i.bakar Posted July 17, 2022 Posted July 17, 2022 well i got a tracking ball mouse the Logitech ergo 575 2 years ago and it was working fine , but since i did the 21H2 windows update , the mouse keep disconnecting if i didn't use it for 5 seconds which is very annoying! i did my research and found a few videos and articles with a few solutions as listed below : - remove the power saving option for the Bluetooth in the device manager under the human interface section ( didn't work ) - covert the Bluetooth support service to automatic in the services ( didn't work) - removing ( let this device turn off to save power ) in the device manager for every single item i found in the device manager ( didn't work ) - in the advanced power plan , turn USB selective support to disable on power and battery ( didn't work ) i thought maybe the mouse is defective so i installed an older copy of windows that i had on a USB drive the 1903 to test it and the mouse works fine ! but of course as soon as the windows update, the same issue starts again !! so i don't know what else i can do any advice ? Alienware M18X R1, i7 2960XM @ 4.4Ghz, Nvidia GTX 880M SLI , 32GB RAM , samsung 840pro + samsung 860evo ( THE BEST I EVER HAVE) Alienware Area-51M R1, i9 9900K @ 5.1Ghz, Nvidia RTX 2080, 64GB RAM, samsung 980 Pro( LOVELY MACHINE WITH BAD BIOS ) Alienware M18 R2, i9 14900HX @ 5.2Ghz, Nvidia RTX 4090, 64GB RAM, 4TB SSD (MY current ) Alienware 18 , I7 4930MX @ 4.2Ghz , GTX 980M SLI, 32GB RAM ( MAY REST IN PEACE) (SOLD)
K4sum1 Posted July 18, 2022 Posted July 18, 2022 What Bluetooth device do you use? You might want to get the manufacturer driver for it. Precision M4800 - i7 4810MQ, 32GB RAM, Nvidia Quadro M2200 Thinkpad T430 - i7 3630QM, 16GB RAM, Intel HD 4000, 1080p display mod Main PC - AMD Ryzen 9 5950X, 64GB RAM, RTX 2080 Ti
i.bakar Posted July 18, 2022 Author Posted July 18, 2022 1 hour ago, K4sum1 said: What Bluetooth device do you use? You might want to get the manufacturer driver for it. im using laptop Bluetooth connection which i believe is killer AX1550 and i already have the driver for it Alienware M18X R1, i7 2960XM @ 4.4Ghz, Nvidia GTX 880M SLI , 32GB RAM , samsung 840pro + samsung 860evo ( THE BEST I EVER HAVE) Alienware Area-51M R1, i9 9900K @ 5.1Ghz, Nvidia RTX 2080, 64GB RAM, samsung 980 Pro( LOVELY MACHINE WITH BAD BIOS ) Alienware M18 R2, i9 14900HX @ 5.2Ghz, Nvidia RTX 4090, 64GB RAM, 4TB SSD (MY current ) Alienware 18 , I7 4930MX @ 4.2Ghz , GTX 980M SLI, 32GB RAM ( MAY REST IN PEACE) (SOLD)
K4sum1 Posted July 18, 2022 Posted July 18, 2022 Just now, i.bakar said: im using laptop Bluetooth connection which i believe is killer AX1550 and i already have the driver for it Try finding a newer driver Precision M4800 - i7 4810MQ, 32GB RAM, Nvidia Quadro M2200 Thinkpad T430 - i7 3630QM, 16GB RAM, Intel HD 4000, 1080p display mod Main PC - AMD Ryzen 9 5950X, 64GB RAM, RTX 2080 Ti
i.bakar Posted July 18, 2022 Author Posted July 18, 2022 26 minutes ago, K4sum1 said: Try finding a newer driver i di try 2 drivers the older one and the latest one . plus this is happening on 3 different computers all of them has 3 different Bluetooth devices. Alienware M18X R1, i7 2960XM @ 4.4Ghz, Nvidia GTX 880M SLI , 32GB RAM , samsung 840pro + samsung 860evo ( THE BEST I EVER HAVE) Alienware Area-51M R1, i9 9900K @ 5.1Ghz, Nvidia RTX 2080, 64GB RAM, samsung 980 Pro( LOVELY MACHINE WITH BAD BIOS ) Alienware M18 R2, i9 14900HX @ 5.2Ghz, Nvidia RTX 4090, 64GB RAM, 4TB SSD (MY current ) Alienware 18 , I7 4930MX @ 4.2Ghz , GTX 980M SLI, 32GB RAM ( MAY REST IN PEACE) (SOLD)
i.bakar Posted July 19, 2022 Author Posted July 19, 2022 no one have this issue ? Alienware M18X R1, i7 2960XM @ 4.4Ghz, Nvidia GTX 880M SLI , 32GB RAM , samsung 840pro + samsung 860evo ( THE BEST I EVER HAVE) Alienware Area-51M R1, i9 9900K @ 5.1Ghz, Nvidia RTX 2080, 64GB RAM, samsung 980 Pro( LOVELY MACHINE WITH BAD BIOS ) Alienware M18 R2, i9 14900HX @ 5.2Ghz, Nvidia RTX 4090, 64GB RAM, 4TB SSD (MY current ) Alienware 18 , I7 4930MX @ 4.2Ghz , GTX 980M SLI, 32GB RAM ( MAY REST IN PEACE) (SOLD)
Meaker Posted July 23, 2022 Posted July 23, 2022 Bluetooth is usually based on the wifi card these days, make sure you turn off power management on it too. Louqe Ghost S1 case (Top hat and bottom extension) Powercolor RX 9070 XT Reaper 16GB 32" MSI 4k 160HZ IPS display AMD Ryzen 7 7700 cooled via Thermalright 240mm AIO 48GB (2x24) DDR5 6000 CL36 Asus B650E-I motherboard 2TB T500 nvme SSD + 2TB SN770 nvme Corsair SF750 platinum SFX PSU
