Reciever Posted November 2, 2022 Posted November 2, 2022 Quote Raijintek teases that its upcoming Morpheus 8069 is a completely black-coated heat sink, and is a "superior high-end VGA cooler" that's designed to cool up to 360W of TDP.'' Keep in mind, NVIDIA's new GeForce RTX 4090 has a 450W TDP (and above) but with fans attached, the new Raijintek Morpheus 8069 VGA cooler can handle the AD102 GPU beast. Source Well I know what I am getting for my 3090 1 AM4-DD | 5800X3D @ 4.45Ghz | Wet Devil 7900 XTX / Pulse 9070 XT (LSFG) | 32GB DDR4 3200Mhz | 2TB NVME | EVGA 1300w | NVME to 10Gbps | Win11 IoT UNRAID | Xeon Gold 6248 40c/80t | 64GB + 512GB PMEM | P1000 | 9300i-16P | 68TB HDD's | 5TB SSD's | BeQuiet DP 13 1000w ProxMox | E5-2697A 32c/64t | 128GB DDR4 2133Mhz | 2x2x1x1TB NVME Bifurcated | GTX 1060 3GB | X550 10Gbps Telegram / TS3 / Twitter 2700X to 5800X3D upgrade! With a 10850K cameo!
jaybee83 Posted November 3, 2022 Posted November 3, 2022 13 hours ago, Reciever said: Source Well I know what I am getting for my 3090 hmmm no VRM cooling....is morpheus including those wimpy lil addon heatsinks again for vrms? they should offer smth for that. also, am i understanding that correctly? 360W TDP is with PASSIVE cooling? i.e. adding fans increases that? that sounds a bit over the top, 360W WITH fans would be more realistic. and in that case could be a tight fit cooling a 4090, or even a 3080 😅 Mine: Hyperion "Titan God of Heat, Heavenly Light, Power" (2022-26) AMD Ryzen 9 9950X3D (delidded) / Asus ROG Crosshair X670E Extreme (Qualcomm QCNCM865 Wifi 7 Upgrade) / MSI Geforce RTX 5090 Suprim SOC / G.Skill Trident Z5 RGB DDR5-8000 2x24 GB / 4x Western Digital Black SN850P/X 8TB in 2x16TB RAID 0 / Arctic Liquid Freezer III Pro 420 (Push/Pull 6x Noctua NF-A14 IndustrialPPC-3000 exhaust) / Seasonic TX-1600 W Titanium / Phanteks NV9 MKII Black incl. Premium D-RGB Light Strips Kit (6x Arctic P14 Pro A-RGB black intake / 2x Arctic P14 Pro A-RGB black exhaust / 1x Arctic P14 Pro A-RGB black RAM cooling) / Samsung Odyssey Neo G8 32" 4K 240 Hz / Ducky One 3 Daybreak Fullsize Cherry MX Brown / Corsair M65 Ultra RGB / PDP Afterglow Wave Black / Beyerdynamic DT 770 Pro X Limited Edition My Lady's: Clevo NH55JNNQ "Alfred" (2022-26) Sharp LQ156M1JW03 FHD matte 15.6" IGZO 8 bit @248 Hz / Intel Core i5 12600 / Nvidia Geforce RTX 3070 Ti / Mushkin Redline DDR4-3200 2x32 GB / Samsung 970 Pro 1 TB / Samsung 870 QVO 8 TB / Intel AX201 WIFI 6+BT 5.2 / Win 11 Pro Phoenix Lite OS / 230 W PSU powered by Prema Mod!
Reciever Posted November 3, 2022 Author Posted November 3, 2022 8 hours ago, jaybee83 said: hmmm no VRM cooling....is morpheus including those wimpy lil addon heatsinks again for vrms? they should offer smth for that. also, am i understanding that correctly? 360W TDP is with PASSIVE cooling? i.e. adding fans increases that? that sounds a bit over the top, 360W WITH fans would be more realistic. and in that case could be a tight fit cooling a 4090, or even a 3080 😅 Dont really need larger heatsinks when you have fans with significantly higher static pressure. Though due to its distance from the heatsink and the card you could always get larger heatsinks if you plan to take it to extremes. I like big air coolers, my bias is showing lol Currently my 3090 is like 4.5 slots due to the heatsinks I have on the backplate AM4-DD | 5800X3D @ 4.45Ghz | Wet Devil 7900 XTX / Pulse 9070 XT (LSFG) | 32GB DDR4 3200Mhz | 2TB NVME | EVGA 1300w | NVME to 10Gbps | Win11 IoT UNRAID | Xeon Gold 6248 40c/80t | 64GB + 512GB PMEM | P1000 | 9300i-16P | 68TB HDD's | 5TB SSD's | BeQuiet DP 13 1000w ProxMox | E5-2697A 32c/64t | 128GB DDR4 2133Mhz | 2x2x1x1TB NVME Bifurcated | GTX 1060 3GB | X550 10Gbps Telegram / TS3 / Twitter 2700X to 5800X3D upgrade! With a 10850K cameo!
jaybee83 Posted November 4, 2022 Posted November 4, 2022 On 11/3/2022 at 8:00 AM, Reciever said: Dont really need larger heatsinks when you have fans with significantly higher static pressure. Though due to its distance from the heatsink and the card you could always get larger heatsinks if you plan to take it to extremes. I like big air coolers, my bias is showing lol Currently my 3090 is like 4.5 slots due to the heatsinks I have on the backplate id love to see what u would do to a 4090, go from 4 slots stock to 6 slots? 😂 Mine: Hyperion "Titan God of Heat, Heavenly Light, Power" (2022-26) AMD Ryzen 9 9950X3D (delidded) / Asus ROG Crosshair X670E Extreme (Qualcomm QCNCM865 Wifi 7 Upgrade) / MSI Geforce RTX 5090 Suprim SOC / G.Skill Trident Z5 RGB DDR5-8000 2x24 GB / 4x Western Digital Black SN850P/X 8TB in 2x16TB RAID 0 / Arctic Liquid Freezer III Pro 420 (Push/Pull 6x Noctua NF-A14 IndustrialPPC-3000 exhaust) / Seasonic TX-1600 W Titanium / Phanteks NV9 MKII Black incl. Premium D-RGB Light Strips Kit (6x Arctic P14 Pro A-RGB black intake / 2x Arctic P14 Pro A-RGB black exhaust / 1x Arctic P14 Pro A-RGB black RAM cooling) / Samsung Odyssey Neo G8 32" 4K 240 Hz / Ducky One 3 Daybreak Fullsize Cherry MX Brown / Corsair M65 Ultra RGB / PDP Afterglow Wave Black / Beyerdynamic DT 770 Pro X Limited Edition My Lady's: Clevo NH55JNNQ "Alfred" (2022-26) Sharp LQ156M1JW03 FHD matte 15.6" IGZO 8 bit @248 Hz / Intel Core i5 12600 / Nvidia Geforce RTX 3070 Ti / Mushkin Redline DDR4-3200 2x32 GB / Samsung 970 Pro 1 TB / Samsung 870 QVO 8 TB / Intel AX201 WIFI 6+BT 5.2 / Win 11 Pro Phoenix Lite OS / 230 W PSU powered by Prema Mod!
Reciever Posted November 4, 2022 Author Posted November 4, 2022 2 hours ago, jaybee83 said: id love to see what u would do to a 4090, go from 4 slots stock to 6 slots? 😂 If there was improvement to be had, definitely. Gets tricky though on air, dont want to recycle hot air and all that 1 AM4-DD | 5800X3D @ 4.45Ghz | Wet Devil 7900 XTX / Pulse 9070 XT (LSFG) | 32GB DDR4 3200Mhz | 2TB NVME | EVGA 1300w | NVME to 10Gbps | Win11 IoT UNRAID | Xeon Gold 6248 40c/80t | 64GB + 512GB PMEM | P1000 | 9300i-16P | 68TB HDD's | 5TB SSD's | BeQuiet DP 13 1000w ProxMox | E5-2697A 32c/64t | 128GB DDR4 2133Mhz | 2x2x1x1TB NVME Bifurcated | GTX 1060 3GB | X550 10Gbps Telegram / TS3 / Twitter 2700X to 5800X3D upgrade! With a 10850K cameo!
