SuperMG Posted 2 hours ago Posted 2 hours ago Hello. I installed the RTX 4080 MXM on this laptop. It displays but the GPU temps are stuck at 40C in the ClevoFanControl and in the central center. However the GPU temps are working in GPU-Z and on the windows built-in temperature readings. For example it says 60C on Windows and the 2 softwares are stuck at 40C still. I tested a Quadro P3000 and the temps are working and not stuck at 40C with the 2 softwares. I remember the 4080 worked on the P870, the temperatures weren't stuck at 40C. The same card works in the Dell Precision M6800 without any temps issues. I would pay someone 40€ if they can modify this open source project to support Windows built-in GPU temperature reading or using GPU-Z GPU temperature readings. It's called ClevoFanControl and it's on GitHub, it's written in C# by djsubtronic
