Since the RTX 2080s in my P870TM don’t have SLI capabilities, what would be the best use for them? Should I sell one of the MXM cards for some sweet $$?
If you can't think of a use for a second 2080, sell it.
How did you end up with 2x of them in your TM?
I bought the TM from Eurocom and I configured it with 2x 2080s to use with a dual monitor setup with multiple GPU intensive applications running on each (I'm an auto engineer). I'm just wondering if there were any other use cases besides the one I mentioned.
3d modeling (arhicad, autocad) / foto-video editing
If I can make my Titan V do SLI, you can make your RTX 2080 do SLI:
Can I try this on m18x r2 with P4000 x 2 in SG mode cause I don't think P4000 will work in PEG
If you don't know thats OK, Just tell me it's worth a shot even if you have to LIE to me!!! HAHAHA
I used 2x RTX2080 in the P870TM. It worked well. I tried all this almost 2 years ago. This is so-called SEMI-SLI. In games it also works, but you don't have extreme advantages. I can send a benchmark from 3D MArk later.
Oh wow! Do you mind linking a tutorial or telling me how you did it?
You should look at the video mentioned by @ssj92 - https://youtu.be/R1CG9sCMmnA
I think this is how you can do it aswell. This video and the SEMI-SLI or whatever is probably the same thing. That's my guess anyway.
Clevo P775TM1-G:
You can try but I heard Optimus was an issue.
Follow my video, it's probably the same method. If it's a different method I'd be interested too.
