panda_zzz Posted March 21, 2025 Posted March 21, 2025 13 hours ago, ssj92 said: My m15x has 980M with latest driver. so i'm running the latest 460 driver available for windows 7 i think or something like that. but windows 10 is having problems. Both drivers have been modified by NVCleanstall.
SuperMG Posted March 23, 2025 Posted March 23, 2025 @panda_zzz Hello. I got the P5200 work on the Clevo X7200 as the slave GPU. Temps monitoring all works but the performance isn't good. Because the master GPU is a Fermi based GTX 485M... And there are no drivers that's shared between Fermi and Pascal. I just installed inf drivers for the p5200 then installed the 485M one. Because I need to install the master's drivers or nothing would work. Now Nvidia Panel states the version I'm running is the 391 lol I tried to run the HD 5870 as the master but it keeps dying at the first minute of the boot (Windows and DOS)... And the HD 5870 is from the clevo WU860. I tested the HD 5870 with and without the slave GPU, still the same shutdown issue.
SuperMG Posted March 23, 2025 Posted March 23, 2025 @ssj92Hello. How did you manage to make the GTX 980M + RTX 5000 combo work together with the drivers? Can the RTX 5000 render in DirectX 11/12?
SuperMG Posted March 23, 2025 Posted March 23, 2025 On 3/18/2025 at 3:51 AM, ssj92 said: Yes with 880M + RTX 5000 and M2000M + RTX 5000. not all cards work. GTX 1080 causes restart loop. 3080 causes laptop to freeze at Alienware logo. 980M also causes freeze at AW logo. How do you make them work without losing any performance and use DirectX on the slave card? I use 485M and 680M + P5200 and I get crappy performance. I'm at full PCIE speed too.
ssj92 Posted March 23, 2025 Author Posted March 23, 2025 2 hours ago, SuperMG3 said: How do you make them work without losing any performance and use DirectX on the slave card? I use 485M and 680M + P5200 and I get crappy performance. I'm at full PCIE speed too. 880M + RTX 5000 was using older drivers that had both kepler and turing M2000M + RTX 5000 are both supported in latest drivers so I can use one driver for both (2 INF mods). I can use every feature of RTX 5000 even DX12, ray tracing, dlss, etc. In PEG mode. Alienware Area-51 18 : Intel Core Ultra 9 275HX @ ??? | nVidia GeForce RTX 5090 | BE200 | 1TB Gen5 9100 PRO Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080 | AX210 | Samsung 970 Evo+ Alienware M18x R2 : Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080 | AX210 | Samsung 980 PRO Alienware 18 : Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000 | AX210 | Samsung 980 NVMe More Laps: M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000) | M17xR3 (WX 7100) | M18xR1 (RTX 5000) BEAST Server: Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYT
SuperMG Posted March 23, 2025 Posted March 23, 2025 29 minutes ago, ssj92 said: 880M + RTX 5000 was using older drivers that had both kepler and turing M2000M + RTX 5000 are both supported in latest drivers so I can use one driver for both (2 INF mods). I can use every feature of RTX 5000 even DX12, ray tracing, dlss, etc. In PEG mode. No registry mods? Can I do K3000M + P5200? 427.68?
ssj92 Posted March 23, 2025 Author Posted March 23, 2025 13 minutes ago, SuperMG3 said: No registry mods? Can I do K3000M + P5200? 427.68? Just the registry mode for "high performance" and "power saving" gpu that I wrote in the rtx 5000 post in m18x thread On 3/21/2025 at 1:19 PM, panda_zzz said: so i'm running the latest 460 driver available for windows 7 i think or something like that. but windows 10 is having problems. Both drivers have been modified by NVCleanstall. I'm on 551.xx driver on Win10 Alienware Area-51 18 : Intel Core Ultra 9 275HX @ ??? | nVidia GeForce RTX 5090 | BE200 | 1TB Gen5 9100 PRO Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080 | AX210 | Samsung 970 Evo+ Alienware M18x R2 : Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080 | AX210 | Samsung 980 PRO Alienware 18 : Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000 | AX210 | Samsung 980 NVMe More Laps: M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000) | M17xR3 (WX 7100) | M18xR1 (RTX 5000) BEAST Server: Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYT
SuperMG Posted March 23, 2025 Posted March 23, 2025 14 minutes ago, ssj92 said: Just the registry mode for "high performance" and "power saving" gpu that I wrote in the rtx 5000 post in m18x thread I'm on 551.xx driver on Win10 Did you try on your M18X R1 AMD + RTX 5000?
SuperMG Posted March 24, 2025 Posted March 24, 2025 (edited) 16 hours ago, ssj92 said: Just the registry mode for "high performance" and "power saving" gpu that I wrote in the rtx 5000 post in m18x thread Hi. I saw your video about installing unsupported notebook GPUs on desktop drivers. You had the GK104 GTX 880M. Can I install the newest quadro driver that's supported by GK104 chip? (k3000m, k4000m, k5000m, k4200) ? Drivers for K3000M are from 2019 but the desktop one is from 2023. Edited March 24, 2025 by SuperMG3
ssj92 Posted March 26, 2025 Author Posted March 26, 2025 On 3/23/2025 at 4:41 PM, SuperMG3 said: Did you try on your M18X R1 AMD + RTX 5000? Not yet, I’m trying this on M17xR2 first. and yes you can use desktop Kepler driver for mobile. I normally use GTX 770 for 880M Alienware Area-51 18 : Intel Core Ultra 9 275HX @ ??? | nVidia GeForce RTX 5090 | BE200 | 1TB Gen5 9100 PRO Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080 | AX210 | Samsung 970 Evo+ Alienware M18x R2 : Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080 | AX210 | Samsung 980 PRO Alienware 18 : Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000 | AX210 | Samsung 980 NVMe More Laps: M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000) | M17xR3 (WX 7100) | M18xR1 (RTX 5000) BEAST Server: Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYT
SuperMG Posted March 26, 2025 Posted March 26, 2025 13 hours ago, ssj92 said: Not yet, I’m trying this on M17xR2 first. and yes you can use desktop Kepler driver for mobile. I normally use GTX 770 for 880M Hello. I see that GK104 576 CUDA doesn't have a desktop part. But there are many GK104 with 900-1300 CUDAs, would that work for the K3000M?
ssj92 Posted March 26, 2025 Author Posted March 26, 2025 3 hours ago, SuperMG3 said: Hello. I see that GK104 576 CUDA doesn't have a desktop part. But there are many GK104 with 900-1300 CUDAs, would that work for the K3000M? As long as the chipset is the same (gk104) then it should work Alienware Area-51 18 : Intel Core Ultra 9 275HX @ ??? | nVidia GeForce RTX 5090 | BE200 | 1TB Gen5 9100 PRO Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080 | AX210 | Samsung 970 Evo+ Alienware M18x R2 : Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080 | AX210 | Samsung 980 PRO Alienware 18 : Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000 | AX210 | Samsung 980 NVMe More Laps: M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000) | M17xR3 (WX 7100) | M18xR1 (RTX 5000) BEAST Server: Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYT
SuperMG Posted March 26, 2025 Posted March 26, 2025 2 hours ago, ssj92 said: As long as the chipset is the same (gk104) then it should work Okay. I did inf mod a GTX 680M for quadro drivers but meh. If I wanna use recent quadro drivers then that won't work great so that's where the K3000M comes handy. Also is it better having a K3000M or HD 6990M in master and P5200 in slave?
SuperMG Posted March 26, 2025 Posted March 26, 2025 5 hours ago, ssj92 said: As long as the chipset is the same (gk104) then it should work Because on 3dmark I'm getting 3400. While the other person was getting 5700. We both have the same PCIE speed (x16 2.0). He's only using one GPU because of one MXM slot and he also uses a newer driver.
SuperMG Posted March 27, 2025 Posted March 27, 2025 2 hours ago, SuperMG3 said: Because on 3dmark I'm getting 3400. While the other person was getting 5700. We both have the same PCIE speed (x16 2.0). He's only using one GPU because of one MXM slot and he also uses a newer driver. Do I need more power on my power supply? I have a 300W PSU. With 100W GTX 680M + "100W" P5200 (Max measured at 79W) and 80-130W Xeon E6520. I then set high performance on the bios for the Power savings mode and the laptop SHUTDOWN INSTANTLY when booting windows... K3000M is a 75W card HD 6990M is a 100W card. So I need to inf mod TWO hardware IDs to get them both (K3000m and P5200) working on the recent drivers? We can't add more than 2 hardware IDs on NVCleanInstall...
ssj92 Posted March 27, 2025 Author Posted March 27, 2025 4 hours ago, SuperMG3 said: Do I need more power on my power supply? I have a 300W PSU. With 100W GTX 680M + "100W" P5200 (Max measured at 79W) and 80-130W Xeon E6520. I then set high performance on the bios for the Power savings mode and the laptop SHUTDOWN INSTANTLY when booting windows... K3000M is a 75W card HD 6990M is a 100W card. So I need to inf mod TWO hardware IDs to get them both (K3000m and P5200) working on the recent drivers? We can't add more than 2 hardware IDs on NVCleanInstall... Laptop shutting down at windows boot tells me something is overheating Alienware Area-51 18 : Intel Core Ultra 9 275HX @ ??? | nVidia GeForce RTX 5090 | BE200 | 1TB Gen5 9100 PRO Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080 | AX210 | Samsung 970 Evo+ Alienware M18x R2 : Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080 | AX210 | Samsung 980 PRO Alienware 18 : Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000 | AX210 | Samsung 980 NVMe More Laps: M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000) | M17xR3 (WX 7100) | M18xR1 (RTX 5000) BEAST Server: Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYT
SuperMG Posted March 27, 2025 Posted March 27, 2025 (edited) 2 hours ago, ssj92 said: Laptop shutting down at windows boot tells me something is overheating I set to high performance in the unlocked bios, how will that overheat instantly? I think it had no power and cut. It never cuts on benchmark at 70W ( should be running at 100W instead). The guy who sold it to me was running at 110W with PCIE 2.0 X16 Do I need dual PSUs? Because I'm gonna upgrade to the W3680.. I found a power box converter for dual PSUs for 60USD (Clevo AC 200) Edited March 27, 2025 by SuperMG3
Mr. Wind Posted April 25, 2025 Posted April 25, 2025 On 3/21/2025 at 10:42 AM, SuperMG3 said: Oh yeah my bad. On my previous M17X R4 I was sometimes limited by 60fps on dx12 using RTX 3000 MXM I have this problem too, I solve it by doing alt+tab.
SuperMG Posted April 25, 2025 Posted April 25, 2025 1 hour ago, Mr. Wind said: I have this problem too, I solve it by doing alt+tab. Hello... What is that easy? No need to overclock the screen?
sliderfra Posted April 26, 2025 Posted April 26, 2025 On 3/23/2025 at 11:42 PM, ssj92 said: 880M + RTX 5000 was using older drivers that had both kepler and turing M2000M + RTX 5000 are both supported in latest drivers so I can use one driver for both (2 INF mods). I can use every feature of RTX 5000 even DX12, ray tracing, dlss, etc. In PEG mode. Hi. Do you still suffer from low TDP on the RTX in PEG mode or did you find a workaround?
Mr. Wind Posted April 26, 2025 Posted April 26, 2025 11 hours ago, SuperMG3 said: Hello... What is that easy? No need to overclock the screen? No, you can solve it by using alt+enter or alt+tab.
SuperMG Posted April 26, 2025 Posted April 26, 2025 3 hours ago, Mr. Wind said: No, you can solve it by using alt+enter or alt+tab. I'll try this once my M18X R2 gets fixed. How did you find this out?
ssj92 Posted April 27, 2025 Author Posted April 27, 2025 21 hours ago, sliderfra said: Hi. Do you still suffer from low TDP on the RTX in PEG mode or did you find a workaround? Think I figured it out but need more testing https://www.3dmark.com/fs/33274452 Alienware Area-51 18 : Intel Core Ultra 9 275HX @ ??? | nVidia GeForce RTX 5090 | BE200 | 1TB Gen5 9100 PRO Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080 | AX210 | Samsung 970 Evo+ Alienware M18x R2 : Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080 | AX210 | Samsung 980 PRO Alienware 18 : Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000 | AX210 | Samsung 980 NVMe More Laps: M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000) | M17xR3 (WX 7100) | M18xR1 (RTX 5000) BEAST Server: Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYT
SuperMG Posted April 27, 2025 Posted April 27, 2025 16 hours ago, ssj92 said: Think I figured it out but need more testing https://www.3dmark.com/fs/33274452 @ssj92Hello, what did you find? On how to fix that TDP issue on the slave card?
ssj92 Posted April 27, 2025 Author Posted April 27, 2025 1 hour ago, SuperMG3 said: @ssj92Hello, what did you find? On how to fix that TDP issue on the slave card? Unfortunately it started doing the TDP thing again, still trying to figure out what it is Alienware Area-51 18 : Intel Core Ultra 9 275HX @ ??? | nVidia GeForce RTX 5090 | BE200 | 1TB Gen5 9100 PRO Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080 | AX210 | Samsung 970 Evo+ Alienware M18x R2 : Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080 | AX210 | Samsung 980 PRO Alienware 18 : Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000 | AX210 | Samsung 980 NVMe More Laps: M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000) | M17xR3 (WX 7100) | M18xR1 (RTX 5000) BEAST Server: Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYT
