SuperMG Posted November 20, 2025 Posted November 20, 2025 (edited) Hello. I bought 2 Dell precision 7720. One was with a Quadro P3000, working fine, until I put the RTX 4070 MXM. I modded the heatsink (1.2mm copper plate) so it has a good contact with the RTX MXM. The CPU temperature reading are WTF. When the CPU or GPU is doing something, the CPU is pegged at 99-100C. With PTM 7950 and cleaned vents... When I insert back the Quadro P3000 with the modded heatsink, same issue. So I bought another 7720 with M1200. Quadro M1200 and CPU works fine. After, testing the new 7720, I reuse the modified heatsink with the RTX 4070 and I get the same problem, CPU temperature readings from 40c to 99c in an instant... Does random spikes at 70-80c in idle too... Windows 10 and 11 fresh copy. When I remove the MXM GPU, the CPU no longer reaches 99c. It's normal. Is this a heatsink problem or is this an RTX 4070 MXM problem? The RTX 4070 stays cool at idle and no random spikes. Did anyone get this issue before? RESOLVED! Read the thread to know more! Upgrade successful! Edited November 26, 2025 by SuperMG
Chalybion Posted November 20, 2025 Posted November 20, 2025 Since the issue persists with the P3000 reinstalled, the problem is with your modified heat sink - either the CPU is no longer making contact, or the fluid flow/wicking cycle in the heatpipes is blocked. But all three heatpipes would have to be damaged to get 99C immediately, and even then there is some heat transfer by conduction. So my guess is that the CPU is not making good contact - does the PTM 7950 show contact w/ the heatsink after the heatsink is removed? Can you describe the modifications that you made? Precision 7520 / Xeon E3-1535m v6 / 32 gb DDR4 2666 MHz CL15 / GTX 1650 Mobile / LP156QHG-SP(V1) Precision 7540 / i9-9980HK / 32 gb DDR4 2666 MHz CL15 / RTX 4000 / LP156QHG-SP(V1) / Delta Fans
SuperMG Posted November 20, 2025 Author Posted November 20, 2025 35 minutes ago, Chalybion said: Since the issue persists with the P3000 reinstalled, the problem is with your modified heat sink - either the CPU is no longer making contact, or the fluid flow/wicking cycle in the heatpipes is blocked. But all three heatpipes would have to be damaged to get 99C immediately, and even then there is some heat transfer by conduction. So my guess is that the CPU is not making good contact - does the PTM 7950 show contact w/ the heatsink after the heatsink is removed? Can you describe the modifications that you made? Yes it does show contact. My modification is just to add one piece of 4cmx4cmx1.2mm copper plate on the GPU's section. I did the same modification on the newer heatsink, same issue I think? There's good amount of pressure on the CPU, I can't do that far. This happens on two different 7720 laptops. 6920HQ and 7820HQ
Chalybion Posted November 20, 2025 Posted November 20, 2025 That still sounds like a contact problem. The heatsink isn't mounted with much pressure, and all of the pressure comes from the springs around each of the four mounting screws. So if the GPU side is raised by 1.2 mm, then those springs have to push the heatpipes downward by 1.2 mm, and that much less force is applied to the CPU. Is it possible to do away with the GPU copper plate by using thinner thermal pads? Or shim the CPU heatsink an equal amount? Precision 7520 / Xeon E3-1535m v6 / 32 gb DDR4 2666 MHz CL15 / GTX 1650 Mobile / LP156QHG-SP(V1) Precision 7540 / i9-9980HK / 32 gb DDR4 2666 MHz CL15 / RTX 4000 / LP156QHG-SP(V1) / Delta Fans
SuperMG Posted November 20, 2025 Author Posted November 20, 2025 1 hour ago, Chalybion said: That still sounds like a contact problem. The heatsink isn't mounted with much pressure, and all of the pressure comes from the springs around each of the four mounting screws. So if the GPU side is raised by 1.2 mm, then those springs have to push the heatpipes downward by 1.2 mm, and that much less force is applied to the CPU. Is it possible to do away with the GPU copper plate by using thinner thermal pads? Or shim the CPU heatsink an equal amount? I don't know, the CPU doesn't seem hot. I feel the wind on my hand, it's cold. If it doesn't do good contact, how is it possible for the CPU to cool down? Visually with the other heatsink with the copper plate, I see that they're aligned good, like on line between the CPU and GPU parts. Like there's some sort of an elevation gap Let me remove the copper plate on the other heatsink and test it with P3000
SuperMG Posted November 20, 2025 Author Posted November 20, 2025 (edited) I removed the copper plate and used the previous Dell Precision 7720 where the Quadro P3000 and 4070 with the custom heatsink had weird CPU temp spikes issues. I removed the copper and added the M1200 because the P3000 was somewhere else. And now the CPU doesn't act up! It's not doing 40c to 99c. Or doing 99c at 35W! I'll test further more. Edit: no problems with unmodified heatsink (removed copper plate) on both Dell Precisions with P3000 and M1200. Edited November 20, 2025 by SuperMG 1
SuperMG Posted November 21, 2025 Author Posted November 21, 2025 I still get the same issue with the copper plate installed. I installed it correctly before it wasn't installed correctly. I had to cut the plate so it can fit flat. VRAM pads are ok now. Still peaks at 99c when being at 35W I touch the CPU side, it's not even hot, the vents have cold air. The GPU temps don't even go at 99c. Max is like 80c but when at 115W 100%. The GPU temps are like 27-30c idle. No weird spikes on the GPU side. When I insert an USB key, CPU spikes at 99c... I'll try 0.8mm thick and 1mm thick copper plates in 2 weeks. 1.2mm is probably too much. Because I have the NV-A heatsink and it doesn't even touch the "tall" R22 inductor, like there's a 0.2-0.3mm gap "visually". On the NV-B heatsink (old 7720), 0mm gap. Need to cut impossible corner. I want to try undervolting at -100mV but it's locked of course and I have the latest bios. FurMark 1.37: RTX 4070 MXM, 116W max, 79C max, 205 fps AVG 1080p
darnok44 Posted November 21, 2025 Posted November 21, 2025 Hi. Let me get this straight, because maybe I don't get something. It's OK with stock heatsink? But when you add 1.2mm plate on the heatsink in the place of gpu die and you install it cpu temps are mess? I quickly checked how this heatsink looks like and it's two plates basically with shared heatpipes. So if you add at one side/gpu 1.2mm height... I don't see how could you clamp it down on the cpu side? Logically thinking cpu side/ die plate/ has to be raised that same amount - 1.2mm to maintain that same level a flatness of the whole heatsink. If ou added height at gpu side and screwed down heatsink everywhere/ including cpu side/ it had to bend the heatsink (I guess heatpipes itself between gpu and cpu). There is no way that cpu side is sitting flat on the cpu itself. Maybe is touching in some place but surely it's not sitting on the whole die. That's just my guess. Check everything closely again. There has to be something bent. Maybe photo would share some light and give clues. 2
Chalybion Posted November 21, 2025 Posted November 21, 2025 3 hours ago, darnok44 said: Logically thinking cpu side/ die plate/ has to be raised that same amount - 1.2mm to maintain that same level a flatness of the whole heatsink. Exactly this, and need to add thicker thermal pads for the CPU VRM to compensate. 4 hours ago, SuperMG said: I touch the CPU side, it's not even hot, the vents have cold air. The vents are blowing cold air because the heatsink is not contacting the CPU well, so heat is not being transferred to the heatsink 4 hours ago, SuperMG said: FurMark 1.37: RTX 4070 MXM, 116W max, 79C max, 205 fps AVG 1080p Really cool that the 4070 is working! 4 hours ago, SuperMG said: I want to try undervolting at -100mV but it's locked of course and I have the latest bios. The last BIOS which allows undervolting on the 7720 is 1.15.1 The procedure to downgrade BIOS is here, and moderately complicated: https://github.com/vuquangtrong/Dell-PFS-BIOS-Assembler The basic steps are: - Download 1.15.1 and the newest BIOS 1.40.0 - Extract the contents of both BIOSes (this will include packages for the dell BIOS, as well as Intel Management Engine, etc. - Replace the 1.40.0 package with the 1.15.1 package - Recompile the 1.40.0 BIOS - The version check will pass, and the 1.15.1 BIOS will install Also, keep an original version of BIOS 1.40.0 on a USB drive, and learn how to recover from USB just in case the BIOS update goes wrong 1 Precision 7520 / Xeon E3-1535m v6 / 32 gb DDR4 2666 MHz CL15 / GTX 1650 Mobile / LP156QHG-SP(V1) Precision 7540 / i9-9980HK / 32 gb DDR4 2666 MHz CL15 / RTX 4000 / LP156QHG-SP(V1) / Delta Fans
SuperMG Posted November 21, 2025 Author Posted November 21, 2025 5 hours ago, Chalybion said: Exactly this, and need to add thicker thermal pads for the CPU VRM to compensate. The vents are blowing cold air because the heatsink is not contacting the CPU well, so heat is not being transferred to the heatsink Really cool that the 4070 is working! The last BIOS which allows undervolting on the 7720 is 1.15.1 The procedure to downgrade BIOS is here, and moderately complicated: https://github.com/vuquangtrong/Dell-PFS-BIOS-Assembler The basic steps are: - Download 1.15.1 and the newest BIOS 1.40.0 - Extract the contents of both BIOSes (this will include packages for the dell BIOS, as well as Intel Management Engine, etc. - Replace the 1.40.0 package with the 1.15.1 package - Recompile the 1.40.0 BIOS - The version check will pass, and the 1.15.1 BIOS will install Also, keep an original version of BIOS 1.40.0 on a USB drive, and learn how to recover from USB just in case the BIOS update goes wrong Thanks a lot for telling me how to undervolting. I tried without GPU, without copper plate. Only CPU. Managed to get the "famous" 40c to 99c. Screws 3 and 2 at max torque. Screws 1 and 4 at 70%. Even without a copper plate and a x-bracket with the RTX 4070, I managed to get the 40c to 99c on the CPU. I need to cut some aluminium on the heatsink where the R22 inductor is touching. Because this component is taller than the GPU's die and can mess both CPU and GPU temps (because die doesn't touch)
SuperMG Posted November 25, 2025 Author Posted November 25, 2025 Finally the RTX 4070 works fine without any temp issues. Same for the CPU. No more craziness overheating from 40c to 99c. Max temp was 72c and not 100c! Here's a picture on where to cut in order to make your XVSION and ZRT RTX 4050/4060/4070 to work in your Dell Precision 7710 and 7720. I'm thanking X-VSION and ZRT for making such incompatible GPUs in terms of heatsinks! We need to either Dremel for hours or just add a copper plate of 1mm with thermal glue (only for separate heatsinks) DP, HDMI and eDP (using my flex FPC custom cable) are working in PEG mode. USB-C display is not working? (Lacking drivers maybe?) By the way, I did downgrade the BIOS but I still can't manage to undervolt, do I need to edit the UEFI variables using grub? 1
Chalybion Posted November 25, 2025 Posted November 25, 2025 16 minutes ago, SuperMG said: By the way, I did downgrade the BIOS but I still can't manage to undervolt, do I need to edit the UEFI variables using grub? Yes. The relevant variables are in varstoreID 0x1 Setup Disable Overclocking Lock: 0x59c 0x0 On later BIOSes, you can still change the variable, but it will revert back to locked (0x1) on restart Without undervolting, a 7820HQ should use 47W of power at 3.5 gHz all-core; with undervolting it should use ~37W at 3.5 gHz all-core. Both are within the 60W PL1, so clockspeed won't throttle because of power; the only benefit will be 10W of power/heat dissipated. Precision 7520 / Xeon E3-1535m v6 / 32 gb DDR4 2666 MHz CL15 / GTX 1650 Mobile / LP156QHG-SP(V1) Precision 7540 / i9-9980HK / 32 gb DDR4 2666 MHz CL15 / RTX 4000 / LP156QHG-SP(V1) / Delta Fans
Chalybion Posted November 25, 2025 Posted November 25, 2025 If the 6920HQ has the same overclocking features as the 7920HQ, you should be able to run 3.8 gHz on all four cores. With an undervolt, it will probably use 50-55W at that clockspeed Precision 7520 / Xeon E3-1535m v6 / 32 gb DDR4 2666 MHz CL15 / GTX 1650 Mobile / LP156QHG-SP(V1) Precision 7540 / i9-9980HK / 32 gb DDR4 2666 MHz CL15 / RTX 4000 / LP156QHG-SP(V1) / Delta Fans
SuperMG Posted November 26, 2025 Author Posted November 26, 2025 (edited) On 11/25/2025 at 10:53 PM, Chalybion said: If the 6920HQ has the same overclocking features as the 7920HQ, you should be able to run 3.8 gHz on all four cores. With an undervolt, it will probably use 50-55W at that clockspeed Hello. Managed to get 415 in single-thread and 2222 in multi-thread in CPU-Z on the i7 7820HQ with -100mV, max temp 70c no fans kicking on Edit: was able to pull 433 in single-thread and 2260 in multi-thread using -100mV and 3.9GHz all cores. Edited November 28, 2025 by SuperMG
Will Posted November 26, 2025 Posted November 26, 2025 20 hours ago, SuperMG said: Finally the RTX 4070 works fine without any temp issues. Same for the CPU. No more craziness overheating from 40c to 99c. Max temp was 72c and not 100c! Here's a picture on where to cut in order to make your XVSION and ZRT RTX 4050/4060/4070 to work in your Dell Precision 7710 and 7720. I'm thanking X-VSION and ZRT for making such incompatible GPUs in terms of heatsinks! We need to either Dremel for hours or just add a copper plate of 1mm with thermal glue (only for separate heatsinks) DP, HDMI and eDP (using my flex FPC custom cable) are working in PEG mode. USB-C display is not working? (Lacking drivers maybe?) By the way, I did downgrade the BIOS but I still can't manage to undervolt, do I need to edit the UEFI variables using grub? Can you reupload the pictures, please? The links are broken
SuperMG Posted November 26, 2025 Author Posted November 26, 2025 20 hours ago, Will said: Can you reupload the pictures, please? The links are broken https://drive.google.com/file/d/1l13P6GNHi3hWIna5HTG3mWBfl_ebePoW/view?usp=drivesdk https://drive.google.com/file/d/11J6h_73VVxpgkYjJSPEq__wUkjG0siZy/view?usp=drivesdk Also is it normal, when I restart I can no longer undervolt? Also when I downgrade the BIOS, when I restart again, another bios update is happening?! Fix: Enable UEFI Capsule Firmware Updates = OFF in the BIOS. 1
SuperMG Posted November 29, 2025 Author Posted November 29, 2025 (edited) @Chalybion Hello. I got 208 FPS AVG on Furmark 1.37, max 61C!! So yes, everything is cool. CPU undervolt stays, getting good single-thread performance (from 380 to 430 CPU-Z) TimeSpy Normal: 12700 GPU score 3DMark Port Royale: 7260 GPU score Userbenchmark GPU test: 60% and 61.5% (+45MHz overclock) GPU max peak TDP was 118W! Max GPU temp ever recorded was 72C! Is it possible to upgrade the display? I need a new cable since it's 40 pin, what display should I use? Edited November 29, 2025 by SuperMG
Chalybion Posted December 9, 2025 Posted December 9, 2025 On 11/12/2025 at 7:56 AM, Chalybion said: www.panelook.com Screen options are limited for the Precision 7740 screen mounting style (Face U/D Lock on Slug). There are 1920x1080 144 Hz screens that also use a 40 pin connection; most of the other resolution/frequency options are TN instead of IPS On 11/11/2025 at 11:29 AM, Chalybion said: Yes, if you want a UHD screen / 40 pin connector, the compatible webcamera is the IR one, which doesn't fit in the space between the WWAN antenna on the carbon fiber lid. If you don't want a webcam, I think the screen mounting points are the same on both lids. The VBIOS on the card you bought is the best you'll get. No need to download another UHD / 40 pin parts Aluminum back cover: https://www.parts-people.com/index.php?action=item&id=31777 IR Webcam: https://www.parts-people.com/index.php?action=item&id=30446 Bezel: (see eBay) UHD Screen: Dell Part # CK7T7. Below is a list of compatible UHD screen models: Sorry, I haven't had time to research your question above about the 40 pin screen options for the 7720, but check out the posts quoted above from the Precision 7740 subforum. I'm almost certain that Dell used the same screen type for the Precision 7710/7720/7730/7740 (and maybe even the preceding M-series), as well as 17" Alienwares of the same vintage. Theoretically more screen options are possible if you can get mounting brackets. However, I've only seen similar mounting brackets for 14"/15" screens on Ali/eBay. For the 7740 at least, the lid frame extends only partway up the lid, so I really think the screen needs a mounting bracket to keep the top half of the screen from flexing when opening/closing the lid. Precision 7520 / Xeon E3-1535m v6 / 32 gb DDR4 2666 MHz CL15 / GTX 1650 Mobile / LP156QHG-SP(V1) Precision 7540 / i9-9980HK / 32 gb DDR4 2666 MHz CL15 / RTX 4000 / LP156QHG-SP(V1) / Delta Fans
Annihilator Posted February 12 Posted February 12 On 11/25/2025 at 10:01 PM, SuperMG said: Finally the RTX 4070 works fine without any temp issues. Same for the CPU. No more craziness overheating from 40c to 99c. Max temp was 72c and not 100c! Here's a picture on where to cut in order to make your XVSION and ZRT RTX 4050/4060/4070 to work in your Dell Precision 7710 and 7720. I'm thanking X-VSION and ZRT for making such incompatible GPUs in terms of heatsinks! We need to either Dremel for hours or just add a copper plate of 1mm with thermal glue (only for separate heatsinks) DP, HDMI and eDP (using my flex FPC custom cable) are working in PEG mode. USB-C display is not working? (Lacking drivers maybe?) By the way, I did downgrade the BIOS but I still can't manage to undervolt, do I need to edit the UEFI variables using grub? i spoke to cicichen, for 100 bucks he will make a RTX(those with the GPU in the middle of the PCB = 3080, 4080, 4090 etc.) compatible heatsink for the 7720, so when someone want one i think will order one, maybe getting cheaper when he will make some more. Phantom Gaming ITX B550 - 5950X @ 5.3GHz PBO - 2x16GB @ 3800 C14 - 9060 XT 16GB @ 4GHz boost 2850MHz vram - 2TB + 1TB NVMe - 2TB + 2x1TB SATA SSD - Win 11 Pro 7720 - i7-7820HQ - 2x 8GB 2400 C17 - P5200 16GB - Samsung 960 Pro 512GB NVMe - Wifi 6E - Win 11 Pro M6800 - i7-4930MX - 4x4GB 2133 C11 - GTX 880M 8GB(not working atm😒) - Kioxa BG5 1TB mPCIe - 2x Samsung 850 Evo 250GB Raid0 - Wifi AX - Win 11 Pro
SuperMG Posted February 12 Author Posted February 12 Just now, Annihilator said: i spoke to cicichen, for 100 bucks he will make a RTX compatible heatsink for the 7720, so when someone want one i think will order one, maybe getting cheaper when he will make some more. That was for the RTX 4050/4060/4070 MXM type A. This cutting mod won't work on the offset center RTX cards.
Annihilator Posted February 12 Posted February 12 2 minutes ago, SuperMG said: That was for the RTX 4050/4060/4070 MXM type A. This cutting mod won't work on the offset center RTX cards. yep i know, but maybe someone want put in one of those cards with the center placed GPU, then need a new heatsink. Phantom Gaming ITX B550 - 5950X @ 5.3GHz PBO - 2x16GB @ 3800 C14 - 9060 XT 16GB @ 4GHz boost 2850MHz vram - 2TB + 1TB NVMe - 2TB + 2x1TB SATA SSD - Win 11 Pro 7720 - i7-7820HQ - 2x 8GB 2400 C17 - P5200 16GB - Samsung 960 Pro 512GB NVMe - Wifi 6E - Win 11 Pro M6800 - i7-4930MX - 4x4GB 2133 C11 - GTX 880M 8GB(not working atm😒) - Kioxa BG5 1TB mPCIe - 2x Samsung 850 Evo 250GB Raid0 - Wifi AX - Win 11 Pro
SuperMG Posted February 12 Author Posted February 12 Just now, Annihilator said: yep i know, but maybe someone want put in one of those cards with the center placed GPU, then need a new heatsink. Yes they need a newer one and a better one... 4 heatpipes design if possible.
