Hi all,
I need help modifying 970m vBIOS to work in M17xR3.
M17xR3 has no UEFI so it only works with legacy vBIOS. If newer card such as 970m with UEFI vBIOS is used, we get 8 beeps.
I've been told by another person they had M5000M (980m Quadro) working in M17xR3/m18xR1 by modifying vBIOS and removing UEFI gop portion.
I have tried this by removing UEFI gop and by removing ifr header and it still does 8 beep. Perhaps someone can help me modify it, maybe I am doing it wrong.
I've attahced vBIOS.
970mstock = stock 970m vBIOS card came with
970mnogop = Removed uefi gop portion and padded file with FF
970mnogopnoifr = same as above but also removed ifr header to see if it helps
only other option would be bios mod but that will probably be even harder. The original person claiming M5000M working has yet to respond to me.
in theory this should work, when I had 8970m, I had same issue but VBE7 removes UEFI gop and the card worked for me. I do get a backlight on the screen but before posting it 8 beeps.
970m_vBIOS.zip
Alienware Area-51M R2 : Intel Core i9-10900K                   | nVidia GeForce RTX 2080 SUPER
Alienware Area-51M :      Intel Core i9-9900K @ 5.3Ghz    | nVidia GeForce RTX 2080
Alienware 18 :                   Intel Core i7 4930MX @ 4.5Ghz  | nVidia Quadro RTX 5000
Alienware 17 :                   Intel Core i7 4940MX @ 4.5Ghz  | nVidia GeForce RTX 4090
Alienware M18x R2 :        Intel Core i7 3920XM @ 4.7Ghz  | nVidia GeForce RTX 3080
Alienware M18x :              Intel Core i7 2960XM @ 4.7Ghz | nVidia Quadro RTX 5000
Alienware M17xR3 :         Intel Core i7 2920XM @ 4.7Ghz  |  nVidia Quadro RTX 5000
Alienware M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000)| Precision M6600 (P4000) | 7520 (T1000) | 7720 (Tesla P6)
  • 4 weeks later...
Are there any other particular differences between the 970m and M4000M?
VRAM
4GB 256-Bit M4000M
3GB/6GB 192-Bit 970M
Otherwise pretty much same
