MiRaGe Posted January 26, 2023 Posted January 26, 2023 Hi guys, would you tell me how can I unlock 200W from my RTX 2080? Do I need specific vBios or something else? The laptop is P775TM1-G XMG Neo 17 (E24) | 14900HX | 32GB (2X16) Kingston HyperX Fury DDR5@7200 CL36 | RTX4090 (+285/900) | QHD @240Hz G-Sync | 2x2TB Samsung 990 PRO | Killer WiFi 1675i | Oasis MK2 WC | Win 11 Home - TimeSpy Clevo X170KM-G | 11700KF | 64GB (4x16) Crucial Ballistix DDR4@3066 CL14 | RTX3080 (+220/1650) | QHD @165Hz G-Sync | 1TB WD SN850X + 1TB WD SN750 | Intel AX200 WiFi | Win 11 Pro - TimeSpy
Developer79 Posted January 26, 2023 Posted January 26, 2023 Hi:-), the Vbios has a cryptography key, so it is impossible to increase the power consumption via the software. This is only possible through hardware tricks! Greetz MiraGe
zex4 Posted January 26, 2023 Posted January 26, 2023 There's someone selling a 2080 with 200w but i dont know if thats right... https://www.willhaben.at/iad/kaufen-und-verkaufen/d/nagel-neue-rtx2080-mxm-desktop-version-mit-200-watt-in-ovp-630925624/
ssj92 Posted January 26, 2023 Posted January 26, 2023 Flashing Alienware RTX 2080 vBIOS from Area-51m R1 will boost TDP to 200w. However, unless you are benchmarking, it will probably not be worth it 1 1 Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080 | AX210 | Samsung 970 Evo+ Alienware M18x R2 : Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080 | AX210 | Samsung 980 PRO Alienware 18 : Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000 | AX210 | Samsung 980 NVMe More Laps: M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000) | M17xR3 (WX 7100) | M18xR1 (RTX 5000) Precision 7520 (T1000) | 7720 (Tesla P6) BEAST Server: Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYT
MiRaGe Posted January 26, 2023 Author Posted January 26, 2023 You mean I won‘t get any FPS gain in games? XMG Neo 17 (E24) | 14900HX | 32GB (2X16) Kingston HyperX Fury DDR5@7200 CL36 | RTX4090 (+285/900) | QHD @240Hz G-Sync | 2x2TB Samsung 990 PRO | Killer WiFi 1675i | Oasis MK2 WC | Win 11 Home - TimeSpy Clevo X170KM-G | 11700KF | 64GB (4x16) Crucial Ballistix DDR4@3066 CL14 | RTX3080 (+220/1650) | QHD @165Hz G-Sync | 1TB WD SN850X + 1TB WD SN750 | Intel AX200 WiFi | Win 11 Pro - TimeSpy
ssj92 Posted January 26, 2023 Posted January 26, 2023 If 1-5 fps gain is worth it to you then sure. But going from 180w to 200w on rtx 2080 is barely any faster. Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080 | AX210 | Samsung 970 Evo+ Alienware M18x R2 : Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080 | AX210 | Samsung 980 PRO Alienware 18 : Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000 | AX210 | Samsung 980 NVMe More Laps: M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000) | M17xR3 (WX 7100) | M18xR1 (RTX 5000) Precision 7520 (T1000) | 7720 (Tesla P6) BEAST Server: Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYT
MiRaGe Posted January 26, 2023 Author Posted January 26, 2023 Can I find somewhere 180W vbios then? I would prefer it if it is the same speedwise as it won‘t heat up the GPU too much… XMG Neo 17 (E24) | 14900HX | 32GB (2X16) Kingston HyperX Fury DDR5@7200 CL36 | RTX4090 (+285/900) | QHD @240Hz G-Sync | 2x2TB Samsung 990 PRO | Killer WiFi 1675i | Oasis MK2 WC | Win 11 Home - TimeSpy Clevo X170KM-G | 11700KF | 64GB (4x16) Crucial Ballistix DDR4@3066 CL14 | RTX3080 (+220/1650) | QHD @165Hz G-Sync | 1TB WD SN850X + 1TB WD SN750 | Intel AX200 WiFi | Win 11 Pro - TimeSpy
MiRaGe Posted January 26, 2023 Author Posted January 26, 2023 Is this vBios (180W) from Dell going to work on my P775TM1? XMG Neo 17 (E24) | 14900HX | 32GB (2X16) Kingston HyperX Fury DDR5@7200 CL36 | RTX4090 (+285/900) | QHD @240Hz G-Sync | 2x2TB Samsung 990 PRO | Killer WiFi 1675i | Oasis MK2 WC | Win 11 Home - TimeSpy Clevo X170KM-G | 11700KF | 64GB (4x16) Crucial Ballistix DDR4@3066 CL14 | RTX3080 (+220/1650) | QHD @165Hz G-Sync | 1TB WD SN850X + 1TB WD SN750 | Intel AX200 WiFi | Win 11 Pro - TimeSpy
ssj92 Posted January 26, 2023 Posted January 26, 2023 You won't know until you try. As always backup original vBIOS in the event the other vBIOS doesn't work. Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080 | AX210 | Samsung 970 Evo+ Alienware M18x R2 : Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080 | AX210 | Samsung 980 PRO Alienware 18 : Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000 | AX210 | Samsung 980 NVMe More Laps: M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000) | M17xR3 (WX 7100) | M18xR1 (RTX 5000) Precision 7520 (T1000) | 7720 (Tesla P6) BEAST Server: Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYT
srs2236 Posted January 27, 2023 Posted January 27, 2023 Also flashing the Alienware VBIOS will break both of your display ports on your P775TM1-G. Doesn't matter if 180W or 200W. Be aware of that. + It might even break G-Sync support but I am not sure about that one. About Display Ports I am 100% sure. Clevo P775TM1-G: Spoiler GPU: NVIDIA GeForce RTX 3080 Laptop 16GB (150W, +110MHz Core, +350MHz Mem) CPU: Intel(R) Core(TM) i9-9900KS (5GHz, 4GHz Cache, -130mV, 255A, 200W PL1/2) RAM: DDR4 32 GB (3333MHz, 14-17-17-32, 2x16, Micron rev.E, 1.45v) Storage 1: Kingston KC3000 2TB RAID0 (2x1TB, NVME, PCI-E 3.0) Storage 2: Seagate LM015 2TB (2.5, HDD, SATA3) Storage 3: Integral UltimaPro 512GB (SDXC, 100r/50w, PCI-E) Display: AU Optronics B173ZAN0.10 (4K, 60Hz) Wi-Fi/BT: Killer(R) Wireless-AC 1550 (9260NGW, PCI-E) Operating system: Windows 11 Pro x64 (23H2)
MiRaGe Posted January 27, 2023 Author Posted January 27, 2023 8 hours ago, srs2236 said: Also flashing the Alienware VBIOS will break both of your display ports on your P775TM1-G. Doesn't matter if 180W or 200W. Be aware of that. + It might even break G-Sync support but I am not sure about that one. About Display Ports I am 100% sure. Do you have Clevo 180W or 200W vBios for RTX 2080 by chance? 😊 XMG Neo 17 (E24) | 14900HX | 32GB (2X16) Kingston HyperX Fury DDR5@7200 CL36 | RTX4090 (+285/900) | QHD @240Hz G-Sync | 2x2TB Samsung 990 PRO | Killer WiFi 1675i | Oasis MK2 WC | Win 11 Home - TimeSpy Clevo X170KM-G | 11700KF | 64GB (4x16) Crucial Ballistix DDR4@3066 CL14 | RTX3080 (+220/1650) | QHD @165Hz G-Sync | 1TB WD SN850X + 1TB WD SN750 | Intel AX200 WiFi | Win 11 Pro - TimeSpy
srs2236 Posted January 27, 2023 Posted January 27, 2023 I found these: https://drive.google.com/file/d/10bU9egVEpbdLLAHE-DBZo0fdOnN8DQjN/view Clevo P775TM1-G: Spoiler GPU: NVIDIA GeForce RTX 3080 Laptop 16GB (150W, +110MHz Core, +350MHz Mem) CPU: Intel(R) Core(TM) i9-9900KS (5GHz, 4GHz Cache, -130mV, 255A, 200W PL1/2) RAM: DDR4 32 GB (3333MHz, 14-17-17-32, 2x16, Micron rev.E, 1.45v) Storage 1: Kingston KC3000 2TB RAID0 (2x1TB, NVME, PCI-E 3.0) Storage 2: Seagate LM015 2TB (2.5, HDD, SATA3) Storage 3: Integral UltimaPro 512GB (SDXC, 100r/50w, PCI-E) Display: AU Optronics B173ZAN0.10 (4K, 60Hz) Wi-Fi/BT: Killer(R) Wireless-AC 1550 (9260NGW, PCI-E) Operating system: Windows 11 Pro x64 (23H2)
MiRaGe Posted January 28, 2023 Author Posted January 28, 2023 On 1/27/2023 at 1:00 PM, srs2236 said: I found these: https://drive.google.com/file/d/10bU9egVEpbdLLAHE-DBZo0fdOnN8DQjN/view Wow, thanks! 200W vbios, not bad at all! Now I am even more considering water cooling…😆 Max GPU temp 76-77C, is this ok? Overall not bad at all for RTX 2080. iI completely abandoned the idea of upgrading to RTX 3080… XMG Neo 17 (E24) | 14900HX | 32GB (2X16) Kingston HyperX Fury DDR5@7200 CL36 | RTX4090 (+285/900) | QHD @240Hz G-Sync | 2x2TB Samsung 990 PRO | Killer WiFi 1675i | Oasis MK2 WC | Win 11 Home - TimeSpy Clevo X170KM-G | 11700KF | 64GB (4x16) Crucial Ballistix DDR4@3066 CL14 | RTX3080 (+220/1650) | QHD @165Hz G-Sync | 1TB WD SN850X + 1TB WD SN750 | Intel AX200 WiFi | Win 11 Pro - TimeSpy
zex4 Posted January 28, 2023 Posted January 28, 2023 holy moly i tought that was not possible on 2000 series..also i coud not unlock my rtx 2060,even not with pascal tdp tweaker with programmer 😞 is there any chance that you guys also have a unlocked rtx 2060 mobile vbios ? GPU Shark ---------------------------------------- - GL_VERSION: 4.6.0 NVIDIA 527.56 (# ext: 432) - GL_RENDERER: NVIDIA GeForce RTX 2060/PCIe/SSE2 GPU 1 - NVIDIA GeForce RTX 2060 - GPU: (rev: A1) - GPU brand type: GeForce - Bus ID: 1 - Device ID: 10DE-1F51 - Subvendor: unknown (1558-7710) - Driver version: R527.56 - NV driver branch: r527_32-11 - Bios version: 90.06.2d.00.c2 - GPU memory size: 6143MB - GPU memory vendor: Samsung
srs2236 Posted January 28, 2023 Posted January 28, 2023 55 minutes ago, zex4 said: holy moly i tought that was not possible on 2000 series..also i coud not unlock my rtx 2060,even not with pascal tdp tweaker with programmer 😞 is there any chance that you guys also have a unlocked rtx 2060 mobile vbios ? GPU Shark ---------------------------------------- - GL_VERSION: 4.6.0 NVIDIA 527.56 (# ext: 432) - GL_RENDERER: NVIDIA GeForce RTX 2060/PCIe/SSE2 GPU 1 - NVIDIA GeForce RTX 2060 - GPU: (rev: A1) - GPU brand type: GeForce - Bus ID: 1 - Device ID: 10DE-1F51 - Subvendor: unknown (1558-7710) - Driver version: R527.56 - NV driver branch: r527_32-11 - Bios version: 90.06.2d.00.c2 - GPU memory size: 6143MB - GPU memory vendor: Samsung It is not an unlocked VBIOS and in terms of what you are thinking it hasn't been modded in any way. The reason why it works is it was officially released by Alienware for their Area 51m laptop. You can flash this VBIOS also on Clevo and other machines but most of the time you lose Display Port funcionality. Clevo P775TM1-G: Spoiler GPU: NVIDIA GeForce RTX 3080 Laptop 16GB (150W, +110MHz Core, +350MHz Mem) CPU: Intel(R) Core(TM) i9-9900KS (5GHz, 4GHz Cache, -130mV, 255A, 200W PL1/2) RAM: DDR4 32 GB (3333MHz, 14-17-17-32, 2x16, Micron rev.E, 1.45v) Storage 1: Kingston KC3000 2TB RAID0 (2x1TB, NVME, PCI-E 3.0) Storage 2: Seagate LM015 2TB (2.5, HDD, SATA3) Storage 3: Integral UltimaPro 512GB (SDXC, 100r/50w, PCI-E) Display: AU Optronics B173ZAN0.10 (4K, 60Hz) Wi-Fi/BT: Killer(R) Wireless-AC 1550 (9260NGW, PCI-E) Operating system: Windows 11 Pro x64 (23H2)
iamanixh Posted May 23, 2024 Posted May 23, 2024 On 1/28/2023 at 9:29 PM, MiRaGe said: Wow, thanks! 200W vbios, not bad at all! Now I am even more considering water cooling…😆 Max GPU temp 76-77C, is this ok? Overall not bad at all for RTX 2080. iI completely abandoned the idea of upgrading to RTX 3080… hi brother, i also have p775tm1 with rtx and i have 2 charger also with a converter from my previous p870dm sli model... so i want to try 200 watt vbios so just want to ask u few question? 1. after flashing does it break display port?? or its working fine? 2. what about gsync? 3. and temperature while gaming? or any other issue going to face ?? and at last is it worth can continue for my daily use?
