2 hours ago, DDAY3493 said:
Please explain?! How is that not correct, glad that I came here.
You're not even close to being correct, first of all, get some flux and properly flow solder. You forced it and as such weakened the solder joints on that cap. Secondly. I said DOUBLE the capacitor not... This? It means stack 2 capacitors either one on top of the other or literally stacking them and solder them. Right now you're not gonna get any improvement because basically you've done literally nothing. Right now looks like you got 3 capacitors. And 2 of em aren't doing anything- and the aforementioned flux issue.
Also! I want some screen shots of the current performance.
Alienware 18 R1 / xR3: 4940MX-4.3GHz / RTX 5000 - 16GB / RTX 2080 🙂
Alienware M17x R5 (Ranger): 4940MX 4.35 GHz / RTX 4000. (CURRENT)
Aliennware M17 R4: 10870H 4.8 GHz / 3080 16 Gb 165W
Alienware M17x r4 3940MX 4.1 GHz / Aetina GTX 1080.
Alienware M18x R2 Intel i7 3940XM. 4.2 GHz / RTX 4&5000 / 32Gb 1866
MSI GT75 'Titan' VR 8SF (upgraded to 8SG)
I'm really happy that you told me this, and I will definitely send you those pictures of the performance. But didn't ssj92 do the same thing in one of the other threads?! I know he posted a picture of it somewhere! I can't recall where. Anyway, how can I fix this without messing up like that again?
If he did then he messed it up too. I thought I made it clear how to do it. That's what I get for not really elaborating on it.
It needs to look like this. I insulated mine so I could prevent any possible shorts. @ssj92 did you make your cap mod look like this or like DDAYs?
20240309_200211.jpg?ex=65ff97d3&is=65ed2
It's really hard to see on yours with the insulation (probably TG shield)?? How exactly did you go about doing this. It looks very cool though, thanks for sharing!
Not sure what you mean by how did I go about doing it? It's literally matching 2 capacitors on top of one another and soldering the ends together. You can see that in the picture. Those 2 capacitors are solid and there only 2. No gaps in the middle.
6 minutes ago, DDAY3493 said:
Oh. It could be that's why it looked funky. That cap is a different color. Also doesn't have the writing on top of it. I thought you had soldered 2 mini R004 caps vertically I'm so sorry that's my bad.
3 minutes ago, DDAY3493 said:
What was your score before you did the mod???
To be honest I'm not even sure, the last time I did the benchmark for timespy and firestrike, is wasn't much higher! The last time I had 6716. The graphics score 7481 and CPU 4254
And that's why you do a before and after. Your scores actually did better than mine with that card. Also your driver's are setup as a RTX 2080?  I use the actual quadro drivers.  This is my mistake though, I completely overlooked your capacitor being a different color from mine. It looked way wrong from my perspective. As it stands yes you've done it correctly but I would touch up that solder joint with some flux and flow it so it doesn't crack down the line. Other than that you did 200 points better than my 5000. Shoot me a DM to the link on your results Im very curious.
In what test??? None of my RTX 4000s or 5000s ever hit that kind of score. They all seemed capped at most 6400 combined.
I sent you mine on discord. It looks similar to both of yours. Just added capacitor behind the original and bridged them
Yeah I looked at the picture wrong.
On 4/20/2024 at 5:09 AM, Mashcar said:
Anyone tried using external outputs with rtx 5000 ? Does it work ?
What do you mean? Like through the HDMI out?
On 9/3/2024 at 23:04, Falinov said:
Si lo hizo entonces también lo arruó. Pensé que había dejado claro cómo hacerlo. Eso es lo que obtengo por no enseguir adelante.
Tiene que verse así. Aislara la mía para poder evitar cualquier pantalones cortos posibles.El Sr.Hiciste que tu gorra mod se parar así o como DDAYs?
I can't see the photograph, can you send? again
---Dell Precision M6700---, i7-4900MQ, Tesla M6, M6100/HD 8950M, 1920x1080p 6bits LVDS.
---Dell Precision M6800---, i7-4900MQ, Tesla M6, M6100/HD 8950M, 1920x1080p 6bits LVDS.
---Alienware M17x R2--, I7-940MX, HD 8970M Crossfire, M6100/HD 8950M, GTX 765M, 1920x1200P OC 75 Hzt.
---Alienware 17-- i7-4940MX, RTX 3000(LVDS),P3000, GTX 980M, 880M,860M, M6100/HD 8950M,  1080P, 120 Hz, 3D.
--Alienware 18-- i7-4930MX, 32GB RAM 1866 MHz, RTX 4000, RTX 3000, P3000, M6100/HD 8950M, 1920x1080P. LCDOC 75 Hzt. (In use).
---Alienware M18x R2- i7-3940XM, 32GB RAM 1866 MHz, GTX 980M SLI, 1920x1080p 6bits OC 75 Hzt.
Youtube Channel : https://www.youtube.com/channel/UCi0b4otJZHtUJePgIejiI4Q.
  • 7 months later...
Hi everyone I have a alienware m18x r2 I want to update it's currently running a gtx 1060 but it's starting to become dated and what would I need to install the rtx 5000 since it would last a few years long then the 3000
I'm trying to install a RTX A3000 12GB MXM (GA104, 4096 CUDA, 12GB, better than RTX 3000) on AW 18 R1. I didn't receive the heatsink for it yet.
