MiRaGe Posted March 18, 2023 Share Posted March 18, 2023 yes, UV is a must with 9900K. -100mV should work perfect XMG Neo 17 (E24) | 14900HX | 32GB (2X16) Kingston HyperX Fury DDR5@7200 CL36 | RTX4090 (+285/900) | QHD @240Hz G-Sync | 2x2TB Samsung 990 PRO | Killer WiFi 1675i | Oasis MK2 WC | Win 11 Home - TimeSpy Clevo X170KM-G | 11700KF | 64GB (4x16) Crucial Ballistix DDR4@3066 CL14 | RTX3080 (+220/1650) | QHD @165Hz G-Sync | 1TB WD SN850X + 1TB WD SN750 | Intel AX200 WiFi | Win 11 Pro - TimeSpy Link to comment Share on other sites More sharing options...
the jg89 Posted March 18, 2023 Author Share Posted March 18, 2023 would'nt it cost performance if you do that? Link to comment Share on other sites More sharing options...
MiRaGe Posted March 18, 2023 Share Posted March 18, 2023 just on a contrary - it will gain performance. XMG Neo 17 (E24) | 14900HX | 32GB (2X16) Kingston HyperX Fury DDR5@7200 CL36 | RTX4090 (+285/900) | QHD @240Hz G-Sync | 2x2TB Samsung 990 PRO | Killer WiFi 1675i | Oasis MK2 WC | Win 11 Home - TimeSpy Clevo X170KM-G | 11700KF | 64GB (4x16) Crucial Ballistix DDR4@3066 CL14 | RTX3080 (+220/1650) | QHD @165Hz G-Sync | 1TB WD SN850X + 1TB WD SN750 | Intel AX200 WiFi | Win 11 Pro - TimeSpy Link to comment Share on other sites More sharing options...
the jg89 Posted March 18, 2023 Author Share Posted March 18, 2023 16 minutes ago, MiRaGe said: just on a contrary - it will gain performance. interesting just wondering, how low did you manage to get with the new heatsink? Link to comment Share on other sites More sharing options...
MiRaGe Posted March 18, 2023 Share Posted March 18, 2023 Around 10C lower on the CPU’s side and 7-8C lower on the GPU’s. XMG Neo 17 (E24) | 14900HX | 32GB (2X16) Kingston HyperX Fury DDR5@7200 CL36 | RTX4090 (+285/900) | QHD @240Hz G-Sync | 2x2TB Samsung 990 PRO | Killer WiFi 1675i | Oasis MK2 WC | Win 11 Home - TimeSpy Clevo X170KM-G | 11700KF | 64GB (4x16) Crucial Ballistix DDR4@3066 CL14 | RTX3080 (+220/1650) | QHD @165Hz G-Sync | 1TB WD SN850X + 1TB WD SN750 | Intel AX200 WiFi | Win 11 Pro - TimeSpy Link to comment Share on other sites More sharing options...
the jg89 Posted March 18, 2023 Author Share Posted March 18, 2023 10 minutes ago, MiRaGe said: Around 10C lower on the CPU’s side and 7-8C lower on the GPU’s. Sweet 🙂 how'd you manage to tweak it further? Link to comment Share on other sites More sharing options...
MiRaGe Posted March 18, 2023 Share Posted March 18, 2023 Just cut the bottom cover, put liquid metal on the GPU, delidded the CPU and using liquid metal between the die and IHS. And measured very precise how thick the thermal pads should be. XMG Neo 17 (E24) | 14900HX | 32GB (2X16) Kingston HyperX Fury DDR5@7200 CL36 | RTX4090 (+285/900) | QHD @240Hz G-Sync | 2x2TB Samsung 990 PRO | Killer WiFi 1675i | Oasis MK2 WC | Win 11 Home - TimeSpy Clevo X170KM-G | 11700KF | 64GB (4x16) Crucial Ballistix DDR4@3066 CL14 | RTX3080 (+220/1650) | QHD @165Hz G-Sync | 1TB WD SN850X + 1TB WD SN750 | Intel AX200 WiFi | Win 11 Pro - TimeSpy Link to comment Share on other sites More sharing options...
the jg89 Posted March 18, 2023 Author Share Posted March 18, 2023 Ah I see Link to comment Share on other sites More sharing options...
srs2236 Posted March 19, 2023 Share Posted March 19, 2023 Meanwhile my 9900KS: 2 1 Clevo P775TM1-G: Spoiler GPU: NVIDIA GeForce RTX 3080 Laptop 16GB (150W, +110MHz Core, +350MHz Mem) CPU: Intel(R) Core(TM) i9-9900KS (5GHz, 4GHz Cache, -130mV, 255A, 200W PL1/2) RAM: DDR4 32 GB (3333MHz, 14-17-17-32, 2x16, Micron rev.E, 1.45v) Storage 1: Kingston KC3000 2TB RAID0 (2x1TB, NVME, PCI-E 3.0) Storage 2: Seagate LM015 2TB (2.5, HDD, SATA3) Storage 3: Integral UltimaPro 512GB (SDXC, 100r/50w, PCI-E) Display: AU Optronics B173ZAN0.10 (4K, 60Hz) Wi-Fi/BT: Killer(R) Wireless-AC 1550 (9260NGW, PCI-E) Operating system: Windows 11 Pro x64 (23H2) Link to comment Share on other sites More sharing options...
srs2236 Posted March 19, 2023 Share Posted March 19, 2023 I am daily driving it at 99c pretty much nowadays. I don't even care anymore. Clevo P775TM1-G: Spoiler GPU: NVIDIA GeForce RTX 3080 Laptop 16GB (150W, +110MHz Core, +350MHz Mem) CPU: Intel(R) Core(TM) i9-9900KS (5GHz, 4GHz Cache, -130mV, 255A, 200W PL1/2) RAM: DDR4 32 GB (3333MHz, 14-17-17-32, 2x16, Micron rev.E, 1.45v) Storage 1: Kingston KC3000 2TB RAID0 (2x1TB, NVME, PCI-E 3.0) Storage 2: Seagate LM015 2TB (2.5, HDD, SATA3) Storage 3: Integral UltimaPro 512GB (SDXC, 100r/50w, PCI-E) Display: AU Optronics B173ZAN0.10 (4K, 60Hz) Wi-Fi/BT: Killer(R) Wireless-AC 1550 (9260NGW, PCI-E) Operating system: Windows 11 Pro x64 (23H2) Link to comment Share on other sites More sharing options...
the jg89 Posted March 19, 2023 Author Share Posted March 19, 2023 5 hours ago, srs2236 said: I am daily driving it at 99c pretty much nowadays. I don't even care anymore. And no problems whatsoever? like the laptop shutting down suddenly? That hasn't happened to me though but wondering if that's happened. Link to comment Share on other sites More sharing options...
srs2236 Posted March 19, 2023 Share Posted March 19, 2023 2 hours ago, the jg89 said: And no problems whatsoever? like the laptop shutting down suddenly? That hasn't happened to me though but wondering if that's happened. It is thermal throttling almost all the time. It doesn't really shut down. After maybe 2 days of running it sometimes crashes but thats probably more like some OC or undervolt of mine to blame and not really the temperature. I am not worried about the CPU degrading or dying because of these temps but more worried about the longevity of the motherboard and its components around the CPU when running these types of temperatures. However so far it is perfectly fine. I will maybe in the future do some mods to try and improve the cooling though. Curious about the new fans, need delid IHS, perhaps order the phase changing thermal pad etc. I am 100% sure it will improve my situation. Last time I repasted was once I installed 3080. And Thermal Grizzly likes to lose it's performance over time like crazy. Clevo P775TM1-G: Spoiler GPU: NVIDIA GeForce RTX 3080 Laptop 16GB (150W, +110MHz Core, +350MHz Mem) CPU: Intel(R) Core(TM) i9-9900KS (5GHz, 4GHz Cache, -130mV, 255A, 200W PL1/2) RAM: DDR4 32 GB (3333MHz, 14-17-17-32, 2x16, Micron rev.E, 1.45v) Storage 1: Kingston KC3000 2TB RAID0 (2x1TB, NVME, PCI-E 3.0) Storage 2: Seagate LM015 2TB (2.5, HDD, SATA3) Storage 3: Integral UltimaPro 512GB (SDXC, 100r/50w, PCI-E) Display: AU Optronics B173ZAN0.10 (4K, 60Hz) Wi-Fi/BT: Killer(R) Wireless-AC 1550 (9260NGW, PCI-E) Operating system: Windows 11 Pro x64 (23H2) Link to comment Share on other sites More sharing options...
the jg89 Posted March 19, 2023 Author Share Posted March 19, 2023 If only there was someone that can build custom laptop parts for you, now that would be something 😄 Link to comment Share on other sites More sharing options...
srs2236 Posted March 19, 2023 Share Posted March 19, 2023 18 minutes ago, the jg89 said: If only there was someone that can build custom laptop parts for you, now that would be something 😄 I have an update. It does eventually shut down. I was playing Little Misfortune for maybe 1 hour on Quiet mode. Quiet mode means, fans run at very low (inaudible) speed. CPU ran 100C for the whole time. What happened was the 100C went slowly to GPU, and just spread I guess through the whole computer until it just litterally shut down. Not crash, not restart but shutdown. I can only assume this is a safety mechanism before something overheats badly. I can say, I was suprised how hot the PC had gotten. The whole chassis was litterally on fire xD It took like 30 mins to cool down passively to room temp. So yeah. I have just been recently very annoyed at the stock fan speed profile. It's litterally a jet engine. I need to order some new cooling supplies and put a custom fan profile or something. I don't mind it being loud while gaming. I slap on 100% fan speed on both fans, put on headset and game on. It works for hours, CPU is on 100c but it doesn't shut down or anything like that. I just hate that it sounds like a jet engine while playing a indie game like Little Misfortune or just idle. So I have been punishing it a bit lately haha. But turns out it will shut down eventually if you let it burn without any fans working. It was roughly 60W on CPU and 50W GPU. 110W without fans for an hour is actually not bad. Clevo P775TM1-G: Spoiler GPU: NVIDIA GeForce RTX 3080 Laptop 16GB (150W, +110MHz Core, +350MHz Mem) CPU: Intel(R) Core(TM) i9-9900KS (5GHz, 4GHz Cache, -130mV, 255A, 200W PL1/2) RAM: DDR4 32 GB (3333MHz, 14-17-17-32, 2x16, Micron rev.E, 1.45v) Storage 1: Kingston KC3000 2TB RAID0 (2x1TB, NVME, PCI-E 3.0) Storage 2: Seagate LM015 2TB (2.5, HDD, SATA3) Storage 3: Integral UltimaPro 512GB (SDXC, 100r/50w, PCI-E) Display: AU Optronics B173ZAN0.10 (4K, 60Hz) Wi-Fi/BT: Killer(R) Wireless-AC 1550 (9260NGW, PCI-E) Operating system: Windows 11 Pro x64 (23H2) Link to comment Share on other sites More sharing options...
MiRaGe Posted March 19, 2023 Share Posted March 19, 2023 You need a cooling pad like mine (custom made, 2x80mm inaudible fans) this laptop can’t be cooled down without custom mods. Don’t let this to happen again, especially on the GPU side - it could kill it. The thermal limit for those GPUs is 87C. XMG Neo 17 (E24) | 14900HX | 32GB (2X16) Kingston HyperX Fury DDR5@7200 CL36 | RTX4090 (+285/900) | QHD @240Hz G-Sync | 2x2TB Samsung 990 PRO | Killer WiFi 1675i | Oasis MK2 WC | Win 11 Home - TimeSpy Clevo X170KM-G | 11700KF | 64GB (4x16) Crucial Ballistix DDR4@3066 CL14 | RTX3080 (+220/1650) | QHD @165Hz G-Sync | 1TB WD SN850X + 1TB WD SN750 | Intel AX200 WiFi | Win 11 Pro - TimeSpy Link to comment Share on other sites More sharing options...
1610ftw Posted March 23, 2023 Share Posted March 23, 2023 On 3/19/2023 at 9:25 PM, srs2236 said: I have an update. It does eventually shut down. I was playing Little Misfortune for maybe 1 hour on Quiet mode. Quiet mode means, fans run at very low (inaudible) speed. CPU ran 100C for the whole time. What happened was the 100C went slowly to GPU, and just spread I guess through the whole computer until it just litterally shut down. Not crash, not restart but shutdown. I can only assume this is a safety mechanism before something overheats badly. I can say, I was suprised how hot the PC had gotten. The whole chassis was litterally on fire xD It took like 30 mins to cool down passively to room temp. So yeah. I have just been recently very annoyed at the stock fan speed profile. It's litterally a jet engine. I need to order some new cooling supplies and put a custom fan profile or something. I don't mind it being loud while gaming. I slap on 100% fan speed on both fans, put on headset and game on. It works for hours, CPU is on 100c but it doesn't shut down or anything like that. I just hate that it sounds like a jet engine while playing a indie game like Little Misfortune or just idle. So I have been punishing it a bit lately haha. But turns out it will shut down eventually if you let it burn without any fans working. It was roughly 60W on CPU and 50W GPU. 110W without fans for an hour is actually not bad. That sounds rather dangerous and swapping a motherboard is a pita and a new GPU is very expensive so you may not want to do that anymore😄 Do you still run at 5.0 GHz all cores for the CPU? As an immediate measure you could get that fan profile changed and go down by 0.1 or 0.2 GHz - that will cost you 2 to 4% CPU performance at most (less if it is throttling anyway) and you will surely need 10 to 20% less power which will help a lot with temps. Recently got to play with a nice SL 10900K and X170SM-G that I got from brother @electrosoft and for a single CB R23 run it goes from 77°C 4.9 all cores 165W to 91°C 5.1 all cores with some appropriate undervolt. That is a lot more power for relatively little gain in performance, about 25% more power and less than 4% performance increase in this case so I will probably dial it down to 4.9 all cores as a daily driver, no need to overdo things. 1 Link to comment Share on other sites More sharing options...
the jg89 Posted May 23, 2023 Author Share Posted May 23, 2023 Just wondering when undervolting the cpu with control centre, do you select Adaptive or Override? Link to comment Share on other sites More sharing options...
srs2236 Posted May 23, 2023 Share Posted May 23, 2023 1 hour ago, the jg89 said: Just wondering when undervolting the cpu with control centre, do you select Adaptive or Override? I undervolt with BIOS, and if I am testing I personally use XTU. Both do the same thing but I use offset instead of constant voltage. In your case that would be Adaptive. I tested Override but it resulted in worse results. Clevo P775TM1-G: Spoiler GPU: NVIDIA GeForce RTX 3080 Laptop 16GB (150W, +110MHz Core, +350MHz Mem) CPU: Intel(R) Core(TM) i9-9900KS (5GHz, 4GHz Cache, -130mV, 255A, 200W PL1/2) RAM: DDR4 32 GB (3333MHz, 14-17-17-32, 2x16, Micron rev.E, 1.45v) Storage 1: Kingston KC3000 2TB RAID0 (2x1TB, NVME, PCI-E 3.0) Storage 2: Seagate LM015 2TB (2.5, HDD, SATA3) Storage 3: Integral UltimaPro 512GB (SDXC, 100r/50w, PCI-E) Display: AU Optronics B173ZAN0.10 (4K, 60Hz) Wi-Fi/BT: Killer(R) Wireless-AC 1550 (9260NGW, PCI-E) Operating system: Windows 11 Pro x64 (23H2) Link to comment Share on other sites More sharing options...
the jg89 Posted May 23, 2023 Author Share Posted May 23, 2023 2 hours ago, srs2236 said: I undervolt with BIOS, and if I am testing I personally use XTU. Both do the same thing but I use offset instead of constant voltage. In your case that would be Adaptive. I tested Override but it resulted in worse results. Cool, Thanks 😄 Link to comment Share on other sites More sharing options...
Developer79 Posted May 24, 2023 Share Posted May 24, 2023 On 2/9/2023 at 3:32 PM, the jg89 said: Just wondering, is there another place that sells this heatsink - https://www.aliexpress.com/item/4000174372901.html I haven't heard good things about aliexpress in that they are a sham site so I'm not exactly comfortable about getting something from there ^_^' Hi, you can use this heatsink also for RTX30xx Series! Link to comment Share on other sites More sharing options...
MiRaGe Posted May 24, 2023 Share Posted May 24, 2023 2 hours ago, Developer79 said: Hi, you can use this heatsink also for RTX30xx Series! This particular version - yes. XMG Neo 17 (E24) | 14900HX | 32GB (2X16) Kingston HyperX Fury DDR5@7200 CL36 | RTX4090 (+285/900) | QHD @240Hz G-Sync | 2x2TB Samsung 990 PRO | Killer WiFi 1675i | Oasis MK2 WC | Win 11 Home - TimeSpy Clevo X170KM-G | 11700KF | 64GB (4x16) Crucial Ballistix DDR4@3066 CL14 | RTX3080 (+220/1650) | QHD @165Hz G-Sync | 1TB WD SN850X + 1TB WD SN750 | Intel AX200 WiFi | Win 11 Pro - TimeSpy Link to comment Share on other sites More sharing options...
Developer79 Posted May 24, 2023 Share Posted May 24, 2023 2 hours ago, MiRaGe said: This particular version - yes. I mean exactly this heatsink is compatible with the RTX30xx series! Of course you still need extra accessories:-) Link to comment Share on other sites More sharing options...
MiRaGe Posted May 24, 2023 Share Posted May 24, 2023 1 hour ago, Developer79 said: I mean exactly this heatsink is compatible with the RTX30xx series! Of course you still need extra accessories:-) Yes, this one with 8 holes from the link is plug and play with RTX3xxx. The one I bought it (not listed on AliExpress anymore) is not. XMG Neo 17 (E24) | 14900HX | 32GB (2X16) Kingston HyperX Fury DDR5@7200 CL36 | RTX4090 (+285/900) | QHD @240Hz G-Sync | 2x2TB Samsung 990 PRO | Killer WiFi 1675i | Oasis MK2 WC | Win 11 Home - TimeSpy Clevo X170KM-G | 11700KF | 64GB (4x16) Crucial Ballistix DDR4@3066 CL14 | RTX3080 (+220/1650) | QHD @165Hz G-Sync | 1TB WD SN850X + 1TB WD SN750 | Intel AX200 WiFi | Win 11 Pro - TimeSpy Link to comment Share on other sites More sharing options...
Sentarshi Posted February 3, 2025 Share Posted February 3, 2025 On 3/2/2023 at 2:00 PM, MiRaGe said: Your measurement is wrong. You will have problems with overheating VRMs I got mine, wait a bit until I assembly everything and I will give you info. don’t run your system with the pad’s thickness you’ve used. Could you pls share the correct thikness than? Link to comment Share on other sites More sharing options...
MiRaGe Posted February 4, 2025 Share Posted February 4, 2025 Hi, just use a high quality thermal putty and you don´t need to worry about the correct thickness. XMG Neo 17 (E24) | 14900HX | 32GB (2X16) Kingston HyperX Fury DDR5@7200 CL36 | RTX4090 (+285/900) | QHD @240Hz G-Sync | 2x2TB Samsung 990 PRO | Killer WiFi 1675i | Oasis MK2 WC | Win 11 Home - TimeSpy Clevo X170KM-G | 11700KF | 64GB (4x16) Crucial Ballistix DDR4@3066 CL14 | RTX3080 (+220/1650) | QHD @165Hz G-Sync | 1TB WD SN850X + 1TB WD SN750 | Intel AX200 WiFi | Win 11 Pro - TimeSpy Link to comment Share on other sites More sharing options...
