On 2/4/2025 at 1:40 PM, MiRaGe said:
Hi, just use a high quality thermal putty and you don´t need to worry about the correct thickness.
Could you advice any?
Yes - Upsiren U6 or CX-H1300 13,5W/mk are among the best.
XMG Neo 17 (E24)  | 14900HX | 32GB (2X16) Kingston HyperX Fury DDR5@7200 CL36 | RTX4090 (+285/900) | QHD @240Hz G-Sync | 2x2TB Samsung 990 PRO | Killer WiFi 1675i | Oasis MK2 WC | Win 11 Home - TimeSpy
Clevo X170KM-G | 11700KF | 64GB (4x16) Crucial Ballistix DDR4@3066 CL14 | RTX3080 (+220/1650) | QHD @165Hz G-Sync | 1TB WD SN850X + 1TB WD SN750 | Intel AX200 WiFi | Win 11 Pro - TimeSpy
  • 4 weeks later...
On 3/18/2023 at 4:58 PM, MiRaGe said:
yes, UV is a must with 9900K.
-100mV should work perfect
I can’t undervolt my 9900KF any further than -135mV in the BIOS (-138mV overall) or Throttlestop, but do you know how to adjust the Amperage to the VRM?  I’m stuck at 123, or is that the limit for my P750DM3 motherboard?
Also I’m actively reading this thread and taking notes since I might order this heatsink…. It cost as much as my entire laptop!
On 2/9/2023 at 12:43 PM, zex4 said:
I also got the 20 Series heatsink long time ago from the same seller....arrived around two weeks to germany via ali "express" delivery Service..
Before I go full send, will this Radiator work as a heatsink for my P750DM3?
It looks like there’s more back portion and my laptop could be alright with a BBL.
  • 8 months later...
Why shit?
I think it is really good especially for custom heatsinks.
I use Thermal Grizzly Putty Pro a several times and I have very good experience with it.
It is a bit expensive and hard to work with.
Clevo P870DM2 9900k GTX1080
Clevo P775TM1 9900k RTX3080
From my own experience and tests thermallputy and honeywell stuff is worse than good thermal paste and thermopads. I tried and tested many of top product and for me putty is big no same as overrated ptm7950. I open and clean my laptop every year. Most important thing is to use good thermalpaste for laptops which dont dry out and lose conductive properties over time.
