Reciever Posted November 22, 2022 Posted November 22, 2022 Was there an attempt made on Linux? AM4-DD | 5800X3D @ 4.45Ghz | Wet Devil 7900 XTX | 32GB DDR4 3200Mhz | 2TB NVME | EVGA 1300w | Win11 IoT UNRAID | Xeon Gold 6248 40c/80t | 64GB + 512GB PMEM | RTX 3090Ti | 9300i-16P | 68TB HDD's | BeQuiet DP 13 1000w HomeLab | E5-2697A 32c/64t | 128GB DDR4 2133Mhz | 2x2x1x1TB NVME Bifurcated | GTX 1060 3GB | X550 10Gbps Telegram / TS3 / Twitter 2700X to 5800X3D upgrade! With a 10850K cameo!
ssj92 Posted November 23, 2022 Author Posted November 23, 2022 4 hours ago, Komputers-Best said: Have you ever tried to run it on other similar laptops except R2 and A18..? Alienware M18xR2 Alienware 17 R1 Alienware 18 R1 My friend has my old Clevo P870DM, I will see if we can test it in there 1 hour ago, aldarxt said: What systems does this card work on? And not meaning civilian Dell with BGA cards. Did you compare the vBios from the manufacturer (adlink) to the downloadable vBios they provide? As to the Dell and HP vBios. Just a difference from the military/medical versus civilian setups. And the difference of rtx 3000 vBios. It's an embedded card made to work on those super small embedded computers these companies sell. They all worked (up until RTX 3000) in our laptops. The only difference is, RTX 3000 has eDP support and all older cards. A4500 is the first to remove eDP support. So this may be why. 56 minutes ago, Reciever said: Was there an attempt made on Linux? Not yet. Still have this to try and also have this to try: https://egpu.io/forums/pc-setup/fix-dsdt-override-to-correct-error-12/#step1 I put RTX 3000 back for now, but as ideas come back I'll try more. Also contacted Aetina to see if I can send it back for a refund or swap it with a RTX 5000 since my heatsink is already made at this point. Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080 | AX210 | Samsung 970 Evo+ Alienware M18x R2 : Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080 | AX210 | Samsung 980 PRO Alienware 18 : Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000 | AX210 | Samsung 980 NVMe More Laps: M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000) | M17xR3 (WX 7100) | M18xR1 (RTX 5000) Precision 7520 (T1000) | 7720 (Tesla P6) BEAST Server: Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYT
aldarxt Posted November 23, 2022 Posted November 23, 2022 Right according to this eDP, LVDS, VGA, USB-C display output are not supported) EMB-G663-A0-Brochure.pdf 1 Clevo P870DM3-G i9-9900k-32.0GB 2667mhz-RTX3080+GTX1080 Alienware M18x R2 i7-3920xm-32GB DDR3-RTX 3000 Alienware M17x R4 i7-3940XM-16GB DDR3-RTX 3000 Alienware M17x R4 i7-3940XM 20GB DDR3-P4000 120hz 3D Precision m6700 i7-3840QM-16GB DDR3-GTX 970M Precision m4700 i7-3840QM-16GB DDR3-T2000M HP ZBook 17 G6 i7 9850H-32GB DDR4-RTX4000maxQ GOBOXX SLM G2721-i7-10875H RTX 3000-32GB ddr4
ssj92 Posted December 19, 2022 Author Posted December 19, 2022 Does anyone know how to edit pci device id in bios? Would be worth a shot to see if I can change pci id in bios so that it doesn't need inf mod and see if that works 1 Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080 | AX210 | Samsung 970 Evo+ Alienware M18x R2 : Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080 | AX210 | Samsung 980 PRO Alienware 18 : Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000 | AX210 | Samsung 980 NVMe More Laps: M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000) | M17xR3 (WX 7100) | M18xR1 (RTX 5000) Precision 7520 (T1000) | 7720 (Tesla P6) BEAST Server: Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYT
simon h Posted January 5, 2023 Posted January 5, 2023 I have just read from top to bottom and was hoping to read at the bottom of the thread you had it working.... Is it a dead end for sure now ?
ssj92 Posted January 6, 2023 Author Posted January 6, 2023 18 hours ago, simon h said: I have just read from top to bottom and was hoping to read at the bottom of the thread you had it working.... Is it a dead end for sure now ? Yep, unfortunately. I have returned it and will be going bga as I have no other choice for now. If someone else figures it out or some other mxm variant comes along things may change but for now, RTX 5000 is the best that works in laptops. Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080 | AX210 | Samsung 970 Evo+ Alienware M18x R2 : Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080 | AX210 | Samsung 980 PRO Alienware 18 : Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000 | AX210 | Samsung 980 NVMe More Laps: M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000) | M17xR3 (WX 7100) | M18xR1 (RTX 5000) Precision 7520 (T1000) | 7720 (Tesla P6) BEAST Server: Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYT
panda_zzz Posted April 22, 2024 Posted April 22, 2024 Sorry for necroposting and bad English) Is it still possible to buy this card? I would like to do some experiments with my m17x r4 Judging by the behavior of A4500 with native vbios, the problem is that the submodule of this bios is waiting for confirmation from the system bios to enable the "4gb above" option and does not allow the card itself to start normally. That's why the author's laptop complained about the absence of the card in SG mode. You can try either to manually disable the blocking module in the bios of the video card, or ask the manufacturer (judging by the screenshots they met and at least responded). Unfortunately I don't see any possibility to modify system bios of Alienware m17x r4, r5 m18x r2, m18 r1 laptops - there are no necessary modules in our bios from Insyde.
ssj92 Posted April 22, 2024 Author Posted April 22, 2024 15 hours ago, panda_zzz said: Sorry for necroposting and bad English) Is it still possible to buy this card? I would like to do some experiments with my m17x r4 Judging by the behavior of A4500 with native vbios, the problem is that the submodule of this bios is waiting for confirmation from the system bios to enable the "4gb above" option and does not allow the card itself to start normally. That's why the author's laptop complained about the absence of the card in SG mode. You can try either to manually disable the blocking module in the bios of the video card, or ask the manufacturer (judging by the screenshots they met and at least responded). Unfortunately I don't see any possibility to modify system bios of Alienware m17x r4, r5 m18x r2, m18 r1 laptops - there are no necessary modules in our bios from Insyde. You can buy from Aetina but it's very expensive. It's possible to enable resizable bar in bios using this module. But I am not good at BIOS editing. It's same way NVMe support was added. https://github.com/xCuri0/ReBarUEFI/wiki/Enabling-hidden-4G-decoding https://github.com/xCuri0/ReBarUEFI The module might have been enough to make it work but I didn't know how to add to bios. Maybe if I still had the card it would be possible. We need someone to modify AW 18 R1, AW 17 R1, M18xR2, M17xR4 bios to inject that uefi module. Then it might work with stock vBIOS. Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080 | AX210 | Samsung 970 Evo+ Alienware M18x R2 : Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080 | AX210 | Samsung 980 PRO Alienware 18 : Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000 | AX210 | Samsung 980 NVMe More Laps: M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000) | M17xR3 (WX 7100) | M18xR1 (RTX 5000) Precision 7520 (T1000) | 7720 (Tesla P6) BEAST Server: Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYT
panda_zzz Posted April 22, 2024 Posted April 22, 2024 5 hours ago, ssj92 said: You can buy from Aetina but it's very expensive. It's possible to enable resizable bar in bios using this module. But I am not good at BIOS editing. It's same way NVMe support was added. https://github.com/xCuri0/ReBarUEFI/wiki/Enabling-hidden-4G-decoding https://github.com/xCuri0/ReBarUEFI The module might have been enough to make it work but I didn't know how to add to bios. Maybe if I still had the card it would be possible. We need someone to modify AW 18 R1, AW 17 R1, M18xR2, M17xR4 bios to inject that uefi module. Then it might work with stock vBIOS. Can I ask you the price you bought it for back then? I understand it's just not sold on Ebay and can only be bought directly in the US. It's just that I'm in Europe and need to look for intermediaries). About the bios. According to my assumption for correct start of Vbios card there should be a response from system bios about 4g addressing support. Presence of ReBar module is secondary and is necessary for acceleration of work, but is not a prerequisite. Therefore 4G decoding is a problem in our case, because it is not provided in the bios itself (there are no such hidden options in the latest versions of bios for m17x r4, r5, m18x r2 - I checked). In general, for ivy bridge platform I've seen only one successful case of enabling this function - for desktop ASUS P8Z77-V PRO, but it uses their proprietary bios and there is just such a hidden option. In the case of our laptops we use another platform bios from Insyde and there is no such setting either for ivy bridge platform or for Haswell and I don't know anything about adding such support, it is necessary to have access directly to the documentation of this company. That's why I say that it is easier to modify the vbios of the card and remove this check that did not allow to start the laptop with native vbios, but at the same time with the bios from dell it started. Of course, so far these are my assumptions, but I want to check them in practice. At least it is possible to test the card in a desktop motherboard with the debug connector connected and see the error message. Just for fun, I checked - the "4G decoding" setting appears in the bios of the Alienware 17 R2. In earlier models, unfortunately, it just doesn't exist
ssj92 Posted April 23, 2024 Author Posted April 23, 2024 12 hours ago, panda_zzz said: Can I ask you the price you bought it for back then? I understand it's just not sold on Ebay and can only be bought directly in the US. It's just that I'm in Europe and need to look for intermediaries). About the bios. According to my assumption for correct start of Vbios card there should be a response from system bios about 4g addressing support. Presence of ReBar module is secondary and is necessary for acceleration of work, but is not a prerequisite. Therefore 4G decoding is a problem in our case, because it is not provided in the bios itself (there are no such hidden options in the latest versions of bios for m17x r4, r5, m18x r2 - I checked). In general, for ivy bridge platform I've seen only one successful case of enabling this function - for desktop ASUS P8Z77-V PRO, but it uses their proprietary bios and there is just such a hidden option. In the case of our laptops we use another platform bios from Insyde and there is no such setting either for ivy bridge platform or for Haswell and I don't know anything about adding such support, it is necessary to have access directly to the documentation of this company. That's why I say that it is easier to modify the vbios of the card and remove this check that did not allow to start the laptop with native vbios, but at the same time with the bios from dell it started. Of course, so far these are my assumptions, but I want to check them in practice. At least it is possible to test the card in a desktop motherboard with the debug connector connected and see the error message. Just for fun, I checked - the "4G decoding" setting appears in the bios of the Alienware 17 R2. In earlier models, unfortunately, it just doesn't exist At the time it was $2,500. Aetina ships worldwide if you want to get it from them. They have newer Ada Lovelace RTX cards now too. Yes I also tried looking for above 4g decode but never found it. Editing vBIOS is tricky because Quadro vBIOS is encrypted and signed. If it is modded the card won't boot. HP/Dell/Lenovo vBIOS allows card to boot but upon driver install I got code 43 error. This is most likely due to vBIOS and card id not matching. One theory I had was find a way to remove the device id. On desktop cards, even with MXM used in PCIe adapter, there is no unique device id added from the pc. In our laptops there is unique device id added to the mxm card. This is also why we need to modify INF everytime but on desktop there is no need to modify INF. Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080 | AX210 | Samsung 970 Evo+ Alienware M18x R2 : Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080 | AX210 | Samsung 980 PRO Alienware 18 : Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000 | AX210 | Samsung 980 NVMe More Laps: M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000) | M17xR3 (WX 7100) | M18xR1 (RTX 5000) Precision 7520 (T1000) | 7720 (Tesla P6) BEAST Server: Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYT
panda_zzz Posted April 23, 2024 Posted April 23, 2024 @ssj92 Thanks for the reply. I will try to contact Aetina to see if they will agree to send me the card and if they will contact me at all.) Yes I have seen the new Ada Lovelace modules, but I'm afraid to imagine how much they cost and what problems they will have. If Ampere family bios are still somehow studied, these new ones will be full of surprises.
