I recently picked up an HP EliteBook 8570W and was wondering how it holds up today. Is it still a decent laptop for daily use or light workloads in 2025?
Also, what upgrades make the biggest difference more RAM, an SSD, or even GPU/CPU changes? Curious if its worth upgrading or if its better to move on to something newer.
Depends what you have, what you'd like to achieve and how much time, money and effort it's worth.
If the CPU's a dualcore, you could upgrade to quadcore, like i7-3840QM.
Some dualcore 8750w's have 2 x 8Gb DDR3 RAM slots, other dualcores and all quadcores have 4. So you may be limited to 16gb.
M.SATA SSD, like Samsung EVO, can be used as the primary disk.
The stock GPU, K1000M 2Gb, is very modest. But it can be upgraded. That's one place where performance gains can be made.
It's decent system, overall. The chassis is good. But the dualcore model in particular grows long in the teeth when you try to upgrade it.
i got one a while ago. with an i7 3630QM and a firepro M4000. its been a solid machine
i upgraded ram 16GB 1600
popped in a 500GB HDD
and a 128 GB Msata ssd for windows
changed out thermal paste.
i use it daily at school and home and its been a solid machine.
its been a tank. its actaully bent but it still works perfect except for the right side holding thingy for closing the screen doesnt hold the screen. but it works fine with only the left.
My wife is using an HP8570W
CPU is I7 3840QM
GPU is a Quadro K2000M
Changes the 6505 WiFi card to an AC7260
The screen is the top of the range
Still usable to this date.
just seen the post.
Running an 8750W - i7-3940Xm / 32gb@1866mz / 1Tb HDD / 1TB Msata / k1000M GPU.  Been working on GPU upgrades recently with some success (k2000M / failiures (965M). also upgrading heatsink assembly to improve cooling.
would like to upgrade screen to DC
HP EliteBook 8570W is still a solid machine for basic or light daily use in 2025, especially if you picked it up at a good price. It’s built like a tank, has great connectivity, and can handle office work, browsing, and even some light creative tasks.
To get the most out of it, install an SSD — that’s the biggest performance boost you’ll notice right away. Upgrading the RAM (up to 16–32GB) also helps with multitasking. As for the CPU or GPU, it’s usually not worth swapping them out; the gains are small and not cost-effective compared to buying a newer laptop.
