seanwee Posted March 5, 2022 Share Posted March 5, 2022 Backup of post by Che0063 on forum.notebookreview.com With manufacturers chasing for thin and light systems, we haven’t seen much innovation in battery capacity and soon will have laptops so thin they'll slit our fingers when we touch them. Manufacturers now think that if new hardware is more efficient then the need for a large battery has reduced. In some laptop line-ups, the battery capacity has actually reduced, such as the Aspire E15 series. To get your battery’s capacity in Whrs, multiply the voltage by the amp-hour rating. Your cell count doesn’t matter. E.g. a 11.4v 5.2Ah battery = 59Whrs. On idle and a 0% brightness setting with no programs in the background (just windows desktop), modern & optimised: 13" laptops with 5th gen Intel Y-series CPUs (or later) should idle at around 2W. 15” laptops with 4th gen Intel U/Y series CPUs (or later) should idle at or below 3W. 15” laptops with HQ/HK CPUs should aim for about 6-8W on idle. Far more if you don’t have Optimus. Laptops with full-on desktop CPUs and dual 1080s will have a hard time hitting even 10-15W on idle, I imagine. Don't get them. My 14" Thinkpad E14 Idles at 2.0-2.1W (specs in signature). Check with BatteryInfoViewAll my PCs have been laptops. This guide includes all my experiences with working with laptops and will take some time and may be quite advanced to some users. If you are not comfortable doing something, please research before doing it yourself. Some parts may be risky and (unlikely) cause software issues (Windows failing to boot, iTunes not recognising devices). I will not be responsible for any harm done to your computer. Your mileage may vary, but: I raised my battery life on my Xiaomi from 7hrs to 10+ hrs. Also my Teclast from 5hrs to a comfortable 7-8hrs In 20 minutes of fiddling around with the settings, I raised the battery life of my friends’ Aspire V Nitro from 2-3hrs to 6hrs. I could have increased it more but I didn’t have the time. Premise: Laptop battery life can mostly be split up into two parts: System baseline power usage, and power usage actually dedicated to doing tasks. System baseline power refers to the power your laptop uses when it’s on and doing nothing. This is power used for CPU Idle, display backlight, HDD/SSD idle, and for devices such as RAM just to stay on. Regardless of what you are doing on your laptop, this power remains constant. Depending on your Power usage for processing is mostly affected by your CPU and GPU. This is unavoidable and no amount of software optimization will change how much power a CPU or GPU uses to complete a task. However, it is more efficient for a CPU to quickly boost to its maximum performance state to finish a task quickly, then rapidly drop down to an idle state. This is the system power consumption of my ThinkPad E14 during a PC-Mark 10 Benchmark. I do not have a dedicated GPU on my laptop, so the chart tells you two things: The majority of power is consumed during tasks. The spikes are my CPU boosting to around 4GHz to complete a task, and then dropping down quickly to a baseline idle power.Research Ensure that the display is bright enough. You should look for a display brightness of at least 250 nits. A 300nit screen operating at 50% screen brightness is significantly efficient than a 150nit screen operating at 100% brightness. Ensure that the touchpad/keyboard is good enough. By 2021, all laptops should be using Microsoft Precision touchpad drivers. Avoid using external mice, as they keep the CPU PCH/IO controllers active, along with using extra power. Ensure that the battery life capacity is well over 50Whrs for all-day battery life. DO NOT purchase laptops with G-Sync, unless you can turn it off, otherwise the dedicated GPU must stay on. Don’t expect more than 4 hours with these laptops, even with 99Whr-batteries. DO NOT purchase laptops where the discrete graphics are enabled and bypass the integrated graphics. Your battery will die.Every MILLIWATT counts. External mice keeps your internal USB I/O controller to be active as it waits for an input from the mouse. In 2021, all laptops should be using Microsoft Precision certified touchpads, which are extremely responsive and handle gestures flawlessly. The keyboard backlight should be turned off, unless needed in the dark. They generally use between 0.5W-1W of power, which doesn’t sound like a much, but over the course of an entire discharge cycle, that costs over 1hr of battery life. Avoid port-expansion hubs (E.g. Type C, USB hubs etc) if you can. Some are poorly designed and excessively keep the CPU’s IO controller awake. If the ports of that laptop weren’t enough for you, you shouldn’t have bought that laptop. USB to HDMI converters are an absolute no-no. USB was not designed to carry a video signal, and there will be significant CPU-overhead when used.From basic, to advanced.“Disable unnecessary background tasks, services, apps” blah blah blah No. Actually do it. Pressing X doesn’t help. On a few of my friends’ laptop they had all sorts of things in the background, including Skype, Discord, Steam, Intel HD Graphics Control Panel, Dolby Audio, Adobe Creative Cloud, Nvidia Control Panel, Realtek HD Audio Controller, and worst of all McAfee. All in the background. They were complaining about 2hrs of battery life. Manufacturers boast about 10+ hours of battery life, and then they ruin it themselves by preloading garbage on their devices. Go to Task Manager (Right click taskbar)>Startup. Disable all the things you don’t need. You should be able to disable most of the things here. The world will not end if Adobe Acrobat doesn’t get its update. Gaming launchers such as Steam and Epic Games Launchers are poorly optimized and chew through CPU cycles even when doing nothing. All non-Microsoft services should be disabled, unless you specifically need it. Here is a good way to do so: Win+R, then type in "msconfig" without quotes, then press enter:Warning: DO NOT modify anything you are unsure of. This may render your computer unbootable. Go to the Services tab, then click "Hide all Microsoft Services" Essentially all programs can be disabled, unless you absolutely need it. If your life support depends on Adobe Acrobat downloading an update the instant it comes out, then enable it.Note: This one-click 'solution' entirely disables the services. If you are worried that it may break some things, set it to 'manual' in services.msc Some programs also put pesky startup scripts, which are not viewable in Windows’ Startup Folder. They are hidden in Task Scheduler. To view and disable some of these scripts: Win+R > taskschd.msc > Task Scheduler Library (on the Left side) Most of these check for updates on startup, and depending on your usage patterns they really bog down your startup times.Use UWP programs, where possible. Watching videos? Use the built in Films and TV app in Windows. This video player is far more energy efficient than other alternatives such as VLC. When watching a 720p video, Films and TV used 1.4-1.6W of power, whilst VLC used 2.5-3W (CPU-Package consumption)Disable eye-candy (Skip if in a hurry) Desktop Windows Manager (dwm.exe) renders things related to mouse movements, window movements, animations etc. Disabling effects like shadows will reduce the amount of rendering done by dwm.exe. To do so, go to Control Panel > System and Security > System > Advanced System Settings > Performance Settings and uncheck things you don’t need. Things especially like shadows behind windows and shadows behind mouse pointer are so useless and I never even knew there were such shadows until I discovered this ‘Performance Options’ window. This will result in the dwm.exe service (The process that draws windows) using less CPUHIPM+DIPM+DevSleep (important) Host-Initiated Power Management (HIPM), Device-Initiated Power Management (DIPM), and Device Sleep (DevSleep/DevSlp) are power saving features of almost all modern hard drives. DevSleep is only available on SSDs, and generally puts the SSD into a sleep function than uses >5mW. That being said, your motherboard needs to support DevSleep. By default, Windows only enables Host-Initiated Power Management. To change this: Win+R > Regedit > HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Power\PowerSettings\0012ee47-9041-4b5d-9b77-535fba8b1442\0b2d69d7-a2a1-449c-9680-f91c70521c60 There should be a Description that says ‘Configures the LPM state’, as well as an ‘Attributes’ DWORD with the value 1. Change the value of ‘Attributes’ to "2,” as per this image: Now go to Control Panel > Hardware and Sound > Power Options > Change plan settings (of your active power plan) > Change advanced Power Settings > Hard disk > ACHI Link power Management and set it to Lowest. If that is not an option, change it to HIPM+DIPM. Additionally, in the same subfolder, change the value of "Attributes" to "2" in these folders: d3d55efd-c1ff-424e-9dc3-441be7833010 d639518a-e56d-4345-8af2-b9f32fb26109 dab60367-53fe-4fbc-825e-521d069d2456 And play around with these settings: Try lowering these values (but not to 0ms) and you may see differences in your C7/C8 states. the ACHI Link Power Management especially may be beneficial. My laptop does not have a NVMe drive so changing the nVMe settings do not change anything.As a side effect, on some systems, such as my older Aspire V Nitro and Mi Notebook Pro, enabling DevSleep and DIPM allowed the Package C State to enter C3, using 2.1W of power on idle. Previously it idled at C2, using 2.4W. Modern mobile CPUs should idle at less than 0.5W, however. (Tested on U, Y, and HQ CPUs) More about C states below. EDIT: It seems that more people are benefiting from this than I thought. Give it a try and measure idle power consumption using ThrottleStop.Undervolt (EXTREMELY IMPORTANT) You can reduce the voltage of your CPU, making it use less power. This increases battery runtime and reduces temperatures. There are plenty of guides and explanations out there so have a look if you aren’t familiar. There are no downsides apart from possibly unstable system if you are lazy or stupid. I highly recommend ThrottleStop for Intel CPUs, an extremely lightweight but powerful program made my unclewebb and backed by an equally supportive community. Download here: http://forum.notebookreview.com/threads/the-throttlestop-guide.531329/ I do not have any experience with AMD’s APUs, so I cannot comment if there are similar undervolting software. Extract the files anywhere but your Temp folders, and double click ThrottleStop.exe to start the program. For beginners, this program will be quite intimidating. Tip: Don’t click anything you don’t know about. Search the ThrottleStop thread and your question likely has been answered. In the unlikely event of you mucking up ThrottleStop, delete the ThrottleStop.ini and reboot to reset the settings. For undervolting, all you are interested in is the FIVR button (Fully Integrated Voltage Regulator). Open that up, and you should see something like this. Here, you can go undervolt your Intel CPU. Check ‘Unlock Adjustable Voltage’ and move the slider left to decrease the voltage. Here are the estimates for the average undervolt of your CPU. Results vary heavily depending on your luck. 7th gen U CPUs and earlier: -80mV 8/9th gen U CPUs: -100mV or more 10th gen U CPUs and later: -80mV 6th+ gen HQ/HK CPU: -120mV or more Y CPUs: 50-80mV Ensure the undervolt is the exact same for both your CPU Core and CPU Cache. One some systems if these values are different the undervolt won’t be applied. To check if the undervolt is stable, run a Prime95, LinX, IntelBurnTest, AIDA64 Stress Test or whatever benchmark and see if your laptop crashes. If it doesn’t, keep lowering the voltages until you hit the point where your system is unstable. Then, raise the voltage by a few millivolts to ensure you have a stable undervolt. Now here’s the fun part: Sometimes a voltage will be stable under a CPU stress test, but will crash when opening something simple such as Edge. If this happens, it means your undervolt is not yet stable so you have to raise the voltage. On some systems, you can disable TurboBoost and get an even better undervolt. On my i5-8250U, I can only undervolt -140mV with TurboBoost enabled, but can undervolt to -200mV with TurboBoost disabled. For best results, set ThrottleStop to start on startup. The guide is in the ThrottleStop thread.Enable Speedshift Speedshift is a technology available on 6th+ generation Intel CPUs. Basically it is a newer version of SpeedStep, allowing the CPU itself to control its frequency and power states instead of the OS. This reduces the time required for the CPU to raise its frequency and go back to its idle state, reducing power usage and decreasing latency. Intermittent tasks such as loading webpages can see benefits. On some systems, Speedshift is automatically enabled by the BIOS. But on many, they have to be manually enabled. To enable Speedshift: Go to ThrottleStop, and check the Speed Shift -EPP box. The SST should light up in green. You can choose from a range of 0 to 255, where 0 maximises the CPU frequency at a cost of higher power consumption, but 255 reduced frequency to the point where your laptop may be unbearably slow. 128 is great for a balance, 80 is sufficient for games, and 180 is my value for battery savings. Your mileage may vary.Check/Enable deeper C States [Intel] (VERY IMPORTANT) Once again, this is an issue faced by Intel users. I don’t know if this is experienced by Ryzen mobile APU users. Generally speaking, if you have clean reinstalled Windows (without manufacturer image) you may have this issue. This may be the most effective battery saving tweak in this entire guide if your laptop isn’t configured correctly. Once again, open ThrottleStop and look at the C0% column. Your C0% state in all cores should be less than 1% on idle, if you have been correctly following this guide. If your C0% is below 1%, then check your package power consumption. Is it less than 0.5W? If it is, you may skip this section. If it is above 1W, and you are certain your C0% is below 1%, then you may have an issue many users face on NotebookReview Forums. Now click this button It should say CX (C7, C8, C9, etc) Check that 95% of your cores are in C7. It should be. Now check your Package C State Percent. This is where the problem lies on a lot of notebooks with incorrect drivers Over 80% of your package should be in either C6, C7, or C8 state (maybe perhaps even C10!). Is your package idling in C2 or C3? Then you likely have a problem. I am still not completely sure about what exactly causes the issue, however it is thought that the cause is a generic or outdated disk-related driver. Try updating your disk controller. If you have a SATA based SSD, updating the ACHI controller may work. Some users have reported success by uninstalling Intel Rapid Storage Technology (IRST) or installing IRST and disabling a performance related setting. Some users have reported success by enabling IRST SATA power savings. For me, all I had to do was update the disk controller. Since I have a Samsung NVMe SSD, all I had to do was update the disk driver from a generic Microsoft one. SATA based SSD/HDDs usually benefit from an updated Intel ACHI controller. My current tablet shipped with a generic Chinese SSD - it may have been a faulty one but it prevented the CPU from entering anything lower than C2 Package. The moment I upgraded the SSD, the system power draw dropped from 3.5W immediately to 2.5 watts. That is a huge improvement. That being said, it may also be any other driver. Some members have reported that outdated Realtek Drivers for LAN/Ethernet or Wifi and the card reader was the issue. Try updating any driver from its generic Microsoft one. Alternatively, you can install every driver provided by your manufacturer. They should provide the configuration that allows your CPU to enter a deeper idle C state. Enabling DevSleep and DIPM appears to also work on some systems. On some systems, adding and removing devices (USBs, etc) change C state residency. If all else fails, you could try downloading a driver updater utilityAS A LAST RESORT. Update drivers one by one to isolate the issue. Don't pay for a 'pro' version. After a reboot, your package should idle at C6/C7/C8, depending on your manufacturer and CPU. Essentially, this is a driver issue most of the time. If you, after many months, have not solved the issue, it may be down to a BIOS/EC/hardware fault. Search around if anybody else has the same issue, and if they do, GET IT RETURNED ASAP W/ FULL 100% REFUND. Don't put up with manufacturer garbage. Some users will notice that, after connecting various devices (Thunderbolt/External Display, USB devices etc) your computer will get stuck in C3, instead of C8. If this issue still remains after you disconnect the device, see if a sleep cycle resolves this issue. This is likely a BIOS bug - something that manufacturers unfortunately can never be arsed to fix. Return the laptop, if possible. Don't put up with manufacturer crap. ALL 4th Generation Intel Core CPUs and later should idle at less than 0.5W. Thank you to @ONjA for the following tips: "- In case, your PC is stuck at C2, C3 and 'powercfg -energy' report says there are USB devices without selective suspend - you can force them to use it: either by VID/PID or simply: find 'SelectiveSuspendEnabled' under HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\HID and HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\USB\ subkeys, changing 0 to 1 (or 00 to 01) forces it on. After you forced Selective suspend, check Device Manager and enable "Windows can power down this device" for USB devices. I can even force it for my mouse and it forces mouse off after about of 2 secs of inactivity. I forced it on for problematic devices (touchpad in my case), and can achieve C6/C7 package state now with 0.3W package power. (I7-6700HQ) "Advanced Advanced Power Options (Meh) There are many hidden power options in Windows. These require the Attributes value of each key in Computer\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Power\PowerSettings to be set to 2. After running the script below, you should see a plethora of settings enabled in Advanced Power Options. You should be interested in the processor settings. Each device is unique – one some systems some settings don’t do anything. You should find your optimal value in each setting.Download Script here.https://gist.github.com/Nt-gm79sp/1f8ea2c2869b988e88b4fbc183731693Intel Graphics (relatively important) As terrible as intel integrated graphics are, they use a tiny amount of power. Right Click Desktop > Intel Graphics Settings > PowerEdit: In the UWP version/after Windows 1809: Go to Start, then type in Intel Graphics. And change all the settings to be Maximum Battery. Be sure to enable Display Power Saving Technology and Enhanced Power Saving Mode. Lord knows what that does, but it reduces power consumption of my laptop by 1W by (presumably) reducing LED brightness and reducing contrast. If you are a graphics designer then maybe don’t enable this. Consider enabling panel self-refresh, etc. Enabling Panel Self-Refresh can help, especially when displaying still images.Fan With high end laptops featuring multiple fans, they can use 1W of power even on their lowest speed. Try editing the fan profile of your laptop. This can take hours to find the correct settings, and most people give up. On some laptops it is very difficult. Very few manufacturers allow users to control their fans but recommended third party fan controllers include NoteBook FanControl. I’ve spent over one month reading hundreds of pages of datasheets and still haven’t figured out how to control my right fan. Each laptop is different, and I suggest searching google for the resources or spend hours, days, or even months trying to find the appropriate registers to control your fan. Most laptops don’t need this, but I find that it is completely unnecessary to have a laptop fan running when the CPU is below 45C.Physically disconnect devices you don’t need Did you know you had a second hard drive? Both my friends didn’t. Another one knew, but it stayed empty. If you aren’t regularly using your second hard drive, consider removing it and putting it into an external enclosure instead. According to various datasheets, 5400RPM Hard Drives use 0.5-1W when spinning and idling, but most high end 7200RPM drives use upwards of 1W Disabling the drive in Device Manager won’t work. The HDD might spun down, but the hard drive circuitry will still draw power, between 100-300mW of power. If you have programs on your HDD which you regularly access, having your HDD constantly spin up and down not only wastes power but puts unnecessary strain on your HDD motor. If you use a program frequently, consider moving it onto your SSD as they are more efficient. Once again, disabling a device in Device Manager disables all the device’s features, including any power saving features. It might still be kept on. If you have a secondary solid state drives, you might be tempted to think that it does not drain much power. However, you must ensure that DevSleep is supported BOTH by your SATA interface, AND by your SSD. It must also be enabled as well. Use HW-Info64 to check. Alternatively, use BatteryInfoView to measure your system idle power consumption, both with and without the SSD. The difference should be negligible, because SSDs use <50mV in DevSleep mode.Increase the longevity of your laptop battery. Every time you recharge your battery, you lose a tiny bit of battery capacity. This is an unavoidable effect of using any battery, and most laptop batteries are rated for 300-500 cycles before their full charge capacity drops below 80% of their design capacity. For example, after 500 cycles, a 100Whr battery will only be able to hold 80Whrs. The battery used in your laptop is based on the Lithium-ion chemistry. Tips for extending battery longevity: Do not keep it plugged in 100% all the time. Lithium Ion batteries in laptops are generally charged to 4.2 or even 4.4v per cell to maximise battery runtime. Unfortunately, prolonged exposure to voltages above 4v (about 80%) per cell results in permanent capacity loss. Don’t store your laptop in warm conditions. 20C is ideal, but during operation the inner case temperature of a laptop can reach 35C. This is unavoidable, short of moving to Antarctica or using your laptop in a fridge, but high voltages and high temperatures are the absolute killers of lithium ion batteries. Don’t store your laptop in a car on a hot summer day. Similarly, don’t constantly drain your laptop down to 0% if you can avoid it. Full discharge cycles put strain on the laptop battery. Laptop batteries do not require full cycling. This is actually very damaging to Li-ion batteries. It is better to have very small charge cycles. Aim to keep your battery capacity between 20% and 80%. Physically disconnect your battery if you can. Unfortunately, on increasingly more modern laptops with embedded batteries this is no longer possible, in which case you are out of luck. When not using the laptop, aim to store the battery in a cool environment in a 40% state of charge. This keeps each li-ion cell to a nice 3.7-3.8v. As far as I'm aware, Lenovo and Microsoft are the only mainstream laptop manufacturers to offer a "charge limit" - in Lenovo, this can be changed in the Lenovo Vantage software. TLDR: Keep battery capacity between 20% and 80%. Keep battery cool. Store in a cool place at 40% when not used. Don’t use it if you don’t have to.Antiviruses Depending on your usage of computers, antiviruses may be more of a burden than a help. If you do not need an Antivirus software, don't use one. You do not need a software to be monitoring your every activity and every file you download.Do not: (VERY IMPORTANT, PLEASE READ) Do not disable your dedicated graphics card. When you disable the graphics card, you disable every feature… including Nvidia Optimus or AMD Switchable Graphics. Instead of being completely off and using (theoretically 0W), your GPU will be constantly on but idling and unable to do anything. This consumes an extra 3+ Watts depending on what dGPU you have, which is huge. Some laptops disable Optimus completely, which results in drastically reduced battery life. Don't get those laptops. Do not lock your CPU down to 400MHz, or whatever the lowest operating frequency point of your CPU is. This makes your laptop slow and inefficient.Using powercfg By entering "powercfg -energy" in an elevated (administrator) command prompt, you get a nice report outputted as C:/Windows/system32/energy-report.html This highlights major energy problems that Windows can find. Try solving these issues. Devices can be identified here by entering the device Vendor and device ID.Miscellaneous For users with a dGPU, ensure that any monitoring software (e.g. HWInfo, AIDA, OpenHardwareMonitor, esp. MSI Afterburner) is not waking up your dGPU to poll the sensors. At an idle desktop, your dGPU should read 0.0C temperature. MSI Afterburner, for example, is known to keep the dGPU "awake" and not enter "Optimus", causing drastic battery life losses. MSI Afterburner developers know this and have expressed no intention for solving this issue, stating that MSI AB was never intended to support laptops.Please post your experiences after following this guide including which worked and which didn't, as well as which settings were optimal for your device. I only have 1 primary device to test everything on and it'll be nice to compile a list of the best settings for each tweak for the community. I hope this guide has been helpful. Good luck!Edit: Please DO NOT ask for help without providing screenshots, or at least a list of what you have/haven't tried. It is impossible and unreasonable for anybody on the forum here to be able to help somebody who says "My C state P 2 1 2 ASUS Strix Scar 17 Ryzen 9 7945HX CB R23: 37202 32GB x2 DDR5 6000 CL34 Hynix A-die RTX 4090 Laptop (Shunt modded) Firestrike graphics: 58 334 || Timespy graphics: 27049 || Port Royal: 17013 || Steel Nomad DX12: 6639 Link to comment Share on other sites More sharing options...
Vidben Posted October 27, 2022 Share Posted October 27, 2022 Hi, I actually was looking for the link or the data as well to "[Guide] Improving Battery Life on Windows [+Enabling Deeper C States]" on NBR. I found it was saved to a PDF file by a german website schener-tech.de, here's the link Hope this helps 😁 2 Link to comment Share on other sites More sharing options...
ryan Posted December 8, 2023 Share Posted December 8, 2023 @seanwee I was thinking of making a process minimizing tut for nbt showing people an easy way to get cpu and ram usage down without disabling vital services and apps like windows store and calculator security ect. one thing I will say is ive had a big improvement on my battery life like 45min extra after lowering processes. I went from 260 to 90 with chrome/spotify/battery bar and throttlestop open. just let me know if you can help make one it will attract more people to nbt and add to its library of useful content as that will decide if it survives or not I use this powershell launched app and selct laptop under tweaks tab and apply that irm christitus.com/win | iex then use de crapifier. https://community.spiceworks.com/how_to/148624-how-to-clean-up-a-single-windows-10-machine-image-using-decrapifier tuts on both one click optimization and i would skip the tweaking of OS with ntlite or mstoolkit as processes difference without is like 4 processes so in the end not worth the trouble for rookies. and optional i highly recommend skipping this as if you selct extreme and apply you will ruin your install. but is safe with tweaked and safe settings https://www.sordum.org/8637/easy-service-optimizer-v1-2/ note you can change the xbox services to auto/manual with the settings just goto properties and change it doing those 3 simple one button click tweaks with a copy paste you will drop from 260-down to 70 without ridding anything 2 ZEUS-COMING SOON Omen 16 2021 Zenbook 14 oled Vivobook 15x oled Link to comment Share on other sites More sharing options...
Chalybion Posted January 17, 2024 Share Posted January 17, 2024 This evening, I was troubleshooting an issue with a Dell Precision 7540 with "Total System Power" indicating 25 - 45w, even though the CPU was idling at <2w. One issue appears to be with the NVIDIA driver itself. I downloaded the latest driver directly from NVIDIA as I have previously done. This time, I used nvcleaninstall, and found that the driver, despite selecting the mobile Quadro option, does not include Optimus!!! Helpfully, nvcleaninstall provides an option to download and install the best driver for my hardware, which DID include Optimus. A second issue: When plugged in, the "Total System Power" still increases to 25-35 W. After unplugging the AC adapter, "Total System Power" remains at ~20 W for a minute or so, before finally dropping to a more reasonable ~4W. I haven't troubleshooted this issue yet, but my working hypothesis is the PCIe Link State Power Management, e.g. shutting off power to the graphics card a certain time period after no activity is detected. If that is the case, I wonder if there is a way to force the low power state quicker? Precision 7520 / Xeon E3-1535m v6 / 32 gb DDR4 2666 MHz CL15 / GTX 1650 Mobile / LP156QHG-SP(V1) Precision 7540 / i9-9980HK / 32 gb DDR4 2666 MHz CL15 / RTX 4000 / LP156QHG-SP(V1) / Delta Fans Link to comment Share on other sites More sharing options...
Aaron44126 Posted January 17, 2024 Share Posted January 17, 2024 On 1/17/2024 at 12:10 AM, Chalybion said: This evening, I was troubleshooting an issue with a Dell Precision 7540 with "Total System Power" indicating 25 - 45w, even though the CPU was idling at <2w. One issue appears to be with the NVIDIA driver itself. (Rant time...) Optimus is a wreck. It is a really cool idea for power savings, but it is a kind of tacked-on solution to Windows that I have not found to work well. Specifically, the dGPU frequently does not power off when it should, rendering the solution pointless. Many users have reported issues with it on the Precision line. It is way too easy for the system to get "stuck" with the NVIDIA GPU powered on even when no apps are using it. The tray icon that shows whether the GPU is powered on or off isn't even always reliable and sometimes shows that the dGPU is powered off when it is actually on; you might have to check using the nvidia-smi command line tool, or the NVAPI library. Some easy ways to get the NVIDIA GPU stuck on: Plug in an external monitor that attaches directly to the GPU, and then unplug it to go back to a single display powered by the iGPU. Some processes will be locked to the NVIDIA GPU and keep it powered on. Use fast user switching to activate a second Windows desktop session under a second account. Same thing, some processes will be locked to the NVIDIA GPU and keep it powered on. Run a background application that just doesn't have good "Optimus-awareness" and improperly attaches to the dGPU for tasks that could be handled fine by the iGPU. Examples: Epic Games client, Cygwin X Windows server. Some of these can be "solved" by specifically setting them to use the iGPU in either NVIDIA control panel or Windows graphics settings... but some apps bypass those settings and attach to the dGPU anyway. A possible solution when this happens is to just use Device Manager to disable and then re-enable the NVIDIA GPU, causing the NVIDIA display driver to reset and all apps attached to the dGPU to detach. This seems to kick it back into the correct state so that it will power off. You can script this with a tool like DevManView, which has command line options to enable and disable devices. Linux isn't much better. At least when I tried Ubuntu on the Precision 7770, getting the system configured so that Optimus would even properly shut the dGPU at all took some reading and experimentation, and then it was pretty easy to get it into a state where the dGPU would not power off even though it "should" if certain programs were running. (Doesn't help that many tools that monitor the GPU will cause it to power on, too...) I'm not sure how far it extends; Precisions are the only laptops with NVIDIA GPUs that I have used in recent memory. I have no idea if similar issues occur on systems with AMD dGPUs. I will say that I have much appreciation of my MacBook Pro in this area after 10+ years on the Precision; it reminded me that high-performance laptops can actually be portable without a constant worry over power management — I routinely have it unplugged and powered on for over 12 hours at a time (not in use with the display on the entire time, but never "sleeping") and it usually still has over 50% left on the battery! I wish the PC laptop ecosystem would get this figured out. Apple MacBook Pro 16-inch, 2023 (personal) • Dell Precision 7560 (work) • Full specs in spoiler block below Info posts (Windows) — Turbo boost toggle • The problem with Windows 11 • About Windows 10/11 LTSC Spoiler Apple MacBook Pro 16-inch, 2023 (personal) M2 Max 4 efficiency cores 8 performance cores 38-core Apple GPU 96GB LPDDR5-6400 8TB SSD macOS 15 "Sequoia" 16.2" 3456×2234 120 Hz mini-LED ProMotion display Wi-Fi 6E + Bluetooth 5.3 99.6Wh battery 1080p webcam Fingerprint reader Also — iPhone 12 Pro 512GB, Apple Watch Series 8 Dell Precision 7560 (work) Intel Xeon W-11955M ("Tiger Lake") 8×2.6 GHz base, 5.0 GHz turbo, hyperthreading ("Willow Cove") 64GB DDR4-3200 ECC NVIDIA RTX A2000 4GB Storage: 512GB system drive (Micron 2300) 4TB additional storage (Sabrent Rocket Q4) Windows 11 Enterprise LTSC 2024 15.6" 3940×2160 IPS display Intel Wi-Fi AX210 (Wi-Fi 6E + Bluetooth 5.3) 95Wh battery 720p IR webcam Fingerprint reader Previous Dell Precision 7770, 7530, 7510, M4800, M6700 Dell Latitude E6520 Dell Inspiron 1720, 5150 Dell Latitude CPi Link to comment Share on other sites More sharing options...
Chalybion Posted January 17, 2024 Share Posted January 17, 2024 Yeah, I found a number of post from people with Dell / Lenovo laptops and 20W+ idle power due to Optimus issues. Despite its problems, I find it crazy that NVIDIA publishes a graphics driver for notebooks without Optimus. I'm going to investigate further, but it seems that "Maximum power savings" PCIe Link State Power Management is the only one that will actually turn off the discrete graphics, which is odd. Tinkering can be fun, but it does consume time and require appropriate tools and some knowledge - there's a lot to be said for technology that just works! Apple's vertical integration gives them that advantage over PC OEMs. Precision 7520 / Xeon E3-1535m v6 / 32 gb DDR4 2666 MHz CL15 / GTX 1650 Mobile / LP156QHG-SP(V1) Precision 7540 / i9-9980HK / 32 gb DDR4 2666 MHz CL15 / RTX 4000 / LP156QHG-SP(V1) / Delta Fans Link to comment Share on other sites More sharing options...
Aaron44126 Posted January 17, 2024 Share Posted January 17, 2024 33 minutes ago, Chalybion said: Despite its problems, I find it crazy that NVIDIA publishes a graphics driver for notebooks without Optimus. Same driver but it is pretty easy to accidentally have Optimus not available if you are doing manual mucking in the driver INF file. (I think NVCleanInstall does modifications to the INF but I have not used it myself...?) I found this out when trying to do an "unsupported" GPU upgrade on my Precision M6700, putting in a Quadro M5000M, which requires INF editing; on my first try, the driver installed properly but Optimus simply would not engage and render anything. There are a a few flags that need to be set properly in the INF in order for Optimus to be activate after the install is done (NVSupportMSHybrid, NVSupportOptimus, NVOptimusHCloneDisabled, ...). NVIDIA does not tend to set them for laptop configurations that do dGPU-only output, and they have a separate set of configuration/flags for pretty much every laptop model / dGPU combination. Apple MacBook Pro 16-inch, 2023 (personal) • Dell Precision 7560 (work) • Full specs in spoiler block below Info posts (Windows) — Turbo boost toggle • The problem with Windows 11 • About Windows 10/11 LTSC Spoiler Apple MacBook Pro 16-inch, 2023 (personal) M2 Max 4 efficiency cores 8 performance cores 38-core Apple GPU 96GB LPDDR5-6400 8TB SSD macOS 15 "Sequoia" 16.2" 3456×2234 120 Hz mini-LED ProMotion display Wi-Fi 6E + Bluetooth 5.3 99.6Wh battery 1080p webcam Fingerprint reader Also — iPhone 12 Pro 512GB, Apple Watch Series 8 Dell Precision 7560 (work) Intel Xeon W-11955M ("Tiger Lake") 8×2.6 GHz base, 5.0 GHz turbo, hyperthreading ("Willow Cove") 64GB DDR4-3200 ECC NVIDIA RTX A2000 4GB Storage: 512GB system drive (Micron 2300) 4TB additional storage (Sabrent Rocket Q4) Windows 11 Enterprise LTSC 2024 15.6" 3940×2160 IPS display Intel Wi-Fi AX210 (Wi-Fi 6E + Bluetooth 5.3) 95Wh battery 720p IR webcam Fingerprint reader Previous Dell Precision 7770, 7530, 7510, M4800, M6700 Dell Latitude E6520 Dell Inspiron 1720, 5150 Dell Latitude CPi Link to comment Share on other sites More sharing options...
Chalybion Posted January 17, 2024 Share Posted January 17, 2024 NVCleanInstall provides the option edit the INF through the "enable hardware support" feature; I didn't use it since the card was OEM/supported already. Beyond editing the INF, it also provides the option to install customize which components of the driver package are installed. Normally, Optimus shows up on this list as a separate component from the Display Driver, but here it is missing completely: 1 Precision 7520 / Xeon E3-1535m v6 / 32 gb DDR4 2666 MHz CL15 / GTX 1650 Mobile / LP156QHG-SP(V1) Precision 7540 / i9-9980HK / 32 gb DDR4 2666 MHz CL15 / RTX 4000 / LP156QHG-SP(V1) / Delta Fans Link to comment Share on other sites More sharing options...
1610ftw Posted January 18, 2024 Share Posted January 18, 2024 Interesting discussion and it also leads me to the question as to why Nvidia can't be assed to allow its GPU to perform basic functions without guzzling double digit watts even on battery. It would really be cool to have a tool that allows setting the Nvidia card to minimum power consumption manually when on battery - not because i prefer to do things manually but because Nvidia / Windows cannot be trusted to get this sorted in a proper way. Link to comment Share on other sites More sharing options...
Aaron44126 Posted January 18, 2024 Share Posted January 18, 2024 42 minutes ago, 1610ftw said: Nvidia can't be assed to allow its GPU to perform basic functions without guzzling double digit watts You can force the NVIDIA GPU to the P8 "idle" state using something like NVIDIA Inspector. It still pulls too much power in this state (IMO), especially when it is basically doing nothing while the iGPU drives the display. I'm not aware of a way to force the NVIDIA GPU to fully power off on Windows; I think it stays powered on even if you disable the device in Device Manager. But, on Linux you can unload the NVIDIA kernel modules and then force the NVIDIA GPU to power off with Bumblebee, which does some ACPI magic to make it happen. 1 Apple MacBook Pro 16-inch, 2023 (personal) • Dell Precision 7560 (work) • Full specs in spoiler block below Info posts (Windows) — Turbo boost toggle • The problem with Windows 11 • About Windows 10/11 LTSC Spoiler Apple MacBook Pro 16-inch, 2023 (personal) M2 Max 4 efficiency cores 8 performance cores 38-core Apple GPU 96GB LPDDR5-6400 8TB SSD macOS 15 "Sequoia" 16.2" 3456×2234 120 Hz mini-LED ProMotion display Wi-Fi 6E + Bluetooth 5.3 99.6Wh battery 1080p webcam Fingerprint reader Also — iPhone 12 Pro 512GB, Apple Watch Series 8 Dell Precision 7560 (work) Intel Xeon W-11955M ("Tiger Lake") 8×2.6 GHz base, 5.0 GHz turbo, hyperthreading ("Willow Cove") 64GB DDR4-3200 ECC NVIDIA RTX A2000 4GB Storage: 512GB system drive (Micron 2300) 4TB additional storage (Sabrent Rocket Q4) Windows 11 Enterprise LTSC 2024 15.6" 3940×2160 IPS display Intel Wi-Fi AX210 (Wi-Fi 6E + Bluetooth 5.3) 95Wh battery 720p IR webcam Fingerprint reader Previous Dell Precision 7770, 7530, 7510, M4800, M6700 Dell Latitude E6520 Dell Inspiron 1720, 5150 Dell Latitude CPi Link to comment Share on other sites More sharing options...
1610ftw Posted January 18, 2024 Share Posted January 18, 2024 15 hours ago, Aaron44126 said: You can force the NVIDIA GPU to the P8 "idle" state using something like NVIDIA Inspector. It still pulls too much power in this state (IMO), especially when it is basically doing nothing while the iGPU drives the display. I'm not aware of a way to force the NVIDIA GPU to fully power off on Windows; I think it stays powered on even if you disable the device in Device Manager. But, on Linux you can unload the NVIDIA kernel modules and then force the NVIDIA GPU to power off with Bumblebee, which does some ACPI magic to make it happen. That's interesting, I'll have to try that on a laptop with a working iGPU. But actually I meant that it is not really acceptable that even when performing basic GPU functions an Nvidia GPU has to consume so much more power than an Intel/AMD or Apple solution in order to just show a desktop in idle. Link to comment Share on other sites More sharing options...
raptorddd Posted January 18, 2024 Share Posted January 18, 2024 18 hours ago, Chalybion said: NVCleanInstall provides the option edit the INF through the "enable hardware support" feature; I didn't use it since the card was OEM/supported already. Beyond editing the INF, it also provides the option to install customize which components of the driver package are installed. Normally, Optimus shows up on this list as a separate component from the Display Driver, but here it is missing completely: same for quadro 2000m the one from nvidia doesnt have it.. what i end up was using another driver that had it used nvclean and selected optimus.. 3.77 was the latest on nvidia officially. but i end up using 390. driver with optimus.. what i did was i search using the Hw id. example PCI\VEN_10DE&DEV_0DDA started looking for most recent version and using nvclean i found 390.65 has optimus and its the latest.. in this page i clcik and search for latest https://treexy.com/products/driver-fusion/database/id/pci/ven_10de/dev_0dda/ dell precision m4600 i7 2760QM 8GB ram MX500 crucial SSD 500GB. win 10 21H2 Link to comment Share on other sites More sharing options...
Chalybion Posted January 19, 2024 Share Posted January 19, 2024 OK, I may have a solution... Long ago, I remember a forum poster (NotebookReview, or maybe Reddit?) sharing that the NVIDIA Control Panel is deceiving when it says, "Windows OS now manages selection of the graphics processor." It can actually make a difference to change the preferred graphics processor from "Automatic" to "Integrated Graphics." I changed the setting and monitored for a couple of hours; games still use the NVIDIA card automatically, but idle/web browsing power peaked at ~20W on battery (vs. 50W before), and ~35W plugged in (vs 80W before). Precision 7520 / Xeon E3-1535m v6 / 32 gb DDR4 2666 MHz CL15 / GTX 1650 Mobile / LP156QHG-SP(V1) Precision 7540 / i9-9980HK / 32 gb DDR4 2666 MHz CL15 / RTX 4000 / LP156QHG-SP(V1) / Delta Fans Link to comment Share on other sites More sharing options...
1610ftw Posted January 19, 2024 Share Posted January 19, 2024 5 hours ago, Chalybion said: OK, I may have a solution... Long ago, I remember a forum poster (NotebookReview, or maybe Reddit?) sharing that the NVIDIA Control Panel is deceiving when it says, "Windows OS now manages selection of the graphics processor." It can actually make a difference to change the preferred graphics processor from "Automatic" to "Integrated Graphics." I changed the setting and monitored for a couple of hours; games still use the NVIDIA card automatically, but idle/web browsing power peaked at ~20W on battery (vs. 50W before), and ~35W plugged in (vs 80W before). Yes, that is a good first place to look. And even then it does not always succeed in handing over control to the Intel GPU so one has to check power consumption with something like battery monitor. Link to comment Share on other sites More sharing options...
raptorddd Posted January 19, 2024 Share Posted January 19, 2024 i would like to run amd GPU only but when i only use dGPU some programs closes like windows media player the newest. snipping tool doesnt work and solitaire from microsoft and also the store closes if the dgpu is only selected.. i have to select on control panel to auto select then all of them works. am in an old system maybe it oesnt support it and it closes. dell precision m4600 i7 2760QM 8GB ram MX500 crucial SSD 500GB. win 10 21H2 Link to comment Share on other sites More sharing options...
TheQuentincc Posted August 30, 2024 Share Posted August 30, 2024 On 1/18/2024 at 5:37 PM, Aaron44126 said: You can force the NVIDIA GPU to the P8 "idle" state using something like NVIDIA Inspector. It still pulls too much power in this state (IMO), especially when it is basically doing nothing while the iGPU drives the display. I'm not aware of a way to force the NVIDIA GPU to fully power off on Windows; I think it stays powered on even if you disable the device in Device Manager. But, on Linux you can unload the NVIDIA kernel modules and then force the NVIDIA GPU to power off with Bumblebee, which does some ACPI magic to make it happen. To make the nvidia dGPU power off you need to be pretty strict. I found out the best way to power off the dGPU is to enable the "show dGPU activity icon in the task bar" from the Nvidia panel/desktop menu, this way you can check which program is using the dGPU. Then in both nvidia panel and windows "graphics" settings you can force the program to run with the iGPU instead of the dGPU. If no program is using the dGPU then it goes to "sleep mode" and basically consume no power so you can profit of a great battery life. -> this doesn't work if the video output is directly connected to the dGPU Desktop / I7 14700KF @5.4/4.5GHz 1.25v delidded / MSI Z690 Edge Wifi DDR4 / 32GB DDR4 B-die @4200c16 / RTX 3080 Ti MSI Trio Plus / Triple 27" 4k120 + 2*4k60 XPS 9500 / I7 10750H @3.2GHz all-core / 32GB DDR4 2400MHz / GTX 1650Ti 4GB @50W / 15.6" UHD / NVME / 86Wh Precision 7550 / I9 10885H @4.6GHz all-core / 32GB DDR4 2933MHz / Quadro RTX3000 6GB @80W / 15.6" FHD IPS 500nits / NVME / 95Wh I was once running an overclocked I7 3920XM @4.2GHz all-core (nvram edit) in a Dell Precision M6700 with 32GB 2133MHz DDR3L, a Quadro P4000 and a 4k eDP display (using 3d cable) Link to comment Share on other sites More sharing options...
