Clamibot Posted January 14, 2025 Posted January 14, 2025 7 hours ago, StripeySnake said: I forgot to post it last time, here is a sneak peek at the shorty config. P.S. going forward I will be modifying the main design to allow compatibility with Pico style PSUs, as well as FLEX of course. I am currently working on parity between the expensive sheet cut sections so that every configuration will only require 3D printing to reconfigure, which is a lot cheaper than sheet cutting. I will also be mocking up an optional mod to the liquid cooled chassis to add two additional 40mm dual radiators (and fans) stacked with the 60mm dual rads for 1.6x radiator capacity. Hopefully I won't need it, but if the 60mm can handle 5950x/5700 xt, then adding these additional radiators might be able to further improve cooling for even more powerful graphics. I would say if you're going to replace the Flex ATX PSU with a Pico PSU, then being able to house 2 of those HDPlex 500W PicoSPUs would be awesome as that would allow for very high power builds using a dual PSU config. 1 AlienyHackbook: Alienware M17X R5 | i7-4930MX | GTX 1060 | 32GB DDR3L Kingston HyperX @ 2133 MHz CL 12 | MacOS Sierra 10.12.5 | Windows 10 LTSC | Hackintoshes Rule! Desktop Killer: Clevo X170SM-G | i9-10900K | RTX 2080 Super | 32GB DDR4 Crucial Ballistix @ 3200 MHz CL 16 | Windows 10 LTSC | Slayer Of Desktops Sagattarius A: Custom Built Desktop | i9-10900K | RX 6950 XT | 32GB DDR4 G.Skill Ripjaws @ 4200 MHz CL 15 | Windows 10 LTSC | Ultimate Performance Desktop With Cryo Cooling!
StripeySnake Posted January 14, 2025 Author Posted January 14, 2025 That should be possible, I have also already included special standoff mounts for the HD plex 800w, and I'm not sure if you would really want more than that all things considered. Also I am not abandoning flex, I find dedicated self cooled PSU's to be much more reliable than AC adapters, but I have made it so that the design may be configured with FLEX or Pico based upon user preference. 1 Daily Drivers: JANKTOP IV Mini-ITX Laptop - R5 2600X, 16gb DDR4 3000 Mhz, RX 5700 XT - (ONGOING) Claymore V2 Cyberdeck, 6900HX, 680m iGPU, 16gb DDR5, 185 Wh Battery 14 R1 - 4710MQ @ 3.6 Ghz, hd 4600, 12gb DDR3L 1600 Mhz Past Projects: 15 R3 - GTX 1060 6gb, i7 7700HQ, 16gb DDR4 17 R4 - RX 470 8gb i7 6700HQ, 16gb DDR4 M17x R4 - 3630QM, Quadro P4000, 16gb DDR3L 1600 Mhz M17x R2 - i7 920XM @ 3.4 Ghz, GTX 770m 2gb, 16gb DDR3
Eban Posted February 2, 2025 Posted February 2, 2025 @StripeySnake .... @Socket Science Mmmmm...doesnt look like the Janktop 1 Thunderchild // Lenovo Legion Y740 17" i7-9750H rtx2080maxQ win10LTSC RainBird // Alienware 17 (Ranger) i7-4910mq gtx860m win8.1 JunkDog // Desktop Asrock 660M i3-12100F ARC A580 win10LTSC
StripeySnake Posted February 3, 2025 Author Posted February 3, 2025 I’ve seen that project, really cool stuff. Definitely a lot prettier and more normal looking than my project, albeit less powerful/ upgradable. The work he did to make it look professional/ like a mass produced unit was really impressive. I’m not so sure about the “worlds first” title though, I’ve seen ITX laptops dating back to the early 2000s and definitely some older performance machines. It’s pretty niche history though and a lot of people don’t know about it. Daily Drivers: JANKTOP IV Mini-ITX Laptop - R5 2600X, 16gb DDR4 3000 Mhz, RX 5700 XT - (ONGOING) Claymore V2 Cyberdeck, 6900HX, 680m iGPU, 16gb DDR5, 185 Wh Battery 14 R1 - 4710MQ @ 3.6 Ghz, hd 4600, 12gb DDR3L 1600 Mhz Past Projects: 15 R3 - GTX 1060 6gb, i7 7700HQ, 16gb DDR4 17 R4 - RX 470 8gb i7 6700HQ, 16gb DDR4 M17x R4 - 3630QM, Quadro P4000, 16gb DDR3L 1600 Mhz M17x R2 - i7 920XM @ 3.4 Ghz, GTX 770m 2gb, 16gb DDR3
Papusan Posted April 16, 2025 Posted April 16, 2025 1 "The Killer" ASUS Z790 Apex Encore | 14900KS | 4090 HOF + 20 other graphics cards | 32GB DDR5 | Be Quiet! Dark Power Pro 12 - 1500 Watt | Second PSU - Cooler Master V750 SFX Gold 750W (For total of 2250W Power) | Corsair Obsidian 1000D | Custom Cooling | Asus ROG Strix XG27AQ 27" Monitors | Papusan @ HWBOT | Team PremaMod @ HWBOT | Papusan @ YouTube Channel
Rengsey R. H. Jr. Posted April 17, 2025 Posted April 17, 2025 On 4/15/2025 at 6:25 PM, Papusan said: I made one the same way, except mine is 2.5” thick. Almost done too lol. Heavy as a tank though. 4
