SOYOON Posted August 31 Posted August 31 I successfully shunt modded an rtx 2070 to 153w by mounting 4x r015 resistors, and I used 1206 resistors sideways just to prove a point🤣 It resulted in 1920mhz constant and 2010-2050mhz peak in most games Gained 10 to 30fps in games Playing cyberpunk maxed out rt psycho at 35fps I payed 20usd for a Smd solder pro at a videogame repair store to do it, the Chad lady did it flawlessly lol The gpu can easily sustain +160mhz in cyberpunk and even 170(it crashes after 1 hour or 30min...or15) but 160 is stable and 155 is stable for fire strike
kela-slk Posted September 2 Posted September 2 On 8/31/2026 at 10:20 AM, SOYOON said: I successfully shunt modded an rtx 2070 to 153w by mounting 4x r015 resistors, and I used 1206 resistors sideways just to prove a point🤣 It resulted in 1920mhz constant and 2010-2050mhz peak in most games Gained 10 to 30fps in games Playing cyberpunk maxed out rt psycho at 35fps I payed 20usd for a Smd solder pro at a videogame repair store to do it, the Chad lady did it flawlessly lol The gpu can easily sustain +160mhz in cyberpunk and even 170(it crashes after 1 hour or 30min...or15) but 160 is stable and 155 is stable for fire strike great work, but low data - needs benchmarks and compare results with stock oem.Â
SOYOON Posted September 3 Author Posted September 3 Well all i have is two cyberpunk runs one before and other after On 9/2/2026 at 2:55 AM, kela-slk said: great work, but low data - needs benchmarks and compare results with stock oem. Â
