So i am upgrading my i7-8700k to a i9 9900k and i was wondering if there is much i need to change for the power limits and overclocking / undervolting for my new CPU. I know i am most likely going to try and clock the new CPU higher but are their any other things i need to change apart from the voltage and clock multipliers?
Clevo P751TM-G / i7-9700KF OC 4.9GHz Undervolted -95mV / RTX 2070 / 32GB DDR4 @ 3200Mhz
Don‘t try to overclock the 9900k. The P751tm is at it’s cooling limits with this CPU.
So what max clock should I aim for, would 4.9 / 5 GHz on 1 core be ok?
For only one core this could be possible. But not for all. Then it would throttle.
im in a similar situation, upgraded my initial 6700K to 7700K and then to my current 9900K. iirc the TM had stronger CPU VRMs on the mobo, so juice-wise ull likely be able to clock higher than me. at the same time though, i have a SiliconLottery binned chip thats in the top 5% of all 9900K so less voltage needed to reach certain multis.
one core u can basically go as far as the silicon lets you, u just need to ensure that the applied voltage offset is also stable at the higher core count multis.
the max settings i could achieve wattage and thermal wise were the following, at -100mV offset:
1C = 50x
2-3C = 48x
4-5C = 47x
6C = 46x
7C = 44x
8C = 42x
note that these settings are for everyday usage, including hot summer days and heavy loads with AVX enabled. so fire and forget, basically. based on testing, i was able to run up to 46x all cores on medium to heavy-ish loads without AVX, gaming could potentially be even higher.
so depending on
- your ambient temps
- your cooling capabilities (i.e. thermal paste, liquid metal, delid, copper IHS, etc.)
- your chip quality (UV stability)
- VRMs (max wattage possible before your mobo gives out)
- usage pattern (AVX, non-AVX or gaming only)
u will see significantly different results.
best thing to do: get to know your specific chip and its limits in your particular machine with the applications u most use. its a journey! 🙂
1C = 50x
2-3C = 48x
4-5C = 47x
6C = 46x
7C = 44x
8C = 42x
so depending on
Thanks dude, that helps alot I've run into a larger error where the power indicator is flashing orange when I try and boot the pc, no image displaying at all. I have tried booting with 1 stick of ram but it still doesn't post all that happens is that the power light flashes and the fans go to max any help?!
have u gotten the 9900K to boot at all yet in your machine? or is that still with ur old cpu?
if its with the 9900K and u havent gotten it to work at all, swap back the old cpu and update ur bios & EC to the newest versions. if its with ur old cpu, take out RAM, battery, power cable and the CMOS battery, then keep the power button pressed for 20 seconds, reassemble and try again. thatll reset ur bios, NVRAM and EC to default values in case u made some non-booting changes.
My bios and ec are on the latest already I tried a CMOS reset but I didn't know I had to hold the power button
it can sometimes take a bit of time until the capacitors are fully drained of all power.
also, be aware that after a cmos pull the first boot takes a lot of time, let it sit for at least 5-10 minutes to make absolutely sure it does not boot.
so i assume ure trying to boot with the 9900K? has it successfully booted before in your machine?
Sometimes you have to do the cmos reset 2 or 3 times before you get a picture. Happens to me with my p750tm in the past with latest Bios and upgrade from 8700k.
No I haven't managed to get a success full boot with it yet, I bought it from my work and had to go in and so I refunded it, but I will most likely try purchasing again and trying it out with your advice. The i7 8700k worked perfectly fine this morning so I recon it's just due to me being in a rush and not doing things 100%
take ur time, such things better not be rushed 🙂 im not sure if the TM stock bios already implemented support for CFL-R or if u actually need a modded bios for that. but first things first, lets cross that bridge when we get there. as plan B u might still be able to flash Dsanke bios for proper support.
Yeah I meant to take my time with it but external circumstances didn't really allow me to, I'm going to have to wait for the refund to come in and then re purchase the CPU if it doesn't sell
I dont remember exactly anymore but when i went to the 9900k from the old 8700k i needed to reset the cmos like two times and also take the battery out, drained and back again, there was a little bit of a hassle for sure.
Thanks ill try it again soon and let you know how it goes!
kool, keep us updated 🙂
Alright I'm really stuck now, I've tried CMOS resetting 3 times and still no luck I can't flash the dsanke bios since I don't have the old CPU anymore and I'm not confident with flashing at all anyone got any ideas?
Only a programmer will save you.
So I guess I'll just return it and stick with the i7 😞
Unless anyone has some clear instructions on how to flash the bios be sure that's mostly why I struggle, I can't find any resources to teach me how.
I'm not sure how I managed to originally and the dsanke bios I downloaded only comes with the rom and doesn't have all the other bits for the dos usb boot that I need
Also follow this tutorial for the Ch43a programmer. Software + drivers use this.
Unfortunately I do not know where the bios chip is located on the mobo, maybe somebody else can help with an image.
Thank you for the instructions!!
I think this is the original post i used to flash the new bios from CLEVO PC.
I think i'll stay on this one for now as i have gotten back my old processor and refunded the old one 😕 although the 8700k is still a beast so im not too upset.
If i decide to upgrade the bios in the future ill let you guys know how it goes!
This is strange, im also on the latest clevo official bios and the 9900k is working with it. Did u try the 9900k in a desktop to see if its working? Maybe the CPU is defective.
Tbh, you are better of with de lidding the 8700k, liquid metal and OC the sucker to almost 5Ghz.
