTX4000maxQ GOBOXX SLM G2721-i7-10875H RTX 3000-32GB ddr4 Link to comment Share on other sites More sharing options...
aldarxt Posted October 6, 2024 Share Posted October 6, 2024 2 hours ago, nforce4max said: Have to wonder is it the vbios or the pcb isn't wired to drive a display so either way for it to not work sucks. Do you have an mxm to desktop pci-e adapter to see if it would drive a regular monitor at all. I am looking at vBios on Techpowerup and there are 44 unverified for RTX 4050 mobile, 1 for 4050 laptop GPU and 1 for 4050 laptop. Looking at the card the vBios chip is on the back, I'll have a look and extract it and do a little comparing, maybe a Dell vBios if I can get past the nVidia Lock No pci-e adapter and no monitor, but I do see that as becoming an advantage 1 Clevo P870DM3-G i9-9900k-32.0GB 2667mhz-RTX3080+GTX1080 Alienware M18x R2 i7-3920xm-32GB DDR3-RTX 3000 Alienware M17x R4 i7-3940XM-16GB DDR3-RTX 3000 Alienware M17x R4 i7-3940XM 20GB DDR3-P4000 120hz 3D Precision m6700 i7-3840QM-16GB DDR3-GTX 970M Precision m4700 i7-3840QM-16GB DDR3-T2000M HP ZBook 17 G6 i7 9850H-32GB DDR4-RTX4000maxQ GOBOXX SLM G2721-i7-10875H RTX 3000-32GB ddr4 Link to comment Share on other sites More sharing options...
aldarxt Posted October 6, 2024 Share Posted October 6, 2024 Got out the Ch341a Programmer V2.2.0.10 and read the card It will not flash Dell vBios. Ran As Administrator and unlocked but says Buffer size not equal to IC size 1 1 Clevo P870DM3-G i9-9900k-32.0GB 2667mhz-RTX3080+GTX1080 Alienware M18x R2 i7-3920xm-32GB DDR3-RTX 3000 Alienware M17x R4 i7-3940XM-16GB DDR3-RTX 3000 Alienware M17x R4 i7-3940XM 20GB DDR3-P4000 120hz 3D Precision m6700 i7-3840QM-16GB DDR3-GTX 970M Precision m4700 i7-3840QM-16GB DDR3-T2000M HP ZBook 17 G6 i7 9850H-32GB DDR4-RTX4000maxQ GOBOXX SLM G2721-i7-10875H RTX 3000-32GB ddr4 Link to comment Share on other sites More sharing options...
ssj92 Posted October 14, 2024 Author Share Posted October 14, 2024 On 10/6/2024 at 7:59 AM, aldarxt said: Got out the Ch341a Programmer V2.2.0.10 and read the card It will not flash Dell vBios. Ran As Administrator and unlocked but says Buffer size not equal to IC size Take a picture of the vBIOS chip up close and see what chip it is. Your program shows generic 1 kbit which is incorrect. I personally use ASProgramer 1 Alienware Area-51 18 : Intel Core Ultra 9 275HX @ ??? | nVidia GeForce RTX 5090 | BE200 | 1TB Gen5 9100 PRO Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080 | AX210 | Samsung 970 Evo+ Alienware M18x R2 : Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080 | AX210 | Samsung 980 PRO Alienware 18 : Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000 | AX210 | Samsung 980 NVMe More Laps: M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000) | M17xR3 (WX 7100) | M18xR1 (RTX 5000) BEAST Server: Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYT Link to comment Share on other sites More sharing options...
Derpmaster69 Posted October 15, 2024 Share Posted October 15, 2024 Will xvision RTX 4060 MXM work on the alienware 18 (2014)? The tdp is 110W and I think that that it could handle the extra 10W? The only thing that would make it hard is that the AW18 only has LVDS. But could it work on SG? Link to comment Share on other sites More sharing options...
aldarxt Posted October 15, 2024 Share Posted October 15, 2024 23 hours ago, ssj92 said: Take a picture of the vBIOS chip up close and see what chip it is. Your program shows generic 1 kbit which is incorrect. I personally use ASProgramer Thanks for looking out @ssj92 I am held up about the vBios looking like nothing is in there. I want to try flashing but it seems to be locked with CH341A - USB Programmer Never heard of ASProgramer, will look into it Here is a pic of vBios chip. It looked blank till I got the lighting at the right angle Clevo P870DM3-G i9-9900k-32.0GB 2667mhz-RTX3080+GTX1080 Alienware M18x R2 i7-3920xm-32GB DDR3-RTX 3000 Alienware M17x R4 i7-3940XM-16GB DDR3-RTX 3000 Alienware M17x R4 i7-3940XM 20GB DDR3-P4000 120hz 3D Precision m6700 i7-3840QM-16GB DDR3-GTX 970M Precision m4700 i7-3840QM-16GB DDR3-T2000M HP ZBook 17 G6 i7 9850H-32GB DDR4-RTX4000maxQ GOBOXX SLM G2721-i7-10875H RTX 3000-32GB ddr4 Link to comment Share on other sites More sharing options...
aldarxt Posted October 15, 2024 Share Posted October 15, 2024 Found a .pdf data sheet, but I don't know where to start, pg. 17 states "If the bit defaults to “1” or programmed to “1”, it can’t be programmed to “0” again." makes me nervous. https://www.issi.com/WW/pdf/25WP016_080_040_020.pdf Clevo P870DM3-G i9-9900k-32.0GB 2667mhz-RTX3080+GTX1080 Alienware M18x R2 i7-3920xm-32GB DDR3-RTX 3000 Alienware M17x R4 i7-3940XM-16GB DDR3-RTX 3000 Alienware M17x R4 i7-3940XM 20GB DDR3-P4000 120hz 3D Precision m6700 i7-3840QM-16GB DDR3-GTX 970M Precision m4700 i7-3840QM-16GB DDR3-T2000M HP ZBook 17 G6 i7 9850H-32GB DDR4-RTX4000maxQ GOBOXX SLM G2721-i7-10875H RTX 3000-32GB ddr4 Link to comment Share on other sites More sharing options...
Derpmaster69 Posted October 16, 2024 Share Posted October 16, 2024 Any updates? Link to comment Share on other sites More sharing options...
Derpmaster69 Posted October 17, 2024 Share Posted October 17, 2024 On 10/1/2024 at 2:57 AM, aldarxt said: According to the spec sheet it is DP/DP/HDMI/EDP I am just hoping There is one empty vram thingy in there. Imagine soldering another 2gb vram chip and having a RTX 4050 8gb. By the way @aldarxt did you try it in your m18x r2? It may work in the 2nd slot. Link to comment Share on other sites More sharing options...
Jerryzago Posted October 17, 2024 Share Posted October 17, 2024 On 10/15/2024 at 8:51 PM, aldarxt said: Thanks for looking out @ssj92 I am held up about the vBios looking like nothing is in there. I want to try flashing but it seems to be locked with CH341A - USB Programmer Never heard of ASProgramer, will look into it Here is a pic of vBios chip. It looked blank till I got the lighting at the right angle How about going the M18x R1 route. Install 4050 to the secondary slot and a "known to work" GPU in the primary slot (780, 880, 980 with unlocked BIOS) and set the GPU to PEG. If the system detects it, then drivers will be installed and MAYBE it might work? Spoiler Alienware M18x R2 | i7 3720qm -> i7 3940XM | Dual 7970m -> 980m SLI -> HP Quadro RTX 3000 Alienware 17 R1 | 4710MQ | 880M GTX -> PNY Quadro RTX 3000 HP 8570w | i7 3820qm | Quadro K2000M HP DV6000 | T72000 -> T9500 Link to comment Share on other sites More sharing options...
Derpmaster69 Posted October 17, 2024 Share Posted October 17, 2024 2 hours ago, Jerryzago said: How about going the M18x R1 route. Install 4050 to the secondary slot and a "known to work" GPU in the primary slot (780, 880, 980 with unlocked BIOS) and set the GPU to PEG. If the system detects it, then drivers will be installed and MAYBE it might work? Exactly @aldarxt try this and let us know. 1 Link to comment Share on other sites More sharing options...
cdoublejj Posted October 17, 2024 Share Posted October 17, 2024 no way it's size limitation of 128 bytes, thats way too small. is it eFused? can we not buy a vbios chip and program it and solder it on? Link to comment Share on other sites More sharing options...
