Hello. I'm the person who made the Turing to Ada MXM cards to work on eDP with a solder-less eDP backlight flex cable mod.
I need your help everyone.
The XVSION 4080M and 4090M have eDP disabled on the VBIOS. Which means, once the drivers are installed, we are greeted with a blackscreen, no signal. The drivers uninstall the PnP drivers and installs a non-PnP one, resulting to an error 43 and a blackscreen, making the GPU not to work natively.
However, this doesn't happen with the X-VSION 4050M, 4060M, 4070M because they have eDP enabled on the VBIOS and once the drivers are installed, it works natively.
Only way to make the 4080M and 4090M to work is to trick the OS and install the laptop's display EDID data after the drivers are initialised from the startup. It's not a native way and requires extra steps.
But... We are also losing DP_A, so the external DP is useless. Only DP_C (HDMI) works for external display.
The 4070M, all the external output of DP_A, DP_B, DP_C are working great.
What we want:
Enable back the eDP on DP_D for the 4080M and 4090M.
Change the display orders to DP/DP/HDMI/eDP (like on the 4050M to 4070M)
I tried to contact Nvidia support for help, but they don't make "VBIOSes". I then asked help from people who sell Frankenstein RTX 4080M/4090M GPUs (X-Vsion used these), I wanted to know who makes the VBIOS and where they source them from. They don't know either?
I saw that ZRT have the perfect VBIOS configuration for the 4080M and 4090M but... They never replied to me about the VBIOS files. I even tried to buy a GPU from them but still nothing. It's silent.
On ZRT's datasheet, I found the VBIOS version numbers from their GPU-Z screenshot but no vBios are available online.
4090M: 95.03.2A.00.1D
4080M: 95.04.3A.00.0E
Xvsion doesn't help either.
So that's why I'm asking for some help. If any of you know who can edit/make signed VBIOSes or if any of you have a ZRT MXM 4080M, 4090M, let me know. I can pay money for the VBIOSes and test them on the X-VSION 4080M/4090M cards.
Thank you.
After trying to get an answer from Xvsion, here's their answer:
"Hello,
4080M and 4090M.
eDP enabled and VBIOS It is fixed and cannot be changed."
"sir,
I consulted my engineer, and it's impossible to do that—it would completely destroy the GPU's PCB.
You're talking about a fairy tale, something that's impossible. Are you kidding"
Do they know what they are saying?
My answer:
Did I mention to remake the PCB? Are you kidding me?
vBios is a file, just edit the file that's inside the sop8 chip and enable the eDP like on the 4050/4060/4070 vBios.
vBios STORES THE DISPLAY DATA!!
DP_A = DP
DP_B = DP
DP_C = HDMI
DP_D = eDP enabled
The person who said to edit the PCB doesn't even know what a vBios is or maybe you made a miscommunication with them, who knows.
vBios edit = file of 2MB containing display outputs data and GPU's
information."
... I told them exactly the issues with days of testing and this is how they "fix" the issue, by saying lies. I'm giving up man, no one cares...
Edit:
"sir,
Cannot change or modify.
Thank you for your understanding."
??? Makes no sense, it's a vBios file that can be edited with the right tools.
Edited by SuperMG
Hi,
Look here, these mac guys managed to edit the display tables on pascal Pxx00 MXM gpus
iMac 2011 Maxwell and Pascal GPU upgrade | Page 21 | MacRumors Forums
I personally tested their p3000 vbios and indeed the eDP is changed from port DP_D (stock vbios) to DP_C (to comply with the iMAC's MXM slot).
I tried getting in contact with M0bil who seems to be the lead modder but no reply unfortunately
He put up some links to this github saying it helped him mod the vbios but not sure how
GitHub - envytools/envytools: Tools for people envious of nvidia's blob driver.
I assume that display table modding should be the same for pascal and newer GPUs so there is hope if these modders tell you how to do it.
The last heardle is that starting from pascal, nvidia vBios have a checksum lock that means vbios needs to be packed in a special way so that the security chip on the nvidia GPU runs the vbios (I tried manually editing power limits on a vbios and the p3000 and it wouldn't even post, even with 2 bytes being changed).
Precision 7720 : i7-6820HQ -80mv & 102.7mhz BCLK| Zotac GTX1060 6gb, 100w OC vbios | 16gb DDR4 2666Mhz | (crappy) FHD ips -> 1440p165hz upgraded
25 minutes ago, JadeRover said:
Hi,
Hello.
Above Pascal, no editors work, need a signed vbios or it won't work too...
Only hope is to find someone WHO HAS BOUGHT the ZRT 4080 and 4090, but who? Xvsion doesn't really care and that's very concerning, they do a bad job for their "customer care service" or whatever it's called...
Do you know any pascal editors ?
For the display table definition it is pretty much universal for nvidia, these guys know how to do it. They used a hex editor, they talk about it in the forum posts.
But did they find a way to edit Ada Lovelace VBIOS display tables? And apply the right checksum? If you could contact one of them and compare both 4070 MXM VBIOS and 4080M VBIOS for example, it would be good for us!
I don't understand why X-VSION don't help their customers, do they want a bad review?
How do they get the VBIOS if it's not them? Are they magically appearing? There should be a company or someone who makes VBIOSes... Nvidia support say that they don't know who makes VBIOSes... I proposed to X-VSION and Nvidia some good amount of money for a vBios edit but no...
The 4080 and 4090 have a major problem and they should fix it, not us.
About ZRT, still no reply as usual, I use new email addresses just to buy from them but they don't answer (1 month ago, 3 weeks ago, 2 weeks ago).
I don't give up now, I'll beg more and more just to buy a GPU from ZRT and extract the VBIOS, test the card and then send them back the card.
If someone got in contact with ZRT successfully, please buy the 4080 or 4090 and extract the VBIOS. I can pay 100% of the shipping return fees so you won't lose money. I don't know if that's a good alternative idea to obtain the VBIOS.
Hello some news.
Someone called Moonshine got in contact with ZRT finally thru Blibli.
ZRT said they can't "sell or give VBIOS files", they only do "Graphics cards" sale.
So the only way is to buy their card and extract the VBIOS. If someone has the ZRT 4080 or 4090 MXM, please upload your VBIOS on techpowerup using GPU-Z.
News about X-VSION, the representative isn't helping and now is making joke about "K***ing h*mself" because they don't want to update the VBIOS to support DP/DP/HDMI/eDP(enabled)... The reason is... "I'll lose warranty and it's not compatible with my eDP laptop". Makes no sense whatsoever. They aren't professional when there's a major problem on their 4080 and 4090 VBIOS. Blackscreen after installing the drivers and you need to do EDID manipulation for it...
Still the X-VSION person didn't answer me why they didn't keep the same display tables as the 4050/4060/4070 from them? But ZRT did...
Also one another Manufacturer is selling RTX MXM cards with "eDP VBIOS", did somebody bought from them or is in contact with them? https://enbik.com/products/enbik-mxm-gpu-module-nvidia-rtx4090-16gb-130w/
That's it for today...
On 12/11/2025 at 10:49 AM, SuperMG said:
Hello some news.
just checked the specs, the 4080 isnt faster then the 3080, slightly less mem bandwith + lower clock speeds ending up in a tie between both cards. so when i want no mess n just plug n play i should take the 3080(lil benefit on top: 180 bucks cheaper then the 4080)
Phantom Gaming ITX B550 - 5950X @ 5.3GHz PBO - 2x16GB @ 3700 C14 - 9070 XT 16GB - 2TB + 1TB NVMe - 2TB + 2x1TB SATA SSD - Win 11 Pro
4080 is better, newer architecture, beats 3080 by a margin, lower nanometers, DLSS 4, etc.
Or get the 4090. It's ZRT not X-VSION. X-vsion is bad for 4080 and 4090 because of the VBIOS! I had a 3080 X-VSION, no issues when installing the drivers but the 4080 is faster, pulls more frames on furmark and heaven, don't have the pictures with me
DLSS 4 already works on 3000 series, so no benifit for that. think biggest gain would be that same performance with 30W less TDP. but first will finish the M6800 anyway, may put an RTX in there n the P5200 in the 7720 then... still not sure 😄
Just get RTX 4080/4090, easy (I need their Vbios) I tested RTX Ada and my backlight mod on over a few pc and only the M6700 didn't work... Could be an issue with the motherboard since it shares LVDS lines too... You can search online for benchmarks.
I am making a v2 of the backlight cable mod, I dropped the price of the v1.
