should a and b still be reserved for floppy drives?
When assigning drive letters to internal hard drives, should a and b still be reserved -- they used to be for floppy drives, but not sure if there is a reason to not use them for internal drives now with windows 10 and later that floppies don't exist...
You can use them for internal, external, or network drives if you like. I had a B: SSD drive for a while, no trouble with it at all.
