1 hour ago, AL123 said:
why not go with the longer 68mm dual channel module
i believe heat was the issue with the larger modules,
Yeh just seems odd that the engineering to create a 2 slot single Channel stacked arrangement was easier than cooling a single 256GB dual channel module.
it does open up even larger quantities in future but don’t think the market for 128GB is huge let alone 256GB or 512 GB
not to mention most of this is not supported by current and likely next gen mobile CPU IMC's to begin with,
these are "LaLa Land" numbers, by the time these will be a reality this platform will be too old to even get driver updates,
pointless cramming into this particular platform generation imho.
The official specs of the core ultra HX series definitely support 256GB, but sure it will be niche for a while yet.
512GB wouldnt seem to crazy for future with the AI focus especially if these CAMM modules end up on DDR6 desktops atleast they are planning ahead. I think they need speed parity with soldered to really gain ground though.
Dell do seem cautious even on the pro Max tower T2 desktops we use featuring core ultra CPUs they max out at 128GB currently.
On desktops I suspect some of that is to try and push to higher priced workstation platforms but the sapphire rapids Xeons are very poor performance wise.
the Precision 7875 is the only one we will consider and it just got an update to Zen 5 threadripper Pro 9000. it didn’t even get a name update let alone pro max rebrand, maybe Intel bias is still present.
I’m going to test out the base pro max 16 with AMD CPU’s but the graphics cards top out at RTX 1000 Blackwell which is a bit low for most of our users and the RAM is soldered which we try to avoid.
Hopefully see some AMD competition to the core ultra K desktop and core ultra HX based systems next gen Dell workstations
i was looking at Intel® Core™ Processors HX-Series (14th gen) brief specs,
interesting, the Ultra Core for Desktop processor is showing 192GB limit with 2 memory channels only
while the Core Ultra Mobile 285HX is Listing 256GB limit still with 2 memory channels,
CAMM's 4 channel is still in the air outside of Dell's marketing bubble,
until CPU's ship with 4 IMC's CAMM's are pointless atm.
mobile platforms with these processors onboard will never be able to utilize CAMM's 4 channels as the CPU is soldered to the board, since the premises of CAMM is quad channel, the tech currently embedded is moot.
sorry forgot to put a link but officially specs I was looking at are here, I think these may have changed after the launch. pretty sure that happened before when 48GB dimms became available there was a subtle update of the product pages to show and increase from 128 to 192 GB
 https://www.intel.com/content/www/us/en/products/sku/241060/intel-core-ultra-9-processor-285k-36m-cache-up-to-5-70-ghz/specifications.html
https://www.intel.com/content/www/us/en/products/sku/242297/intel-core-ultra-9-processor-285hx-36m-cache-up-to-5-50-ghz/specifications.html
Suspect we will always be limited to dual channel on Intel core CPUs to segment the market/ keep prices reasonable, same for AMD Ryzen as far as I know and intel seem to have abandoned high end desktop CPUs. AMD technically have them with threadripper non pros but cpu and motherboard prices are high.
I hadn’t really seen quad channel as a potential advantage of CAMM.
Until dell shared details of the 256GB option i’d always seen it as a single dual channel card as its primary advantage. saving space vs so-DIMM and an alternative to soldered memory that will allow for higher speeds while being upgradable/ replaceable.
Making it a 2 module system just doesn’t make much sense for me on laptops at least seems needlessly complicated.
to be honest for our use it might be moot anyway, when we get to 256Gb or more for us we are usually looking at massive FEA/CFD simulations where it is more memory bandwidth sensitive anyway. for these Threadripper Pro is our current choice all the memory/ bandwidth you could want! , hoping Intel will come back with something competitive next gen to compete, much as Intel had dominance in data centre and high performance cpu compute for years AMD are so strong current that I worry for Intel now!
Quad channel here is a bit misleading as it's two 32bit subchannels with ddr5 instead of DDR4 which had a single 64bit channel per module.
CAMM's advantage will be better signal integrity over sodimm or csodimm even rivaling udimm. So 256gb might be stable at 5600mt at a given temperature compared to 4x64gb sodimm that may be stable up to 4000mt under the same conditions.
My Pro Max Plus 18 shipped on 24th August from China to Germany - might arrive next week 🙂
RAM is already waiting 2x Kingston CSoDimm 32GB
Dell Pro Max Plus 18 * Ultra 7 265HX * 64GB CSoDIMM * 4TB, 2TB, 2560x1600, iGPU
previous; Dell Precision 7680 * i7 13850hx * 64GB SO-DIMM * 4TB, 2TB, 1920x1200
previous: Dell Precision 7740 * i7 9750h * 48GB * 512GB, 2TB, 4TB * RTX 3000 * 1920x1080
Had to google that as been so long since I read anything about DDR5 standards but sounds like it is still 64bit total per module but split into 2x32bit
Various articles say this should actually be better
https://www.kingston.com/unitedkingdom/en/blog/pc-performance/ddr5-overview
i presume when CAMM is referred to as dual channel it is 4x 32bit sub channels?
What you describe is what I am going for larger capacity but better speed than 4x SO-DIMM so manufacturers don’t tell us soldered is the only option for the future of high performance. Realistically it’s rare we upgrade but ram is one of the most common failures, not sure on soldered ram failure rates vs descrete dimms
44 minutes ago, addabis said:
Is it stated somewhere whether the GPU (RTX5000 specifically) uses 8x or 16x PCIE 5.0?
Curious about this too. @AL123 Can you check? GPU-Z will report this under "bus interface".
On 8/23/2025 at 6:29 PM, win32asmguy said:
Thanks for your continued review / information! By chance would you be able to check HWInfo64 memory information page for detailed specs on the timings for both the CSODIMMs and CAMM modules? It looks like this:
That is from a non-CSODIMM Kingston Fury kit with tREFI tuned and at 1.25v. With SA Fabric and D2D tuned its around 90ns latency which while far behind a tuned desktop 285K is much better than most stock OEM shipping laptops. Some guys with Lenovo Legion 7i's have also hit close to 80ns as well. In theory a CAMM XMP module could do really well here if they offered single rank Hynix modules with desktop-grade timings.
Finally back in the office again image is is for pro max 18 plus with 2 x 64 CSODIMM
Expecting a unit with 128GB CAMM module in 1-2 weeks don’t have the other unit that had 64GB CAMM anymore
I only have Pro Max 18 Plus with RTX PRO 4000 Blackwell currently but screen grab attached. Will have an RTX5000 in the next 1-2 weeks
Looks like x16 but let me know if there is another location to check
I think this is reporting that the GPU supports 16 lanes, but it is only running at 8 lanes (that "@8" at the end). The very low GT/s value would be because at the time that you took this, it was only running at low speed (PCIe1 or PCIe2?) because the GPU was not busy.
This makes sense, I can personally confirm that previous generations (Precision 7560 and 7770 that I have access to) only have 8 lanes for the dGPU. They moved from 16 lanes to 8 lanes at the same time that they moved from PCIe3 to PCIe4.
It wouldn't matter if it is a 4000 or a 5000 card. The limiting factor is the physical DGFF interface and motherboard layout. If Dell only ran 8 lanes for the dGPU, then that's that.
[Edit]
Tried to check if my Precision 7560 reports similarly but the security measures that they have in place now will not allow me to run GPU-Z. 😕
(That's my work system. None of my personal systems are running Windows anymore.)
That is great to see gear 2 on the csodimms. Trfc is also good for jedec timings.
I guess it's the CPU limitation on the number of lanes (24) and the presence of 4 M.2 slots.
ChatGPT even tells me that PCIE 5 is limited to M.2 slots, and the GPU would use PCIE 4 x8. I'm not sure if I can trust that.
Somehow they managed 16-lane for the GPUs in Precision 7750 and earlier. Precision 7750 also had four M.2 slots.
The PCH does allow for some additional (shared-bandwidth) PCIe lanes. In the last few generations of systems, Dell has had one of the four M.2 slots attached directly to the CPU, and the other three routed through the PCH.
(Even though there aren't that many "slots" on the motherboard, there are a multitude of other devices that gobble up PCIe lanes — the Wi-Fi, Ethernet, and WWAN chips, the memory card reader, the sound chip, Thunderbolt ports, ...)
...Not that I really think that them having it limited to 8 lanes is a big deal. The performance impact on the GPU should be minimal. It is hard to push enough data to "need" 16 lanes of PCIe4 speed, and clearly you can keep the GPU busy (100% utilization / max power draw) with this setup. I think it would not be noticed so much in real-world situations but probably appears as a slight dip on GPU-heavy benchmarks.
It depends, I think it could make local usage of some larger MoE LLMs that are not needed in entirety in VRAM all the time, practically viable. But I'm yet to test that it'd be really practical, but it's very tempting. Then, if I need to replace 1-2 GB chunks of VRAM multiple times a second, it matters whether this is 16 GB/s (PCIE 4 8x) or 64 GB/s (PCIE 5 16x).
Regarding "AI", does the advertised NPU card have any expected price? Specs I've found do not look that good (apart from the total memory).
From the exploded view it seems that they’ve cut the flat connectors from 3 to 2, maybe that’s the reason for the lane reduction.
8740w - DreamColor 2 | 920XM | GTX 980M 8GB | 32GB | MX200 mSATA 500GB + 7K1000 | 6300AGN | W10P64 | 350W | MX Master 3s | MX Keys S | ZR30w | Z-5500 | G29 + shifter
8740w - testbed
HDX9000
I loaded up GPU-Z
looks like it is maximum of PCie Gen 5 x8
interestingly when not doing anything it shows x8 1.1 but then when I do something graphical it kicks up to 5
see attached
OK yes, I was thinking more about "graphics" and not so much "AI", but if you have a workload that relies on quickly and repeatedly swapping stuff out in vRAM, you'll certainly notice this more.
At least, according to @AL123's screen shot above, it runs the dGPU at PCIe5. So, you're looking at the bandwidth cut in half, not cut down to a quarter.
Exactly right. From Precision 7750 to 7760, they removed one DGFF connector. They can run 8 lanes through each connector ... but one of the connectors is used power and control stuff, not for PCIe data. So, two connectors = 8 lanes, and three connectors = 16 lanes. Dell dropping one connector corresponded with the transition from PCIe3 to PCIe4, and as PCIe4 is twice as fast as PCIe3, technically they did not cut the dGPU bandwidth by cutting the lanes.
(I think also in consideration is the limited number of PCIe4 lanes off of the CPU at the time, and the limited number of PCIe5 lanes available now. They want to allocate some to both the dGPU and to at least one of the NVMe slots...)
I thought that with the connector revamp this time around, maybe they switched the pinout around and added some lanes back, but that does not appear to be the case.
Hi, I am interested in an Pro Max 16 Plus. Can someone explain how the noise is in comparison to an Precision 7670 or 7680?
The fans on my 7680 are not that loud but the fan management isn't that good. The fans turn often on and off, when the fans turn on the rpm is very high for a short time and that's a loud "whoosh" sound. After the fans have started, they are relatively quiet.
The second question is, does it use a haptic Touchpad?
My Max Pro Plus 18 arrived today and I just completed the SSD switch from my old 7680 - a few driver updates and reboots later I am up and running again.
The Pro Max came with Raid On enabled, had to activate Advanced Settings to find the option to switch to AHCI/NVMe - otherwise my Win11 would not find the boot device.
Screen is amazing.
Works flawlessly with my WD19DC to connect 2 additional displays, USB mouse, keyboard and LAN - no extra power supply needed - guess that would be a different story for those with a dGPU where you might need to switch to the new SD25TB5 to get 280W.
Screen is amazing.
Great yeh just seeing the screen in person was enough to convince me to stick with the largest screen option rather than go for the smaller 16 inch option from my current 17.3 inch screen.
glad it’s working with the wd19dcs dock most I saw was around 100W sustained on the cpu so plenty of headroom. With 175w on descrete GPU definitely better with the new 300W dock but I might try with 1 lead plugged into dock and one to the power supply since all our desks have wd19dcs docks on them currently
Yeah, dock and power supply together should work.
