DoenerBoy123 Posted 7 hours ago Posted 7 hours ago Hello folks! I’m currently modding my Clevo’s keyboard. Like on lots of these machines, my keyboard backlight burned out, and I’m not in the mood at all to buy a new keyboard just because of that. So far, I’ve completely replaced the stock LED strip with an addressable one. It works as intended and is a huge upgrade over the stock LEDs, but it’s still far from perfect. I’m controlling the LEDs with a Nollie 1 controller, which works with either SignalRGB or OpenRGB, completely bypassing Clevo’s crappy software. The problem I’m facing now is finding an unused USB port to connect the controller to. I thought about using the webcam or fingerprint reader data lines, but I don’t want to lose any features for this mod. So, the big question: does anyone know of unused pads on the motherboard that I could connect the controller to? That would be awesome for this mod! I’ll post a follow-up once I’m done with it. Thanks! 1 Alienware Area 51 ALX R7 5800X 32GB DDR4 3200MHz RTX 2080 Ti FE (Full Custom Loop) Alienware M18x R2 I7 3840QM 4.2GHz 16GB DDR3 1600MHz GTX 1070(Zotac MXM, 10 MOSFETs) Alienware M17x R4 I7 3630QM 16GB DDR3 1600MHz GTX 1080 150W 8GB(Zotac MXM 3.0B) MacBook Pro 16 2019 I7 9750H 16GB DDR4 2133MHz Radeon Pro 5300M Cevo P775TM1-G I9 9900K 32GB DDR4 3200MHz RTX 2080 And lot's of other stuff in my hobby corner (old Clevo's 'n' stuff like that)😄
incendery Posted 23 minutes ago Posted 23 minutes ago Hey mate sounds like a great project! Here's a link to the service manual / schematic for the board, you might be able to find something unused on here https://www.e-weekly.co.uk/download/rnd/drivers/clevo/p775tm1/esm.pdf?lce My Clevo P775dm3 8700k @4.7 3080mxm (180w) 32gb cl18
