TheQuentincc Posted May 14, 2024 Posted May 14, 2024 Hi, I wanna know if any of you guys could be interested paying a service to upgrade/replace the GPU memory of your workstation/laptop so you could double the capacity ? For now I'm offering such upgrade (on local France forum) for like 150€ the 6GB to 12GB upgrade (192bits bus width) and 200€ for the 8GB to 16GB upgrade (256bits bus width). It's mostly aimed at lower SKU like Quadro RTX 3000/4000 (low/mid tier series) cause Quadro RTX 5000 (high end series) is already at his max capacity, it applies to Turing and Ampere generation (Ada is already using high density memory IC). It also apply to gaming cards but it's a lot harder to find the memory strap resistor/boardview. I don't know if there is any needs to double the memory capacity on portable workstation, 6/8GB should already be plenty for many uses cases but I don't know I upgraded the RTX3000 of my Precision 7730 to 12GB anyway 😄 So what's your thoughts ? 3 Desktop / I7 14700KF @5.4/4.5GHz 1.25v delidded / MSI Z690 Edge Wifi DDR4 / 32GB DDR4 B-die @4200c16 / RTX 3080 Ti MSI Trio Plus / Triple 27" 4k120 + 2*4k60 XPS 9500 / I7 10750H @3.2GHz all-core / 32GB DDR4 2400MHz / GTX 1650Ti 4GB @50W / 15.6" UHD / NVME / 86Wh Precision 7550 / I9 10885H @4.6GHz all-core / 32GB DDR4 2933MHz / Quadro RTX3000 6GB @80W / 15.6" FHD IPS 500nits / NVME / 95Wh I was once running an overclocked I7 3920XM @4.2GHz all-core (nvram edit) in a Dell Precision M6700 with 32GB 2133MHz DDR3L, a Quadro P4000 and a 4k eDP display (using 3d cable)
Reciever Posted May 15, 2024 Posted May 15, 2024 I've been curious about having this done to my older cards liek the 5970, 690, gtx 295 and such but I dont have a hot air station nor have any skill in such things lol I can solder more or less but no experience with hot air yet AM4-DD | 5800X3D @ 4.45Ghz | Wet Devil 7900 XTX / Pulse 9070 XT (LSFG) | 32GB DDR4 3200Mhz | 2TB NVME | EVGA 1300w | NVME to 10Gbps | Win11 IoT UNRAID | Xeon Gold 6248 40c/80t | 64GB + 512GB PMEM | P1000 | 9300i-16P | 68TB HDD's | 5TB SSD's | BeQuiet DP 13 1000w ProxMox | E5-2697A 32c/64t | 128GB DDR4 2133Mhz | 2x2x1x1TB NVME Bifurcated | GTX 1060 3GB | X550 10Gbps Telegram / TS3 / Twitter 2700X to 5800X3D upgrade! With a 10850K cameo!
GuitarG Posted May 15, 2024 Posted May 15, 2024 4 hours ago, Reciever said: I've been curious about having this done to my older cards liek the 5970, 690, gtx 295 and such but I dont have a hot air station nor have any skill in such things lol I can solder more or less but no experience with hot air yet With heating plate and hot air everything is possible 😄 It would be cool to replace mobile core with desktop one, like one guy did on NBR with 980. In China lately a lot of older GPU gets more memory upgrade, sometimes even up to 24GB I heard. Don't know about older, newer GPU needs correct strap resistors to set up memory vendor and capacity. Also force eDP output (and use mining GPUs with laptop). With steady hand and BGA soldering skill, every BGA CPU is socketed. ^_^ Beginning is harsh, with every try it get easier.
Reciever Posted May 15, 2024 Posted May 15, 2024 1 hour ago, GuitarG said: With heating plate and hot air everything is possible 😄 It would be cool to replace mobile core with desktop one, like one guy did on NBR with 980. In China lately a lot of older GPU gets more memory upgrade, sometimes even up to 24GB I heard. Don't know about older, newer GPU needs correct strap resistors to set up memory vendor and capacity. Also force eDP output (and use mining GPUs with laptop). With steady hand and BGA soldering skill, every BGA CPU is socketed. ^_^ Beginning is harsh, with every try it get easier. With that premise the one thing I really wanted was the Alienware 13 R3 with 7820hx instead of the 7700hq, heck maybe a 8850h and disable the dGPU for eGPU but nothing like that existed or exists. Would've been really cool to see. Older GPU may be similar, that was the main issue @Khenglish ran into with installing desktop GPU vRAM modules to MXM board on the same mod you are referring to IIRC. Love seeing these kinds of mods though! AM4-DD | 5800X3D @ 4.45Ghz | Wet Devil 7900 XTX / Pulse 9070 XT (LSFG) | 32GB DDR4 3200Mhz | 2TB NVME | EVGA 1300w | NVME to 10Gbps | Win11 IoT UNRAID | Xeon Gold 6248 40c/80t | 64GB + 512GB PMEM | P1000 | 9300i-16P | 68TB HDD's | 5TB SSD's | BeQuiet DP 13 1000w ProxMox | E5-2697A 32c/64t | 128GB DDR4 2133Mhz | 2x2x1x1TB NVME Bifurcated | GTX 1060 3GB | X550 10Gbps Telegram / TS3 / Twitter 2700X to 5800X3D upgrade! With a 10850K cameo!
TheQuentincc Posted May 29, 2024 Author Posted May 29, 2024 On 5/15/2024 at 7:53 PM, GuitarG said: With heating plate and hot air everything is possible 😄 It would be cool to replace mobile core with desktop one, like one guy did on NBR with 980. In China lately a lot of older GPU gets more memory upgrade, sometimes even up to 24GB I heard. Don't know about older, newer GPU needs correct strap resistors to set up memory vendor and capacity. Also force eDP output (and use mining GPUs with laptop). With steady hand and BGA soldering skill, every BGA CPU is socketed. ^_^ Beginning is harsh, with every try it get easier. No not really, for sure it can be done, but it's not like the "good old days" 20sec CPU swap. Regarding the initial subject the memory upgrade can be done only if the actual vbios supports higher density memory (also means if the actual vbios was made when x memory density was available). So it's pretty hard on GDDR5, however on GDDR6 nearly all vbios supports the Samsung 16Gbit memory, that's including lower SKU like TU117, so we can upgrade almost all GPU except those with 16Gbit memory IC (like RTX5000/newer GPU). I was wondering in which case would someone wants (and pay "that much") to double their memory. Right now I'm doing this cause I can resell workstation more easily/at slightly higher price. 1 Desktop / I7 14700KF @5.4/4.5GHz 1.25v delidded / MSI Z690 Edge Wifi DDR4 / 32GB DDR4 B-die @4200c16 / RTX 3080 Ti MSI Trio Plus / Triple 27" 4k120 + 2*4k60 XPS 9500 / I7 10750H @3.2GHz all-core / 32GB DDR4 2400MHz / GTX 1650Ti 4GB @50W / 15.6" UHD / NVME / 86Wh Precision 7550 / I9 10885H @4.6GHz all-core / 32GB DDR4 2933MHz / Quadro RTX3000 6GB @80W / 15.6" FHD IPS 500nits / NVME / 95Wh I was once running an overclocked I7 3920XM @4.2GHz all-core (nvram edit) in a Dell Precision M6700 with 32GB 2133MHz DDR3L, a Quadro P4000 and a 4k eDP display (using 3d cable)
TheQuentincc Posted November 14, 2024 Author Posted November 14, 2024 I figured I should share the mod (along the memory IC replacement with K4ZAF325BM-HC14 or HC16) needed to upgrade RTX 3000 to 12GB on Precision 7730 and 7550. 2 Desktop / I7 14700KF @5.4/4.5GHz 1.25v delidded / MSI Z690 Edge Wifi DDR4 / 32GB DDR4 B-die @4200c16 / RTX 3080 Ti MSI Trio Plus / Triple 27" 4k120 + 2*4k60 XPS 9500 / I7 10750H @3.2GHz all-core / 32GB DDR4 2400MHz / GTX 1650Ti 4GB @50W / 15.6" UHD / NVME / 86Wh Precision 7550 / I9 10885H @4.6GHz all-core / 32GB DDR4 2933MHz / Quadro RTX3000 6GB @80W / 15.6" FHD IPS 500nits / NVME / 95Wh I was once running an overclocked I7 3920XM @4.2GHz all-core (nvram edit) in a Dell Precision M6700 with 32GB 2133MHz DDR3L, a Quadro P4000 and a 4k eDP display (using 3d cable)
Reciever Posted November 15, 2024 Posted November 15, 2024 It looks like there is a guy also modding the 5700 xt to have 16GB of vram. Hasn't been completed yet but looks to be towards the tail of the project. 2 AM4-DD | 5800X3D @ 4.45Ghz | Wet Devil 7900 XTX / Pulse 9070 XT (LSFG) | 32GB DDR4 3200Mhz | 2TB NVME | EVGA 1300w | NVME to 10Gbps | Win11 IoT UNRAID | Xeon Gold 6248 40c/80t | 64GB + 512GB PMEM | P1000 | 9300i-16P | 68TB HDD's | 5TB SSD's | BeQuiet DP 13 1000w ProxMox | E5-2697A 32c/64t | 128GB DDR4 2133Mhz | 2x2x1x1TB NVME Bifurcated | GTX 1060 3GB | X550 10Gbps Telegram / TS3 / Twitter 2700X to 5800X3D upgrade! With a 10850K cameo!
