yslalan Posted July 18, 2025 Share Posted July 18, 2025 I am skeptical as to whether the design of sandwiching the heat spreader between the CPU and GPU is truly effective. Another interesting point is that the power board for the 48V regulator has been designed as a daughter board. Dell Pro Max 16 Plus Ultra9-285HX - NVIDIA RTX Pro 4000 Blackwell - 48G DDR5 - UHD+ Display - 3840*2400 OLED - 7T NVMe Precision 7680 i9-13950HX - NVIDIA RTX 5000 Ada 16G - 96G DDR5 - UHD+ Display - 3840*2400 OLED - 6T NVMe Link to comment Share on other sites More sharing options...
yslalan Posted July 18, 2025 Share Posted July 18, 2025 12 hours ago, MyPC8MyBrain said: The "c" in cSODIMM stand for CAMM, or more precisely, "CAMM-based SODIMM". That's not true; there are two types of DIMM form factors: CUDIMMs and CSODIMMs. The "C" stands for "Clocked," indicating that there are clock drivers on the DIMM board. 14 hours ago, MyPC8MyBrain said: USB-C Power Delivery — A Downgrade I believe it is guided by EU regulations. 2 Dell Pro Max 16 Plus Ultra9-285HX - NVIDIA RTX Pro 4000 Blackwell - 48G DDR5 - UHD+ Display - 3840*2400 OLED - 7T NVMe Precision 7680 i9-13950HX - NVIDIA RTX 5000 Ada 16G - 96G DDR5 - UHD+ Display - 3840*2400 OLED - 6T NVMe Link to comment Share on other sites More sharing options...
MyPC8MyBrain Posted July 18, 2025 Share Posted July 18, 2025 @yslalan 14 minutes ago, yslalan said: The "C" stands for "Clocked," as in XMP? (Extreme Memory Profile) 14 minutes ago, yslalan said: there are two types of DIMM form factors that is true with a very big distinction, cSODIMM (CAMM-based SODIMM) = Laptop DDR5 SODIMM cUDIMM (CAMM-based UDIMM) = Desktop DDR5 UDIMM both are still essentially a CAMM adapter/interposer that allows you to plug in SODIMM modules into a CAMM memory slot, both of which are Dell-specific (and somewhat confusing) terminologies built around the CAMM platform. the impossible is not impossible, its just haven't been done yet. Link to comment Share on other sites More sharing options...
yslalan Posted July 18, 2025 Share Posted July 18, 2025 2 minutes ago, MyPC8MyBrain said: that is true with a very big distinction, cSODIMM (CAMM-based SODIMM) = Laptop DDR5 SODIMM cUDIMM (CAMM-based UDIMM) = Desktop DDR5 UDIMM https://www.kingston.com/en/blog/system-builder/what-is-a-cudimm-csodimm Just check out this link, and you'll get a better idea of what they truly are. Dell Pro Max 16 Plus Ultra9-285HX - NVIDIA RTX Pro 4000 Blackwell - 48G DDR5 - UHD+ Display - 3840*2400 OLED - 7T NVMe Precision 7680 i9-13950HX - NVIDIA RTX 5000 Ada 16G - 96G DDR5 - UHD+ Display - 3840*2400 OLED - 6T NVMe Link to comment Share on other sites More sharing options...
MyPC8MyBrain Posted July 18, 2025 Share Posted July 18, 2025 @yslalan In JEDEC-standard terminology you are correct, the “C” in CSODIMM and CUDIMM stands for “Clocked”, referring to the presence of a Client Clock Driver (CKD). In Dell/OEM usage, "cSODIMM" has also been used to mean "CAMM-based SODIMM", which adds to the confusion, but is technically inaccurate by JEDEC standards. the impossible is not impossible, its just haven't been done yet. Link to comment Share on other sites More sharing options...
yslalan Posted July 18, 2025 Share Posted July 18, 2025 2 minutes ago, MyPC8MyBrain said: And the "c" has nothing to do with the CKD, it's all about the CAMM slot interface. JEDEC-CAMM does not affect the standard UDIMM and SODIMM slots. The "C" simply represents "clock" and is not related to CAMM. As for the CKD Small Outline DIMM (CSO-DIMM), here is the link from JEDEC.org for you to check. https://www.jedec.org/category/keywords/csodimm And here are some links from OEMs: https://www.kingston.com/en/blog/system-builder/what-is-a-cudimm-csodimm https://www.klevv.com/ken/products_details/memory/D5_CSODIMM https://www.innodisk.com/en/products/dram-modules/ddr5/ddr5-csodimm https://industrial.adata.com/en/product/DDR5_CSO-DIMM https://www.crucial.com/memory/ddr5/ct16g64c52cs5 The CSODIMM referenced in Dell's tech specifications is the one outlined by JEDEC, which has been updated to support high frequencies of up to 6400MHz. Dell Pro Max 16 Plus Ultra9-285HX - NVIDIA RTX Pro 4000 Blackwell - 48G DDR5 - UHD+ Display - 3840*2400 OLED - 7T NVMe Precision 7680 i9-13950HX - NVIDIA RTX 5000 Ada 16G - 96G DDR5 - UHD+ Display - 3840*2400 OLED - 6T NVMe Link to comment Share on other sites More sharing options...
ceasar2k6 Posted July 18, 2025 Share Posted July 18, 2025 5 hours ago, MyPC8MyBrain said: @ceasar2k6 simple decision, get a Precision platform while you still can. i have a 7760 and it's 4 years, i still have 1 year on accidental. i dont think 7780 is an upgrade unfortunately, as i am mostly looking for newer cpu's... ideally i'd want them to use and, but u know... but tb5 for docks, sounds nice and maybe worth it 2 hours ago, Howard N said: What is the vertical screen resolution of the 18" screen in pixels (not just saying QHD+). Is it 1400, 1600 or some higher resolution? 2560x1600 i think? Link to comment Share on other sites More sharing options...
MyPC8MyBrain Posted July 18, 2025 Share Posted July 18, 2025 23 minutes ago, yslalan said: here is the link from JEDEC.org for you to check. indeed, i read up on that link, you just quoted my response before i re-edited it. 19 minutes ago, ceasar2k6 said: i dont think 7780 is an upgrade its somewhat of a 30% upgrade id say between the cpu and the gpu overall, it would been nice if intel didn't completely messed up 14 gen line and dell at least integrated with the 14900 for the last precision gen, but it still be lagging way behind the 285H or the 5090/6000 you could (potentially) fit in it now, still I'd grab a 7780 over the newer 18 pro max plus which im about to do to replace a 7770. the impossible is not impossible, its just haven't been done yet. Link to comment Share on other sites More sharing options...
ceasar2k6 Posted July 18, 2025 Share Posted July 18, 2025 47 minutes ago, MyPC8MyBrain said: indeed, i read up on that link, you just quoted my response before i re-edited it. its somewhat of a 30% upgrade id say between the cpu and the gpu overall, it would been nice if intel didn't completely messed up 14 gen line and dell at least integrated with the 14900 for the last precision gen, but it still be lagging way behind the 285H or the 5090/6000 you could (potentially) fit in it now, still I'd grab a 7780 over the newer 18 pro max plus which im about to do to replace a 7770. main issue for me is 5 year accidental. with 7760, they been here 5 or 6 times now replacing this godIO&*&%^&%^&& keyboard.... paint peeling, keys stop working, so.... ya, i mean, if 7780 goes on clearance next year, ill consider it, but right now. i may just keep using this and my razor which has 3090 and 13th gen cpu Link to comment Share on other sites More sharing options...
Mambucho Posted July 18, 2025 Share Posted July 18, 2025 15 часов назад, MyPC8MyBrain сказал: @SvenC Буква «c» в слове cSODIMM означает CAMM, а точнее «SODIMM на основе CAMM». Это не новый стандарт памяти — это стандартные модули SODIMM, установленные на промежуточной или преобразовательной плате, которая вставляется в разъем CAMM. Dell разработала эту технологию, чтобы обеспечить обратную совместимость с обычными модулями SODIMM DDR5 на материнских платах, предназначенных для CAMM — в основном потому, что JEDEC одобрила CAMM2 в качестве будущего, но большинство пользователей по-прежнему полагаются на SODIMM. как я уже упоминал выше, Camm на самом деле еще не работает над этими платами, на данный момент времени Camm в основном теоретический и больше похож на маркетинговую шумиху, SoDimm работает так же быстро, как модули Camm на той же системе, и может работать с высокой плотностью стиков, и они лучше рассеивают тепло, но Dell не хочет, чтобы люди знали, так как они изначально были настроены на продвижение модулей camm, пока не поняли, что некоторые из нас образованы и Не судите о маркетинговой шумихе только по обложке. edit: важно отметить, что модули Camm дороже, чем модули Sodimm, и в этом формате нет никакой реальной пользы. Dell Precision 7680, RTX 3500 ADA, CAMM 32 ГБ, FHD+, WIN 11 Pro for Workstations (25H2.Dev) Link to comment Share on other sites More sharing options...
yslalan Posted July 18, 2025 Share Posted July 18, 2025 @Dell-Mano_G Hello, the ProMax-Plus series has finally been released. Is it possible to share any information regarding the TDP and TGP? On the spec sheet, it indicates a 256G DRAM option. Will the 256GB CAMM (2x128 GB) be released to the market, and does that setup include 2 CAMM slots as mentioned in the spec sheet? Dell Pro Max 16 Plus Ultra9-285HX - NVIDIA RTX Pro 4000 Blackwell - 48G DDR5 - UHD+ Display - 3840*2400 OLED - 7T NVMe Precision 7680 i9-13950HX - NVIDIA RTX 5000 Ada 16G - 96G DDR5 - UHD+ Display - 3840*2400 OLED - 6T NVMe Link to comment Share on other sites More sharing options...
SvenC Posted July 18, 2025 Share Posted July 18, 2025 CSoDimm 64 GB 418€ - thats the first time that the upgrade price from Dell from 16 to 64GB is not that much of an issue with 474€ - maybe a step in the right direction. We'll see how Dell behaves if the CSoDimm prices drop - SO-DIMM 64 GB is around 160€ and less. Dell Pro Max Plus 18 * Ultra 7 265HX * 64GB CSoDIMM * 4TB, 2TB, 2560x1600, iGPU previous; Dell Precision 7680 * i7 13850hx * 64GB SO-DIMM * 4TB, 2TB, 1920x1200 previous: Dell Precision 7740 * i7 9750h * 48GB * 512GB, 2TB, 4TB * RTX 3000 * 1920x1080 Link to comment Share on other sites More sharing options...
Howard N Posted July 18, 2025 Share Posted July 18, 2025 I looks like from the newest specs on the Dell 16 pro max premium that the verticle resolution on that model is 2400 (3840 x 2400). That is what I was hoping to find. Link to comment Share on other sites More sharing options...
Aaron44126 Posted July 18, 2025 Author Share Posted July 18, 2025 The 16" Pro Max Plus has options for 1920×1200 and 3840×2400. The 18" Pro Max Plus just has one option and it is in between, 2560×1600. (You can see these right on the order page where you select your configuration.) 1 Apple MacBook Pro 16-inch, 2023 (personal) • Dell Precision 7560 (work) • Full specs in spoiler block below Info posts (Windows) — Turbo boost toggle • The problem with Windows 11 • About Windows 10/11 LTSC Spoiler Apple MacBook Pro 16-inch, 2023 (personal) M2 Max 4 efficiency cores 8 performance cores 38-core Apple GPU 96GB LPDDR5-6400 8TB SSD macOS 15 "Sequoia" 16.2" 3456×2234 120 Hz mini-LED ProMotion display Wi-Fi 6E + Bluetooth 5.3 99.6Wh battery 1080p webcam Fingerprint reader Also — iPhone 12 Pro 512GB, Apple Watch Series 8 Dell Precision 7560 (work) Intel Xeon W-11955M ("Tiger Lake") 8×2.6 GHz base, 5.0 GHz turbo, hyperthreading ("Willow Cove") 64GB DDR4-3200 ECC NVIDIA RTX A2000 4GB Storage: 512GB system drive (Micron 2300) 4TB additional storage (Sabrent Rocket Q4) Windows 11 Enterprise LTSC 2024 15.6" 3940×2160 IPS display Intel Wi-Fi AX210 (Wi-Fi 6E + Bluetooth 5.3) 95Wh battery 720p IR webcam Fingerprint reader Previous Dell Precision 7770, 7530, 7510, M4800, M6700 Dell Latitude E6520 Dell Inspiron 1720, 5150 Dell Latitude CPi Link to comment Share on other sites More sharing options...
Mike Posted July 19, 2025 Share Posted July 19, 2025 When selecting the Pro Max 18 Plus, depending on the configuration a 280W power supply is required. But suggested Dockingstation is a WD19DCS with 240W. So do you think I have to connect the power supply in parallel to the dock or is the dock alone enough ? Link to comment Share on other sites More sharing options...
yslalan Posted July 21, 2025 Share Posted July 21, 2025 On 7/19/2025 at 2:04 PM, Mike said: When selecting the Pro Max 18 Plus, depending on the configuration a 280W power supply is required. But suggested Dockingstation is a WD19DCS with 240W. So do you think I have to connect the power supply in parallel to the dock or is the dock alone enough ? The WD19DCS provides a maximum output of 210W when both USB-C ports are used simultaneously. Therefore, even under the assumption that the Pro Max supports older docking stations, it still demands 280W to function properly. Without this, you’ll experience a performance downgrade and see a warning screen when you boot up the system. In the worst-case scenario, if the Pro Max model only recognizes a single cable input, then your WD19DCS will function as a WD19S and your system will receive only 130W from the dock (Yes, in this case, you definitely need a 280W psu connected in parallel.). Dell Pro Max 16 Plus Ultra9-285HX - NVIDIA RTX Pro 4000 Blackwell - 48G DDR5 - UHD+ Display - 3840*2400 OLED - 7T NVMe Precision 7680 i9-13950HX - NVIDIA RTX 5000 Ada 16G - 96G DDR5 - UHD+ Display - 3840*2400 OLED - 6T NVMe Link to comment Share on other sites More sharing options...
AL123 Posted July 21, 2025 Share Posted July 21, 2025 On 7/19/2025 at 7:04 AM, Mike said: When selecting the Pro Max 18 Plus, depending on the configuration a 280W power supply is required. But suggested Dockingstation is a WD19DCS with 240W. So do you think I have to connect the power supply in parallel to the dock or is the dock alone enough ? Seems they haven’t updated the configurator this is the supported dock for the Pro Max Plus laptops https://www.dell.com/en-us/shop/dell-pro-thunderbolt-5-smart-dock-sd25tb5/apd/210-brqs/docks it can do 300W power delivery over a single USB C so a little bit of future proofing. Significantly higher cost of course though. what we really need is an adaptor to dual usb-c for our existing precision 7000 series laptops. The current WD19 DCS we have will only do 230W so not enough for the new Pro Max Plus and this new docking station will only do 130W over a single usb-c to the old precision models as that is their max We aren’t going to upgrade everyone’s laptop over night so this is going to make hot-desking tricky for us, where as for years even if you forgot your power supply you were fine. see also Link to comment Share on other sites More sharing options...
Mambucho Posted July 23, 2025 Share Posted July 23, 2025 Dell Precision 7680, RTX 3500 ADA, CAMM 32 ГБ, FHD+, WIN 11 Pro for Workstations (25H2.Dev) Link to comment Share on other sites More sharing options...
win32asmguy Posted July 24, 2025 Share Posted July 24, 2025 On 7/18/2025 at 1:12 AM, yslalan said: @Dell-Mano_G Hello, the ProMax-Plus series has finally been released. Is it possible to share any information regarding the TDP and TGP? On the spec sheet, it indicates a 256G DRAM option. Will the 256GB CAMM (2x128 GB) be released to the market, and does that setup include 2 CAMM slots as mentioned in the spec sheet? I have not gotten any info about TDP and TGP from my sales rep but have a Pro Max 18 Plus on order. I will share what I find when it arrives. This time around these workstations finally have a vapor chamber and a third full sized fan so they should do better than the 7780. Hopefully the memory will not be running in Gear4 as that is a huge latency penalty compared to Gear2. 1 Desktop - Intel 285K, Asus Z890 Apex, 48GB DDR5-8400 C36, 800GB Optane P5800X, MSI RTX 5090 Gaming Trio OC, Corsair HX1500i, Fractal Define 7 XL, Windows 10 Pro 22H2 Lenovo Legion 9i G10 - 275HX, 2x32GB Kingston Fury DDR5-5200 CL38, 4TB WD 8100, RTX 5090 mobile, 18.0 inch FHD+ 440hz IPS, Windows 10 Pro 22H2 Hydroc G2 / Uniwill IDY X6AR559Y - 275HX, 2x16GB DDR5-6400 CL38, 4TB WD SN850X, RTX 5090 mobile, 16.0 inch QHD+ 300hz MiniLED, Windows 11 Pro 24H2 Link to comment Share on other sites More sharing options...
MyPC8MyBrain Posted July 27, 2025 Share Posted July 27, 2025 Oh no... the disappointments just keep rolling in, one after another. From the image above, it’s clear we've lost all port modularity. Aside from the GPU, Wi-Fi, and RAM, nothing appears to be modular anymore. If a port fails, you're either stuck living with it or replacing the entire motherboard. This is deeply underwhelming—a staggeringly uneventful product launch, perhaps the most forgettable in Dell’s Precision history. It feels poorly executed and hastily thrown together, made worse by the absence of a complete, finalized spec sheet. Once again, those of us who care about workstation-grade quality are left with little more than plain crackers to choose from. No surprise that none of Dell’s execs are chiming in on this—likely out of embarrassment, and perhaps because there’s simply no way to justify this brutal dismantling of a once-legendary product line. RIP Dell Precision. It was a great run—nearly three decades of innovation and reliability. Sadly, it seems even Dell has forgotten what made it great in the first place. the impossible is not impossible, its just haven't been done yet. Link to comment Share on other sites More sharing options...
win32asmguy Posted July 27, 2025 Share Posted July 27, 2025 5 hours ago, MyPC8MyBrain said: Oh no... the disappointments just keep rolling in, one after another. From the image above, it’s clear we've lost all port modularity. Aside from the GPU, Wi-Fi, and RAM, nothing appears to be modular anymore. If a port fails, you're either stuck living with it or replacing the entire motherboard. This is deeply underwhelming—a staggeringly uneventful product launch, perhaps the most forgettable in Dell’s Precision history. It feels poorly executed and hastily thrown together, made worse by the absence of a complete, finalized spec sheet. Once again, those of us who care about workstation-grade quality are left with little more than plain crackers to choose from. No surprise that none of Dell’s execs are chiming in on this—likely out of embarrassment, and perhaps because there’s simply no way to justify this brutal dismantling of a once-legendary product line. RIP Dell Precision. It was a great run—nearly three decades of innovation and reliability. Sadly, it seems even Dell has forgotten what made it great in the first place. It looks like the USB-C ports are modular according to the service manual, so if they wear out one would have to pull the motherboard, unscrew the port connector (appears to be something like DGFF if its similar to the XPS 13), and screw down a new replacement connector. Its definitely a must too as power jacks commonly wear out first as they are frequently used. I guess those USB-C ports can function as power / video / data so if your USB-A or HDMI ports failed they could be used in lieu of board repair. Desktop - Intel 285K, Asus Z890 Apex, 48GB DDR5-8400 C36, 800GB Optane P5800X, MSI RTX 5090 Gaming Trio OC, Corsair HX1500i, Fractal Define 7 XL, Windows 10 Pro 22H2 Lenovo Legion 9i G10 - 275HX, 2x32GB Kingston Fury DDR5-5200 CL38, 4TB WD 8100, RTX 5090 mobile, 18.0 inch FHD+ 440hz IPS, Windows 10 Pro 22H2 Hydroc G2 / Uniwill IDY X6AR559Y - 275HX, 2x16GB DDR5-6400 CL38, 4TB WD SN850X, RTX 5090 mobile, 16.0 inch QHD+ 300hz MiniLED, Windows 11 Pro 24H2 Link to comment Share on other sites More sharing options...
MyPC8MyBrain Posted July 28, 2025 Share Posted July 28, 2025 if it is then its not reflected in the image @Mambucho posted, red circles seem to be embedded USB-C ports, the other silver looking marked in blue i'm not sure what it is, if its usb ports it appears that only the outer shell is potentially replaceable, seems oddly conductive material whatever it is, either way i a m not seeing modular daughter boards separate from the main board the way it used to be, it seem cheaper and less modular then id expect from a flagship stepping around with shoes it cant fill. i cant wait to hear the verdict on thermals with the main nvme slot stacked with another nvme below and surrounded with ram slots and another nvme on the other side, and for good measure the new AI gpu right above to make sure heat buildup as much as possible, maybe its just my bad vision but it seem that the fans are all pointing in the other direction of that massive heat centered area, so heat is dissipated away from cpu and gpu mainly in this 3 fan layout that completely neglect the hottest area under the hood in this carefully thought out new design. the impossible is not impossible, its just haven't been done yet. Link to comment Share on other sites More sharing options...
Aaron44126 Posted July 28, 2025 Author Share Posted July 28, 2025 @Mambucho's image is a CG representation, you get this by picking the "explode system" view in the 3D/360° viewer thing on the order page. The best place for images is the service manual. I posted a few previously but there are many more. You have to navigate to the section on replacing or installing a specific part and see what you can see. https://www.dell.com/support/manuals/en-us/dell-pro-max-mb18250-laptop/dell-pro-max-18-plus-mb18250-owners-manual/Dell-Pro-Max-18-Plus-MB18250-Owners-Manual?guid=guid-0882cfdc-c140-418b-942d-feaed12da755&lang=en-us It does look like the USB-C connectors can be replaced separately from the entire motherboard. [Edit] I appreciate that it doesn't look too hard to get the fans out, and you can also remove the fans (i.e. for proper cleaning) without removing the entire heatsink? This hasn't been possible since Precision M6800 (2013). Apple MacBook Pro 16-inch, 2023 (personal) • Dell Precision 7560 (work) • Full specs in spoiler block below Info posts (Windows) — Turbo boost toggle • The problem with Windows 11 • About Windows 10/11 LTSC Spoiler Apple MacBook Pro 16-inch, 2023 (personal) M2 Max 4 efficiency cores 8 performance cores 38-core Apple GPU 96GB LPDDR5-6400 8TB SSD macOS 15 "Sequoia" 16.2" 3456×2234 120 Hz mini-LED ProMotion display Wi-Fi 6E + Bluetooth 5.3 99.6Wh battery 1080p webcam Fingerprint reader Also — iPhone 12 Pro 512GB, Apple Watch Series 8 Dell Precision 7560 (work) Intel Xeon W-11955M ("Tiger Lake") 8×2.6 GHz base, 5.0 GHz turbo, hyperthreading ("Willow Cove") 64GB DDR4-3200 ECC NVIDIA RTX A2000 4GB Storage: 512GB system drive (Micron 2300) 4TB additional storage (Sabrent Rocket Q4) Windows 11 Enterprise LTSC 2024 15.6" 3940×2160 IPS display Intel Wi-Fi AX210 (Wi-Fi 6E + Bluetooth 5.3) 95Wh battery 720p IR webcam Fingerprint reader Previous Dell Precision 7770, 7530, 7510, M4800, M6700 Dell Latitude E6520 Dell Inspiron 1720, 5150 Dell Latitude CPi Link to comment Share on other sites More sharing options...
win32asmguy Posted July 28, 2025 Share Posted July 28, 2025 As @Aaron44126 mentioned the blue circled ports are USB-C and can be replaced. It looks like they have pins that compress against the motherboard when screwed down. There is also a modular "power" daughterboard but I am not sure what it has unless its something related to USB-C power delivery and the systems shipped with the 165W adapter get a different board here. I think the stacked drives could have thermal issues. The memory would hopefully be ok although its hard to say until we have numbers from a system under sustained load. The unified vapor chamber should help things this year paired with the three full sized fans. Hopefully under max sustained loads it does not constantly trip bidirectional PROCHOT which would drop CPU cores and the iGPU to 400mhz for short periods of time on the 7670 and 7780. I really hope they have a better built in microphone this year. Everything from the 7560 my wife uses, 7670, 7780 all have issues with it periodically dropping voice in calls probably due to some AI enhancement in the driver that could not be disabled. Desktop - Intel 285K, Asus Z890 Apex, 48GB DDR5-8400 C36, 800GB Optane P5800X, MSI RTX 5090 Gaming Trio OC, Corsair HX1500i, Fractal Define 7 XL, Windows 10 Pro 22H2 Lenovo Legion 9i G10 - 275HX, 2x32GB Kingston Fury DDR5-5200 CL38, 4TB WD 8100, RTX 5090 mobile, 18.0 inch FHD+ 440hz IPS, Windows 10 Pro 22H2 Hydroc G2 / Uniwill IDY X6AR559Y - 275HX, 2x16GB DDR5-6400 CL38, 4TB WD SN850X, RTX 5090 mobile, 16.0 inch QHD+ 300hz MiniLED, Windows 11 Pro 24H2 Link to comment Share on other sites More sharing options...
MyPC8MyBrain Posted July 29, 2025 Share Posted July 29, 2025 Thank you for the links @Aaron44126 i still don't see daughter boards in the explosion image (Direct Link) it also appears that not all 4 SSD slot are made equal, its 3 x M.2 2280 SSD and 1 x M.2 2230 SSD Sliding door (optional) GPU card Heat sink for computers shipped with discrete graphics Discrete FPC beam connector cable SSD1 thermal shield SSD holder M.2 2280 SSD Battery Battery cable Memory interposer board bracket Memory connector Memory module Memory interposer board WLAN card bracket WLAN card SSD3 thermal shield SSD2 thermal shield SSD4 thermal shield Inner frame Smart card reader WLAN antenna module Left speaker Darwin bracket Display bracket Right speaker Display assembly Power button board with fingerprint reader (FIPS) Power button board with fingerprint reader bracket Interposer board Power board Power button Power button board USH board cable System board Keyboard Power button board cable Keyboard bracket Fan assembly WWAN card bracket WWAN card WWAN card shielding cover Base cover for computers with sliding door M.2 2230 SSD the impossible is not impossible, its just haven't been done yet. Link to comment Share on other sites More sharing options...
