yslalan Posted December 18, 2025 Posted December 18, 2025 11 hours ago, SvenC said: My PM18P is with iGPU only and I kept my dock WD19DC with that Dell specific double USB-C cable which is using the two USB-C ports on the left side of my laptop. The dock uses an old "power brick" with 240W. IIRC the laptop gets around 210W from the dock with that dual USB-C connector. Thanks for sharing your case. It's resolved by removing one power supply. Probably the GND issue I will get one WD19DC/DCS. 1 Dell Pro Max 16 Plus Ultra9-285HX - NVIDIA RTX Pro 4000 Blackwell - 48G DDR5 - UHD+ Display - 3840*2400 OLED - 7T NVMe Precision 7680 i9-13950HX - NVIDIA RTX 5000 Ada 16G - 96G DDR5 - UHD+ Display - 3840*2400 OLED - 6T NVMe
ov_Darkness Posted December 19, 2025 Posted December 19, 2025 23 hours ago, Easa said: Check my testing about three or four pages back. You are paying same money for up to 30% more performance (at least if you include graphics) when you go Dell. But it has its issues. Thinkpad has flaws too. I know that there's a problem with idle power consumption in PMP16, I've seen a review on the YT, where the reviewer claimed it's because it has OLED display. But other similar platforms with OLED don't have this issue. The question is will Dell fix it with eg. UEFI update, or not? 30% is a lot, but it also consumes a lot more power (285W in test vs 180W theoretical in Thinkpad). Unfortunately, I haven't seen performance figures from P16G3 yet. Is it really that much? It'd put P16G3 on par with last gen platforms or current gen slim 16's.
OneSunOne Posted December 19, 2025 Posted December 19, 2025 I eventually received my replacement dell 18 Pro Max although the replacement machine has the same issue with intermittent buzzing when I play audio. Can someone please check for me if you experience the following when the machine is plugged in: If you change the power mode (in windows settings) between any of the three power modes whilst playing audio, does the machine make a slight buzzing noise when it switches power mode? For references, my specs: Core ultra 9 HX 64gb SODIMM RAM RXT 4000 2tb SSD
Easa Posted December 20, 2025 Posted December 20, 2025 13 hours ago, OneSunOne said: If you change the power mode (in windows settings) between any of the three power modes whilst playing audio, does the machine make a slight buzzing noise when it switches power mode? Tested, mine does it too. Clearly a platform problem. 13 hours ago, ov_Darkness said: Unfortunately, I haven't seen performance figures from P16G3 yet. Is it really that much? It'd put P16G3 on par with last gen platforms or current gen slim 16's. Like I have said before, we have tested it, me and my friend. He has basically the same config as my PMP18, in his P16 G3. It is much slower, especially in GPU power and sustained CPU power, due to the power limit. Cant beat physics there, that 180W cap has its price. The cooling system is also smaller in size. ACE-Floodland Project CPU: Intel Core Ultra9 285K | MBD: MSI MEG Z890 ACE | RAM: G.Skill Z5CK 48GB 8400/40 | GPU: Gainward Phantom RTX 5090 GS 32GB | OS SSD: Intel Optane 905P M.2 380GB | STORAGE: 4x Intel Optane 905P U.2 1.5TB / 2x Kingston DC600M 960GB | PSU: CoolerMaster X Silent Edge Platinum 1100W | CASE: Lian Li V3000+ COOLING: CPU WB: Aquacomputer Cuplex Kryos NEXT NiSG | GPU WB: Watercool Heatkiller V Ultra 5090 | PUMP/TOP: Aquacomputer Ultitop Dual Brass / 2x AQC D5 Next | EXP: AQC Ultitube 150 / EK-Quantum Volume FLT 360 | SENSOR: AQC High Flow Next | RAD: 4x HardwareLabs SR2 480MP | FITTINGS: Bitspower Black Sparkle / 4x Koolance QD3 | TUBING: EK-ZMT 16/10 | FAN: 16x Phanteks T30-120 / 4x Noctua NF-A12x25 G2 / 2x Noctua NF-A4x20 SCREEN: Sony Inzone M9II 27" 4K | MOUSE: Razer Naga V2 Pro | KBD: Razer Huntsman V2 | PAD: Asus ROG Scabbard II | DAC: RME ADI2 DAC FS | HP: BeyerDynamic DT880 250Ω MWS: Dell Pro Max Plus 18 | CPU: Ultra9 285HX | GPU: RTX Pro 4000 BW | RAM: 2x32GB CSODIMM 6400 | SCREEN: IPS 2560x1600 120Hz | SSD: PM9E1 1TB + 2x 990 PRO 2/4TB
ov_Darkness Posted December 20, 2025 Posted December 20, 2025 4 hours ago, Easa said: Tested, mine does it too. Clearly a platform problem. Like I have said before, we have tested it, me and my friend. He has basically the same config as my PMP18, in his P16 G3. It is much slower, especially in GPU power and sustained CPU power, due to the power limit. Cant beat physics there, that 180W cap has its price. The cooling system is also smaller in size. Looks like PMP16 is a better choice than the P16G3. The only thing that worries me is that the OLED display seems to add 20-30W(!!!) to idle power consumption. This hurts run times BAD. I would love to have a tandem OLED display, but I'm not willing to sacrifice the battery life.
SvenC Posted December 21, 2025 Posted December 21, 2025 20 hours ago, ov_Darkness said: Looks like PMP16 is a better choice than the P16G3. The only thing that worries me is that the OLED display seems to add 20-30W(!!!) to idle power consumption. This hurts run times BAD. I would love to have a tandem OLED display, but I'm not willing to sacrifice the battery life. Funny, how new display technology seems announced as better for color accuracy (and whatever more) with potentially less power draw. But somehow an optimized LED 1920 x 1200 with 500+ nits (appreciated for both 16" and 18") could/should be even less power hungry, if you care about readability anywhere outside with daylight and much less about color accuracy - e.g. as a code and text reader and writer who likes contrast and reduced blue light 😉 Dell Pro Max Plus 18 * Ultra 7 265HX * 64GB CSoDIMM * 4TB, 2TB, 2560x1600, iGPU previous; Dell Precision 7680 * i7 13850hx * 64GB SO-DIMM * 4TB, 2TB, 1920x1200 previous: Dell Precision 7740 * i7 9750h * 48GB * 512GB, 2TB, 4TB * RTX 3000 * 1920x1080
yslalan Posted December 22, 2025 Posted December 22, 2025 On 12/20/2025 at 2:49 AM, OneSunOne said: If you change the power mode (in windows settings) between any of the three power modes whilst playing audio, does the machine make a slight buzzing noise when it switches power mode? Same here on PM16P Dell Pro Max 16 Plus Ultra9-285HX - NVIDIA RTX Pro 4000 Blackwell - 48G DDR5 - UHD+ Display - 3840*2400 OLED - 7T NVMe Precision 7680 i9-13950HX - NVIDIA RTX 5000 Ada 16G - 96G DDR5 - UHD+ Display - 3840*2400 OLED - 6T NVMe
OneSunOne Posted December 22, 2025 Posted December 22, 2025 On 12/20/2025 at 10:18 AM, Easa said: Tested, mine does it too. Clearly a platform problem. Like I have said before, we have tested it, me and my friend. He has basically the same config as my PMP18, in his P16 G3. It is much slower, especially in GPU power and sustained CPU power, due to the power limit. Cant beat physics there, that 180W cap has its price. The cooling system is also smaller in size. 32 minutes ago, yslalan said: Same here on PM16P Thanks for checking. The audio buzzing issues clearly seems to be a widespread issue. I’ll have to contact Dell again… it’s immensely frustrating that a machine of this calibre has such fundamental flaws
MyPC8MyBrain Posted December 22, 2025 Posted December 22, 2025 This is not a defect, not a failing speaker, and not Windows “doing something wrong.” It’s a byproduct of modern mobile power design, aggressive firmware control, and minimal analog isolation. Dell’s recent designs prioritize efficiency and thinness over the kind of electrical overengineering older workstations had. If you want it gone don’t change power modes during playback, or Lock the system to a single power mode, or Use external audio (USB DAC or Bluetooth), which bypasses the internal analog path entirely. the impossible is not impossible, its just haven't been done yet.
OneSunOne Posted December 24, 2025 Posted December 24, 2025 On 12/22/2025 at 4:56 PM, MyPC8MyBrain said: This is not a defect, not a failing speaker, and not Windows “doing something wrong.” It’s a byproduct of modern mobile power design, aggressive firmware control, and minimal analog isolation. Dell’s recent designs prioritize efficiency and thinness over the kind of electrical overengineering older workstations had. If you want it gone don’t change power modes during playback, or Lock the system to a single power mode, or Use external audio (USB DAC or Bluetooth), which bypasses the internal analog path entirely. The buzzing noise happens even when I don’t change the power modes. Intermittent buzzing still occurs when listening to music or streaming video. Buzzing also occurs on external monitor’s speakers when connected via HDMI. This type of buzzing is unacceptable for such an expensive machine, especially when audio and video editing will be done on the machine.
yslalan Posted December 24, 2025 Posted December 24, 2025 In the 2025 model, Dell chose Cirrus as the sound card provider, which is uncommon in previous mobile Precision models. I assume that waiting for a firmware update may resolve the issue. Edit: Not really the sound card issue, all sound devices connected to the system have the same behavior Dell Pro Max 16 Plus Ultra9-285HX - NVIDIA RTX Pro 4000 Blackwell - 48G DDR5 - UHD+ Display - 3840*2400 OLED - 7T NVMe Precision 7680 i9-13950HX - NVIDIA RTX 5000 Ada 16G - 96G DDR5 - UHD+ Display - 3840*2400 OLED - 6T NVMe
yslalan Posted December 24, 2025 Posted December 24, 2025 On 12/22/2025 at 10:56 PM, MyPC8MyBrain said: This is not a defect, not a failing speaker, and not Windows “doing something wrong.” It’s a byproduct of modern mobile power design, aggressive firmware control, and minimal analog isolation. Dell’s recent designs prioritize efficiency and thinness over the kind of electrical overengineering older workstations had. If you want it gone don’t change power modes during playback, or Lock the system to a single power mode, or Use external audio (USB DAC or Bluetooth), which bypasses the internal analog path entirely. Just have a double check, even Bluetooth audio has that unexpected noise Dell Pro Max 16 Plus Ultra9-285HX - NVIDIA RTX Pro 4000 Blackwell - 48G DDR5 - UHD+ Display - 3840*2400 OLED - 7T NVMe Precision 7680 i9-13950HX - NVIDIA RTX 5000 Ada 16G - 96G DDR5 - UHD+ Display - 3840*2400 OLED - 6T NVMe
SvenC Posted December 24, 2025 Posted December 24, 2025 8 hours ago, OneSunOne said: The buzzing noise happens even when I don’t change the power modes. Intermittent buzzing still occurs when listening to music or streaming video. Buzzing also occurs on external monitor’s speakers when connected via HDMI. This type of buzzing is unacceptable for such an expensive machine, especially when audio and video editing will be done on the machine. 2 hours ago, yslalan said: Just have a double check, even Bluetooth audio has that unexpected noise Did you check if disabling Intel SpeedStep fixes those intermittend noises? Maybe that cirrus driver "only" runs into trouble in some or all cases if ACPI stuff happens to save some power? Dell Pro Max Plus 18 * Ultra 7 265HX * 64GB CSoDIMM * 4TB, 2TB, 2560x1600, iGPU previous; Dell Precision 7680 * i7 13850hx * 64GB SO-DIMM * 4TB, 2TB, 1920x1200 previous: Dell Precision 7740 * i7 9750h * 48GB * 512GB, 2TB, 4TB * RTX 3000 * 1920x1080
MyPC8MyBrain Posted December 24, 2025 Posted December 24, 2025 13 hours ago, OneSunOne said: This type of buzzing is unacceptable for such an expensive machine i agree! my point wasn't to challenge the phenomena just explain the root cause of it so you don't end up chasing windmills. analog Isolation means physically separating two circuits so they don't share electricity or ground which Dell redesign cutbacks and consolidation we seen the past few years is losing modularity in design not adding complexity, hence the circuits designs also getting chopped and consolidated all in name of selling more laptops faster, soon we will pickup laptops like a hotdog from 7-Eleven with same emotions and customization reserved for socks. the impossible is not impossible, its just haven't been done yet.
Aaron44126 Posted December 24, 2025 Author Posted December 24, 2025 If it's happening even on a Bluetooth device that is connected, that's not an analog/grounding issue. The Bluetooth audio chain is all digital until it gets to your actual external speakers/headset, which wouldn't be physically connected to the laptop. I'm glad that they dumped Realtek as the sound chip manufacturer, I never liked them, but I don't know if Cirrus is any better. In any case, I agree that this buzzing is unacceptable. Again, if the buzzing is observed even over Bluetooth audio, that points more to a software / audio stack issue. The first thing that I would check is make my way to the "legacy" Sound control panel and disable "audio enhancements" for your sound output device. Dell has been known to include a stack of audio "enhancements" with the "Dell Optimizer" package which have also always been undesirable to me. Apple MacBook Pro 16-inch, 2023 (personal) • Dell Precision 7560 (work) • Full specs in spoiler block below Info posts (Windows) — Turbo boost toggle • The problem with Windows 11 • About Windows 10/11 LTSC Spoiler Apple MacBook Pro 16-inch, 2023 (personal) M2 Max 4 efficiency cores 8 performance cores 38-core Apple GPU 96GB LPDDR5-6400 8TB SSD macOS 15 "Sequoia" 16.2" 3456×2234 120 Hz mini-LED ProMotion display Wi-Fi 6E + Bluetooth 5.3 99.6Wh battery 1080p webcam Fingerprint reader Also — iPhone 12 Pro 512GB, Apple Watch Series 8 Dell Precision 7560 (work) Intel Xeon W-11955M ("Tiger Lake") 8×2.6 GHz base, 5.0 GHz turbo, hyperthreading ("Willow Cove") 64GB DDR4-3200 ECC NVIDIA RTX A2000 4GB Storage: 512GB system drive (Micron 2300) 4TB additional storage (Sabrent Rocket Q4) Windows 11 Enterprise LTSC 2024 15.6" 3940×2160 IPS display Intel Wi-Fi AX210 (Wi-Fi 6E + Bluetooth 5.3) 95Wh battery 720p IR webcam Fingerprint reader Previous Dell Precision 7770, 7530, 7510, M4800, M6700 Dell Latitude E6520 Dell Inspiron 1720, 5150 Dell Latitude CPi
MyPC8MyBrain Posted December 24, 2025 Posted December 24, 2025 this is not an analog grounding case, analog isolation in this context is referring to the circuit design with no relation to "ground" in this spesific context. Dell relies heavily on Intel Dynamic Platform & Thermal Framework (DPTF). Power mode changes trigger firmware level policy changes, not just windows settings. these transitions are abrupt by design to meet thermal and battery targets. this is common on Dell (not so much with other brands) due to tighter power envelopes, Less analog isolation on modern, compact boards. emphasis on efficiency over electrical quietness, older, systems masked this better with larger inductors, heavier grounding, and more conservative power transitions. the impossible is not impossible, its just haven't been done yet.
OneSunOne Posted December 25, 2025 Posted December 25, 2025 22 hours ago, MyPC8MyBrain said: i agree! my point wasn't to challenge the phenomena just explain the root cause of it so you don't end up chasing windmills. analog Isolation means physically separating two circuits so they don't share electricity or ground which Dell redesign cutbacks and consolidation we seen the past few years is losing modularity in design not adding complexity, hence the circuits designs also getting chopped and consolidated all in name of selling more laptops faster, soon we will pickup laptops like a hotdog from 7-Eleven with same emotions and customization reserved for socks. I completely agree. Most industries are moving in this direction as a way to reduce costs. My main concern right now is that this expensive machine is proving frustrating to use for video and audio editing. I could ask Dell to replace it with a lower-spec model from a different product range, but that would mean compromising on performance and potentially ending up with the same issues, given that this seems to be a widespread problem.
ov_Darkness Posted December 25, 2025 Posted December 25, 2025 22 hours ago, Aaron44126 said: If it's happening even on a Bluetooth device that is connected, that's not an analog/grounding issue. The Bluetooth audio chain is all digital until it gets to your actual external speakers/headset, which wouldn't be physically connected to the laptop. I'm glad that they dumped Realtek as the sound chip manufacturer, I never liked them, but I don't know if Cirrus is any better. In any case, I agree that this buzzing is unacceptable. Again, if the buzzing is observed even over Bluetooth audio, that points more to a software / audio stack issue. The first thing that I would check is make my way to the "legacy" Sound control panel and disable "audio enhancements" for your sound output device. Dell has been known to include a stack of audio "enhancements" with the "Dell Optimizer" package which have also always been undesirable to me. May be an I2S stream issue when switching from DAC to BT codec.
1610ftw Posted December 30, 2025 Posted December 30, 2025 On 12/18/2025 at 1:10 PM, SvenC said: Not sure what you would like to me? Which cable switch? Which bios option switch? I did not follow your case here and too little time to do now. Could you provide context and test questions again? And I'll see if I can be of any help. My PM18P is with iGPU only and I kept my dock WD19DC with that Dell specific double USB-C cable which is using the two USB-C ports on the left side of my laptop. The dock uses an old "power brick" with 240W. IIRC the laptop gets around 210W from the dock with that dual USB-C connector. I do not connect an additional power adapter to the laptop - power only from WD19DC - and have no problems. Big difference in our setups is: no power draw from a dGPU. I do not need a dGPU for my work and that makes my WD19DC a supported dock. @SvenC or somebody else with the iGPU only version, is your heatsink different / less beefy than the one that is supplied with the higher end GPUs that is pictured here?
SvenC Posted January 2 Posted January 2 Here is mine with iGPU only 1 Dell Pro Max Plus 18 * Ultra 7 265HX * 64GB CSoDIMM * 4TB, 2TB, 2560x1600, iGPU previous; Dell Precision 7680 * i7 13850hx * 64GB SO-DIMM * 4TB, 2TB, 1920x1200 previous: Dell Precision 7740 * i7 9750h * 48GB * 512GB, 2TB, 4TB * RTX 3000 * 1920x1080
MyPC8MyBrain Posted January 2 Posted January 2 it is clear how much thought and high level engineering placed in the new platform, placing the dGpu right under the CPU is clutch. the impossible is not impossible, its just haven't been done yet.
Easa Posted January 5 Posted January 5 Some time ago someone here was describing a behavior where the system locks up in sort of a throttle state until the power connector is disconnected and plugged back in. I have observed the same behavior today. ACE-Floodland Project CPU: Intel Core Ultra9 285K | MBD: MSI MEG Z890 ACE | RAM: G.Skill Z5CK 48GB 8400/40 | GPU: Gainward Phantom RTX 5090 GS 32GB | OS SSD: Intel Optane 905P M.2 380GB | STORAGE: 4x Intel Optane 905P U.2 1.5TB / 2x Kingston DC600M 960GB | PSU: CoolerMaster X Silent Edge Platinum 1100W | CASE: Lian Li V3000+ COOLING: CPU WB: Aquacomputer Cuplex Kryos NEXT NiSG | GPU WB: Watercool Heatkiller V Ultra 5090 | PUMP/TOP: Aquacomputer Ultitop Dual Brass / 2x AQC D5 Next | EXP: AQC Ultitube 150 / EK-Quantum Volume FLT 360 | SENSOR: AQC High Flow Next | RAD: 4x HardwareLabs SR2 480MP | FITTINGS: Bitspower Black Sparkle / 4x Koolance QD3 | TUBING: EK-ZMT 16/10 | FAN: 16x Phanteks T30-120 / 4x Noctua NF-A12x25 G2 / 2x Noctua NF-A4x20 SCREEN: Sony Inzone M9II 27" 4K | MOUSE: Razer Naga V2 Pro | KBD: Razer Huntsman V2 | PAD: Asus ROG Scabbard II | DAC: RME ADI2 DAC FS | HP: BeyerDynamic DT880 250Ω MWS: Dell Pro Max Plus 18 | CPU: Ultra9 285HX | GPU: RTX Pro 4000 BW | RAM: 2x32GB CSODIMM 6400 | SCREEN: IPS 2560x1600 120Hz | SSD: PM9E1 1TB + 2x 990 PRO 2/4TB
1610ftw Posted January 5 Posted January 5 On 1/2/2026 at 4:41 PM, SvenC said: Here is mine with iGPU only Thank you, I like that they kept all three fans! Have you observed the fans ramping up with higher CPU usage or observed any notable throttling? With the CPU getting most of the cooling and power and no additional thermal load I would expect the chassis to be more well behaved than the versions that also have a dedicated GPU.
yslalan Posted January 6 Posted January 6 Ironically, they are once again renaming the product line. 1 2 Dell Pro Max 16 Plus Ultra9-285HX - NVIDIA RTX Pro 4000 Blackwell - 48G DDR5 - UHD+ Display - 3840*2400 OLED - 7T NVMe Precision 7680 i9-13950HX - NVIDIA RTX 5000 Ada 16G - 96G DDR5 - UHD+ Display - 3840*2400 OLED - 6T NVMe
MyPC8MyBrain Posted January 6 Posted January 6 Precision = Pro, calling it "Pro Precision" is redundant especially since theres no non Pro Precision model. cup half full, its better late then never. at the least they came to some senses before they completely blow it out. 1 the impossible is not impossible, its just haven't been done yet.
