ssergey931 Posted July 27 Posted July 27 Hello , i tested this VBIOS on P4000 Mobile on notebook HP Zbook 17 G3 . All work fine , and now normal working discrete mode video on bios , on stock vbios select discrete mode resulted in a black screen. Thankyou
JadeRover Posted July 28 Posted July 28 @ssergey931 Yes that is because the iMac vbios has eDP on the correct spot for the zbook 17 g3. Other vbios have eDP signals on the wrong spot resulting in black screen if dGPU mode is selected. You can use my vbios overclocking program to get more performance out of it. I can get 1898Mhz on my core and 4504Mhz vram with my programs vbios. You feed it this iMac OC vbios and then select the clocks you want. The program only modifies clock tables, display tables are untouched and you will still be able to use the screen in dGPU mode. Precision M6700 : i7-3740QM | P3000 6gb engineering vbios | 20gb DDR3 1600Mhz | FHD ips dreamcolor | delta fans Zbook 17 g3 : i7-6820HQ -75mv | M3000m 4gb | 16gb DDR4 2400Mhz | FHD ips Precision 7720 : i7-6820HQ -80mv & 102.7mhz BCLK| Zotac GTX1060 6gb, 100w OC vbios | 16gb DDR4 3011Mhz | 1440p165hz (upgrad) Zbook 17 g5 : i7-8850H, -140mv | P5200 16gb | 32gb DDR4 2666Mhz | FHD IPS
