MrKoli Posted March 1 Posted March 1 Hello everyone, I just registered and I hope I'm posting in the right section. I'm having an issue with my notebook and I'm hoping someone more experienced can point me in the right direction. The Problem: When I press the power button, the notebook turns on. The fans start spinning slowly for a few seconds, then suddenly ramp up to maximum speed and keep running at full throttle. The screen stays black (no image, not even the boot logo) and it never reaches the BIOS. I've also noticed that both the CPU and the RTX GPU remain cold, as if they aren't receiving power or the system isn't actually starting the Power-On Self-Test (POST). It gives the impression that the system "starts" but gets stuck immediately after. System Details: · Model: Clevo P775TM1-G (or P775TM1) · Serial Number (S/N): 1 TP775TM9440274 TPM · Part Number (P/N): 6-77-P775TM1A-NO2#20 · Processor: Intel Core i9 (9900K) · RAM: 64 GB · Graphics Card: NVIDIA RTX 2060 · MAC Address: 80FA5B765D7D What I've already considered: From the research I've done, I've seen that these chassis often require updated or modified BIOS versions (like the "dsanke mods" mentioned on some forums) to ensure full compatibility with i9 CPUs and RTX graphics cards. I've read that without proper BIOS support, the motherboard might not correctly recognize the hardware, leading to symptoms similar to mine (fans at max speed and black screen). My Request: Does anyone have a valid link for the BIOS (and maybe also the EC firmware) for this model? Possibly an unlocked or modified version that supports the i9-9900K and RTX 2060? Unfortunately, many links I've found in old discussions are dead. If anyone has experienced the same problem and solved it, any guidance on how to proceed (flashing procedure, stable version, etc.) would be incredibly valuable. I know that flashing is a delicate operation, but at the moment the notebook is unusable, and I need to try this path. Thank you very much in advance for any help!
Eban Posted March 1 Posted March 1 Hello, welcome. Sorry Im not sure from your description. Is the laptop new to you or an old one that suddenly died? What diagnostics have you tried? Clear cmos? Strip the board down. Remove ssd, mxm card, wifi, memory. Try to boot. Thunderchild // Lenovo Legion Y740 17" i7-9750H rtx2080maxQ win10LTSC RainBird // Alienware 17 (Ranger) i7-4910mq gtx860m win8.1 JunkDog // Desktop Asrock 660M i3-12100F ARC A580 win10LTSC
SuperMG Posted March 3 Posted March 3 (edited) Hello. Mine has an issue too. I had the RTX 4080 working on it, I removed it. Then days later I put a P5200 and 980M both didn't even work. GPUs COLD. I tested the GPUs on two different laptops and they work. Funny thing is that the pc boots to Windows without any display (Windows start-up sound), also no DP and HDMI out. So the bios isn't corrupted. I tried to hold the power button for 30s too. I don't know if that's sufficient to reset the CMOS. What should I do? Edit: ok 4080 and P3000 work (eDP and UEFI VBIOS) P5200: not work (eDP non-UEFI VBIOS) 980M: not work (no eDP out and UEFI VBIOS). So it seems like the BIOS checks those, if the results are false then the GPU doesn't get powered, so a black screen with no outputs. Edited March 3 by SuperMG
Eban Posted March 7 Posted March 7 On 3/3/2026 at 11:22 AM, SuperMG said: I tried to hold the power button for 30s too. I don't know if that's sufficient to reset the CMOS. Holding the power button down with no internal battery just drains any remaining electrical energy from the capacitors. It won't reset anything. Thunderchild // Lenovo Legion Y740 17" i7-9750H rtx2080maxQ win10LTSC RainBird // Alienware 17 (Ranger) i7-4910mq gtx860m win8.1 JunkDog // Desktop Asrock 660M i3-12100F ARC A580 win10LTSC
