razor0601 Posted July 8, 2022 Posted July 8, 2022 Hi there, are the heatsinks from P750/770zm compatible with P750/770DM? My P750DM Heatsink has 6-31-P75D3-101 and on eBay there is from P770zm 6-31-P7503-103. Anyone tested that? Also I want to know if other LCD‘s than the listed on eurocom upgrade chart list are compatible for P750DM. And why there are so many various LCD cables? I know 4K and FullHD are different. But also for the different 4K Displays are different cables needed? Schenker DTR 15(P751TM1) @Dsanke Bios, I7-8700, 32GB 2666MHz RAM, GTX 1060, 15,6“ 4K B156ZAN02.2 Display
jaybee83 Posted July 8, 2022 Posted July 8, 2022 On 7/8/2022 at 2:09 PM, razor0601 said: Hi there, are the heatsinks from P750/770zm compatible with P750/770DM? My P750DM Heatsink has 6-31-P75D3-101 and on eBay there is from P770zm 6-31-P7503-103. Anyone tested that? Also I want to know if other LCD‘s than the listed on eurocom upgrade chart list are compatible for P750DM. And why there are so many various LCD cables? I know 4K and FullHD are different. But also for the different 4K Displays are different cables needed? iirc they should be compatible, make sure to check NBC reviews of the two models, they definitely show the heatsinks as well. i should know since i had both systems but ZM has been a while back haha. as for the LCD, u can try the following trick: search for ur own lcd and the eurocom models listed on this website: https://www.panelook.com/ check their dimensions and cable types / connections and then use the search engine to filter for displays with the same dimensions and cables. that way ull get an idea of whats out there. can then search for such panels on ebay or aliexpress. for example, in my ZM i originally had a panasonic "3K" display installed that was between an FHD and UHD resolution, basically 1440p-like. so there are definitely more options! just make sure that ur mobo has the required display connectors, be it LVDS or the newer eDP with the respective cable width / pin number. sometimes mobos have both connector traces but only one of the two is actually active / connector soldered in place. Mine: Hyperion "Titan God of Heat, Heavenly Light, Power" (2022-26) AMD Ryzen 9 9950X3D (delidded) / Asus ROG Crosshair X670E Extreme (Qualcomm QCNCM865 Wifi 7 Upgrade) / MSI Geforce RTX 5090 Suprim SOC / G.Skill Trident Z5 RGB DDR5-8000 2x24 GB / 4x Western Digital Black SN850P/X 8TB in 2x16TB RAID 0 / Arctic Liquid Freezer III Pro 420 (Push/Pull 6x Noctua NF-A14 IndustrialPPC-3000 exhaust) / Seasonic TX-1600 W Titanium / Phanteks NV9 MKII Black incl. Premium D-RGB Light Strips Kit (6x Arctic P14 Pro A-RGB black intake / 2x Arctic P14 Pro A-RGB black exhaust / 1x Arctic P14 Pro A-RGB black RAM cooling) / Samsung Odyssey Neo G8 32" 4K 240 Hz / Ducky One 3 Daybreak Fullsize Cherry MX Brown / Corsair M65 Ultra RGB / PDP Afterglow Wave Black / Beyerdynamic DT 770 Pro X Limited Edition My Lady's: Clevo NH55JNNQ "Alfred" (2022-26) Sharp LQ156M1JW03 FHD matte 15.6" IGZO 8 bit @248 Hz / Intel Core i5 12600 / Nvidia Geforce RTX 3070 Ti / Mushkin Redline DDR4-3200 2x32 GB / Samsung 970 Pro 1 TB / Samsung 870 QVO 8 TB / Intel AX201 WIFI 6+BT 5.2 / Win 11 Pro Phoenix Lite OS / 230 W PSU powered by Prema Mod!
razor0601 Posted July 9, 2022 Author Posted July 9, 2022 Ok thanks for your great answer. I will check that. In your P751DM you have installed Prema Mod Bios. Is it the same like DSanke Bios? Schenker DTR 15(P751TM1) @Dsanke Bios, I7-8700, 32GB 2666MHz RAM, GTX 1060, 15,6“ 4K B156ZAN02.2 Display
jaybee83 Posted July 9, 2022 Posted July 9, 2022 4 hours ago, razor0601 said: Ok thanks for your great answer. I will check that. In your P751DM you have installed Prema Mod Bios. Is it the same like DSanke Bios? its not the same but the overall aim is similar, i.e. unlock bios options, provide more performance, allow hardware upgrades, etc. Mine: Hyperion "Titan God of Heat, Heavenly Light, Power" (2022-26) AMD Ryzen 9 9950X3D (delidded) / Asus ROG Crosshair X670E Extreme (Qualcomm QCNCM865 Wifi 7 Upgrade) / MSI Geforce RTX 5090 Suprim SOC / G.Skill Trident Z5 RGB DDR5-8000 2x24 GB / 4x Western Digital Black SN850P/X 8TB in 2x16TB RAID 0 / Arctic Liquid Freezer III Pro 420 (Push/Pull 6x Noctua NF-A14 IndustrialPPC-3000 exhaust) / Seasonic TX-1600 W Titanium / Phanteks NV9 MKII Black incl. Premium D-RGB Light Strips Kit (6x Arctic P14 Pro A-RGB black intake / 2x Arctic P14 Pro A-RGB black exhaust / 1x Arctic P14 Pro A-RGB black RAM cooling) / Samsung Odyssey Neo G8 32" 4K 240 Hz / Ducky One 3 Daybreak Fullsize Cherry MX Brown / Corsair M65 Ultra RGB / PDP Afterglow Wave Black / Beyerdynamic DT 770 Pro X Limited Edition My Lady's: Clevo NH55JNNQ "Alfred" (2022-26) Sharp LQ156M1JW03 FHD matte 15.6" IGZO 8 bit @248 Hz / Intel Core i5 12600 / Nvidia Geforce RTX 3070 Ti / Mushkin Redline DDR4-3200 2x32 GB / Samsung 970 Pro 1 TB / Samsung 870 QVO 8 TB / Intel AX201 WIFI 6+BT 5.2 / Win 11 Pro Phoenix Lite OS / 230 W PSU powered by Prema Mod!
