M18xR2 with build in water/air cooling.
Alienware M18x R1 i7-2720xm-32GB-Adlink RTX5000
Alienware M18x R2 i7-3920xm-32GB-RTX4090 (still in testing) with the latest bios version. A14 specially modified updated and unlocked by me 😎
Asus ROG Zephyrus G14 AMD Ryzen 9 7940HS-32GB-RTX4060
Is it possible to extend the heatpipes to the secondary GPU heatsink to create more dissipation for the CPU?
Always wondered why I hadnt seen anything like that so perhaps there are some obstructions? Or perhaps make it harder to service?
Hi Reciever, no it is not possible because there are not much of space in this area ,and it will be hard to service too as you said.
That does work in the m17x r2 however, it was a long time ago but I was able to use hwinfo to bind the second GPU fan to CPU temp and ran a 920xm at roughly 70-80 watts iirc with decent but higher temps.
Daily Drivers:
JANKTOP IV Mini-ITX Laptop - R5 2600X, 16gb DDR4 3000 Mhz, RX 5700 XT - (ONGOING)
Claymore V2 Cyberdeck, 6900HX, 680m iGPU, 16gb DDR5, 185 Wh Battery
14 R1 - 4710MQ @ 3.6 Ghz, hd 4600, 12gb DDR3L 1600 Mhz
Past Projects:
15 R3 - GTX 1060 6gb, i7 7700HQ, 16gb DDR4
17 R4 - RX 470 8gb i7 6700HQ, 16gb DDR4
M17x R4 - 3630QM, Quadro P4000, 16gb DDR3L 1600 Mhz
M17x R2 - i7 920XM @ 3.4 Ghz, GTX 770m 2gb, 16gb DDR3
Hi StripeySnake, yes for me it was problem too what with fan  . However this problem i was solved by reading rpm on gpu and cpu fans. No need hwinfo anymore. Each fan now can work separately.
  • 2 months later...
