This is vbios that I found on imac forum and made my changes to rise overclock of core and memory. Thanks go to user @m0bil for making imac vbios version.
After my changes overall performance boost is about 30%. Its close now to gtx 1070m.
Tested on MSI 4th gen laptop running in legacy mode and it scores about 4900-5000 pts in timespy graphics score. I have P4000 dell version card.
Vbios is only for P4000 mobile with 8gb ddr5. Do not try flashing on other pascal cards.
To flash this vbios you will need CH341A programmer with 1.8v adapter.
Some info:
- core clock set to max 1747mhz and max voltage is now 0.95v
- memory clock set to 1752mhz
- TDP set to 112W
Core clock set to 1759 is using 0.975v so I decided to stay on 1747mhz. Higher memory clock is not working so its locked on 1752mhz. TDP set on 112w is to protect card from damaging mosfets.
I had to modify inf in latest drivers for my MSI and enable test mode in windows to install unsigned drivers. My max temps are about 75-76 degrees (fans full speed)
I dont recommend using mosfet killer apps like Furmark with this vbios. 😅 You have been warned.
image.gif.580518e0efb10e62ace63b23e58e7136.gifimage.thumb.jpeg.532c12e33533cfa3e79d3f0018153f01.jpeg
P4000M_OC112W1747.ROM
Thing to do in the future:
- enable undervolting
- find where are located voltage values in vbios
Thats pretty amazing for a P4000, my RTX 3000 got 13301 (https://www.3dmark.com/fs/31222747) in my m17x r4. And thats my HIGHEST score! Does this vBios open the Overclocking ability? If it could be OCed it could beat the RTX 3000
I like the vBios version DEAD 00 BEEF, memorable name for vBios. Nice Job
There is no option to change clocks and undervolt in windows. This is bios locked and I dont know how to unlock this using hex editor. With unlocked undervolt I would try to set 1900-2000mhz. Maybe someone in the future will find how to unlock undervolting 😉 My clocks should be safe to use in longterm. I dont recommend higher clocks without undervolting.
Did some modding 😎 I added two small fans. Size 40mm x 40mm x 7mm. There was not much space but I was lucky and made them fit. I hope that one in the center will help to cool down my gpu mosfets. Had to cut down some plastics from bottom cover. I converted fans to usb ( they are 5v ) and will simply connect them to usb port.
Time to test TDP 122W and core clock 1797mhz and see how it goes 😉 maybe nothing will blow up 😅
Last update. 😎
My laptops TDP is 180W so after some thinkin I made one more vbios. This version is 122W. Should be safe for my computer in longterm ( 122W gpu + 50W cpu ) I also rised slightly max core clock to 1772mhz. Extra 10W will help to stabilize clocks to stay above 1700mhz. I also must say that I applied liquid metal to cpu and gpu. This is risky and could burn your laptop if you dont know how to do it properly.
Max temp are about 75-76 degrees.
In nvidia driver settings I locked max FPS in games to 50. I dont see difference between 60fps and 50fps. Its fluently and it lowers temps on my gpu. Now my temp are closer to 70 degrees. This is my workaround to undervolt 😉I used this table 😅
240 FPS: target frame rate for extremely competitive gaming that requires fast reflexes
144 FPS (eSport quality): target frame rate for competitive eSport games like LoL, DotA, and CS:GO
120 FPS: Very good and difficult for the layperson to distinguish any frame rates higher than this.
90 FPS: Target VR framerate as to not feel dizzy
60 FPS (Gaming PC quality): Target FPS for most games. Buttery smooth.
50 FPS: Pretty good
40 FPS: Acceptable.
30 FPS (previously console quality): Noticeably less smooth, but still playable
25 FPS (movie quality): Barely playable.
20 FPS: Very difficult to play and frame rate may prove to be a significant handicap in games.
15 FPS: what is this sh*t
10 FPS: PowerPoint is opening skyrim.pptx
5 FPS: PowerPoint has failed to open skyrim.pptx
2 FPS: Microsoft Word?
I am really happy to know that I have the fastest P4000 mobile in the world 😅 graphics score is above 5200pts in time spy.
Yes I will upload this vbios 🙂
I decided to make second version. Tested 122w vbios for over one month and all was working ok but in long term I would prefer slightly lower TDP and lower temperature. So made some small changes and I give you 121w version.
Update 11.10.2024
And again one more vbios with slightly lower max clock 1759mhz and TDP 120W. I think this is sweet spot. If you dont go over 80 degrees this should be good to go in long term usage. Higher clock would need TDP above 130w+ and this will likely damage your card after 1+ years. No point risking going above 120w.
deleted vbios
Update 14.03.2025
Well higher TDP in heavy gaming takes extra power from my old battery 😅 Dont like that. I will delete this vbios just to be sure that no damage is made.
All user should use 112W version.
  • 7 months later...
hey, i would like to try this in my clevo p170sm. While flashing the bios i have a Board ID mismatch. could you help me with that? thx
To flash this vbios you will need CH341A programmer with 1.8v adapter. 😉
how you how oc the p4000 with the vbios? would like to try it on my m6700 but not sure if these vbios are like compatible with m6700.
Do some training on older gpu and if you succeed then you can try with P4000.
Which values in hex editor did you mod for core clock, memory clock, and tdp?
I assume the 112w vBIOS will not work with every single P4000 due to silicon lottery?
I have P4000 coming and will test this
I spend some time on this card and believe me this clocks are safe in longterm and there is no point to change anything in hex editor. There is risk that you will damage gpu when you change more values. Do as you wish but I will not help on this 😎
I suppose it concerns just mobile P4000 version but do you know any proven method for desktop P4000 version? Mine desktop P4000 reaches 4 952 graphic score in time spy now on some custom production made bios. The card came from some medical facility
Are you able to apply these clocks/TDP to my specific factory vBIOS for P4000? My laptop only boots with this specific vBIOS...
https://drive.google.com/file/d/1ubOX_qahZZU46uMrXccDeUl_AvMl0LAi/view?usp=sharing
Maybe msi afterburner to overclock or at least undervolt? this is locked on mobile version.
You would need signed vbios with higher gpu core/memory clocks and then flash it. Something like crossflash but this could brick your gpu.
I was playing with this vbios one year ago and decided to mod vbios from imac forum. Modding original one was time consuming. I also had original dell vbios and this mod is working on MSI 4th gen. Set boot mode to UEFI with CSM.
It’s sandy bridge laptop. Only works with the vBIOS I uploaded. Already tried everything else. If you cannot mod this one it’s fine I’ll run it stock.
