lime Posted July 1 Share Posted July 1 Hello once again, After much deliberation I have installed an M4000m, originally out of a HP Zbook, in my 18r1. Nvcleaninstall got drivers working and the GPU was detected in the bios. But the GPU clock is stuck at 405mhz and the reported power draw caps out at 30w. Could this be rectified by using a dell m4000m bios? Thanks in advance. Link to comment Share on other sites More sharing options...
Jerryzago Posted July 3 Share Posted July 3 Is this GPU is similar to 980m? 980m has native support for the 18r1. Why not install drivers and "rebrand" is as an 980m. Maybe the limitations will go away. Also do you run this GPU in PEG or SG mode? 1 Spoiler Alienware M18x R2 | i7 3720qm -> i7 3940XM | Dual 7970m -> 980m SLI -> HP Quadro RTX 3000 Alienware 17 R1 | 4710MQ | 880M GTX -> PNY Quadro RTX 3000 HP 8570w | i7 3820qm | Quadro K2000M HP DV6000 | T72000 -> T9500 Link to comment Share on other sites More sharing options...
lime Posted July 4 Author Share Posted July 4 On 7/3/2025 at 10:07 PM, Jerryzago said: Is this GPU is similar to 980m? 980m has native support for the 18r1. Why not install drivers and "rebrand" is as an 980m. Maybe the limitations will go away. Also do you run this GPU in PEG or SG mode? Has less shaders than the 980m, currently running in SG mode as system didn't post in PEG mode. Currently solved the issue by abusing the sleep bug, which when woken up allows the GPU's power usage double to ~75w. Have some current sense resistors on order, will try to piggyback on top of the existing one and see how I go. Link to comment Share on other sites More sharing options...
sliderfra Posted July 5 Share Posted July 5 you should flash dell vbios for m4000m, as it will enable PEG mode that does not work with HP vbios 1 Link to comment Share on other sites More sharing options...
zerokool Posted August 2 Share Posted August 2 On 7/5/2025 at 3:50 AM, sliderfra said: you should flash dell vbios for m4000m, as it will enable PEG mode that does not work with HP vbios This . When I had a m5000 I had to flash the Dell bios Link to comment Share on other sites More sharing options...
