Seeking Help with MSI GT72 6QD Graphics Card Upgrade Issue!
Hello fellow tech enthusiasts,
I could really use some assistance and insights on a problem I'm facing with my MSI GT72 6QD gaming laptop. Recently, my GTX 970M graphics card became faulty, prompting me to purchase a replacement GTX 980M. However, after installation, I've encountered a perplexing issue.
The problem is as follows:
1. The laptop screen remains blank; there is no display whatsoever.
2. The laptop does seem to be functioning correctly as the external display (LED) works without any issues.
After encountering these problems I decided to install vbios without having any experience and ended up flashing wrong bios, however I got the display but gpuz show GTX 980 without Physx and few other. Sequentially, I tried so many bios but none of them worked, came up with mismatch GPU, mismatch device ID, wrong firmware etc.
Have any of you experienced a similar situation when upgrading a GPU on an MSI GT72 6QD laptop?
Your valuable expertise would be greatly appreciated, and any guidance you can provide will be a huge help to me. Thank you in advance for your time and assistance!
Hi Basim,
I have a GT72 2QD and tried to update from a 970m to a 980m but display don't turn one.
So, I’m also looking for a clear software installation tutorial.
Hope someone is going to post the unser.
Well first things first, what vendor 980m did you purchase?
I bought it second hand from some how was trying to save this Clevo but after investigrations the motherborad was broken. He said the card came from a MSI GT80S 6QD. It was cheep so I bought it.
  • 2 months later...
It could be you simply need to change the Bios setting from Legacy to UEFI or enable CSM support.
Issue sound just like i had when i first tried a GTX1060m in my now dead GT72-6QD.
Photo of the MXM card will help though.
{Main System:} The Beast
{Mainboard:} Asrock X670E Pro
{OS:} Windows 11 Pro
