pukemon Posted December 21, 2022 Share Posted December 21, 2022 what's the story on MXM lately? I'm about to give away a P770zm with 980M inside and I believe the next couple of years at least out of spec MXM cards were being put in notebooks. Has it come back to spec? I was looking up stuff and MXM stuff isn't easy to find unless you know what you're looking for. Which leads to next question because I am lightly researching eGPUs and I was wondering because of the previous question has any ODM/OEM made a dock/eGPU with MXM card? Link to comment Share on other sites More sharing options...
Aaron44126 Posted December 21, 2022 Share Posted December 21, 2022 AFAIK, no laptop manufacturers are putting MXM cards in current-generation laptops anymore. You can find "standard" Turing and Ampere MXM cards (T1000/T2000/A1000/A2000), but they are more built for small embedded systems and "happen to work" in some older laptops with MXM slots. (They are also hard to find and expensive when they do pop up.) Higher-end cards like A4500 exist but are even more difficult to come by. I don't recall seeing a GeForce MXM card since RTX 2080 and those were wildly out of spec in terms of both size/shape and power requirement. High-end GPUs have moved beyond the MXM spec (it was designed for around 100W TDP max, and it can be pushed a bit higher than that... but Ampere GPUs can pull up to around 175W). A modern standard has not emerged. Laptop manufacturers are happy to either solder GPUs directly onto the motherboard or use proprietary cards. Apple MacBook Pro 16-inch, 2023 (personal) • Dell Precision 7560 (work) • Full specs in spoiler block below Info posts (Windows) — Turbo boost toggle • The problem with Windows 11 • About Windows 10/11 LTSC Spoiler Apple MacBook Pro 16-inch, 2023 (personal) M2 Max 4 efficiency cores 8 performance cores 38-core Apple GPU 96GB LPDDR5-6400 8TB SSD macOS 15 "Sequoia" 16.2" 3456×2234 120 Hz mini-LED ProMotion display Wi-Fi 6E + Bluetooth 5.3 99.6Wh battery 1080p webcam Fingerprint reader Also — iPhone 12 Pro 512GB, Apple Watch Series 8 Dell Precision 7560 (work) Intel Xeon W-11955M ("Tiger Lake") 8×2.6 GHz base, 5.0 GHz turbo, hyperthreading ("Willow Cove") 64GB DDR4-3200 ECC NVIDIA RTX A2000 4GB Storage: 512GB system drive (Micron 2300) 4TB additional storage (Sabrent Rocket Q4) Windows 11 Enterprise LTSC 2024 15.6" 3940×2160 IPS display Intel Wi-Fi AX210 (Wi-Fi 6E + Bluetooth 5.3) 95Wh battery 720p IR webcam Fingerprint reader Previous Dell Precision 7770, 7530, 7510, M4800, M6700 Dell Latitude E6520 Dell Inspiron 1720, 5150 Dell Latitude CPi Link to comment Share on other sites More sharing options...
M4980 Posted December 21, 2022 Share Posted December 21, 2022 The newer Turing/Ampere MXM cards are basically only targeted at industries like medical, military, rail transport for example There are also some (non standard) MXM cards from egpu enclosures such as the Sonnet Breakaway puck and Sparkle/PowerColor gaming station eGPU Breakaway Puck RX 5550 XT/5700 - Sonnet (sonnettech.com) Sonnet eGFX Breakaway Puck RX 5700 teardown : eGPU (reddit.com) RADEON Mini GameStation - SPARKLE MXM form factor RX 6600 teardown : Amd (reddit.com) (this one looks standard?) Also non standard MXM Quadro T1000/T2000 in the HP Z2 Mini G5 PC HP Z2 Mini G5 with i9-10900 & NVIDIA® Quadro® T1000 (4GB) - HP Store UK Dell Precision 7520: Intel Core i7-7920HQ, 32GB RAM, NVIDIA Quadro T1000 4GB, LG LP156QHG (240Hz QHD, 100% sRGB & P3, 400 nits), Intel AX210 WiFi 6E Dell Precision 3591: Intel Core Ultra 7 165H, 64GB RAM, NVIDIA RTX 2000 Ada 8GB Dell Precision M4800: Intel Core i7-4810MQ, 32GB RAM, NVIDIA Quadro M1200 4GB, Intel AX200 WiFi 6 ThinkPad T440p: Intel Core i7-4980HQ i5-4300M, 16GB RAM, Intel Iris Pro 5200 HD 4600, N140HCE-EN1 Rev.c2 (1080p) ThinkPad X1 Carbon Gen 2: Intel Core i5-4300U, 8GB RAM, Intel HD 4400, QHD ThinkPad X230: Intel Core i5-3320M, 16GB RAM, Intel HD 4000, 16:10 2K display ASRock X570M Pro4: Ryzen 9 3900X, 32GB DDR4 3200MHz, NVIDIA GTX 1070 8GB, Corsair Crystal 280X, Xiaomi Mi Curved 34 + Acer Predator Z35 Link to comment Share on other sites More sharing options...
Csupati Posted December 26, 2022 Share Posted December 26, 2022 On 12/21/2022 at 3:43 AM, pukemon said: what's the story on MXM lately? I'm about to give away a P770zm with 980M inside and I believe the next couple of years at least out of spec MXM cards were being put in notebooks. Has it come back to spec? I was looking up stuff and MXM stuff isn't easy to find unless you know what you're looking for. Which leads to next question because I am lightly researching eGPUs and I was wondering because of the previous question has any ODM/OEM made a dock/eGPU with MXM card? You can put pascal series cards to it without any problem, except for zotac card, the have different thermal sensor output, and they go emergency mode after sime time, but they giving screen and show life, planning to buy a p770zm, and have a p3200 . So my plan is to put the p3200 into the p770zm. Clevo P751TM1-G 8700K/16GB/GTX 1080@120W/1.5TB/FHD 144 G-Sync/ Asus PG279Q Link to comment Share on other sites More sharing options...
