panda_zzz Posted January 18, 2025 Share Posted January 18, 2025 2 hours ago, SuperMG3 said: So 4060M works on M4800/M6800 then? I personally have not decided to try it yet) but another forum member is trying it - the card is visible in the bios, but not in the system. Link to comment Share on other sites More sharing options...
panda_zzz Posted January 18, 2025 Share Posted January 18, 2025 Just now, ssj92 said: Interersting...eDP or LVDS mode? lvds via optimus. I haven't bought myself a cable and matrix yet to try the edp connection Link to comment Share on other sites More sharing options...
ssj92 Posted January 18, 2025 Author Share Posted January 18, 2025 7 minutes ago, panda_zzz said: lvds via optimus. I haven't bought myself a cable and matrix yet to try the edp connection Okay then it should also work in M18xR2. Alienware Area-51 18 : Intel Core Ultra 9 275HX @ ??? | nVidia GeForce RTX 5090 | BE200 | 1TB Gen5 9100 PRO Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080 | AX210 | Samsung 970 Evo+ Alienware M18x R2 : Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080 | AX210 | Samsung 980 PRO Alienware 18 : Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000 | AX210 | Samsung 980 NVMe More Laps: M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000) | M17xR3 (WX 7100) | M18xR1 (RTX 5000) BEAST Server: Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYT Link to comment Share on other sites More sharing options...
panda_zzz Posted January 18, 2025 Share Posted January 18, 2025 Just now, ssj92 said: Okay then it should also work in M18xR2. I'm sure it will work. the native bios does not require 4g decoding. the main problem is with heatsink, but it can be solved. Link to comment Share on other sites More sharing options...
SuperMG Posted January 18, 2025 Share Posted January 18, 2025 1 hour ago, panda_zzz said: I personally have not decided to try it yet) but another forum member is trying it - the card is visible in the bios, but not in the system. He needs correct drivers for windows then? Link to comment Share on other sites More sharing options...
ssj92 Posted January 18, 2025 Author Share Posted January 18, 2025 1 hour ago, panda_zzz said: I'm sure it will work. the native bios does not require 4g decoding. the main problem is with heatsink, but it can be solved. I think vBIOS with 4g decoding is only reason some Ada GPUs and even A4500 Amphere didn't work in M18xR2. It would be quite difficult to implement, but we could at least add ReBar support and see if it helps. Alienware Area-51 18 : Intel Core Ultra 9 275HX @ ??? | nVidia GeForce RTX 5090 | BE200 | 1TB Gen5 9100 PRO Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080 | AX210 | Samsung 970 Evo+ Alienware M18x R2 : Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080 | AX210 | Samsung 980 PRO Alienware 18 : Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000 | AX210 | Samsung 980 NVMe More Laps: M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000) | M17xR3 (WX 7100) | M18xR1 (RTX 5000) BEAST Server: Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYT Link to comment Share on other sites More sharing options...
panda_zzz Posted January 18, 2025 Share Posted January 18, 2025 37 minutes ago, SuperMG3 said: He needs correct drivers for windows then? No, that's not it - the device is just not visible in Device Manager. 5 minutes ago, ssj92 said: It would be quite difficult to implement, but we could at least add ReBar support and see if it helps. It would be nice if they could add support for 4g decoding. Well, in any case, I tried flashing other bios from 4060m - and the first one seems to have checked for this feature. my test computer (and I tested it initially on a PC through an adapter) did not want to boot and judging by the postcodes hung on pcie device detection. here is a screenshot of the current bios Link to comment Share on other sites More sharing options...
ssj92 Posted January 18, 2025 Author Share Posted January 18, 2025 2 minutes ago, panda_zzz said: No, that's not it - the device is just not visible in Device Manager. It would be nice if they could add support for 4g decoding. Well, in any case, I tried flashing other bios from 4060m - and the first one seems to have checked for this feature. my test computer (and I tested it initially on a PC through an adapter) did not want to boot and judging by the postcodes hung on pcie device detection. here is a screenshot of the current bios Is this GPU-Z screenshot in M17xR4 or desktop? If you want to send me your current unlocked BIOS, I can try adding at least resizable bar support and you can test to see if it works. But you need to make sure you have a programmer and can backup your current bios in case flash doesn't work. If it works, I plan to make M17xR4, M18xR2, AW 18 and AW 17 rebar BIOS Alienware Area-51 18 : Intel Core Ultra 9 275HX @ ??? | nVidia GeForce RTX 5090 | BE200 | 1TB Gen5 9100 PRO Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080 | AX210 | Samsung 970 Evo+ Alienware M18x R2 : Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080 | AX210 | Samsung 980 PRO Alienware 18 : Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000 | AX210 | Samsung 980 NVMe More Laps: M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000) | M17xR3 (WX 7100) | M18xR1 (RTX 5000) BEAST Server: Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYT Link to comment Share on other sites More sharing options...
panda_zzz Posted January 18, 2025 Share Posted January 18, 2025 59 minutes ago, ssj92 said: Is this GPU-Z screenshot in M17xR4 or desktop? This is a screenshot from a desktop, I can do the same on a laptop if you need it. The bios modification sounds interesting) Link to comment Share on other sites More sharing options...
janepa Posted January 18, 2025 Share Posted January 18, 2025 1 hour ago, ssj92 said: I think vBIOS with 4g decoding is only reason some Ada GPUs and even A4500 Amphere didn't work in M18xR2. It would be quite difficult to implement, but we could at least add ReBar support and see if it helps. 1 hour ago, ssj92 said: Is this GPU-Z screenshot in M17xR4 or desktop? If you want to send me your current unlocked BIOS, I can try adding at least resizable bar support and you can test to see if it works. But you need to make sure you have a programmer and can backup your current bios in case flash doesn't work. If it works, I plan to make M17xR4, M18xR2, AW 18 and AW 17 rebar BIOS Hi all, at this stage it makes sense to go ahead and try for a small miracle. I have a programmer and one spare M18XR2 motherboard just for testing . I can test and test. Here's my dump. Thank you. M18XR2 A11 unlocked.rar 1 Alienware M18x R1 i7-2720xm-32GB-Adlink RTX5000 Alienware M18x R2 i7-3920xm-32GB-RTX4090 (still in testing) with the latest bios version. A14 specially modified updated and unlocked by me 😎 Asus ROG Zephyrus G14 AMD Ryzen 9 7940HS-32GB-RTX4060 Link to comment Share on other sites More sharing options...
SuperMG Posted January 19, 2025 Share Posted January 19, 2025 12 hours ago, ssj92 said: Is this GPU-Z screenshot in M17xR4 or desktop? If you want to send me your current unlocked BIOS, I can try adding at least resizable bar support and you can test to see if it works. But you need to make sure you have a programmer and can backup your current bios in case flash doesn't work. If it works, I plan to make M17xR4, M18xR2, AW 18 and AW 17 rebar BIOS If I send you my M18X R2 BIOS dump, would you add it too? And in which source are you basing off to add rebar? Link to comment Share on other sites More sharing options...
ssj92 Posted January 21, 2025 Author Share Posted January 21, 2025 On 1/18/2025 at 3:52 PM, janepa said: Hi all, at this stage it makes sense to go ahead and try for a small miracle. I have a programmer and one spare M18XR2 motherboard just for testing . I can test and test. Here's my dump. Thank you. M18XR2 A11 unlocked.rar 3.07 MB · 2 downloads Good luck. First step will be to flash and see if it boots LOL. https://drive.google.com/file/d/1nK4y6axXIB-VZp-b7p7mIIkG_v1-RgBA/view?usp=sharing if it boots, chances are it worked. BUT..after flashing, go to BIOS, make sure legacy rom is completely disabled (no csm mode). Boot to windows and download ReBarstate: https://github.com/xCuri0/ReBarUEFI/releases/download/0.3/ReBarState.exe Type 8 and press enter. Reboot and relaunch rebarstate to see what it says, also check GPU-Z. Since you have rtx 5000 series it should at least recognize if rebar is on in bios or not. If everything boots after typing 8 in rebarstate and rebooting, it technically should be working with 256MB bar size. After that we can try 32 value. The problem is, this bios does have not above 4g decoding option, so we are trying to make it work without it. You can always reset to normal by resetting cmos. I do have one other thing we can try to enable above 4g but first let's test this bios. ALSO NOTE TO ANYONE ELSE: This BIOS was made ysing @janepa BIOS dump. Please do not flash to your own M18x. I can make one for the general once we can figure out if this even works. On 1/19/2025 at 2:21 AM, SuperMG3 said: If I send you my M18X R2 BIOS dump, would you add it too? And in which source are you basing off to add rebar? As long as you have a programmer yes Alienware Area-51 18 : Intel Core Ultra 9 275HX @ ??? | nVidia GeForce RTX 5090 | BE200 | 1TB Gen5 9100 PRO Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080 | AX210 | Samsung 970 Evo+ Alienware M18x R2 : Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080 | AX210 | Samsung 980 PRO Alienware 18 : Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000 | AX210 | Samsung 980 NVMe More Laps: M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000) | M17xR3 (WX 7100) | M18xR1 (RTX 5000) BEAST Server: Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYT Link to comment Share on other sites More sharing options...
SuperMG Posted January 21, 2025 Share Posted January 21, 2025 9 minutes ago, ssj92 said: Good luck. First step will be to flash and see if it boots LOL. https://drive.google.com/file/d/1nK4y6axXIB-VZp-b7p7mIIkG_v1-RgBA/view?usp=sharing if it boots, chances are it worked. BUT..after flashing, go to BIOS, make sure legacy rom is completely disabled (no csm mode). Boot to windows and download ReBarstate: https://github.com/xCuri0/ReBarUEFI/releases/download/0.3/ReBarState.exe Type 8 and press enter. Reboot and relaunch rebarstate to see what it says, also check GPU-Z. Since you have rtx 5000 series it should at least recognize if rebar is on in bios or not. If everything boots after typing 8 in rebarstate and rebooting, it technically should be working with 256MB bar size. After that we can try 32 value. The problem is, this bios does have not above 4g decoding option, so we are trying to make it work without it. You can always reset to normal by resetting cmos ALSO NOTE TO ANYONE ELSE: This BIOS was made ysing @janepa BIOS dump. Please do not flash to your own M18x. I can make one for the general once we can figure out if this even works. As long as you have a programmer yes Yes I had a programmer and thanks god it helped me save my AW18 that got bricked because of editing Short Turbo delay... Yes I have a backup of M18XR2. I'll wait to see if your friend one works. Link to comment Share on other sites More sharing options...
janepa Posted January 22, 2025 Share Posted January 22, 2025 20 hours ago, ssj92 said: Good luck. First step will be to flash and see if it boots LOL. https://drive.google.com/file/d/1nK4y6axXIB-VZp-b7p7mIIkG_v1-RgBA/view?usp=sharing if it boots, chances are it worked. BUT..after flashing, go to BIOS, make sure legacy rom is completely disabled (no csm mode). Boot to windows and download ReBarstate: https://github.com/xCuri0/ReBarUEFI/releases/download/0.3/ReBarState.exe Type 8 and press enter. Reboot and relaunch rebarstate to see what it says, also check GPU-Z. Since you have rtx 5000 series it should at least recognize if rebar is on in bios or not. If everything boots after typing 8 in rebarstate and rebooting, it technically should be working with 256MB bar size. After that we can try 32 value. The problem is, this bios does have not above 4g decoding option, so we are trying to make it work without it. You can always reset to normal by resetting cmos. I do have one other thing we can try to enable above 4g but first let's test this bios. ALSO NOTE TO ANYONE ELSE: This BIOS was made ysing @janepa BIOS dump. Please do not flash to your own M18x. I can make one for the general once we can figure out if this even works. As long as you have a programmer yes Okay, got it . Give me two days for test. Alienware M18x R1 i7-2720xm-32GB-Adlink RTX5000 Alienware M18x R2 i7-3920xm-32GB-RTX4090 (still in testing) with the latest bios version. A14 specially modified updated and unlocked by me 😎 Asus ROG Zephyrus G14 AMD Ryzen 9 7940HS-32GB-RTX4060 Link to comment Share on other sites More sharing options...
ssj92 Posted January 22, 2025 Author Share Posted January 22, 2025 4 hours ago, janepa said: Okay, got it . Give me two days for test. I also have an idea on above 4g decoding option after to test as well. But first let's see that BIOS if it works. BTW do you have RTX 3000 130w or 120w vBIOS? I'm using stock HP vBIOS which is 90W I think. I tried a few from techpowerup but they all caused weird issues. If you have working vBIOS on M18xR2 above 100w I would like to try it out too Alienware Area-51 18 : Intel Core Ultra 9 275HX @ ??? | nVidia GeForce RTX 5090 | BE200 | 1TB Gen5 9100 PRO Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080 | AX210 | Samsung 970 Evo+ Alienware M18x R2 : Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080 | AX210 | Samsung 980 PRO Alienware 18 : Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000 | AX210 | Samsung 980 NVMe More Laps: M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000) | M17xR3 (WX 7100) | M18xR1 (RTX 5000) BEAST Server: Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYT Link to comment Share on other sites More sharing options...
janepa Posted January 23, 2025 Share Posted January 23, 2025 17 hours ago, ssj92 said: I also have an idea on above 4g decoding option after to test as well. But first let's see that BIOS if it works. BTW do you have RTX 3000 130w or 120w vBIOS? I'm using stock HP vBIOS which is 90W I think. I tried a few from techpowerup but they all caused weird issues. If you have working vBIOS on M18xR2 above 100w I would like to try it out too Okay, I understood about this. I have ADLINK RTX5000 with 110W +5% boost peak in games about 130w and drivers installed via NVCleanstall . If do you need vbios from this gpu i can send to you no problem, but i think is completely different iron then you have. Alienware M18x R1 i7-2720xm-32GB-Adlink RTX5000 Alienware M18x R2 i7-3920xm-32GB-RTX4090 (still in testing) with the latest bios version. A14 specially modified updated and unlocked by me 😎 Asus ROG Zephyrus G14 AMD Ryzen 9 7940HS-32GB-RTX4060 Link to comment Share on other sites More sharing options...
janepa Posted January 23, 2025 Share Posted January 23, 2025 1 minute ago, janepa said: Okay, I understood about this. I have ADLINK RTX5000 with 110W +5% boost peak in games about 130w and drivers installed via NVCleanstall . If do you need vbios from this gpu i can send to you no problem, but i think is completely different iron then you have. This is my R2 project. Alienware M18x R1 i7-2720xm-32GB-Adlink RTX5000 Alienware M18x R2 i7-3920xm-32GB-RTX4090 (still in testing) with the latest bios version. A14 specially modified updated and unlocked by me 😎 Asus ROG Zephyrus G14 AMD Ryzen 9 7940HS-32GB-RTX4060 Link to comment Share on other sites More sharing options...
ssj92 Posted January 23, 2025 Author Share Posted January 23, 2025 2 hours ago, janepa said: Okay, I understood about this. I have ADLINK RTX5000 with 110W +5% boost peak in games about 130w and drivers installed via NVCleanstall . If do you need vbios from this gpu i can send to you no problem, but i think is completely different iron then you have. Wow the rare RTX 5000 from Adlink. I can try out the vBIOS and see if it works Alienware Area-51 18 : Intel Core Ultra 9 275HX @ ??? | nVidia GeForce RTX 5090 | BE200 | 1TB Gen5 9100 PRO Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080 | AX210 | Samsung 970 Evo+ Alienware M18x R2 : Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080 | AX210 | Samsung 980 PRO Alienware 18 : Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000 | AX210 | Samsung 980 NVMe More Laps: M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000) | M17xR3 (WX 7100) | M18xR1 (RTX 5000) BEAST Server: Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYT Link to comment Share on other sites More sharing options...
panda_zzz Posted January 23, 2025 Share Posted January 23, 2025 4 hours ago, janepa said: I have ADLINK RTX5000 You're so lucky, I really wanted to buy this card but it didn't pop up on ebay or aliexpress. How much did it cost you? Link to comment Share on other sites More sharing options...
janepa Posted January 24, 2025 Share Posted January 24, 2025 19 hours ago, panda_zzz said: You're so lucky, I really wanted to buy this card but it didn't pop up on ebay or aliexpress. How much did it cost you? I was buing this card in year 2023 on ebay from PNY seller i think. It was new and price was really really good i cant remember how much exactly i think about 350 eur , but shipping was almost the same because the seller was not shipp to my country . It was horor because i want this card ,but shipping options was not . And this is result after years. 3 Alienware M18x R1 i7-2720xm-32GB-Adlink RTX5000 Alienware M18x R2 i7-3920xm-32GB-RTX4090 (still in testing) with the latest bios version. A14 specially modified updated and unlocked by me 😎 Asus ROG Zephyrus G14 AMD Ryzen 9 7940HS-32GB-RTX4060 Link to comment Share on other sites More sharing options...
ssj92 Posted January 24, 2025 Author Share Posted January 24, 2025 3 hours ago, janepa said: I was buing this card in year 2023 on ebay from PNY seller i think. It was new and price was really really good i cant remember how much exactly i think about 350 eur , but shipping was almost the same because the seller was not shipp to my country . It was horor because i want this card ,but shipping options was not . And this is result after years. If you purchased 2, you could have put one in M18xR1 as well lol RTX 5000 in M18xR1:[SG mode] Generic VGA video card benchmark result - Intel Core i7-2960XM Processor,Alienware M18xR1 (3dmark.com) RTX 5000 in M18xR1 [PEG mode 880M Primary, RTX 5000 Secondary]: NVIDIA GeForce GTX 880M video card benchmark result - Intel Core i7-2960XM Processor,Alienware M18xR1 (3dmark.com) Generic VGA video card benchmark result - Intel Core i7-2960XM Processor,Alienware M18xR1 (3dmark.com) Alienware Area-51 18 : Intel Core Ultra 9 275HX @ ??? | nVidia GeForce RTX 5090 | BE200 | 1TB Gen5 9100 PRO Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080 | AX210 | Samsung 970 Evo+ Alienware M18x R2 : Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080 | AX210 | Samsung 980 PRO Alienware 18 : Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000 | AX210 | Samsung 980 NVMe More Laps: M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000) | M17xR3 (WX 7100) | M18xR1 (RTX 5000) BEAST Server: Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYT Link to comment Share on other sites More sharing options...
janepa Posted January 25, 2025 Share Posted January 25, 2025 On 1/24/2025 at 7:44 PM, ssj92 said: If you purchased 2, you could have put one in M18xR1 as well lol RTX 5000 in M18xR1:[SG mode] Generic VGA video card benchmark result - Intel Core i7-2960XM Processor,Alienware M18xR1 (3dmark.com) RTX 5000 in M18xR1 [PEG mode 880M Primary, RTX 5000 Secondary]: NVIDIA GeForce GTX 880M video card benchmark result - Intel Core i7-2960XM Processor,Alienware M18xR1 (3dmark.com) Generic VGA video card benchmark result - Intel Core i7-2960XM Processor,Alienware M18xR1 (3dmark.com) Yes, it will be great to have 2 cards, but I'm happy for this one. I watched your result with R1 a few weeks ago and I'm impressed. I kinda planning RTX5000 to R1 as you write and 4060 to R2 if it works out , because efficiency 4060 are much better and i must make new heatsink for new card too. It what will do RTX5000 with 110w will do the same job RTX4060 only with 30 wats. Anyways i was testing the new bios from you and bingo working like charm without any issues good job. Now i swap testing board and i will continue with procedure. Give me some time please. A little question. I was looking on this thread : https://github.com/terminatorul/NvStrapsReBar and maybe it will be works wih my quadro too or not ? And little present for the end. Perhaps it will be help. 1EF5 rtx5000 ori.rar Alienware M18x R1 i7-2720xm-32GB-Adlink RTX5000 Alienware M18x R2 i7-3920xm-32GB-RTX4090 (still in testing) with the latest bios version. A14 specially modified updated and unlocked by me 😎 Asus ROG Zephyrus G14 AMD Ryzen 9 7940HS-32GB-RTX4060 Link to comment Share on other sites More sharing options...
SuperMG Posted January 25, 2025 Share Posted January 25, 2025 1 hour ago, janepa said: Yes, it will be great to have 2 cards, but I'm happy for this one. I watched your result with R1 a few weeks ago and I'm impressed. I kinda planning RTX5000 to R1 as you write and 4060 to R2 if it works out , because efficiency 4060 are much better and i must make new heatsink for new card too. It what will do RTX5000 with 110w will do the same job RTX4060 only with 30 wats. Anyways i was testing the new bios from you and bingo working like charm without any issues good job. Now i swap testing board and i will continue with procedure. Give me some time please. A little question. I was looking on this thread : https://github.com/terminatorul/NvStrapsReBar and maybe it will be works wih my quadro too or not ? And little present for the end. Perhaps it will be help. 1EF5 rtx5000 ori.rar 333.8 kB · 0 downloads Do you have rebar enabled? Show us your GPU-Z please. Link to comment Share on other sites More sharing options...
janepa Posted January 25, 2025 Share Posted January 25, 2025 31 minutes ago, SuperMG3 said: Do you have rebar enabled? Show us your GPU-Z please. No, not yet, please hold on. I was testing new bios till now on my spare motherboard only with monitor nothing more. Now i will put original board and all other components and will be to continue with right proceed , but i think ,no I'm believe it shud be work . Most important thing was right inserting ffs file and this is was done by ssj92 on first shoot. Alienware M18x R1 i7-2720xm-32GB-Adlink RTX5000 Alienware M18x R2 i7-3920xm-32GB-RTX4090 (still in testing) with the latest bios version. A14 specially modified updated and unlocked by me 😎 Asus ROG Zephyrus G14 AMD Ryzen 9 7940HS-32GB-RTX4060 Link to comment Share on other sites More sharing options...
ssj92 Posted January 26, 2025 Author Share Posted January 26, 2025 On 1/25/2025 at 11:45 AM, janepa said: Yes, it will be great to have 2 cards, but I'm happy for this one. I watched your result with R1 a few weeks ago and I'm impressed. I kinda planning RTX5000 to R1 as you write and 4060 to R2 if it works out , because efficiency 4060 are much better and i must make new heatsink for new card too. It what will do RTX5000 with 110w will do the same job RTX4060 only with 30 wats. Anyways i was testing the new bios from you and bingo working like charm without any issues good job. Now i swap testing board and i will continue with procedure. Give me some time please. A little question. I was looking on this thread : https://github.com/terminatorul/NvStrapsReBar and maybe it will be works wih my quadro too or not ? And little present for the end. Perhaps it will be help. 1EF5 rtx5000 ori.rar 333.8 kB · 0 downloads We can try that one after. Once you test on your normal board, try doing the rebar enable through command prompt. Also, in the BIOS there's a setting called MAX TOLUD. I think default is 2.25GB or 2.5GB. After you have tried the command prompt enable (even if it works or not). Go to bios and change MAX TOLUD value to "Dynamic". Then see if it works. I don't think it's exactly the same as above 4g decode, but should help hopefully. Alienware Area-51 18 : Intel Core Ultra 9 275HX @ ??? | nVidia GeForce RTX 5090 | BE200 | 1TB Gen5 9100 PRO Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080 | AX210 | Samsung 970 Evo+ Alienware M18x R2 : Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080 | AX210 | Samsung 980 PRO Alienware 18 : Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000 | AX210 | Samsung 980 NVMe More Laps: M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000) | M17xR3 (WX 7100) | M18xR1 (RTX 5000) BEAST Server: Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYT Link to comment Share on other sites More sharing options...
