5 hours ago, Aaron44126 said:
The GPU card fits in the top-right area (viewing from the bottom), a custom form factor DGFF card like they've been doing for several years now. It can be seen in the manual. (Tossed some pictures from the manual in the spoiler block below.)
The only new thing here to me is that it appears to be double-stacked over part of the motherboard (but not directly above the CPU). You can see the double-stacking best in the second-to-last image in @AL123's post above. Stacking the dGPU card on top of the motherboard is not that new, it was standard design when Dell was using MXM cards (2017 systems and earlier), but this is the first time that I have seen it since they switched to DGFF.
When the Qualcomm AI thing is available, my understanding is that it will also be a DGFF card fitting in the same space, so you'll have to pick between it or an NVIDIA GPU.
  Reveal hidden contents
GUID-3C90D600-551B-4564-8B9F-DA7DAC1A27E
GUID-8771D76C-0554-48B4-B3CC-AC546F3C52E
I’d certainly like a better idea of how this stacking is arranged, not brave enough to take these apart any further though!
I can try and take some more pictures around that area when I am back in the office though.
5 hours ago, yslalan said:
Well, it’s kind of hard to say. Those AI Chips are not a new model (advertised as dNPUs). In the Pro Max-Plus series, Dell is using the solution from Qualcomm shipped in H1 2021 (a pair of AI 100 Pro chips), but four years have already passed, and there hasn’t been much presence in industrial usage.
ah didn’t realise it was that old,  perhaps the first gen might be a bit limited but hopefully a sign dell are looking to innovate.
i think the NVIDIA spark / Dell Pro Max GB10 will make more sense, 128GB or 256 if you join two together
https://www.nvidia.com/en-gb/products/workstations/dgx-spark/
so small you could jsut pop in your bag,
40 minutes ago, win32asmguy said:
they made a decision of function over form here
I’m not sold on the idea that this form will hold up under sustained heavy loads. Mobile chassis designs already have minimal wiggle room, and if the trade-off here is improve latency over optimizing thermals, I’d take optimizing thermals—because once temps spike, latency will happen anyway. Lower latency isn’t much of a win if the rest of the system is cooking itself. That’s not just counterproductive, it’s self-defeating in the long run.
Yea, I am awaiting news about the Nvidia N1x SoC, which is based on the same architecture as GB10 but targeted towards the laptop market. Hopefully, it's Linux and Windows on Arm compatible.
Dell Pro Max 16 Plus Ultra9-285HX - NVIDIA RTX Pro 4000 Blackwell - 48G DDR5 - UHD+ Display - 3840*2400 OLED - 7T NVMe
Precision 7680 i9-13950HX - NVIDIA RTX 5000 Ada 16G - 96G DDR5 - UHD+ Display - 3840*2400 OLED - 6T NVMe
Ah I hadn’t heard about that one, would be more aligned with the dominance NVIDIA have in that market along with partnership Dell have with them.
perhaps the focus on AI will also mean we will see a mid life increase in graphics memory per ampere mobile where they doubled many of the capacities of the range IIRC. just not sure if the memory density will allow for that in such a small space to cram them in and cool the chips.
While SoCs do offer real engineering advantages in terms of performance per watt, the business model they enable is a major contributor to the growing e-waste problem and the erosion of consumer freedom.
SoCs in personal computing are, in my view, an abomination—a step in the wrong direction for the average user. They exist not because they serve the long-term interests of consumers, but because they maximize profit, streamline manufacturing, and reinforce planned obsolescence.
The trade-off is clear: ownership, control, and product longevity are sacrificed for short-term efficiency and corporate margins.
 Certainly not ideal, but what did surprise me is what NVIDIA is doing with local AI  is making it more affordable for once. With GB10 it’s  ~$3k for 128GB (2bn parameter models)  or $6k for 256GB if you link two together.  won’t be as fast as a system with one or more 96GB RTX 6000 Blackwell but less costly and more capacity. Perhaps I’ll give them a pass on using a SoC in that case. Storage is user upgradable, but the memory is soldered
I hope that CAMM memory will see wider adoption and make it less necessary to have soldered ram. Sometimes it’s the chip makers decision e.g new AMD strix point/ halo have apus with soldered memory In the AMD versions of the base Pro Max 14/16. I believe tthat is the only option due to AMD choices, but more often it’s the manufacturer, Dell, HP, Lenovo….. choice.
I really don’t understand why for instance Dell are using LP-CAMM on their entry level Pro Max 14 but soldered memory on their Pro Max 14 & 16 Premium devices. They really aren’t that much thinner to make be believe soldered is necessary, given the pioneered CAMM modules this is very disappointing.
Apple seem to have gained some advantages from their SoC approach for and I’m fine with a combined APU, if it’s genuinely better, but would be nice to have upgradable memory if CAMM was fast enough and no excuse for non upgradable storage. Not sure apple will ever do this thouge,  even user upgradable storage has gone by the way for no justification I can see just greed, just add gen 5 m.2 pcie slot .
we have to use windows due to certain pro applications, but for teams like our video/ marketing macs would make sense, the snag other than supporting 2 different OS,  is either paying through the nose for storage or having loads of external drives that are harder to control from a IT perspective
Still no review from the new Dell Pro Max Plus 16/18.
We'll order a Pro Max Plus 18" tomorrow. 265HX, iGPU only, CSoDimm (1x 16GB to upgrade myself to 2x 32GB). Should be delivered in 3 weeks, according to our sales rep.
Dell Pro Max Plus 18 * Ultra 7 265HX * 64GB CSoDIMM * 4TB, 2TB, 2560x1600, iGPU
previous; Dell Precision 7680 * i7 13850hx * 64GB SO-DIMM * 4TB, 2TB, 1920x1200
previous: Dell Precision 7740 * i7 9750h * 48GB * 512GB, 2TB, 4TB * RTX 3000 * 1920x1080
Will be interesting to see how the iGPU version performs,  from the manual it looks like the heatsink is different. The Pro Max 18 with RTX 4000 I have runs the Ultra 9 CPU at sustained power of around 100W (PL1 = 98W)
How long does it run on battery on low use? Does it get hot on medium or high load?
Early days for testing not  used it much for day to day work jsut a bit of benchmarking; but had More time with the lower pro max 16 with intel h series and that certainly seems much better than earlier core i7/i9
On the pro max 18 plus so far pleased with the temps under high load, chassis doesn’t seem to heat up the same way as previous gen,
our sales rep called me last week to let me know they are running specials on the new 16/18 pro max's internally for limited time, it seem they proactively trying to push these out.
back in the office today, much to catch up on but couldn’t resist a bit of testing while doing dull admin tasks
Focused on Pro Max 18 as its most popular with our team so far (massive screen!) specs-
Ultra 9, RTX 4000, 64GB CSODIMM, 2TB gen 5 SSD
This is now a full production unit with latest BIOS, drivers etc and my impressions very positive particularly for the new cooling system excellent performance and the chassis is remarkably cool ( just  warm at top left where the fans/ heatsink are)
The CPU still seems to be limited to around 100W for sustained workloads (98w PL1)
I tried more synthetic test cinebench  2024 + a real world CFD simulation which is heavily multi threaded. the power draw hovered around this 100W mark on both, with the average a little higher in the real world CFD  test I suspect because it doesn’t load cores 100% all the time.
From looking at others tests online with u9 275HX gaming laptops this seems to be the sweet spot for performance and you have to go to crazy power levels to get much any more performance vs 100W it just plateaus there for a bit so may be a sensible limit from Dell.
the RTX Pro 4000 on the other hand i am seeing higher power than my last test unit whether it is the newer bios, drivers or jsut because i am using hw info now. It is capable of sitting at a sustained 170-175W for a GPU rendering task  lasting 10 mins +
I then tried GPU+CPU concurrent
the rendering on GPU 100% load and ran a multi threaded cpu test on cinebench 2024 for a concurrent torture test!
 I think dell are under claiming if anything!
. GPU ran at 140-145W and cpu around 60-65 (63W average)  so yes the cpu does throttle back if the GPU is under heavy load but still performant and above the claimed 200W concurrent.
It was reporting 250-260W total system power in hw info. Saw a brief spike to 300W so it used a bit of battery for a while.
Would be nice if there was some utility we could choose to allocate a bit more power budget to the cpu, but right now in the real world the tools we use that benefit from GPU aren’t simultaneously loading the cpu 100%
Haven’t tried it on the dock yet to see if it behaves any different.
did you look into changing power plan settings in bios to performance for low level settings,
and than higher in windows power plan settings?
there's also settings in NVIDIA to prefer more performance etc. in control panel setting as well as additional tweaks via external third party tools.
with my 7770 i undervolted my cpu, run bios on cool profile, and windows profile in balanced mode, i created a powershell script that changed bios power plan to performance from within windows, and switched windows to maximum performance power plan (old classic power schema), the script would toggle everything back if i run it again, i think i posted it somewhere in the 7770 owners thread you could possibly adopt it to this unit easily with your preferred settings to quickly switch to pedal to the metal profile.
The power profiles (Balanced / Quiet / Cool / High performance) will impact power draw behavior. Setting it to "Cool" might be a way to allocate more power budget to the CPU, for example; in past systems that I have messed with, this power setting put a cap on the GPU power draw but not on the CPU power draw.
You used to adjust this in the Dell Power Manager app, but that isn't a thing anymore, I guess maybe it is in Dell Optmizer?
So far this is just Windows Balanced power Plan and then under settings > power, for plugged in it is set to “Best Performance”
Genrally found that on more recent versions of windows 11 balanced  power plan has been fine  rather than needing high performance/ ultimate power plans, but I’ll certainly test to see if they make a difference.
These will have a company image on them, no undervolting/
other tuning  just what we can do out of the box that gives us the best balance for our users
we only tend to include dell command update, no optimiser or support assist, been burnt too many times by that hogging resource, I heard they might be combining command update and support assist, I hope the end result it is more like command update if so!
I’ll take a look at the settings in BIOS/ Dell Optimizer see if they make a difference to power usage  far it just seems like the NVIDIA cards have more headroom pier limit wise this laptop looks like being higher power limit  than a desktop RTX PRO 4000 Blackwell. Although a fairer comparison is really the 4500/5000 desktop card as the product stack is still a little different mobile vs desktop.
the other impressive thing is I was working on the laptop unplugged by mistake for a while and it wasn’t until I ran a benchmark test that I noticed the diffeeence, can’t say the same for older gen laptops, still not worked on this laptop for long on battery but a promising sign
the windows power settings for unplugged were balanced rather than best performance
Yeh worth an experiment even though I think dell have got the cpu power balance about right, be good to have choice for users who aren’t needing high GPU power.
You can also adjust this setting in the BIOS if you don't have Dell Optimizer installed. (You just have to reboot in order to access it...) It is independent from the Windows power settings.
I think you may be able to update it from PowerShell as well, using the tools that Dell has to update system settings from PowerShell (for purposes of mass deployment / standardization), but I have not ever tried to do that myself.
I agree, though, in the event of a combo load I would prefer to see it prioritize the GPU.
most of these setting can definitely be changes via powershell,
porb why Dell retired most of the older resource hogging tools,
@AL123 have a looksee here
https://notebooktalk.net/topic/632-dell-precision-7670-dell-precision-7770-owners-thread/?do=findComment&comment=21688
Thanks for your continued review / information! By chance would you be able to check HWInfo64 memory information page for detailed specs on the timings for both the CSODIMMs and CAMM modules? It looks like this:
That is from a non-CSODIMM Kingston Fury kit with tREFI tuned and at 1.25v. With SA Fabric and D2D tuned its around 90ns latency which while far behind a tuned desktop 285K is much better than most stock OEM shipping laptops. Some guys with Lenovo Legion 7i's have also hit close to 80ns as well. In theory a CAMM XMP module could do really well here if they offered single rank Hynix modules with desktop-grade timings.
Sure I forgot about looking at RAM speeds, thanks for the pointers it’s not something I generally look at  in detail as from my tests most of our workloads aren’t that memory sensitive and if they are we tend to have high end platforms like threadripper pro or Epyc for them.
 I don’t have the system with the CAMM module anymore but will look at the CSODIMM model I have when I’m back in next Wednesday.
we will have a few units of Pro Max 18 with a 128GB CAMM2 module in the next week or two also so I can check then if nobody else has one sooner.
Interestingly HP are quoting slower 5600 MT/s SO-DIMM ram over 4 slots on their fury G1i range, so no CSODIMM But claiming up to 192GB at launch and 256GB once 64GB modules are available.
I can’t find anything that shows the speeds if you use all 4 slots last gen IIRC it dropped to 3600 MT/s. HP are also offering ECC ram, no option for that from dell which is odd for a workstation platform, maybe it doesn’t exist for CSODIMM yet, I know it’s also an optional part of the CAMM2 standard but given the low volumes of regular CAMM2 it’s going to take time before we see that I expect
For our first orders we went with 64GB CSODIMM for most users as it was the only option for 64GB at the time of order and far cheaper than 128GB! You can now choose 64GB CAMM2 but it is a bit more expensive.
Worst case I think we could upgrade to 128GB by removing the interposer, however if it is like the last gen the upgrade cost will likely be so high that 96GB CSODIMM would be our first point of call, hopefully 64GB CSODIMM modules will come in future also.
if Dell want more LPCAMM2 and CAMM2 adoption they should do a trade in program for CAMM and offer them refurb as a cheaper upgrade option, having to remove the existing ram is a major downside cost wise and companies don’t want to get involved selling them on eBay etc!
also no excuse for not using LPCAMM2 on the premium range when they used it on the entry level Pro Max 14.
You don’t need to remove the interposer—dual 64 GB cSO-DIMMs can match or even outperform CAMM in sustained real-world performance while running cooler.
The 4-channel CAMM design in laptops is more about marketing than transformative engineering. While it’s theoretically possible, current mobile CPU IMCs and chassis designs aren’t fully realizing that potential.
HX-series CPUs support dual-channel memory configurations, so any “4-channel” claims are achieved through Dell’s trace routing and rank interleaving techniques.
Dell’s omission of 2×64 GB cSO-DIMM configurations from their official specs may be a strategy to promote proprietary CAMM modules. However, laptops with Intel HX CPUs can support up to 192 GB of DDR5; using two 64 GB cSO-DIMMs is well within spec for the CPU and IMC, and many users have successfully implemented it as a cost-effective alternative to CAMM.
Keep your interposer in place and consider this kit:
https://www.crucial.com/memory/ddr5/ct2k64g64c52cs5
Interesting unless 64GB aren’t widely available from multiple suppliers (Dell want atleast 2 suppliers usually SK Hynix and Samsung IIRC) then as you say no reason for Dell to limit to 96GB CSODIMM other than pushing people to CAMM2 for ~ double the price. I don’t even see 48GB CSODIMM on crucial, so not even likely to be availability reasons to pick it given most gaming laptops have 2 slots maximum capacity per module makes more sense,
For larger organisations slight issue with configs  that are not officially supported it can make it more hassle than it’s worth.  with the quick access door it’s quicker for our IT team to upgrade ourselves but we would atleast have to send the original ram with the unit just incase it’s needed for troubleshooting with support.
the weird thing with the 256GB CAMM2 is based on what I’ve been told and spec sheets is it’s actually 2X single channel modules, different interposer so you can’t upgrade from a single 64 or 128GB dual channel CAMM2 module. I guess you can’t have 2x dual channel modules run as
single channel due to
the intel limitation.
it’s a while since I looked at the JEDEC CAMM2 standard to get an idea of what was likely to be in these.
if speeds were higher or it offered ECC  it would make CAMM easier to justify vs cheaper CSODIMM.  I’m sure faster speeds atleast will come but for now it’s a hard sell.
i was hoping this generation would make it simpler but we have No ECC ram from Dell and the confusing CSO-DIMM vs CAMM2. Meanwhile HP are offering slower 5600 MTs so-dimm with 128 GB ECC or 192GB Non ECC at launch and 256GB in future but not sure how much of a performance penalty there is for 4 dimms this generation.
I think for most Dell customers it’s going to be CSODIMM especially the enthusiasts willing to go with third party upgrades for maximum performance for the money.
Hmm just found this nice summary of current CAMM status rather than trawling the standards dock, includes some future plans for LPCAMM DDR6
https://www.jedec.org/sites/default/files/Tom_Schnell_FINAL_ 2024-05-03.pdf
I didn’t measure it but assuming dell went with the shorter 40mm depth Dual channel (DC) module
why not go with the longer 68mm dual channel module ( I think this was in 7780) that shows as scaling to 256GB on a single dual channel module.
Unless the chips at that density aren’t available yet this it makes no sense to me for them to offer two stacked 57mm single channel modules. Unless maybe heat is a
challenge for dual channel 256GB
That would be great if you could test it.
I generally have interest in these workstations as a professional option to Alienware with full Linux compatibility, better build quality and warranty.
