qadhi79 Posted January 11, 2025 Posted January 11, 2025 My CLEVO P775TM1-G (specs in signature) is still in as good as new condition (changed keyboard and battery) but it is still running Windows 10 and I would like to upgrade to Windows 11. The issue is that the Control Center and CPU/GPU/keyboard controls are not compatible with Windows 11. I tried contacting the place where I originally bought it from and was told that the system is not compatible and there is nothing they can do about it. I didn't buy the Obsdian utilities and they are gone anyway so that's out of question too. Looking for a replacement for Control Center (mainly for fan control), CPU/GPU OC Utility and Keyboard 3-zone RGB control. MSI Raider 18 HX Intel i9 14900HX, RTX 4090, 18" QHD+, 64GB RAM, 4TB NVME, 2TB NVME, 4TB SSD, 4TB HDD MSI Raider GE76 Intel i7 12700H, RTX 3070Ti, 17.3" FHD, 32GB RAM, 2TB NVME, 2TB NVME MSI GF65 Intel i5 10500H, RTX 3060, 15.6" FHD, 16GB RAM, 2TB NVME CLEVO P775TM1-G Intel i7 8700K (Delidded), GTX 1080 MXM, 17.3" FHD G-Sync, 32GB RAM, 2TB NVME ASUS ROG G701VI Intel i7 6700HQ, GTX 1080, 17.3" FHD G-Sync, 32GB RAM, 2TB NVME
srs2236 Posted January 12, 2025 Posted January 12, 2025 2 hours ago, qadhi79 said: My CLEVO P775TM1-G (specs in signature) is still in as good as new condition (changed keyboard and battery) but it is still running Windows 10 and I would like to upgrade to Windows 11. The issue is that the Control Center and CPU/GPU/keyboard controls are not compatible with Windows 11. I tried contacting the place where I originally bought it from and was told that the system is not compatible and there is nothing they can do about it. I didn't buy the Obsdian utilities and they are gone anyway so that's out of question too. Looking for a replacement for Control Center (mainly for fan control), CPU/GPU OC Utility and Keyboard 3-zone RGB control. I am running Windows 11 and the Clevo Control Center is just fine. It is a buggy mess but it works. For CPU/GPU/keyboard. AFAIK it works on W11 just the same as on W10. 1 Clevo P775TM1-G: Spoiler GPU: NVIDIA GeForce RTX 3080 Laptop 16GB (150W, +110MHz Core, +350MHz Mem) CPU: Intel(R) Core(TM) i9-9900KS (5GHz, 4GHz Cache, -130mV, 255A, 200W PL1/2) RAM: DDR4 32 GB (3333MHz, 14-17-17-32, 2x16, Micron rev.E, 1.45v) Storage 1: Kingston KC3000 2TB RAID0 (2x1TB, NVME, PCI-E 3.0) Storage 2: Seagate LM015 2TB (2.5, HDD, SATA3) Storage 3: Integral UltimaPro 512GB (SDXC, 100r/50w, PCI-E) Display: AU Optronics B173ZAN0.10 (4K, 60Hz) Wi-Fi/BT: Killer(R) Wireless-AC 1550 (9260NGW, PCI-E) Operating system: Windows 11 Pro x64 (23H2)
qadhi79 Posted January 12, 2025 Author Posted January 12, 2025 11 hours ago, srs2236 said: I am running Windows 11 and the Clevo Control Center is just fine. It is a buggy mess but it works. For CPU/GPU/keyboard. AFAIK it works on W11 just the same as on W10. I actually upgraded once (2 years ago) to Windows 11 and CCC was not working so reverted back to Windows 10. You have upgraded CPU and GPU so may be with a different BIOS it supports Windows 11. I will give it a shot again with Windows 11 24H2 and report back. MSI Raider 18 HX Intel i9 14900HX, RTX 4090, 18" QHD+, 64GB RAM, 4TB NVME, 2TB NVME, 4TB SSD, 4TB HDD MSI Raider GE76 Intel i7 12700H, RTX 3070Ti, 17.3" FHD, 32GB RAM, 2TB NVME, 2TB NVME MSI GF65 Intel i5 10500H, RTX 3060, 15.6" FHD, 16GB RAM, 2TB NVME CLEVO P775TM1-G Intel i7 8700K (Delidded), GTX 1080 MXM, 17.3" FHD G-Sync, 32GB RAM, 2TB NVME ASUS ROG G701VI Intel i7 6700HQ, GTX 1080, 17.3" FHD G-Sync, 32GB RAM, 2TB NVME
harkaz Posted January 12, 2025 Posted January 12, 2025 16 hours ago, qadhi79 said: My CLEVO P775TM1-G (specs in signature) is still in as good as new condition (changed keyboard and battery) but it is still running Windows 10 and I would like to upgrade to Windows 11. The issue is that the Control Center and CPU/GPU/keyboard controls are not compatible with Windows 11. I tried contacting the place where I originally bought it from and was told that the system is not compatible and there is nothing they can do about it. I didn't buy the Obsdian utilities and they are gone anyway so that's out of question too. Looking for a replacement for Control Center (mainly for fan control), CPU/GPU OC Utility and Keyboard 3-zone RGB control. Have you tried Windows Compatibility Mode? Is HyperV enabled? (this causes problem with Intel XTU)
qadhi79 Posted January 12, 2025 Author Posted January 12, 2025 Updated to Windows 11 24H2 but "CPU Memory OC" utility is not working. Anyway I can disable just this utility so it won't load OC drivers. I will OC from BIOS/XTU/Throttlestop. MSI Raider 18 HX Intel i9 14900HX, RTX 4090, 18" QHD+, 64GB RAM, 4TB NVME, 2TB NVME, 4TB SSD, 4TB HDD MSI Raider GE76 Intel i7 12700H, RTX 3070Ti, 17.3" FHD, 32GB RAM, 2TB NVME, 2TB NVME MSI GF65 Intel i5 10500H, RTX 3060, 15.6" FHD, 16GB RAM, 2TB NVME CLEVO P775TM1-G Intel i7 8700K (Delidded), GTX 1080 MXM, 17.3" FHD G-Sync, 32GB RAM, 2TB NVME ASUS ROG G701VI Intel i7 6700HQ, GTX 1080, 17.3" FHD G-Sync, 32GB RAM, 2TB NVME
qadhi79 Posted January 18, 2025 Author Posted January 18, 2025 Upgrade didn't work so Fresh installed Windows 11 24H2. Kept windows drivers and only installed Nvidia drivers and Clevo Control Center. Everything is working fine now including "CPU Memory OC" utility. MSI Raider 18 HX Intel i9 14900HX, RTX 4090, 18" QHD+, 64GB RAM, 4TB NVME, 2TB NVME, 4TB SSD, 4TB HDD MSI Raider GE76 Intel i7 12700H, RTX 3070Ti, 17.3" FHD, 32GB RAM, 2TB NVME, 2TB NVME MSI GF65 Intel i5 10500H, RTX 3060, 15.6" FHD, 16GB RAM, 2TB NVME CLEVO P775TM1-G Intel i7 8700K (Delidded), GTX 1080 MXM, 17.3" FHD G-Sync, 32GB RAM, 2TB NVME ASUS ROG G701VI Intel i7 6700HQ, GTX 1080, 17.3" FHD G-Sync, 32GB RAM, 2TB NVME
dd14al Posted April 5, 2025 Posted April 5, 2025 Ich habe jetzt auf meinem "ECT ONE GAMING Notebook K73-11NB" mit dem Motherboard "Clevo PC5x_7xHP_HR_HS" Windows 11 Pro installiert und nun geht das Clevo Control Center 3.0 nicht mehr was ich aus dem Microsoft Store installiert habe. Es startet einfach nicht weil es anscheinen inkompatibel ist. Jetzt habe ich mir das Clevo Control Center 3.0 von schenker-tech heruntergeladen und die Setup Datei im Kompatibilitätsmodus (Windows 😎 gestartet und installiert. Nach einem PC-Neustart wurde die APP im Systray geladen und man konnte sie ganz normal öffnen so wie bisher unter Windows 10 Pro. I have now installed Windows 11 Pro on my “ECT ONE GAMING Notebook K73-11NB” with the motherboard “Clevo PC5x_7xHP_HR_HS” and now the Clevo Control Center 3.0, which I installed from the Microsoft Store, no longer works. It just won't start because it seems to be incompatible. I have now downloaded the Clevo Control Center 3.0 from Schenker-Tech and started and installed the setup file in compatibility mode (Windows 😎). After restarting the PC, the app was loaded in the systray and I was able to open it normally, just as before under Windows 10 Pro.
