I tried to install GTX 980M in AlienwareM17x R2 and this is what it displays on the screen. What can it be, because in Alienware 17 the card works perfectly..?
Alienware M18 R1 : Intel Core i9 13900HX | nVidia RTX 4090 16 ГБ | 32 ГБ DDR5
Alienware Area-51M R2 : Intel Core i9 10900K @ | nVidia GeForce RTX 2080 super 8 ГБ | 64 ГБ DDR4 2993 МГц | x2 NVMe емкостью 1 ТБ.
Alienware 17 : Intel Core i7 4900QM @ 4.1 ГГц | nVidia Quadro RTX 3000 6 ГБ | 32 ГБ DDR3 1600 МГц | 2 Samsung 860 Evo 500 ГБ (Raid).
This is a common problem using GTX 980M in M17xR2. Inverted Colors.
Only way to get past this is so switch to a 6-bit display panel. the 8-bit panel has some conflict with GM2xx series cards.
As I understand it, there is no way to run on this display, do you need another display, or is it possible in the settings?
Need another display.
And then how does the M4000M work normally in it?
M5000M should work too.
has to do with quadro having better support for higher bit display
Could you cross flash a quadro vBIOS?
The BIOS card from dell has a factory one, the Chinese card was bought on AliExpress..
188251.rom
And whoever installed this model, cards 780/880/980 and others. Except those that are stated..?
