Chalybion Posted January 6 Posted January 6 Pro Non-precision = Latitude. This naming scheme actually makes some sense, distinguishing the business from consumer lineups without throwing away decades of name recognition associated with "XPS" and "Precision" Precision 7520 / Xeon E3-1535m v6 / 32 gb DDR4 2666 MHz CL15 / GTX 1650 Mobile / LP156QHG-SP(V1) Precision 7540 / i9-9980HK / 32 gb DDR4 2666 MHz CL15 / RTX 4000 / LP156QHG-SP(V1) / Delta Fans
MyPC8MyBrain Posted January 6 Posted January 6 they could just used Pro for the latitude equivalent and leave Precision as Precision for the higher tier up as it already was, so essentially the logical rename would be Latitude to Pro if a name change was so necessary, what is the equivalent entry point Inspirons named now? the impossible is not impossible, its just haven't been done yet.
MyPC8MyBrain Posted January 6 Posted January 6 1 hour ago, yslalan said: Ironically, they are once again renaming the product line. Facts! the impossible is not impossible, its just haven't been done yet.
SvenC Posted January 6 Posted January 6 22 hours ago, 1610ftw said: Thank you, I like that they kept all three fans! Have you observed the fans ramping up with higher CPU usage or observed any notable throttling? With the CPU getting most of the cooling and power and no additional thermal load I would expect the chassis to be more well behaved than the versions that also have a dedicated GPU. BIOS updates and weekly full virus scans (ESET, have to use, company policy...) bring up the fans loud and clear. Sometimes too many browser tabs (e.g. with animated advertising like winfuture.de) uses a few cores with high load Visual Studio updates in sequence for 2019, 2022, 2026 and Preview and SSMS updates. Normal work is pretty silent - but hey, whats normal anyways 😉 I would buy it again - only wishes: 1920x1200 pixels 500+ nits on my 18" and the name Dell Pro Precision 7 oder 9 😉 Dell Pro Max Plus 18 * Ultra 7 265HX * 64GB CSoDIMM * 4TB, 2TB, 2560x1600, iGPU previous; Dell Precision 7680 * i7 13850hx * 64GB SO-DIMM * 4TB, 2TB, 1920x1200 previous: Dell Precision 7740 * i7 9750h * 48GB * 512GB, 2TB, 4TB * RTX 3000 * 1920x1080
Aaron44126 Posted January 6 Author Posted January 6 "Broadest PC portfolio ever"? I already think part of their problem is that they already have too many models for each generation. How many 14" laptop models do you need to be offering at once, really? Slim down the product line, and use that leftover engineering effort to focus on polish and attention to detail. Add more spec options to each model if you think that people need options. 1 Apple MacBook Pro 16-inch, 2023 (personal) • Dell Precision 7560 (work) • Full specs in spoiler block below Info posts (Windows) — Turbo boost toggle • The problem with Windows 11 • About Windows 10/11 LTSC Spoiler Apple MacBook Pro 16-inch, 2023 (personal) M2 Max 4 efficiency cores 8 performance cores 38-core Apple GPU 96GB LPDDR5-6400 8TB SSD macOS 15 "Sequoia" 16.2" 3456×2234 120 Hz mini-LED ProMotion display Wi-Fi 6E + Bluetooth 5.3 99.6Wh battery 1080p webcam Fingerprint reader Also — iPhone 12 Pro 512GB, Apple Watch Series 8 Dell Precision 7560 (work) Intel Xeon W-11955M ("Tiger Lake") 8×2.6 GHz base, 5.0 GHz turbo, hyperthreading ("Willow Cove") 64GB DDR4-3200 ECC NVIDIA RTX A2000 4GB Storage: 512GB system drive (Micron 2300) 4TB additional storage (Sabrent Rocket Q4) Windows 11 Enterprise LTSC 2024 15.6" 3940×2160 IPS display Intel Wi-Fi AX210 (Wi-Fi 6E + Bluetooth 5.3) 95Wh battery 720p IR webcam Fingerprint reader Previous Dell Precision 7770, 7530, 7510, M4800, M6700 Dell Latitude E6520 Dell Inspiron 1720, 5150 Dell Latitude CPi
MyPC8MyBrain Posted January 6 Posted January 6 I’m still skeptical. It remains to be seen how close they’ll actually get to “back to their roots.” So far, the messaging only references XPS and implicitly Precision via the new naming convention. Both lines have earned multi-generation followings, but after the recent roller coaster, there’s real ground to make up to regain trust. And that trust isn’t tied to a name. It’s tied to a philosophy one they’ve been slowly eroding over the past few years. the impossible is not impossible, its just haven't been done yet.
1610ftw Posted January 6 Posted January 6 11 hours ago, SvenC said: BIOS updates and weekly full virus scans (ESET, have to use, company policy...) bring up the fans loud and clear. Sometimes too many browser tabs (e.g. with animated advertising like winfuture.de) uses a few cores with high load Visual Studio updates in sequence for 2019, 2022, 2026 and Preview and SSMS updates. Normal work is pretty silent - but hey, whats normal anyways 😉 I would buy it again - only wishes: 1920x1200 pixels 500+ nits on my 18" and the name Dell Pro Precision 7 oder 9 😉 Loud and clear fans sounds like a lot of fun 😄 I happen to like the QHD resolution but I am not so sure how much my usage would cause the fans to ramp up as quite often I have a lot of tabs open and the only thing that keeps my current MSI Vector from ramping up is a very granular enthusiast fan control that Dell does not offer. Yeah, I also miss the old naming convention, bad idea to so blatantly copy Apple.
OneSunOne Posted January 7 Posted January 7 On 1/5/2026 at 3:12 PM, Easa said: Some time ago someone here was describing a behavior where the system locks up in sort of a throttle state until the power connector is disconnected and plugged back in. I have observed the same behavior today. Happened to me. Did you play any audio when the lockup occurred?
Easa Posted January 7 Posted January 7 3 hours ago, OneSunOne said: Happened to me. Did you play any audio when the lockup occurred? Playing Helldivers II, sound coming through internal speakers. No buzzing though. ACE-Floodland Project CPU: Intel Core Ultra9 285K | MBD: MSI MEG Z890 ACE | RAM: G.Skill Z5CK 48GB 8400/40 | GPU: Gainward Phantom RTX 5090 GS 32GB | OS SSD: Intel Optane 905P M.2 380GB | STORAGE: 4x Intel Optane 905P U.2 1.5TB / 2x Kingston DC600M 960GB | PSU: CoolerMaster X Silent Edge Platinum 1100W | CASE: Lian Li V3000+ COOLING: CPU WB: Aquacomputer Cuplex Kryos NEXT NiSG | GPU WB: Watercool Heatkiller V Ultra 5090 | PUMP/TOP: Aquacomputer Ultitop Dual Brass / 2x AQC D5 Next | EXP: AQC Ultitube 150 / EK-Quantum Volume FLT 360 | SENSOR: AQC High Flow Next | RAD: 4x HardwareLabs SR2 480MP | FITTINGS: Bitspower Black Sparkle / 4x Koolance QD3 | TUBING: EK-ZMT 16/10 | FAN: 16x Phanteks T30-120 / 4x Noctua NF-A12x25 G2 / 2x Noctua NF-A4x20 SCREEN: Sony Inzone M9II 27" 4K | MOUSE: Razer Naga V2 Pro | KBD: Razer Huntsman V2 | PAD: Asus ROG Scabbard II | DAC: RME ADI2 DAC FS | HP: BeyerDynamic DT880 250Ω MWS: Dell Pro Max Plus 18 | CPU: Ultra9 285HX | GPU: RTX Pro 4000 BW | RAM: 2x32GB CSODIMM 6400 | SCREEN: IPS 2560x1600 120Hz | SSD: PM9E1 1TB + 2x 990 PRO 2/4TB
capitainealbator Posted January 7 Posted January 7 On 1/6/2026 at 1:24 PM, SvenC said: I would buy it again - only wishes: 1920x1200 pixels 500+ nits on my 18" and the name Dell Pro Precision 7 oder 9 😉 Why wouldn't you buy the QHD screen ? 🤔
SvenC Posted January 7 Posted January 7 5 hours ago, capitainealbator said: Why wouldn't you buy the QHD screen ? 🤔 Multi monitor DPI scaling with my additional 27" 2560x1440 + 24" 1920x1200 would be easier with 18" 1920x1200 - without quirks (*) the 18" DPI is a bit too high - and no, I do not want to exchange the other displays to higher DPI displays 😉 (*) advanced font changer vs WIndows 11 build in scaling 1 Dell Pro Max Plus 18 * Ultra 7 265HX * 64GB CSoDIMM * 4TB, 2TB, 2560x1600, iGPU previous; Dell Precision 7680 * i7 13850hx * 64GB SO-DIMM * 4TB, 2TB, 1920x1200 previous: Dell Precision 7740 * i7 9750h * 48GB * 512GB, 2TB, 4TB * RTX 3000 * 1920x1080
Tom1939 Posted January 16 Posted January 16 Hi! I got a pro max 18 plus recently (cpu 7-265X and pro 3000 vga) after I used the precision 7740 for 6 years. I only really use it for office and the occasional games (I do not like gaming laptop looks). My question would be, if it is save to uninstall dell optimizer? From my experience power modes are not really usefull as under steam everything will go full blast even with quiet mode choosen (with same fps as in ultra) and gets very loud. Menwhile the windows 11 power modes are greyed out. Did anyone have a sollution for a little more control of the power and the fan noise? Thx!
OneSunOne Posted January 21 Posted January 21 Have any of you with the Ultra9 285HX chip done any Cinebench tests? Results from online reviews, like Notebookcheck, get MultiThread scores around 3800 although I'm only getting 2820. I'd like to see how my results compare to other users' results.
Easa Posted January 21 Posted January 21 5 hours ago, OneSunOne said: Have any of you with the Ultra9 285HX chip done any Cinebench tests? Results from online reviews, like Notebookcheck, get MultiThread scores around 3800 although I'm only getting 2820. I'd like to see how my results compare to other users' results. Which CineBench exactly? ACE-Floodland Project CPU: Intel Core Ultra9 285K | MBD: MSI MEG Z890 ACE | RAM: G.Skill Z5CK 48GB 8400/40 | GPU: Gainward Phantom RTX 5090 GS 32GB | OS SSD: Intel Optane 905P M.2 380GB | STORAGE: 4x Intel Optane 905P U.2 1.5TB / 2x Kingston DC600M 960GB | PSU: CoolerMaster X Silent Edge Platinum 1100W | CASE: Lian Li V3000+ COOLING: CPU WB: Aquacomputer Cuplex Kryos NEXT NiSG | GPU WB: Watercool Heatkiller V Ultra 5090 | PUMP/TOP: Aquacomputer Ultitop Dual Brass / 2x AQC D5 Next | EXP: AQC Ultitube 150 / EK-Quantum Volume FLT 360 | SENSOR: AQC High Flow Next | RAD: 4x HardwareLabs SR2 480MP | FITTINGS: Bitspower Black Sparkle / 4x Koolance QD3 | TUBING: EK-ZMT 16/10 | FAN: 16x Phanteks T30-120 / 4x Noctua NF-A12x25 G2 / 2x Noctua NF-A4x20 SCREEN: Sony Inzone M9II 27" 4K | MOUSE: Razer Naga V2 Pro | KBD: Razer Huntsman V2 | PAD: Asus ROG Scabbard II | DAC: RME ADI2 DAC FS | HP: BeyerDynamic DT880 250Ω MWS: Dell Pro Max Plus 18 | CPU: Ultra9 285HX | GPU: RTX Pro 4000 BW | RAM: 2x32GB CSODIMM 6400 | SCREEN: IPS 2560x1600 120Hz | SSD: PM9E1 1TB + 2x 990 PRO 2/4TB
OneSunOne Posted January 21 Posted January 21 3 hours ago, Easa said: Which CineBench exactly? Forgot to mention it’s Cinebench R23.
Easa Posted January 21 Posted January 21 I will check tomorrow morning. ACE-Floodland Project CPU: Intel Core Ultra9 285K | MBD: MSI MEG Z890 ACE | RAM: G.Skill Z5CK 48GB 8400/40 | GPU: Gainward Phantom RTX 5090 GS 32GB | OS SSD: Intel Optane 905P M.2 380GB | STORAGE: 4x Intel Optane 905P U.2 1.5TB / 2x Kingston DC600M 960GB | PSU: CoolerMaster X Silent Edge Platinum 1100W | CASE: Lian Li V3000+ COOLING: CPU WB: Aquacomputer Cuplex Kryos NEXT NiSG | GPU WB: Watercool Heatkiller V Ultra 5090 | PUMP/TOP: Aquacomputer Ultitop Dual Brass / 2x AQC D5 Next | EXP: AQC Ultitube 150 / EK-Quantum Volume FLT 360 | SENSOR: AQC High Flow Next | RAD: 4x HardwareLabs SR2 480MP | FITTINGS: Bitspower Black Sparkle / 4x Koolance QD3 | TUBING: EK-ZMT 16/10 | FAN: 16x Phanteks T30-120 / 4x Noctua NF-A12x25 G2 / 2x Noctua NF-A4x20 SCREEN: Sony Inzone M9II 27" 4K | MOUSE: Razer Naga V2 Pro | KBD: Razer Huntsman V2 | PAD: Asus ROG Scabbard II | DAC: RME ADI2 DAC FS | HP: BeyerDynamic DT880 250Ω MWS: Dell Pro Max Plus 18 | CPU: Ultra9 285HX | GPU: RTX Pro 4000 BW | RAM: 2x32GB CSODIMM 6400 | SCREEN: IPS 2560x1600 120Hz | SSD: PM9E1 1TB + 2x 990 PRO 2/4TB
1610ftw Posted January 21 Posted January 21 15 hours ago, OneSunOne said: Have any of you with the Ultra9 285HX chip done any Cinebench tests? Results from online reviews, like Notebookcheck, get MultiThread scores around 3800 although I'm only getting 2820. I'd like to see how my results compare to other users' results. I think you mean 38000 and 28200. Your unit should easily be capable of a 35000 score and for example Notebookcheck even got A 38500 score in their review, possibly a better binned chip: https://www.notebookcheck.com/Dell-Pro-Max-18-Plus-Test-18-Zoll-Workstation-mit-USB-C.1167532.0.html
MyPC8MyBrain Posted January 21 Posted January 21 1 hour ago, 1610ftw said: possibly a better binned chip or simply a properly debloated, tweaked and tuned system. the impossible is not impossible, its just haven't been done yet.
heikkuri Posted January 23 Posted January 23 Hi, I found this from reddit r/Dell. Have you seen these kind of problems. What BIOS version are you using? Just wait until Dell replaces the mobo when device is broken.
yslalan Posted January 27 Posted January 27 On 1/21/2026 at 8:56 AM, OneSunOne said: Cinebench R23. R23 is definitely around 35000 for 285HX Dell Pro Max 16 Plus Ultra9-285HX - NVIDIA RTX Pro 4000 Blackwell - 48G DDR5 - UHD+ Display - 3840*2400 OLED - 7T NVMe Precision 7680 i9-13950HX - NVIDIA RTX 5000 Ada 16G - 96G DDR5 - UHD+ Display - 3840*2400 OLED - 6T NVMe
Easa Posted January 27 Posted January 27 I have posted the comparison between PMP18 and P16 G3 and in R23 my result was over 36k for 285HX. ACE-Floodland Project CPU: Intel Core Ultra9 285K | MBD: MSI MEG Z890 ACE | RAM: G.Skill Z5CK 48GB 8400/40 | GPU: Gainward Phantom RTX 5090 GS 32GB | OS SSD: Intel Optane 905P M.2 380GB | STORAGE: 4x Intel Optane 905P U.2 1.5TB / 2x Kingston DC600M 960GB | PSU: CoolerMaster X Silent Edge Platinum 1100W | CASE: Lian Li V3000+ COOLING: CPU WB: Aquacomputer Cuplex Kryos NEXT NiSG | GPU WB: Watercool Heatkiller V Ultra 5090 | PUMP/TOP: Aquacomputer Ultitop Dual Brass / 2x AQC D5 Next | EXP: AQC Ultitube 150 / EK-Quantum Volume FLT 360 | SENSOR: AQC High Flow Next | RAD: 4x HardwareLabs SR2 480MP | FITTINGS: Bitspower Black Sparkle / 4x Koolance QD3 | TUBING: EK-ZMT 16/10 | FAN: 16x Phanteks T30-120 / 4x Noctua NF-A12x25 G2 / 2x Noctua NF-A4x20 SCREEN: Sony Inzone M9II 27" 4K | MOUSE: Razer Naga V2 Pro | KBD: Razer Huntsman V2 | PAD: Asus ROG Scabbard II | DAC: RME ADI2 DAC FS | HP: BeyerDynamic DT880 250Ω MWS: Dell Pro Max Plus 18 | CPU: Ultra9 285HX | GPU: RTX Pro 4000 BW | RAM: 2x32GB CSODIMM 6400 | SCREEN: IPS 2560x1600 120Hz | SSD: PM9E1 1TB + 2x 990 PRO 2/4TB
OneSunOne Posted January 31 Posted January 31 On 1/27/2026 at 11:12 PM, Easa said: I have posted the comparison between PMP18 and P16 G3 and in R23 my result was over 36k for 285HX. On 1/27/2026 at 10:20 PM, yslalan said: R23 is definitely around 35000 for 285HX Thanks for posting your results. I’ve now run Cinebench R23 multiple times, and the highest score I can achieve is 30,054, which is significantly lower than what others with the same spec are reporting. However, in Cinebench 2024 my score is 1,925, which does align with results I’ve seen online. It’s strange that only the R23 scores are coming in so much lower. My specs are: Intel 285HX 64gb CSODIMM Blackwell RTX 4000
Easa Posted January 31 Posted January 31 Hello, The technician was here yesterday and has replaced the parts. So far: The temperatures are sort of better now, laptop is finally idling at around 50-75 degrees during the basic browser work. During heavy load it will still go to 106-109°C, but at least it's doing something. I have not encountered BSODs yet, but I guess it is too soon to call it fixed, we will see. WHEA and ACPI Errors of the are still present after each reboot. The right front side of the palmrest, the area around the fingerprint reader, now depresses with a click each time I rest my hand on it. It is annoying. The problem with the throttle state lock is still present, which is very serious as it limits the machine very much. It is mostly present when CPU and GPU are both loaded simultaneously, like in games. After 10-15 minutes the laptop enters sort of a throttle state, where it locks CPU to 20-25W of power with very low clock, and does not come back, the only solution is to disconnect and reconnect the charger. This happens regardless if the laptop is connected to the main charger, or to the docking station. Having to do this several times per hour is simply annoying and unbearable for such a machine, without even considering the impact it has on the durability of the USB-C connector. It clearly looks like a platform problem. I'll raise you a question - what do we do now? Because I am getting really tired of this machine. 1 ACE-Floodland Project CPU: Intel Core Ultra9 285K | MBD: MSI MEG Z890 ACE | RAM: G.Skill Z5CK 48GB 8400/40 | GPU: Gainward Phantom RTX 5090 GS 32GB | OS SSD: Intel Optane 905P M.2 380GB | STORAGE: 4x Intel Optane 905P U.2 1.5TB / 2x Kingston DC600M 960GB | PSU: CoolerMaster X Silent Edge Platinum 1100W | CASE: Lian Li V3000+ COOLING: CPU WB: Aquacomputer Cuplex Kryos NEXT NiSG | GPU WB: Watercool Heatkiller V Ultra 5090 | PUMP/TOP: Aquacomputer Ultitop Dual Brass / 2x AQC D5 Next | EXP: AQC Ultitube 150 / EK-Quantum Volume FLT 360 | SENSOR: AQC High Flow Next | RAD: 4x HardwareLabs SR2 480MP | FITTINGS: Bitspower Black Sparkle / 4x Koolance QD3 | TUBING: EK-ZMT 16/10 | FAN: 16x Phanteks T30-120 / 4x Noctua NF-A12x25 G2 / 2x Noctua NF-A4x20 SCREEN: Sony Inzone M9II 27" 4K | MOUSE: Razer Naga V2 Pro | KBD: Razer Huntsman V2 | PAD: Asus ROG Scabbard II | DAC: RME ADI2 DAC FS | HP: BeyerDynamic DT880 250Ω MWS: Dell Pro Max Plus 18 | CPU: Ultra9 285HX | GPU: RTX Pro 4000 BW | RAM: 2x32GB CSODIMM 6400 | SCREEN: IPS 2560x1600 120Hz | SSD: PM9E1 1TB + 2x 990 PRO 2/4TB
OneSunOne Posted January 31 Posted January 31 2 hours ago, Easa said: Hello, The technician was here yesterday and has replaced the parts. So far: The temperatures are sort of better now, laptop is finally idling at around 50-75 degrees during the basic browser work. During heavy load it will still go to 106-109°C, but at least it's doing something. I have not encountered BSODs yet, but I guess it is too soon to call it fixed, we will see. WHEA and ACPI Errors of the are still present after each reboot. The right front side of the palmrest, the area around the fingerprint reader, now depresses with a click each time I rest my hand on it. It is annoying. The problem with the throttle state lock is still present, which is very serious as it limits the machine very much. It is mostly present when CPU and GPU are both loaded simultaneously, like in games. After 10-15 minutes the laptop enters sort of a throttle state, where it locks CPU to 20-25W of power with very low clock, and does not come back, the only solution is to disconnect and reconnect the charger. This happens regardless if the laptop is connected to the main charger, or to the docking station. Having to do this several times per hour is simply annoying and unbearable for such a machine, without even considering the impact it has on the durability of the USB-C connector. It clearly looks like a platform problem. I'll raise you a question - what do we do now? Because I am getting really tired of this machine. What parts did they replace? I'm also getting tired of this machine. I've been experiencing the following issues: 1- The machine freezes for a split second every few minutes. When audio is playing at the same time, it also makes a buzzing noise through the speakers when it freezes/stutters for the split second. 2- When pushing the machine hard (doing rendering work), it freezes/stutters more often, to the point that it sounds like a popping/crackling noise coming from the speakers. 3. Every now and then when rendering, the machine would crash, forcing a restart. Dell has replaced the speakers and system board twice. I also believe it's a platform problem.
MyPC8MyBrain Posted January 31 Posted January 31 5 hours ago, Easa said: I'll raise you a question - what do we do now? Because I am getting really tired of this machine. taking you for a full circle 360 degree ride, wasting your time and money, just to leave you exactly where you started is not a solution im sorry, we call this a bunch of BS so other people can justify the poor job they are doing! do not close the ticket as resolved, you raised this ticket specifically for the WHEA errors and is the reason they sent the tech to replace your board with another faulty one in the first place, the errors did not go away, since you followed their protocol and issues still persists next step is a new system or refund your money. over here we have whats called the "Lemon Law" for the car industry, that should cover appliances now days not just cars. its a waste of your time they should now pay for since they feel its their to squander freely with... lets throw a tech visit to shut this case up, just shameful conduct across the board, you should escalate this to Dell corporate USA, and also inform the supervisor you are so he can have a good night sleep. (see your PM for direct emails for the individuals below) Jeff Clarke (Vice Chairman and Chief Operating Officer) - jeff.clarke@ Chris Cowger (lead Global Consumer and eCommerce) - chris.cowger@ the impossible is not impossible, its just haven't been done yet.
