win32asmguy Posted July 2, 2023 Posted July 2, 2023 Recently I decided to attempt a display swap for the Legion Pro 7. My intention is that the standard WQXGA panel while nice for applications that support display scaling, is not really useable for me at 100% display scaling. Even worse under Linux where using Nvidia with Xorg does not fully support GPU scaling. Some other systems do offer lower resolutions but either have poor cooling solutions, high pitched fan noise, or are not available with the 13900HX or 4090. My target panel was a BOE NV160WUM-NX3 V8.0 which is a 16 inch WUXGA, 165hz, 100% sRGB, 500nit panel which was used in the base model Asus M16 2022. Unfortunately no GSync support for this panel. It does have the same 40 pin connection, with the same connector location and pin pitch. Also electrically its backlight uses the same voltage range so the brightness steps used for the stock panel work as expected. For the swap, the initial step is to remove the plastic display bezel. The back of the bezel is completely covered in adhesive tape. I used the iFixit Halbard Spudger to work the bottom center free enough to begin slowly pulling the rest of the bezel away while continuing to use the spudger to separate the adhesive as needed. After the bezel is removed, the next part is the metal hinge cover. I used the blue iFixit Opening Tool, starting at the right edge. I was trying to use the tool to pull on the hinge cover while not pushing/leveraging against the display circuitry as it can damage the pcb or even crack the display panel. After the hinge cover is removed now the double-sided tape under the display must be pulled off. There are two small tabs at the bottom of the display that can be slowly pulled to release the tape. After the tape is removed the display can be rotated out of the a-cover and rest on the keyboard to remove the display cable connector. There is just a piece of tape and then a metal latch securing the cable to the display pcb. I still need to pick up some replacement tape to secure the new panel to the a-cover. I will use Tesa 61395, and because this tape is not an L shape I will have to put a horizontal piece of the that is not adhered to the panel so there will not be a gap between the panel and housing. The vertical strips of tape should be enough to hold it in place and be removable via the same method if I need to swap it back in the future. The bezel should be reusable as most of the adhesive is intact and its shape seems to be correct. It is a $47 replacement part from Lenovo if you want to make it look like new. Some other people in the Lenovo discord are also experimenting with WQUXGA (4k) panels and miniLED panels with some success. 2 1 MSI Raider A18 - 9955HX3D, 2x16GB Kingston Fury DDR5-6000 CL38, 4TB WD SN8100, RTX 5090 mobile, 18.0 inch QHD+ 240hz IPS, Windows 11 Enterprise LTSC
win32asmguy Posted July 7, 2023 Author Posted July 7, 2023 Got the tape in and here are photos with tape in place! 2 MSI Raider A18 - 9955HX3D, 2x16GB Kingston Fury DDR5-6000 CL38, 4TB WD SN8100, RTX 5090 mobile, 18.0 inch QHD+ 240hz IPS, Windows 11 Enterprise LTSC
Reciever Posted July 7, 2023 Posted July 7, 2023 Excellent work, how is the fitment looking so far with the bezel? AM5-DD | 9850X3D2 @ 5.7Ghz | Wet Devil 7900 XTX / Pulse 9070 XT (LSFG) | 32GB DDR5 8000Mhz | 2TB NVME | EVGA 1300w | NVME to 10Gbps | Win11 IoT UNRAID | Xeon Gold 6248 40c/80t | 64GB + 512GB PMEM | P1000 | 9300i-16P | 68TB HDD's | 5TB SSD's | BeQuiet DP 13 1000w ProxMox | E5-2697A 32c/64t | 128GB DDR4 2133Mhz | 2x2x1x1TB NVME Bifurcated | GTX 1060 3GB | X550 10Gbps Telegram / TS3 / Twitter 2700X to 5800X3D upgrade! With a 10850K cameo!
win32asmguy Posted July 7, 2023 Author Posted July 7, 2023 9 minutes ago, Reciever said: Excellent work, how is the fitment looking so far with the bezel? Not bad. It is sitting pretty squarely in the a-cover. It does have a bit of light bleed in the bottom left and right corners after putting the bezel back on completely. One of the slimmer edges wasn't sticking quite as well as I had scraped most of the glue off at that spot to start prying on it. 2 MSI Raider A18 - 9955HX3D, 2x16GB Kingston Fury DDR5-6000 CL38, 4TB WD SN8100, RTX 5090 mobile, 18.0 inch QHD+ 240hz IPS, Windows 11 Enterprise LTSC
