My mother's Inspiron keeps freezing every 20 sec or so then works for 20 sec. Any ideas?
My mom called me yesterday and asked me to come up to their house and see about fixing her trackpad and mouse pointer.  It keeps freezing and the working.  So I did not see anything wrong in any settings, no software using resources in Task Manager, etc.  I did a restore on her system, and while doing the restore, I noticed even the spinner for the update was freezing.  I think it's something other than the mouse, and wondering what could cause this.
I don't think it's heat related as no fans are spinning when it's happening.  Any ideas?
First thought —
Is it an older system?  Could the battery be going out?  Try disconnecting the battery and see if this problem goes away.
Sounds crazy but I have seen issues like this happen if the battery is becoming suspect, even while the system is plugged into power.
I have to go inside the system to disconnect the battery.  I will let you know if I get the system later.
Well, turns out it was a bunch of junk running in the background that I couldn't see in the beginning.  Got it all removed, and it is working fine again.
And while at it, look for any heat build-up? Check with f.ex. cpuid.
Dell Precision 5540 w10 ltsc - Thinkpad P14s G5 w10 ltsc - Thinkpad E14 G5 w11 - HP i5 desktop w10 ltsc - O&O shutup on all w10\11 - Dell E7440 w8.1 - Tosh Satellite w8.1 - Pixel 8 Pro - 2x Samsung A52s - Netguard on all phones
check with microsoft autoruns.
dell precision m4600
i7 2760QM
8GB ram
MX500 crucial SSD 500GB.
win 10 21H2
On 12/20/2024 at 6:28 AM, GuitarG said:
Check HDD/SSD health, things you described sometimes are sign of incoming storage failure.
A 5 month old ssd is in it.  It's running fine now so I will swap the drive if it happens again.
