As of a few hours ago, it appears that the custom air RTX3080 heatsink for P775TM1 is no longer available - only the air/water version is now available: https://www.aliexpress.com/i/1005007688521117.html
Well, it was overpriced anyway. I am waiting for a RTX3080 to arrive within the following days, so I am exploring alternative options.
Are there any measurements-detailed instructions on how to modify the current 31-P77FN-401 heatsink (i.e. by drilling)? Any other options for heatsink mounting? How bad is it if I do not use any screws on the GPU side? If anyone knows of a modified 31-P77FN-401 heatsink that is compatible with RTX3080 and is available for sale within the EU please keep me informed.
  • harkaz changed the title to P775TM1 RTX3080 Chinese Air Heatsinks out of stock - examining alternative options
18 hours ago, SuperMG said:
I found high quality max pro plus heatsink for RTX 4090 and 9900K/KS.
Is this compatible with RTX3080 though? I prefer using the Clevo MXM. The RTX4090 is from XVision I assume. Are you referring to taobao seller? (I am unable to buy from there).
18 hours ago, Selim1905 said:
I know someone who can do this.Bana
Can you elaborate?
The RTX 4090 is way faster than the RTX 3080 165W.
4090 supports G-SYNC on my 1080p 120Hz IPS display. Supports 1 x DP output and 1 x HDMI output. Supports eDP with the backlight mod v2.
The heatsink will be watercooled with more heatpipes (like on the AliExpress 2 in 1 heatsink but better) and it'll be compatible with RTX 40XX. And I'll of course get the powerful fan for the CPU side.
Can handle 9900KS stock. Stock CPU heatsink I have is the small one, 3 heatpipes one, throttles at 155W.
I had that Chinese contact build a heatsink for the Alienware m18x and the P870TM. You can reach out to them via eBay messages. There is already an RTX 3080 heatsink available on Amazon for the P870TM; they manufactured five units based on my request. My order is currently on its way, and I will test it once it arrives.
Contact Cicichen, best heatsinks for Dell Precision M6800 and M17X R4. No thermal throttles. All 2 in 1 = GTX 9XXM support and RTX 40XX support.
He also made a P775 single GPU heatsink for standard MXM and RTX 40XX one. High quality heatpipes and pure copper plate... No thermal throttle, got max 20100 TimeSpy graphics score with an RTX 4090 MXM.
He's making me a better heatsink than the AliExpress one for the P775 watercooling + RTX 40XX support! I paid a lot of money because I don't want thermal throttle on the CPU anymore. I want a full 5GHz all core performance. I'll also tell him to purchase me the P775 performance fans if he can find them locally.
Ive contacted him, i know his account is old and trustworthy, but you did as he want Paying him trhu paypal and he sent you the heatsink?!
1 hour ago, SOYOON said:
Onunla iletişime geçtim, hesabının eski ve güvenilir olduğunu biliyorum, ama onun istediğini yaptın, ona PayPal üzerinden ödeme yaptın ve o da sana soğutucu gönderdi mi?!
They opened an account on Amazon because of an issue with their eBay account, and I bought the product from there. They are a trustworthy person and a long-time eBay seller.
Cicichen? When did you buy it? Proof of Cicichen's account having a problem? Because I'm in transaction with them at the moment...
I don't know the reason why product availability was limited on eBay; he told me he would open an Amazon account, and that is exactly what he did. So, I placed my order through amazon.us. At my request, he manufactured five units of the RTX 3080 cooler for the P870TM.
Does his ebay chat still work? Or not. How do you communicate with them?
eBay chat is working no problem.I was talk on eBay
4 hours ago, Selim1905 said:
Today I try the heatsink it's work very good. I don't have time for detailing test.
Could you please insert a photo for thermals from GPUZ ?
The vapor chamber heatsink with the adapters was great for cooling but rtx 3080 with new nvidia drivers at 150w don’t need it …
In addition, whenever I need to access the CPU to replace the thermal paste, change the thermal pads, or replace the CPU itself, I have to remove the vapor chamber heatsink first. This has become very inconvenient, time-consuming, and completely unnecessary.
Hello. Cicichen ebay's chat work but it's been 6 days he isn't answering to me!
I have no idea what's happening with the new watercooling powerful heatsink + RTX 40XX compatibility I ordered. I hope he bought the powerful P775 fan I told him to order. So the heatsink could handle easily 220W+ till thermal throttling.
Ampere cards have a bad idle in terms of power. I get 18-20W with X-VSION and Clevo cards from that era. However Turing and Ada are sitting at 3-5W! Very efficient.
These are the test results. The maximum values recorded here were obtained with the fans running in automatic mode; with the fans set manually to maximum speed, the temperature did not exceed 72°C. The thermal pads I used aren't top-tier; I used mid-quality pads I had on hand for testing purposes. Temperatures could be improved further with better thermal pads and the necessary software fine-tuning. In my opinion, the cooler performs very well.
