Stale2 Posted May 7, 2023 Posted May 7, 2023 First off I'd like to thank this forum because there's a whole host of very helpful information in here. I am [UK] and have a Clevo P775TM1-G which is branded as PC Specialist OctaneIV. Specs: i7 8700K (Undervolted in BIOS -100) 16GB Corsair VENGEANCE 2400MHz SODIMM DDR4 (2 x 8GB) Nvidia 1080 GPU BIOS: 86.04.80.00.20 System BIOS 1.07.15 Bought at the end of 2017, went back to PC Specialist at one point and they updated BIOS for Mobo and GPU. They may (?) have redone the thermal pastes, I'm not sure. In short, thermal pastes and pads haven't been done in about 5 years. Whist writing this CPU is around 50C, same with GPU. However even menial tasks like copying data, or downloading data (from steam or something) will ramp up the CPU (and therefore fans). Gaming however.... my god, this thing screams, 1080 is sat at 90C all day CPU not far off. --cut to the chase-- I'm looking to strip the laptop down and redo thermal paste. I have seen some people love and hate on the K5 Pro, so that would be good to get some feedback on that. I've not done thermal pads before so K5 Pro looks like good in respect of application and not needing to know 100% the width of each pad. My questions are: 1: Should I just do the CPU and GPU thermal paste and leave the pads or do the pads wear out over time? 1a: if yes, K5 Pro or alternative? 2: Mobo BIOS - updating to the latest / modded. I rarely see a (decent) feature list of what comes with them, so I don't know what's available. I don't overclock so not sure how useful it would be. 3: Is there a dsanke BIOS for me and it is Secure Boot approved? I've only seen one which is 0729-9900KS and I'm not sure if that would work for me or not being on 8700K. 4: Is there anything else I can look at doing? I'm not looking to replace the whole cooling unit (as I have seen on here as another alternative). I already have the laptop on a stand with USB fans underneath. Thanks all
Reciever Posted July 16, 2023 Posted July 16, 2023 thermal compounds do tend to break down over time, all depending on a number of factors in play. I havent personally used anything fancy, so others input may be more valuable on that front. Modded BIOS tends to allow for overclocking better, yes. But also allows greater CPU/GPU support for your chassis. AM4-DD | 5800X3D @ 4.45Ghz | Wet Devil 7900 XTX | 32GB DDR4 3200Mhz | 2TB NVME | EVGA 1300w | Win11 IoT UNRAID | Xeon Gold 6248 40c/80t | 64GB + 512GB PMEM | RTX 3090Ti | 9300i-16P | 68TB HDD's | BeQuiet DP 13 1000w HomeLab | E5-2697A 32c/64t | 128GB DDR4 2133Mhz | 2x2x1x1TB NVME Bifurcated | GTX 1060 3GB | X550 10Gbps Telegram / TS3 / Twitter 2700X to 5800X3D upgrade! With a 10850K cameo!
fricknbot Posted July 17, 2023 Posted July 17, 2023 On 5/7/2023 at 1:35 PM, shuttsies said: First off I'd like to thank this forum because there's a whole host of very helpful information in here. I am [UK] and have a Clevo P775TM1-G which is branded as PC Specialist OctaneIV. Specs: i7 8700K (Undervolted in BIOS -100) 16GB Corsair VENGEANCE 2400MHz SODIMM DDR4 (2 x 8GB) Nvidia 1080 GPU BIOS: 86.04.80.00.20 System BIOS 1.07.15 Bought at the end of 2017, went back to PC Specialist at one point and they updated BIOS for Mobo and GPU. They may (?) have redone the thermal pastes, I'm not sure. In short, thermal pastes and pads haven't been done in about 5 years. Whist writing this CPU is around 50C, same with GPU. However even menial tasks like copying data, or downloading data (from steam or something) will ramp up the CPU (and therefore fans). Gaming however.... my god, this thing screams, 1080 is sat at 90C all day CPU not far off. --cut to the chase-- I'm looking to strip the laptop down and redo thermal paste. I have seen some people love and hate on the K5 Pro, so that would be good to get some feedback on that. I've not done thermal pads before so K5 Pro looks like good in respect of application and not needing to know 100% the width of each pad. My questions are: 1: Should I just do the CPU and GPU thermal paste and leave the pads or do the pads wear out over time? 1a: if yes, K5 Pro or alternative? 2: Mobo BIOS - updating to the latest / modded. I rarely see a (decent) feature list of what comes with them, so I don't know what's available. I don't overclock so not sure how useful it would be. 3: Is there a dsanke BIOS for me and it is Secure Boot approved? I've only seen one which is 0729-9900KS and I'm not sure if that would work for me or not being on 8700K. 4: Is there anything else I can look at doing? I'm not looking to replace the whole cooling unit (as I have seen on here as another alternative). I already have the laptop on a stand with USB fans underneath. Thanks all K5 is a pain in the ass to clean up if you wanna upgrade in the future, I am currently using Artic MX-4 which does a pretty good job but I would recommend using Thermal Grizzly or MX-6. As for the thermal pads, normally they don't wear out as much but if they are completely dry and not sticky / soft then it should be fine. However if you are looking to replace them I am uncertain of what size and thickness the stock ones are. Sounds pretty simple but give your current heatsink and fans a good cleaning dust buildup can inhibit heat transfer between the heatsink and air, and it also worsens the performance of your fans, so i would give them a good wipe down and blow out any dust. The only benefit you get from Dsanke bios is that there are some improved fan curves I believe and unlocked mobo completely. Hope this helped 1 Clevo P751TM-G / i7-9700KF OC 4.9GHz Undervolted -95mV / RTX 2070 / 32GB DDR4 @ 3200Mhz
